  4. Help with Burglar Alarm rule(s)
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
9 Posts 4 Posters 1.4k Views 4 Watching
    I would like to replicate a burglar alarm setup I currently have configured with Vera scenes.
    I need an entry timer of 60 seconds before the siren goes off.
    So the door sensor is armed, I enter the house, this trips and starts a 60 second count down timer.
    If within the 60 seconds I have disarm the house, then the siren does not sound and all the door / window contact sensors are disarmed etc and Vera put in to Home Mode.
    If I do not disarm the house within the 60 seconds then the siren should sound etc.
    Currently I am using three scenes in Vera and the Count Down Timer plugin to achieve this.
    The first scene "Burglar Alarm" its triggers are that an armed door / window sensor is tripped. It then also starts the 60 second count down timer.
    The second scene "Burglar Alarm Delayed" its trigger is that the count down timer completes. i.e. I have not disarmed the house within the 60 seconds count down, so this second scene would then sound the siren.
    If I did disarm the house within the 60 seconds, which is the third scene "Home" which cancels the count down timer, then the second scene is not triggered and therefore the siren does not sound.
    I am not sure what is the best way to handle this? or even how to do this count down timer in MSR ? A count down timer that I can stop when I disarm the house, so it does not complete or it does complete if I haven't disarmed the house in time.
    This is all I have so far the triggers and the constraints that those door sensors must be in Armed state.
    • MikeReadingtonM Offline
      MikeReadington
      I am nowhere near an expert at MSR, but I did do something similar for a specific type of alarm. I might have taken the long way around, but it works for me.
      I have conditions that trigger an alarm and an alarm cancel condition. When the alarm is triggered, it runs a global reaction with the sequence I want and a final delay for sounding the alarm. When the cancel condition is satisfied, I use a "stop reaction" reaction to cancel that global reaction wherever it is in the sequence.
      It's been very solid for me, but I am curious how you end up working through this.
        I concur. Seems like you could almost get away with using only two Rules:
        RULE A > Triggers: (any sensor tripped) > Constraints: (alarm armed?) > SET: Delay 60s, Turn on Siren > RESET: (empty)
        RULE B > Triggers: (alarm disarmed) > Constraints: (optional: [RULE STATE] [Rule A] [is TRUE]) > SET: [STOP REACTION] [Rule A Set], Turn off Siren > RESET: (empty)
        Thoughts?
          MikeReadington
          That was the easiest way at my skill level to accomplish what I needed to do.
          Along this same lines, I found myself looking for a way to evaluate if a reaction was still running in a condition. Is there a way to do that and I missed it? I don't know how many people would find that useful, but if it was there I would have utilized that.
          LibraSunL 1 Reply Last reply
            @mikereadington I think you're describing this setup in MSR:
            ...which would permit the Rule to run if (and only if) the named rule Run A/C Fan happened to be Set (TRUE).
              MikeReadington
              I saw that, and I have used that to see the state of a rule. I was thinking about something more alone the lines of "Global Reaction State" to see if a long reaction was still running.
                @mikereadington said in Help with Burglar Alarm rule(s):
                ... to see if a long reaction was still running.
                Sort of like being able to poll "Status" and get back an array of any Rules currently "Running"? I asked for just such a feature a while back, and believe it may already be considered for future revs.
                  @cw-kid Many moons ago I did an alarm simulator for Reactor for Vera. Here's my interpretation of an MSR version:
                  First, we define three zones: Zone 1 for smoke detectors (always cause noise), Zone 2 for Perimeter devices that when breached activate an entry delay (time to get in and turn off the alarm), and Zone 3 for interior devices (like motion sensors or other interior/instant trigger things). These are just rules; none of them has any reactions. We will use these in other rules we create later.
                  Now let's determine when we're "breached" in Away mode. If Zone 2 Perimeter is breached (by checking that rule we defined above), there's a 60 second delay implemented by a "sustained for" on the "Perimeter Delayed" group (notice yellow highlight on the options button). The group for the Interiors also uses the Zone 2 rule to cut the interiors off (that is, the interiors only go into alarm if the perimeter is not), which makes sure that an interior motion sensor you may trip after entering during the perimeter delay doesn't suddenly make the siren blast.
                  2ff19f41-cbcd-45b1-9110-47e2f26b95c1-image.png 1ca040a2-be45-4993-8bc9-87cba3ef2f39-image.png
                  Still no reactions. Just building logic at this point.
                  For Night mode, we instantly trigger on Perimeter trip only, simple:
                  Again, no reactions yet. Still building logic.
                  Now, we'll make an "In Alarm" rule to roll-up our two breached rules: if either rule is set (OR) and we're not in "home" mode (constraint), we should be in alarm.
                  Now we're ready for some reactions. Here's the "Siren On" rule that turns on the siren when in alarm or smoke detectors are going off (smoke detectors make noise in all house modes):
                  Finally, to turn the siren off when we're not in alarm. This is when either the house mode is set to home, or the breaches/smokes resolve:
                  There are lots of ways to imagine this problem and myriad solutions. This was just something I had done some time ago, now in MSR form.
                    Thanks guys for all the suggestions a lot to take in.
                    I'll have a proper read later and see if I can retire my existing scenes setup in Vera and migrate this functionality to MSR.
                    • Next Release?
