Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
Change in Plans (Don't Panic)
I have an Ezlo Plus and an Ezlo Atom. On the Elzo Plus I have lots of devices on there, however most of them are emulated virtual devices mirrored from the "real" devices on my production Vera Plus, this was done using Rene's 3rd party Vera to Ezlo bridge plugin.
I do also have some real Z-Wave devices paired directly to the Ezlo Plus hub.
I would be happy to help test this new MSR interface and I am very happy to see you have decided to make it. This is a massive boost for Ezlo themselves in my opinion as they currently have no native logic rules engine of their own.
The "rule sets" in the beta Ezlo web GUI are basic and pretty much Vera scenes you would find in the Vera mobile app and only have a little improvement thus far, for example we now have basic AND / OR however in these scenes, which we never had on the Vera firmware hubs.
PM me if you want direct access to my Ezlo Plus controller happy for you to poke around and have a look at it.
@toggledbits I bought 2 test controllers a while back, and I would be more than happy to help any way I can.
Do you have any idea what use case/device interaction scope would look like to give you the data you need?
I am pretty flexible over here...
@toggledbits I’m so thankful for the time and effort you put into MSR so the least I can do is give something back. I’d love to participate with my Ezlo Plus running about 20 zigbee devices in production, the logic is already in MSR so switching to a new interface would be easy for testing.
Thanks to all who have replied/volunteered. Variety of devices is key, so anything and everything is helpful. As you may have seen in these forums, even several months into fairly stable integrations for the other hubs, devices keep popping up with little exceptions or gaps in completion. More data is better is less. All of the interfaces drop files in the
logs
folder at the moment that I can use for fairly good diagnostics and forensics, so that theme will continue and get some embellishments for eZLO.I expect the first wave of testing will just be "look and see"... do the devices come in as correct MSR entities, do they have their correct attributes, and are they correctly identified and, where appropriate, assigned sensible system capabilities (in addition to extension capabilities of the
x_ezlo_etc
variety). Startup configuration is also always a first-level challenge, and in this case, we'll have two different options: secured access (login through eZLO's cloud to get a local access token), and unsecured access (secured access can be disabled on the hub, eliminating the need for cloud login/token requests to get local access to the hub). Login + attributes will enable all of the rule/condition capabilities automatically. The second wave will follow immediately (as in with the next breath) to see that actions work and to what extent they need extension or repair, and that completes reactions. Things converged pretty quickly with the other three interfaces, so I'm hopeful this can be highly functional in short order. -
I have a VeraPlus (daily driver), another VeraPlus (used/spare), an eZLO Atom 2.0 (unused), Vera Edge running the LInux f/w (unused), an eZLO Plus (beta testing / unused) and an old Vera 1 (connected / idle) divided among two different residences.
@toggledbits , surely others have made a similar offer by now, so I presume you are "set" for want of controllers -- but IF you require any of these for use in-house, just ask and I'll happily ship/donate.
Likewise, IF you need me to test some particular thing out from my side (Synology NAS > Docker > MSR > hub(s)), also just ask. Who knows, it might be the first/last thing I ever do with eZLO hardware, which otherwise is going in the trash at some point.
Glad you made this decision; I was concerned that you might inadvertently wind up with spare time on your hands. Oh, and THANK YOU for so thoughtfully grandfathering those who've toiled in the trenches alongside you lo these many weeks and months. For that you will not be sorry.
- Libra
@librasun I actually have a pretty big fist full of controllers myself. It's not really controllers I'm wanting for, it's devices and environments. The more hands this touches that aren't mine, the more things break, and the better things get for it. Hold on to them!
@librasun said in Change in Plans (Don't Panic):
I absolutely doubt most users of the Atom or PlugHub would be a user of MSR (except in some fringe cases, like for an out-building). But those eZLO Plus's (in full or prototype/skeletal form) could be useful. They seem to have a similar architecture to the Raspberry Pi 4. Maybe once I get the ZWaveJS interface fleshed out (that's also been in the works), I can just publish an MSR replacement firmware for the Plus hardware. You know, for science.
@toggledbits said in Change in Plans (Don't Panic):
So would it also act as a Z-Wave radio?
Or would you still need another second hub like Vera or the Ezlo or Hubitat etc, to act as the Z-Wave controller?
ZWaveJS would just talk to the on-board ZWave chip (via a serial/USB interface). Vera works the same way. So, yes, it would function as the ZWave radio in addition to being the rules engine.
So an all in one controller then!
Might have to get my hands on another Ezlo Plus hub, so I can test both setups, native Ezlo or MSR with Z-Wave JS.
Looking forward to this, so I could add openluup to the mix and call it a day
I have as many before me, a Ezlo Plus laying around, and collecting dust. I've been waiting for a good reason to use it. When I got the Ezlo Plus, and I heard of the new Z-wave standard with better range I went really hopeful. Combined with MSR it looked like a winning concept. But the lack of stabilty, a working UI, and non-beta made me loose interest. If I can contribute in any way, I'd be honoured.
While I think a complete replacement firmware would be a fun exercise (and very possibly useful), we already have shown with openLuup and MSR that a Vera on its own is pretty stable in a reduced role as a ZWave radio and little else. So far my testing with the eZLO hub is yielding similar results, with the added benefit that it's demonstrably more stable when ZWave devices become unreachable (the Achilles Heel of current Vera firmware). I suspect we'll find that MSR running on a Pi, NAS, or other host against an eZLO hub still on its native firmware gives almost all of the benefits, without the need to replace the firmware on the hub itself. It will be fun to try it both ways, but I suspect that the simplest solution is going to be the best. And it will be here in a few days, where figuring out the firmware replacement will likely take a good bit more effort (and so is not really a goal, currently, just more of an experiment for a future weekend).
I have already commented on the other forum that my VeraPlus was saved from an incinerator or the tires of my car a few times, thanks to Reactor, and gained new life with MSR, so Patrick you know that you have in my person a collaborator (with limitations of technical knowledge), but a person who likes to explore and especially give suggestions that help users.
But, in my humble opinion, I will not make the mistake of buying an eZLO, I am seriously considering investing now in a Hubitat because I am tired of my VeraPlus being incompatible with any ZegBee or other devices with S2. The eZLO developers should follow the same line of not listening to the 3PP, the independent developers, and go back to repeating Vera's mistakes in my opinion.
This way I recognize your huge effort for the HA community, I am sure you have done a lot but in this new eZLO endeavor I will not be able to help, count me full on MSR for VeraPlus and Hubitat.
My unwillingness to base my own HA on eZLO is what delayed this eventuality, so I completely understand. There's a community that needs this, though, and they are my community from the Vera days. While we may be of the same mind with respect to the future, it's clear that a great many people are still clinging to hope. If they want to stay and wait it out (now nearly three years in the making and not near completion, IMO), at least I can throw them a lifeline to make straddling the Vera-eZLO divide less painful.
I have to say my Ezlo Plus is extremely fast as far a Z-Wave communications are concerned. I don't have many Z-Wave devices directly paired to the Ezlo hub yet, but the ones that are, are very quick !
I setup a Z-wave door contact sensor on a walk in cupboard door and a Z-Wave light bulb and two scenes created on the Ezlo Plus, one for open and one for close.
The bulb turns on instantly and I mean instantly as soon as I open the door even just a little bit when it breaks the door contacts connection.
Yes the Ezlo software is still very lacking and buggy and all still being developed.
But we have MSR support coming for Ezlo hubs soon and Bill the Home Remote dashboard app developer told me only yesterday he is still planning to support Ezlo hubs and it will hopefully happen this summer. So with MSR and Home Remote what other interfaces do you need?
The Ezlo hub can act just as a Z-Wave radio as my Vera Plus does now today.
I am in no rush to replace my production Vera Plus but I will likely one day migrate all the devices to the Ezlo hub, especially if it works also well with Zigbee 3.0 devices, which Vera hubs do not.
