Expression to randomly run Global Reactions ?
@cw-kid This is probably more efficient
${{int(substr(replace("1234567", randomVal || 0,""),floor(random()*6),1))}}Then I looked at moving this to MSR as I have it in Reactor, . I found the remove function and this is now easily expanded to larger number and you can easily set a range
${{remove( 1..7, randomVal - 1)[floor(random()*6)]}}@toggledbits , possible bug
list(1..7]) gives [[1,2,3,4,5,6,7]] a nested array.
Is that expected.@elcid said in Expression to randomly run Global Reactions ?:
Is that expected.Yes, because
1..7on its own produces an array. So wrapping it inlist()gives you an array containing an array.FWIW,
list()is basically deprecated, because lexpjs lets you use common array notation (e.g.[1,2,3,4,5,6,7]) to define an array. -
${{remove( list(1..7)[0], randomVal - 1)[floor(random()*6)]}}GENIUS! Gonna borrow this.
Is that expected.Yes, that's expected, since
1..7itself creates an array – namely,[1,2,3,4,5,6,7]– whilelist()(now deprecated = avoid in MSR) also turns its argument into an array. I suggest omitlistand see if things improve. -
list()is basically deprecated, because lexpjs lets you use common array notation (e.g.[1,2,3,4,5,6,7]) to define an array.@toggledbits just discovered that as you posted, is it mentioned in the docs, as I had not come acreoss it?
Yup. That's in the docs.
Its a bit confusing, i read this
"[5,7,9], so this function is now obsolete and may be removed later)"
and tried [1..7], when that failed, I assumed the only way to spread was list(1..7)
May be add a note about 1..7 being the same as list(1..7). As I found it some what unclear. -
May be add a note about 1..7 being the same as list(1..7). As I found it some what unclear.@elcid , it says:
I think this is pretty clear. The range operator is documented separately.
But it's not. That's how we got started.
@elcid , it says:
@toggledbits said in Expression to randomly run Global Reactions ?:
I mean 1..7 being what I assume list(1..7) would produce a single array. That's why I found it confusing, I think that I expected a array to have [ ] around them.
Maybe add "also see range operator". -
Maybe add "also see range operator".@elcid said in Expression to randomly run Global Reactions ?:
Funny you should mention this, since all yesterday, I grappled with the question, "How can I find the minimum of an array in MSR?" (Answer: Not easily at all!) Turns out the
min()function only works on a list with 2 elements, not arrays of arbitrary length. In other words,min(1,2,3)yields1without a hitch, whereasmin([1,2,3])returnsnull(for good reason: There's no guarantee the argument will always be a 1-dimensional numeric array!). Same formax().Which led me to the realization that there's no direct way in MSR to "convert" an array into a list. Seems your brain encountered the same type of mental collision while trying to work out your imported expression.
What makes the expression run and generate a new number after a period of time?
This is what I have so far.
Trigger is the virtual switch in Vera.
Pulse every 1 seconds and repeat every 60 seconds.Set Reaction - Groups that look at the expression named "ChooseColour" and its current number value
and then runs a Global Reactionnow directly sets that colour on the LED strip.The random number generator expression named "ChooseColour" this is a rule expression not a Global Expression.
I added an 1 minute interval to the triggers and the virtual switch is true trigger is also pulsing every minute.
The expression is now changing numbers every minute, but the reactions don't seem to be running as the colour is stuck and not changing.
Also I think this expression generates the number zero which I don't have assigned to any reaction.
@cw-kid Just so you know, I have a "Color Cycler" rule that uses the [Entity Action] [Set Color RGB] action with this expression inside each field ("R", "G" and "B"):
${{ floor(random()*255) }}which makes the associated light (a Hue bulb) adopt a perfectly random color. Just something you might consider trying.
Thanks I will try the "Color Cycler" in a brand new rule to test it out.
I haven't as yet looked at updating my current rule with the new expression to always guarantee a new random number that hasn't been repeated etc.
I will have a look over the weekend. Sure I will have questions.
Cheers
I've just tried using this in my rule set, I added it as the expression for the rule. When I press the play button next to it, it seems to work and changes to different numbers between 1 to 7 etc.
However when I restart Reactor it says it cannot find the Global Expression named "randomVal".
So I then created it as a Global Expression, the error has now gone away, but I don't understand what this Global Expression is for?
