  4. Entitys coming back
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Entitys coming back
12 Posts 3 Posters 1.4k Views 3 Watching
    Matteburk
    Hi .... Is this reaction made right?
    When I reload reaction the 2entity actions at the bottom is popping up. I erase them but when I reload the reaction they come back...
    I want my shade to go close if window is closed and if open it should go to 70% (0.7).
    /Mattias!Skärmavbild 2021-05-13 kl. 07.51.11.png
      I'm curious what you mean by "reload". Are you editing the Rule, then clicking SAVE and then EXIT? And then clicking EDIT again?
      Also, any chance you are still on version 0.1-21128 or earlier and created the second Group Constrain by clicking "Clone" on the first one?
      I've never witnessed edits "undo" themselves as I believe you are describing. If the problem persists, definitely file a PR on the Mantis bug tracker system, or message @toggledbits here.
      M 1 Reply Last reply
        Matteburk
        ahh, correct wort is Reset , the yellow botton. I save and then go back and reset the rule. I fwill ix a PR for P
          Matteburk
          @librasun I am on latest 30
            I need more detail on the PR you opened. I cannot reproduce your report. When you open a PR, particularly for a UI bug, please document every step you are taking to reproduce the bug.
              Matteburk
              @toggledbits When reproducing it I think I found out that I have been misunderstanding how u use groups in set reactions.... I think msr puts the entity actions on the bottom because on the first group I have no data. I thought I could have a group with an OR and then 2 subgroups with AND that executes entity actions. But it is 3 groups in the picture and not one group with 2 subgroups.... ?
                Since this is my first time seeing or even contemplating nested Group Constraints (neat idea!), I've got to ask @toggledbits this fundamental question about the pacing of Action execution:
                With this setup in Set Reaction...
                SET REACTION ONE
                [Group Outer] [AND]
                No conditions
                  [Group Inner] [AND]
                    Condition == TRUE
                      Delay=3
                      Action A
                  [end Group Inner]
                Action B
                [end Group Outer]
                ...will MSR perform Action B immediately when Group Inner goes TRUE - thereby triggering Group Outer to TRUE (correct? even though Group Outer has no overt Conditions of its own?) - followed by Action A happening 3 seconds later? Or will MSR attempt to finish executing all of Group Inner's steps first, such that Action A completes followed immediately by Action B?
                I strongly suspect the answer is the first of these alternatives. And that if the user intended the second scenario, they should place Action B as the final step inside of Group Inner.
                  Subgroups are always processed inline, so assuming the inner group's constraints were met, the delay + A would run first, then B.
                    Very helpful to know, and glad I asked! Thanks.
                      By the way, you can observe this on the Status tab as well, as the outer reaction group would show "waiting" status while the inner group was running its delay and action A.
                        Funny you should recommend that (though I honestly hadn't tried while fiddling with inner/outer Groups), because that's my normal MO...but I recently noticed that the Status simply wasn't updating in realtime (or at all, sometimes) for one particular simple test Rule.
                        That rule Sets whenever a light changes dimming level, with these expressions defined:
                        dim := getEntity (vera>device_110).attributes.dimming.level #works fine, updates in Status whenever Dim level changes
                        levels = push(levels,dim,5) #does NOT update visibly in Status ... I have to switch to different Rule Set, or collapse/re-expand Rule
                        I also notice that with each run cycle, the push never pushes just one new value; it always pushes 2, often 3 of the same value (though I believe a minimum of two per cycle is to be expected?). This makes it tricky for me to calculate what the effective change was to Dim since the last cycle. levels[4]-levels[3] kept equaling 0, as did levels[4]-levels[2] in Status. Kind of thing that drives me batty, esp. knowing that it's me not MSR. 😉
                          I'm talking about the Status top-level, not Rule status.
                            379
                            3.6k
                            3.2k
                            785
