  4. Issues installing MSR on Debian 10 Linux
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
27 Posts 3 Posters 10.0k Views 3 Watching
    @cw-kid, yeah it takes a little googling to set up and brand new debian OS but I am sure you will get there. I went through the same thing setting up my T640. Debian takes a little bit more work than ubuntu which has a lot of these setup by default.
      Probably a good idea to make sure you have NTP running on the box as well (network time).
      I'm reading this article about Debian and time here.
      The date and time is currently set correctly:
      "By default, Debian 10 runs the standard ntpd server to keep your system time synchronized with a pool of external time servers. We can check that it’s running with the systemctl command:"
      sudo systemctl status ntp
      When I run this command in Putty it says:
      Unit ntp.service could not be found.
      It goes on to say "To get more information about the status of ntpd we can use the ntpq command:"
      ntpq -p
      I get the response:
      -bash: ntpq: command not found
      So maybe its not currently installed on my installation.
      its only a 16GB SSD in the HP Thin Client, so I don't have a desktop environment installed only SSH server etc.
      I will look at installing this ntpd service next.
      EDIT:
      Ran this command to install it:
      apt-get install ntp
      Now the above commands are working.
        @rafale77
        Hi, well I bought the HP T520 Thin Client because of what you said to me previously. It was cheap enough from eBay.
        I had some issues with the power supply however as it didn't come with one.
        I did have a spare suitably spec'd laptop power supply, but it had the wrong DC connector plug on the end of it.
        So I ordered the correct "DC Tip 7.4x5.0mm Power Plug Socket Connector" off eBay and cut the other one off and soldered the new one on.
        However the HP Thin Client was not turning on, no power nothing at all and totally dead.
        I then read that you have to use a genuine HP power supply, as they have some kind of checking so that the thin clients won't power on if you are using a 3rd party power supply.
        Corporate Greed !
        I then found an article about hacking the unit and soldering in a 240K resister on the back of the power input jack and I did this today and amazingly it worked and the thin client powered on.
        alt text
        alt text
        One thing I can't figure out how to do yet is to update the BIOS without having one of their supported OS installed.
          @rafale77
          Corporate Greed !
          alt text
          alt text
          @cw-kid
          I don't have this exact model but... my HP desktops all have the ability to update the BIOS from within the UEFI BIOS. Have you tried that? Sorry for the song and dance on the power supply. I never encountered this since I always got power bricks with the ones I bought and I actually have spare power supplies... Great soldering job though!
            @cw-kid
            @rafale77
            There is an option in the BIOS menu to update / flash the BIOS but when I click OK on it, it says:
            "Can not find bios update interface"
            I've not really looked in to it properly yet as I was keen to get MSR up and running first.
            From the quick Google searches I did, most suggested you need to have one of the HP supported operating systems installed to be able to update the BIOS.
            But there must be some work around some how. I need to read in to it more.
              #21
              @toggledbits I copied over the storage and config folder contents from the Rpi to the HP Thin Client and then restarted MSR on the thin client.
              I did edit the base URL in the Reactor.yaml file.
              I've stopped the MSR service on the Rpi so now the thin client is the only one running..
              None of my scheduled rulesets based around sunset have run their actions this evening for some reason.
              The time shown in the top of the MSR Web GUI is the correct time.
              So seems I need to look into this further.
              There is another schedule up coming, the garden lights should turn on 20 minutes after sunset, that is in about 20 minutes time from now, so will see if that happens?
              EDIT:
              These are the before sunset rules that the other rules reference in their triggers.
              20 and 40 minutes before sunset, not sure why both say true as of the same time at 20:48pm.
              The after sunset 20 minutes rule says:
              waiting for 21:21:00
              Its now 21:25pm and my garden lights have NOT turned on, so something not right here.
              This is the summary card for the rule that turns on the garden lights:
                #22
                Not sure which rule this is, but I am seeing several errors in the log like these:
                2021-05-15T19:48:14.906Z <Rule:5:Rule.js:957> Rule#rule-km50yfxo._evaluate() mutex acquired, evaluating
                2021-05-15T19:48:14.907Z <Rule:5:Rule.js:961> Rule#rule-km50yfxo update rate is 1/min limit 60/min
                2021-05-15T19:48:14.908Z <Rule:5:Rule.js:883> Rule#rule-km50yfxo evaluateExpressions() with 0 expressions
                2021-05-15T19:48:14.910Z <Rule:5:Rule.js:973> Rule#rule-km50yfxo._evaluate() trigger state now true (was true)
                2021-05-15T19:48:14.911Z <Rule:5:Rule.js:1351> Rule#rule-km50yfxo cond cond5hu03sp timer schedule 1621119600000<16/05/2021, 00:00:00>
                2021-05-15T19:48:14.913Z <Rule:5:Rule.js:975> Rule#rule-km50yfxo._evaluate() constraints state false
                2021-05-15T19:48:14.913Z <Rule:null> Rule#rule-km50yfxo rule state now false, changed no
                2021-05-15T19:48:14.915Z <Rule:CRIT> Error: EACCES: permission denied, open '/home/stuart/reactor/storage/states/cs-rule-km50yfxo.json'
                    at Object.openSync (fs.js:498:3)
                    at Object.writeFileSync (fs.js:1524:35)
                    at IndividualFileStrategy.saveDataObject (/home/stuart/reactor/server/lib/IndividualFileStrategy.js:137:29)
                    at Container.saveDataObject (/home/stuart/reactor/server/lib/Container.js:94:54)
                    at Data.save (/home/stuart/reactor/server/lib/Data.js:152:49)
                    at Rule._evaluate (/home/stuart/reactor/server/lib/Rule.js:985:365)
                    at runMicrotasks (<anonymous>)
                    at processTicksAndRejections (internal/process/task_queues.js:95:5)
                    at async /home/stuart/reactor/server/lib/Rule.js:940:17
                Think something may have gone wrong with copying over the stuff from the Pi.
                This is that folder in WinSCP on the HP Thin Client.
                I installed MSR as a none root user aka as my own username name. But these rule set files most are saying root as the owner.
                I was logged in to WinSCP as root user when I did the copy so maybe that is why.
                If I try logging in to WinSCP as my username instead of root and then doing the copy again from the Pi to the Thin Client it doesn't work and I don't seem to have the permissions to do it.
                If instead I try to change the group and owner of a file from root to my username I can't do that either:
                So I am stuck now and don't know what to do.....
                OK I logged back in to WinSCP as root and now I can change all the files their group and owner from root to my own user name. I have done that now for all of them.
                So hopefully that fixes the problem? Will have to wait for later schedules to happen later this evening to see.
                  A scheduled rule set just ran actually and turned on the RGBW light strip in the kitchen, so think it's working now.
                  • toggledbitsT Online
                    toggledbitsT Online
                    #24
                    Make sure your system time zone is set to local time. If the default is UTC or something else, all time-based rules will be a mess. The displayed time in the GUI is browser time, not system (host) time.
                    Fix permissions in your Reactor config and storage with this:
                    sudo chown -R stuart:stuart config/ storage/
                    Edit: To see current host time configuration:
                    http://your-msr-host-ip:8111/diag/sun
                      #25
                      @toggledbits said in Issues installing MSR on Debian 10 Linux:
                      The host time is currently 16/05/2021, 14:20:58 offset 60 minutes from UTC (TZ=undefined); location (lat,lon) 53.99078,-1.5373 elev 127; sunrise 16/05/2021, 05:01:40, sunset 16/05/2021, 21:03:33.
                      {"sunrise":1621137700000,"sunset":1621195413000,"civdawn":1621134941000,"civdusk":1621198173000,"nautdawn":1621130939000,"nautdusk":1621202174000,"astrodawn":null,"astrodusk":null,"solarnoon":1621166557000,"daylength":16.031,"angle":14.6}
                      Time looks to be correct, however it says "TZ=undefined".
                      None of my schedule rules were running last night because of the permissions issue when I copied them from the Pi to the Thin Client.
                      I fixed that and then they started working again OK.
                      I've got everything moved over from the Pi now to the new Thin Client, also setup today Node-Red and Java HA-Bridge.
                      @rafale77
                      What's the best way to be backing up Debian ?
                      The SSD is only 16GB so guess I could take a full system snapshot rather than just backing up certain files and folders.
                        Indeed a full system snapshot would be best and easier to recover but short of that, you can always backup the entire folder by running a cron job to copy the reactor folder either to a network drive or to a USB SSD you would have to plug into the T520.
                          toggledbitsT Online
                          I use scp just to copy the config and storage directories. That's really all you need to from Reactor to get it going on a reinstall, as you've seen.
                          I find file-based backups of entire Linux systems to be perilous, because permissions, links and special files almost always get screwed up somehow, so I never recommend that route. An image backup is better (I use partclone to back up used space only, and it's good about the later target system being a different size/geometry than the original/source), but I'll only do that maybe 1-2 times per year. I figure if I can restore an image quickly and apt-get update my way back to current, that's fast enough on recovery.
                            165.3k
