  4. Entitys coming back
Unable to add new groups in DGC, Reactor latest-26318
Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
Entitys coming back
12 Posts 3 Posters 2.7k Views 3 Watching
    Matteburk
    Hi .... Is this reaction made right?
    When I reload reaction the 2entity actions at the bottom is popping up. I erase them but when I reload the reaction they come back...
    I want my shade to go close if window is closed and if open it should go to 70% (0.7).
    /Mattias!Skärmavbild 2021-05-13 kl. 07.51.11.png
      I'm curious what you mean by "reload". Are you editing the Rule, then clicking SAVE and then EXIT? And then clicking EDIT again?
      Also, any chance you are still on version 0.1-21128 or earlier and created the second Group Constrain by clicking "Clone" on the first one?
      I've never witnessed edits "undo" themselves as I believe you are describing. If the problem persists, definitely file a PR on the Mantis bug tracker system, or message @toggledbits here.
      M 1 Reply Last reply
        Matteburk
        ahh, correct wort is Reset , the yellow botton. I save and then go back and reset the rule. I fwill ix a PR for P
          Matteburk
          @librasun I am on latest 30
            I need more detail on the PR you opened. I cannot reproduce your report. When you open a PR, particularly for a UI bug, please document every step you are taking to reproduce the bug.
              Matteburk
              @toggledbits When reproducing it I think I found out that I have been misunderstanding how u use groups in set reactions.... I think msr puts the entity actions on the bottom because on the first group I have no data. I thought I could have a group with an OR and then 2 subgroups with AND that executes entity actions. But it is 3 groups in the picture and not one group with 2 subgroups.... ?
                Since this is my first time seeing or even contemplating nested Group Constraints (neat idea!), I've got to ask @toggledbits this fundamental question about the pacing of Action execution:
                With this setup in Set Reaction...
                SET REACTION ONE
                [Group Outer] [AND]
                No conditions
                  [Group Inner] [AND]
                    Condition == TRUE
                      Delay=3
                      Action A
                  [end Group Inner]
                Action B
                [end Group Outer]
                ...will MSR perform Action B immediately when Group Inner goes TRUE - thereby triggering Group Outer to TRUE (correct? even though Group Outer has no overt Conditions of its own?) - followed by Action A happening 3 seconds later? Or will MSR attempt to finish executing all of Group Inner's steps first, such that Action A completes followed immediately by Action B?
                I strongly suspect the answer is the first of these alternatives. And that if the user intended the second scenario, they should place Action B as the final step inside of Group Inner.
                  Subgroups are always processed inline, so assuming the inner group's constraints were met, the delay + A would run first, then B.
                    Very helpful to know, and glad I asked! Thanks.
                      By the way, you can observe this on the Status tab as well, as the outer reaction group would show "waiting" status while the inner group was running its delay and action A.
                        Funny you should recommend that (though I honestly hadn't tried while fiddling with inner/outer Groups), because that's my normal MO...but I recently noticed that the Status simply wasn't updating in realtime (or at all, sometimes) for one particular simple test Rule.
                        That rule Sets whenever a light changes dimming level, with these expressions defined:
                        dim := getEntity (vera>device_110).attributes.dimming.level #works fine, updates in Status whenever Dim level changes
                        levels = push(levels,dim,5) #does NOT update visibly in Status ... I have to switch to different Rule Set, or collapse/re-expand Rule
                        I also notice that with each run cycle, the push never pushes just one new value; it always pushes 2, often 3 of the same value (though I believe a minimum of two per cycle is to be expected?). This makes it tricky for me to calculate what the effective change was to Dim since the last cycle. levels[4]-levels[3] kept equaling 0, as did levels[4]-levels[2] in Status. Kind of thing that drives me batty, esp. knowing that it's me not MSR. 😉
                          I'm talking about the Status top-level, not Rule status.
                            164.3k
