Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
126 Posts 5 Posters 106.7k Views 5 Watching
    @toggledbits For today's checkup on how Expressions handle assigning values by reference, I constructed:
    a=b=c=[1,2,3], pop(a), shift(b), [a==b,b==c,a==c,c]
    // result is [true,true,true,[2]]
    A. Pls confirm this is as expected. (I'm guessing 'Yes')
    B. Does result comport with typical user's expectations? (I'm guessing 50/50)
    C. I know you don't want me mashing that "Try" ► button (in lieu of actual, useful, runtime evals).
    Just something that's been on my mind, wondering if it belongs in your Test Suite.
      #109
      You can't compare arrays (or objects) with ==. What it's telling you when you write a==b is that neither a nor b are null, 0, or false, and they are identical references. So yes, this is all expected.
      As for it comporting with user expectations, if the user is a programmer, I think this will be no surprise. Non-programmers have the learning curve. Again, another reason I really don't like guiding users to expressions. New users, IMO, should be blissfully unaware of their existence.
        Wise words!
          #111
          By the way, I forgot to mention, as is often necessary in many languages because of the reference issue, there is a clone() function that makes a new copy of an existing array or object. So a=[1,2,3],b=clone(a),push(b,99) will result in a having [1,2,3] and b having [1,2,3,99].
            #112
            It's as if you read my mind. I suppose my numerous "cloning arrays" examples gave it away.
            Without clone(), I was never (easily) able to manipulate a copied array without affecting the original, and that was driving me bonkers.
              @toggledbits , am digging how the new a..b operator behaves predictably, fixing the decimal of a and spitting out integer steps up to ≤b when both a,b > 0 and a < b. For example:
              a = 1 .. 3.3
              // result (array) [1,2,3]
              a = 1.1 .. 2.3
              // result (array) (array) [1.1,2.1]
              But sometimes it tries too hard, particularly in this case where a < 0:
              a = -2.3 .. 1.1
              // result (array) [-2.3,-1.2999999999999998,-0.2999999999999998,0.7000000000000002]
              or here, where a > b:
              a = 2.3 .. 1.1
              // result (array) [2.3,1.2999999999999998]
              All testing thus far using only INTEGERS has avoided any rounding issues, so that will likely become my mantra on usage.
              rev. 21123
                #114
                KEEP TURNING OFF LIGHTS!
                I thought it might be fun to have a Rule that periodically watches for lights (any device, really) left on, but I wanted the entire "action" part of the Rule to live inside a single expression. Here's what I came up with:
                devs = each dev in getEntity( "vera>controller_all" ).members:
                  match( dev , ".*device_\\d+" ),
                devices = each dev in devs:
                  indexOf( getEntity( dev ).actions, "dimming.set" ) > -1 ? dev : null,
                performAction( f = first dev in devices with getEntity( dev ).attributes.power_switch.state, "power_switch.off", { } ),
                getEntity( f ).name + " turned off."
                This example only checks dimmable lights paired with Vera, but could easily be modified to include other classes of device connected to other controllers, etc.
                The way it works is it (Line 1) pulls all of the member devices associated with Vera; (Line 2) filters the list to disregard devices not of the form device_NNN; (Lines 3-4) checks to see whether each device handles dimming; and, (Line 5) passes along only those for performAction() to turn off individually (one "On" device per cycle); finally, (Line 6) the name of the most recently turned-off device is logged.
                I concocted this behemoth because my Vera routinely chokes on my "Lights Out" rule, which attempts to switch 20 devices OFF all at once. I felt it might be more prudent to handle the switching at a slower pace, with the added benefit that if anyone turns ON one of the listed devices during "Lights Out" time, this rule would spot it and turn it back off automatically.
                Comments?
                • Libra
                  I suggest adding both comments (# to end of line is a comment in lexpjs) and indent spaces for clarity (e.g. the match clause on the second line is part of the each on the first line, so IMO an indent would make this much more clear).
                  That search on the first two lines suggests that MSR may need a deterministic way to differentiate an entity that represents a device from entities that represent other system data. I'll think about that, because it has come up before.
                  Another way to write the test on line 4 is 'dimming' in getEntity( dev ).capabilities. The capabilities property is an object, so the in operator works by directly testing on that object, and will be much faster than using indexof() on the actions array. Given, this operation probably would not run frequently, so that kind of optimization may be overkill, but I assert that this alternative to the array search is actually easier to interpret as well, and where performance is not the leading goal, clarity is a good next candidate.
                  The inline assignment to a temporary variable on 5 and used in line 6 is clever and makes me cackle with glee.
                    #116
                    @toggledbits and other puzzle lovers... I challenge you to paste in this Expression definition and run it with the 'try' button, to solve this heavily obfuscated conundrum:
                    solve="<creator_mystery>";
                    s1="(.)";s2="(..)";s3="(...)";s4=s1+s1;s5=s2+s2;s6=s3+s3;who=getEntity(replace(solve,s4+s6+s4+s4+s5+s1,"\$3\$2\$4\$5\$8\$7\$8\$9\$6\$11\$8\$7\$8\$9\$6"));
                    you=who[keys(who)[0x07]];are=you[keys(you)[0b01]];upper(substr(are[keys(are)[0o10]],0,0o13))
                    |-Answer: _____________°fa-info°(S┴IqpƎ˥פפO┴)-|
                      @toggledbits , how does MSR "know" that an expression like:
                      each dev in devs: getEntity(dev).attributes.power_switch.state ? dev : null
                      contains dependencies on the status of (potentially) many devices?
                      It's neat that MSR almost immediately detects when a light gets turned on, for instance, and the resulting array grows by one within less than a second. But what is cuing MSR to re-evaluate the above expression so quickly behind the scenes?
                        If devs is a constant list, the iteration visits each dev through getEntity(), and that function subscribes to any device it is asked to resolve. So the first time the expression is evaluated, it has subscribed to every device in devs.
                          #119
                          @toggledbits meanwhile, as I watch the steady stream of "changed entities" (involving devices that are otherwise just minding their own business, doing nothing) going by on Status, such as:
                          Sound Bar Beam
                          vera>device_322
                          Playing
                          17:39:11
                          Sofa Lamp
                          vera>device_138
                          false
                          17:39:00
                          do you recommend any changes to Vera in order to throttle that traffic, or is it just customary Z-Wave polling in action?
                            The rule or expression isn't reacting to every device, only those devices that end up being a target of getEntity(). The polling activity will cause additional evaluations, but it causes little actual additional load on the (MSR) system, certainly not enough to make it worth your time to try to put a dent in it. Party on!
                              #121
                              SORTING AN ARRAY IN MSR EXPRESSIONS
                              I somehow doubt this will find much utility among most users' workflows, but here goes...
                              If you want to sort a particular 1-dimensional numerical array:
                              a=[8,3,11,0,5], #unsorted array
                              L=len(a)-1,
                              each i in 0..L: #repeat for each value in a
                              do
                              b=a[0], #beginning with first value in array
                              each j in 0..(L-i): #compare remaining values
                              if min(b,num=a[j])<b then b=num else b endif,
                              remove(a,indexOf(a,b)), #remove b from array
                              b #was lowest number found in original array
                              done
                              // result (array) [ 0 , 3 , 5 , 8 , 11 ]
                              PRO TIP: To sort an array from another expression, simply edit the first line to something like this:
                              a = clone(otherExp),
                              UPDATE: As of release 21153, in which min() may take an array as its argument, the following expression works more cleanly:
                              a=[8,3,11,0,5],
                              each n in a: do b=min(a), remove(a,indexOf(a,b)), b done
                                #122
                                CREATING AN ARRAY OF STEPPED VALUES
                                In case you're looking for a numerical array containing evenly-spaced (linear) DIM values in the range 0 to 1 and back to 0, this expression should fill the bill:
                                each s in split(join(0..10)+","+join(9..0),","): int(s)/10
                                // result (array) [0,0.1,0.2,0.3,0.4,0.5,0.6,0.7,0.8,0.9,1,0.9,0.8,0.7,0.6,0.5,0.4,0.3,0.2,0.1,0]
                                  Also works: each n in -10..10: (10-abs(n))/10.
                                    #124
                                    ARRAY OF RAMPED DIM VALUES USING SINE WAVE PATTERN
                                    pi=3.1415, steps=10; each step in 0..steps:
                                    round(sin(step*(pi/(2*steps))),2)
                                    // result (array) [0,0.16,0.31,0.45,0.59,0.71,0.81,0.89,0.95,0.99,1]
                                    NOTE: You can change the number of steps to any integer value.
                                      #125
                                      ROTATE SET OF LIGHTS
                                      Sometimes you might want a set of lights to swap "On"/"Off" states -- not "toggle" per se, just follow each other based on their starting status, which I'm calling "rotation." (I believe the technical term is "chasing.")
                                      lites=["vera>device_8","vera>device_9","vera>device_110"], patt=each L in lites: getEntity(L).attributes.power_switch.state,
                                      new=slice(push(patt,patt[0]),1), each v,k in new: performAction(lites[k],"power_switch."+(v?"on":"off"),{})
                                      USAGE
                                      Edit the list in lites based on which devices you want to participate in the rotation. Every time this expression evaluates, the on/off states will rotate by one: i.e. 010 ► 100 ► 001, etc.
                                        lexpjs is missing some functions that LuaXP had and range from convenience to vital. Seems that date/time formatting is among them, as this should be a simpler operation, and we can take advantage of all the localization that the system itself offers in the process.
                                        Among the functions I know are missing, or I'm pondering, are:
                                        format( template, ...args ) - A C-style formatter for strings (like sprintf())
                                        strftime( template, time ) - Also C-style, formatting specifically for date parts.
                                        dateadd( time, yy, mm, dd, hh, MM, ss ) - Modify a timestamp; e.g. dateadd( time(), null, null, 1 ) would add one day to the current time (so the result time would have the same hour, minute, second just a day forward)
                                        dateset( time, yy, mm, dd, hh, MM, ss ) - Another way to modify a timestamp, e.g. dateset( time(), null, null, null, 0, 0, 0 ) would result in midnight for the current date, while dateset( time(), null, null, null, 24, 0, 0 ) would be exactly midnight tomorrow.
                                        push, pop, shift and unshift - Array functions to move an element in or out.
                                        concat - Concatenate two arrays; function, or overload + ( e.g. [1,2,3] + [4,5,6] => [1,2,3,4,5,6] )
                                        slice - Return a portion of arrray; pondering whether this should be done as a function, or with python-style array[start:end] syntax (into the whole brevity thing);
                                        splice - Remove elements from, and insert into, and array; splice() is the JavaScript function, and it's very powerful but not particularly user-friendly. Maybe better to have separate remove() and insert() ?
                                        The HubitatController also extends lexpjs with its own private hsltorgb() and rgbtohsl() functions to convert between RGB and HS(L) as part of its entity mappings. I'm considering making these available everywhere (could be useful in some actions in particular on any platform).
                                        You may note that map/reduce functions are missing, but they are covered by the each operator (e.g. each val in numbers: val**2 produces a new array of the square of the values in numbers, the map() function, while t=0, each val in squares: t=t+val is a reduce that produces the sum of the squares); the select() function from LuaXP is covered by the first option (e.g. first element in array-or-object with match-expression). And filtering can also be done with each because any null result during iteration isn't added to the result array.
                                        #126
                                        @toggledbits any chance we'll see strftime function coming up "soon"? Or advice how to implement the same with lexpjs (when you have unix timestamp, RfV example below)?
                                        strftime("%H:%M %d/%m/%y", <timestamp> )
                                          162.4k
