  4. Trying to set variable with HTTP API request
Time series documentation
Reset a delay
Reactor Loading Screen Safari
I'm having an issue with MSR's UI being very unresponsive. It started happening a couple days ago and I didn't make any changes that would have caused this except adding some meross lan devices in HA. When I go into an entity action and use the search functionality, it usually will start filtering and then get to a place after a few letters are entered where it will take 30 seconds or more (sometimes minutes) for the UI to show what I am typing. During this time MSR ui is completely unresponsive. I've tried multiple browsers and multiple computers. HA and MSR are both deployed in docker. I have run HTOP on the host and when the problem happens there are no CPU/Memory spikes at all. From a functionality standpoint MSR is working perfectly. This seems to be an UI issue only. Do i need to ditch Docker and run MSR on a Proxmox VM? I have both stand alone Docker and Proxmox environments. I dont mind doing that I just want to be able to use the UI again... Installation method Home Assistant Container Core 2025.7.3 Frontend 20250702.3 nothing crazy in the logs except some openweather map stuff that doesn't make any sense as it is working fine in MSR Any help would be greatly appreciated Reactor latest-25328-b2ed1365 app 25328 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.843Z <app:null> Reactor build latest-25328-b2ed1365 starting on v24.11.1 /usr/local/bin/node [latest-25328]2025-11-30T20:01:53.844Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #161-Ubuntu SMP Tue Jul 22 14:25:40 UTC 2025; locale (undefined) [latest-25328]2025-11-30T20:01:53.844Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-25328]2025-11-30T20:01:53.844Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.865Z <app:null> Resolved timezone=America/New_York, environment TZ=America/New_York; offset minutes from UTC=-300 [latest-25328]2025-11-30T20:01:53.867Z <default:null> Module i18n v25141 [latest-25328]2025-11-30T20:01:53.867Z <app:null> Configured locale (undefined); selected locale(s) en-US.UTF-8 [latest-25328]2025-11-30T20:01:53.879Z <app:null> Loaded locale en-US for en-US [latest-25328]2025-11-30T20:01:53.879Z <app:null> Local date/time using configured timezone and locale formatting is "11/30/2025, 3:01:53 PM" [latest-25328]2025-11-30T20:01:53.889Z <Structure:null> Module Structure v25326 [latest-25328]2025-11-30T20:01:53.890Z <Capabilities:null> Module Capabilities v24312 [latest-25328]2025-11-30T20:01:53.904Z <Plugin:null> Module Plugin v25141 [latest-25328]2025-11-30T20:01:53.923Z <Timer:null> Module Timer v25279 [latest-25328]2025-11-30T20:01:53.924Z <TimerBroker:null> Module TimerBroker v25314 [latest-25328]2025-11-30T20:01:53.927Z <Entity:null> Module Entity v25251 [latest-25328]2025-11-30T20:01:53.929Z <Controller:null> Module Controller v25253 [latest-25328]2025-11-30T20:01:53.930Z <AlertManager:null> Module AlertManager v25318 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Ruleset v25283 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Rulesets v25141 [latest-25328]2025-11-30T20:01:53.942Z <GlobalExpression:null> Module GlobalExpression v25258 [latest-25328]2025-11-30T20:01:53.953Z <Predicate:null> Module Predicate v25328 [latest-25328]2025-11-30T20:01:53.956Z <Rule:null> Module Rule v25323 [latest-25328]2025-11-30T20:01:53.958Z <GlobalReaction:null> Module GlobalReaction v25292 [latest-25328]2025-11-30T20:01:53.959Z <Engine:null> Module Engine v25325 [latest-25328]2025-11-30T20:01:53.964Z <httpapi:null> Module httpapi v25328 [latest-25328]2025-11-30T20:01:53.972Z <wsapi:null> Module wsapi v25328 [latest-25328]2025-11-30T20:01:53.994Z <TaskQueue:null> Module TaskQueue 24138 [latest-25328]2025-11-30T20:01:53.994Z <VeraController:null> Module VeraController v25141 [latest-25328]2025-11-30T20:01:54.179Z <HassController:null> Module HassController v25325 [latest-25328]2025-11-30T20:02:13.797Z <OWMWeatherController:null> Module OWMWeatherController v25268 [latest-25328]2025-11-30T20:02:13.800Z <SystemController:null> Module SystemController v25323 [latest-25328]2025-11-30T20:02:13.807Z <MQTTController:null> Module MQTTController v22092 [latest-25328]2025-11-30T20:02:20.630Z <OWMWeatherController:CRIT> FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxx&lon=-xxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxxxxxxxxx&units=standard&_r=1xxxxxxxxxxxxxxfailed, reason: [-] FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxxx&lon=-xxxxxxxxxxxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxx&units=standard&_r=xxxxxxxxxxxxxxxfailed, reason: at ClientRequest.<anonymous> (/opt/reactor/node_modules/node-fetch/lib/index.js:1501:11) at ClientRequest.emit (node:events:508:28) at ClientRequest.emit (node:domain:489:12) at emitErrorEvent (node:_http_client:108:11) at TLSSocket.socketErrorListener (node:_http_client:575:5) at TLSSocket.emit (node:events:508:28) at TLSSocket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:170:8) at emitErrorCloseNT (node:internal/streams/destroy:129:3) at processTicksAndRejections (node:internal/process/task_queues:89:21
Date/time condition
Device log?
This post does not apply to users of Intel/AMD-based systems. If you are using a Reactor image tagged latest-amd64 or stable-amd64, then this post does not apply to you. It also does not apply to bare-metal installs; it's for users of docker images on ARM-based systems only (principally Raspberry Pi hosts, but could be others). After January 15, 2026, I will no longer produce the aarch64-tagged docker image for Reactor. The ARM images will be arm64 for 64-bit operating systems, and armv7l for 32-bit operating systems. For those of you running a container from the aarch64 image today, this will be a relatively simple change: you just need to switch the image used for your docker container to a differently-tagged image. If you are using docker-compose, then this is a relatively simple matter of changing the image line in your docker-compose.yaml file and then stopping (docker-compose down) and restarting (docker-compose up -d) your Reactor daemon. But there's a catch... not all of you can safely just switch from the aarch64 image to the arm64 image. And, you can't just trust the output of uname -m, for example, because this exposes the CPU architecture, but not the word size of the OS running on that CPU. For Raspberry Pi systems, the transition to 64-bit operating systems was long (starting in 2016) and not always obvious — although there was a first "official" 64-bit OS for RPis in 2020, it did not become a default recommendation in the Raspberry Pi Imager until 2021, and then that was only the default for Pi 3/4 systems with >4GB RAM; it was 2022 before it was universally recommended for all 64-bit CPUs regardless of RAM size. Depending on when you first imaged your RPi system and what default you may have been offered/chosen, you could today easily have a 64-bit CPU Raspberry Pi running a 32-bit version of the operating system. Upgrades along the way would not change this; changing it to fully 64-bit requires a full reimage of the system. To establish if your OS is 64- or 32-bit, log in to your Pi and run: sudo dpkg-architecture -q DEB_HOST_ARCH. If the response is arm64 or aarch64, then you are running a 64-bit OS and you should use the arm64-tagged image. If it's anything else, you are running a 32-bit OS, and you should use the armv7l-tagged image. pi@rpi4-1:~ $ sudo dpkg-architecture -q DEB_HOST_ARCH armhf pi@rpi4-1:~ $ uname -m aarch64 pi@rpi4-1:~ $ In the example above, the uname command reports that the CPU is 64-bit architecture (aarch64), which is true for the host on which I ran these commands, but the DEB_HOST_ARCH value is armhf, indicating a 32-bit operating system. This system has to use the armv7l-tagged image. Other systems will have their own ways of determining the word size of the running OS. Since the majority of Reactor users running ARM systems are on Raspberry Pis, I am able to supply the above instructions, but if you happen to have a different ARM system, you'll need to do some web searching to figure out how to expose that information. Or, you can just try the arm64 image, and if it doesn't start up, try the armv7l image. Remember to always back up your system before making any changes. For everyone, please make this change as soon as possible, and if you have any trouble finding a working image, please (1) go back to the current aarch64 image; and (2) let me know in this thread along with as much detail about your host system as you can offer (including the output of the dpkg-architecture command mentioned above).
@toggledbits Do you know if this is related to that PR or is it a change they made in 2025.11.1? [latest-25310]2025-11-11T13:16:24.319Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag with { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.320Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag action: { "type": "call_service", "service_data": { "date": (null), "time": "10:45", "datetime": (null), "timestamp": (null) }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_dag" } } [latest-25310]2025-11-11T13:16:24.321Z <HassController:ERR> HassController#hass request 1762866984320<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.321Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "10:45" }) on Entity#hass>input_datetime_vvb_dag failed! [latest-25310]2025-11-11T13:16:24.321Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"10:45","datetime":null,"timestamp":null},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_dag"},"id":1762866984320} [latest-25310]2025-11-11T13:16:24.322Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.322Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 0 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Engine#1 action args: { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 1 [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt with { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt action: { "type": "call_service", "service_data": { "date": (null), "time": "03:00", "datetime": (null), "timestamp": 0 }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_natt" } } [latest-25310]2025-11-11T13:16:24.324Z <HassController:ERR> HassController#hass request 1762866984323<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "03:00", "timestamp": 0 }) on Entity#hass>input_datetime_vvb_natt failed! [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"03:00","datetime":null,"timestamp":0},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_natt"},"id":1762866984323} [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.324Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 1 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <Engine:INFO> Engine#1 action args: { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 2 [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Sätt Schema VVB i Home Assistant<AKTIV> all actions completed.
19 Posts 3 Posters 1.8k Views 3 Watching
    @cw-kid said in Build 21117:
    Trying to set the Global Variable named "run" to a value of "3"
    Documentation fail. The PUT body needs to look like this:
      "name": "<variablename>"
      "value": <new value, any valid JSON type>
    The variable name given must match that in the URL.
    I just added a GET for this as well just for simplicity/basic use only, to be in next build:
    http://msr-ip:8111/api/v1/variable/testme/set?value=123
    In this case, the value set will always be a string type, because that's what query parameter values are.
    @toggledbits said in Build 21117:
    I updated and tried this:
    http://192.168.0.100:8111/api/v1/variable/run/set?value=123
    "run" is the name of my Global Expression.
    In the web browser I get this response:
    Cannot GET /api/v1/variable/run/set
    I can't see anything related in the reactor log file.
      (a) 'run' is all lowercase in Global Expressions?
      (b) which exact version of MSR are you running?
      (c) have you also tried PUT just for testing this?
        @librasun said in Trying to set variable with HTTP API request:
        Yes it was run all lower case. I deleted that Global Expression and created a new one called scene all lower case and tried the HTTP command again but I get the same problem.
        Latest build 21118
        No I have not tried PUT, I would have to try that in the Postman application.
          PUT doesn't appear to be working either:
            @cw-kid The PUT body has to be of the form described in my other post. It needs to be a JSON object containing "name" and "value" keys.
            Here's what I get for GET on a browser:
            And using curl:
              And using curl:
              I don't want to use PUT really at all.
              I want to just use GET.
              I'm not sure why its not working for me in the browser then ?
              I just tried it in a different web browser MS Edge and I get this response:
              Cannot GET /api/v1/variable/scene/set
                Yeah, I'm going cross-eyed spotting any syntactic issues with what you've attempted thus far.
                Did you do a hard refresh on your browser after starting up 21118? (Not that that should matter much I suppose, just curious.)
                I've only used the formal PUT (with JSON) method, but will go test my setup using GET and join in the fracas momentarily.
                  It seems to be related to the name of my Global Expression which was called "scene"
                  I have just created another Global Expression named "my_scene" and now its working in the browser:
                  {"name":"my_scene","expr":"","index":2,"value":"123","since":1619705665552}
                  toggledbitsT 2 Replies Last reply
                    @cw-kid said in Trying to set variable with HTTP API request:
                    Name doesn't matter. Here's "run":
                    and "scene":
                    and "variable":
                    and "set":
                      @cw-kid I will also note that your screen shot in the prior post shows an expression in "scene". That's a no-no. You have to leave the expression blank. Only expressionless variables are settable (as is true within MSR as well).
                        Yes I have just realised my mistake, I was adding a 0 and 1 directly in to that "scene" Global Expression box to test some things e.g. triggering a rule set.
                        I removed the 0 and then it started working.
                          @LibraSun
                          In the other thread that seems to be locked now you said:
                          PRO TIP: Knowing that I will forget these N assignments, I always place a Comment with notes, or even a hand-built Object in an Expression somewhere, reminding me...
                          1 = Lights Out
                          2 = Time for Bed
                          12 = Nightlight Toggle, etc.
                          What does this mean ?
                          "or even a hand-built Object in an Expression somewhere"
                          I'd like to add a comment next to my Global Expression but seems you can't do that currently.
                            First of all, you guys totally beat me to the "But is your scene variable empty?" question, LOL. Knew it!
                            Secondly, here's where I document my more elaborate variables (this may surprise you...):
                            INSIDE THE VARIABLE ITSELF!!
                            If you define, for instance:
                            sceneList := {'1':'Coming Home','2':'Leaving Home','3':'Daytime','4':'Nighttime'} , getEntity ( dev_Num ) . param . value . etc.
                            // result: the value of param under device #dev_Num (first half, my made-up documentation object, gets ignored)
                            Then you have a handy reference for the possible values you might see coming from the last part of the expression (namely, after the last comma). This is a made-up example, but should illustrate where I sometimes tuck things, since expressions can be multi-part.
                            I might even USE the object in some true lookup fashion, within the variable itself (again, this is pseudocode in the middle part):
                            hMode := hm = {'1':'Home','2':'Away','3':'Night','4':'Vacation'} , devNum = 345 , devMode = getEntity (devNum).houseMode , hm[devMode]
                            // result: "Away" (string) when houseMode .eq. "2"
                              @toggledbits Tricky question: Since MSR can receive variable values via HTTP, will there be a corresponding method by which MSR senses these events as "Updates"? You understandably omitted "Updates" as a conventional Trigger – particularly with respect to hub-paired entities – since MSR is not privy to controller internals...
                              ...but now we've come full circle to MSR being the nexus of variable values being updated (not just via HTTP, but also from within Rules and Expressions). Given that MSR tracks the timestamp of when a value (even the same value) was assigned to a variable, might this present a means by which a new "Updates" mechanism could operate?
                              EXAMPLE
                              User sends http://<msr-ip:port>/api/v1/variable/some_var/set?value=5 at midnight
                              User again sends http://<msr-ip:port>/api/v1/variable/some_var/set?value=5 at 12:02am
                              Currently: MSR cannot be made to react, since stored value of some_var never changed
                              Proposed: MSR can react to refreshed value assignment using new "Updates" comparator (available only under [Expression Value])
                              Thoughts?
                                I've anticipated that, and there are some undocumented flags available on the request, but there are some conflicting scenarios I'm still working out.
                                  This has stopped working and I'm not sure why?
                                  I was sending this command previously to MSR to set a Global Expression called "scene" and change its value:
                                  http://192.168.0.4:8111/api/v1/variable/scene/set?value=frontcam
                                  This was then triggering a RuleSet to run etc.
                                  However now I am getting an error in the browser when I try it:
                                  ReferenceError: self is not defined
                                      at /home/username/reactor/server/lib/httpapi.js:512:21
                                      at Layer.handle [as handle_request] (/home/username/reactor/node_modules/express/lib/router/layer.js:95:5)
                                      at next (/home/username/reactor/node_modules/express/lib/router/route.js:137:13)
                                      at Route.dispatch (/home/username/reactor/node_modules/express/lib/router/route.js:112:3)
                                      at /home/username/reactor/node_modules/express/lib/router/index.js:281:22
                                      at param (/home/username/reactor/node_modules/express/lib/router/index.js:354:14)
                                      at param (/home/username/reactor/node_modules/express/lib/router/index.js:365:14)
                                      at Function.process_params (/home/username/reactor/node_modules/express/lib/router/index.js:410:3)
                                      at next (/home/username/reactor/node_modules/express/lib/router/index.js:275:10)
                                    Fixed in build 21189
                                      I'm not sure how this worked for you before... really odd... that code is untouched for months... the line that was breaking was debug/logging, added on April 28. You would have first seen it in version 21118, and it was unchanged until today. Really weird we didn't see that raise its head before. But in any case, I'm glad you found it, and the fix is working.
                                        It's not something I've been using often and I'd known it had broken for a few months and not looked into it, which is why I only reported it had broken yesterday..
                                        • Time series documentation
                                        • Tuya Wifi to Tasmota flashing
                                        • Reset a delay
                                        • Single protocol?
                                        • HDMI oddness
