  4. Using MSR as a Gaming Engine: LIGHTS OUT
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
6 Posts 2 Posters 922 Views 2 Watching
    CONCEPT
    Inspired by my love for MSR as a logic engine, as well as my undying nostalgia for two early console games -- Merlin (1978) by Parker Brothers and Lights Out (1995) by Tiger -- I decided to try my hand at recreating "LIGHTS OUT" just using MSR.
    DESIGN
    After an evening of playing around with Expressions inside a single Rule, my gambit succeeded. The result is a 3x3 version of "Lights Out" that can be played on any suitably configured Dashboard (Home Remote, Imperihome, MSR's built-in, etc.), where multiple buttons can be arranged in a grid. To play without a Dashboard, one can advance play manually and monitor game status under Rule Sets.
    IMPLEMENTATION
    Each button press must send an HTTP GET Request (examples to follow) to MSR. (Alternatively, game play could involve inputs from another Rule or even physical device.) In turn, MSR will toggle the virtual switch corresponding to that position on the grid along with those adjacent to it in the up/down/left/right directions. The objective is to turn all of the devices (e.g. lights) OFF.
    NOTE: This on/off behavior (of devices) is not yet implemented, as it would require nine virtual or actual switches that I have not installed. (Suitable candidate: Multi-switch VS in Switchboard on Vera.) Instead, as a proof of concept, the 3x3 playing grid is -- for now at least -- represented internally by a 9-element array of 0's (Off) and 1's (On). A player 'wins' once the array contains all zeroes.
    In the posts below, I present how I crafted "Lights Out" in MSR.
      Readers may first want to familiarize themselves with the game of "Lights Out" by visiting an online solver. This lets you mock up your own starting grid of on/off lights, then either try solving it yourself, or compute a solution. Many sites (references to follow) exist online which teach playing strategies, logical concepts, and even programming approaches to "Lights Out". Most of them also generalize from the 3x3 playing grid to larger grids of arbitrary dimension.
      My MSR version of the game could likewise be expanded to larger grids, but does not attempt to solve the board, nor show you a potential solution. It only offers the following modes:
      • 'reset' = return the playing grid to all zeros / Off
      • 'start' = generate a random grid of On / Off values
      • 0 .. 8 = press button N to advance play one cycle
      • 3, 1, ... , 5 = advance play multiple cycles at once
      The values to the left of the = get sent via HTTP GET Request to MSR, using the following syntax:
      http://<msr-ip>:8111/api/v1/variable/LightsOutGame/set?value=
      String values reset or start must not contain quotes. Single digits 0 through 8 correspond to grid positions, as shown:
      _____________
      | 0 | 1 | 2 |
      | 3 | 4 | 5 |
      | 6 | 7 | 8 |
      A typical randomized starting grid might look like this, where X represents an 'On', and empty positions are 'Off':
      _____________
      | X |   |   |
      | X |   | X |
      |   | X |   |
      the (only) solution for which is the series of keypresses -- in no particular order -- of 0, 1, 2, 3, 4, 7 and 8. (The game allows all seven moves to be made in a single cycle using value = 0,1,2,3,4,7,8.)
        Here's a look at the internals of the game Rule itself:
        lights_out_game_triggers+constraints.png lights_out_game_set_reaction.png lights_out_game_reset_reaction.png lights_out_game_expressions.png
          COMING SOON: How it works! Ways to win! Real life applications!
            As is often the case, the line between genius and madness can be a bit blurry. 🙂 Kudos on this tour de force!
              LOL So true. So true. I just had to get it out of my system. It's your fault, basically, for unleashing Group Constraints. This would have been a bear to implement without 'em. 🙂
                2.1k
                3.9k
