  4. Issues connecting to Ezlo Controller
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
16 Posts 2 Posters 1.7k Views 2 Watching
    I've read the thread and the docs, thought I'd setup everything correctly, but MSR doesn't connect to my Ezlo controller.
    The docs don't say what to do if you have already previously enabled anonymous access via their Online API Tool.
    “offlineAnonymousAccess” and “offlineInsecureAccess” are set to true on my controller already.
    In my Reactor.yaml file I decided to try it first with the username and password entries commented out and also the "set_anonymous_access: true" commented out.
    I see these errors in the log file:
    2021-07-16T08:53:56.225Z <app:NOTICE> Starting Structure...
    2021-07-16T08:53:56.235Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController)
    2021-07-16T08:53:56.245Z <Structure:INFO> Structure#1 starting controller interface vera-edge (VeraController)
    2021-07-16T08:53:56.248Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController)
    2021-07-16T08:53:56.250Z <Structure:INFO> Structure#1 starting controller interface weather (OWMWeatherController)
    2021-07-16T08:53:56.252Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController)
    2021-07-16T08:53:56.379Z <default:null> Module VeraController v21195
    2021-07-16T08:53:56.402Z <default:null> Module OWMWeatherController v21140
    2021-07-16T08:53:56.407Z <default:null> Module SystemController v21102
    2021-07-16T08:53:56.419Z <VeraController:NOTICE> VeraController#vera starting
    2021-07-16T08:53:56.582Z <VeraController:INFO> VeraController#vera loaded mapping ver 21177 rev 1 format 1 notice
    2021-07-16T08:53:56.623Z <VeraController:NOTICE> VeraController#vera-edge starting
    2021-07-16T08:53:56.629Z <Controller:CRIT> Controller: failed to load ezlo implementation file:///home/username/reactor/server/lib/EzloController.js: Error: Cannot find module 'uuid'
    Require stack:
    - /home/username/reactor/server/lib/EzloController.js
    2021-07-16T08:53:56.632Z <Controller:CRIT> Error: Cannot find module 'uuid'
    Require stack:
    Require stack:
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:885:15)
        at Function.Module._load (internal/modules/cjs/loader.js:730:27)
        at Module.require (internal/modules/cjs/loader.js:957:19)
        at require (internal/modules/cjs/helpers.js:88:18)
        at Object.<anonymous> (/home/username/reactor/server/lib/EzloController.js:478:84)
        at Module._compile (internal/modules/cjs/loader.js:1068:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1097:10)
        at Module.load (internal/modules/cjs/loader.js:933:32)
        at Function.Module._load (internal/modules/cjs/loader.js:774:14)
        at ModuleWrap.<anonymous> (internal/modules/esm/translators.js:199:29)
    2021-07-16T08:53:56.692Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
    2021-07-16T08:53:56.828Z <Structure:ERR> [Structure:start] failed to start controller ezlo: Error: Cannot find module 'uuid'
    Require stack:
    2021-07-16T08:53:56.829Z <Structure:CRIT> Error: Cannot find module 'uuid'
    Require stack:
    Require stack:
    2021-07-16T08:53:56.831Z <Controller:CRIT> Controller: failed to start controller reactor_system (file:///home/username/reactor/server/lib/SystemController.js): TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
    2021-07-16T08:53:56.832Z <Controller:CRIT> TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
        at Entity.setAttribute (/home/username/reactor/server/lib/Entity.js:308:19)
        at SystemController.run (/home/username/reactor/server/lib/SystemController.js:224:643)
        at /home/username/reactor/server/lib/SystemController.js:172:35
        at new Promise (<anonymous>)
        at SystemController.start (/home/username/reactor/server/lib/SystemController.js:170:76)
        at /home/username/reactor/server/lib/Controller.js:273:89
    2021-07-16T08:53:56.833Z <Structure:ERR> [Structure:start] failed to start controller reactor_system: TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
    2021-07-16T08:53:56.833Z <Structure:CRIT> TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
    2021-07-16T08:53:56.835Z <app:INFO> Structure running; pausing for controllers' initial ready
      In the Reactor.yaml file I then removed the "#" next to username and password but not for "set_anonymous_access: true" and restarted MSR.
      The Ezlo controller is still not seen in Entities area.
      2021-07-16T09:09:11.206Z <app:NOTICE> Starting Structure...
      2021-07-16T09:09:11.216Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController)
      2021-07-16T09:09:11.226Z <Structure:INFO> Structure#1 starting controller interface vera-edge (VeraController)
      2021-07-16T09:09:11.229Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController)
      2021-07-16T09:09:11.231Z <Structure:INFO> Structure#1 starting controller interface weather (OWMWeatherController)
      2021-07-16T09:09:11.233Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController)
      2021-07-16T09:09:11.364Z <default:null> Module VeraController v21195
      2021-07-16T09:09:11.386Z <default:null> Module OWMWeatherController v21140
      2021-07-16T09:09:11.391Z <default:null> Module SystemController v21102
      2021-07-16T09:09:11.403Z <VeraController:NOTICE> VeraController#vera starting
      2021-07-16T09:09:11.574Z <VeraController:INFO> VeraController#vera loaded mapping ver 21177 rev 1 format 1 notice
      2021-07-16T09:09:11.606Z <VeraController:NOTICE> VeraController#vera-edge starting
      2021-07-16T09:09:11.613Z <Controller:CRIT> Controller: failed to load ezlo implementation file:///home/username/reactor/server/lib/EzloController.js: Error: Cannot find module 'uuid'
      Require stack:
      2021-07-16T09:09:11.615Z <Controller:CRIT> Error: Cannot find module 'uuid'
      Require stack:
      Require stack:
      2021-07-16T09:09:11.675Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
      2021-07-16T09:09:11.804Z <Structure:ERR> [Structure:start] failed to start controller ezlo: Error: Cannot find module 'uuid'
      Require stack:
      2021-07-16T09:09:11.804Z <Structure:CRIT> Error: Cannot find module 'uuid'
      Require stack:
      Require stack:
      2021-07-16T09:09:11.806Z <Controller:CRIT> Controller: failed to start controller reactor_system (file:///home/username/reactor/server/lib/SystemController.js): TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
      2021-07-16T09:09:11.807Z <Controller:CRIT> TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
      2021-07-16T09:09:11.808Z <Structure:ERR> [Structure:start] failed to start controller reactor_system: TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
      2021-07-16T09:09:11.809Z <Structure:CRIT> TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
      2021-07-16T09:09:11.811Z <app:INFO> Structure running; pausing for controllers' initial ready
        Finally I removed the "#" for the "set_anonymous_access: true" and restarted MSR.
        Also in the docs it says:
        source: "wss://192.168.1.15:17000" # change the IP address
        However all my other Vera controllers have single quotes around their URL.
        source: 'wss://192.168.1.15:17000' # change the IP address
        I tried changing the double quotes to single quotes in my Reactor.yaml file but it made no difference.
        Just thought I would point out the quotes thing.
          Should I also see Reactor System in the Entities area?
          Looking in my log file now I've just seen this:
          And these error:
          2021-07-16T13:17:31.337Z <Controller:CRIT> TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
          And several errors like these:
          2021-07-16T13:17:35.032Z <default:ERR> [Entity:setPrimaryAttribute] Attempt to set primary to power_switch.state invalid, not in { "x_vera_device": { "device_number": 434, "device_type": "urn:schemas-upnp-org:device:RGBController:1", "parent_device": 0, "failed": --null--, "configured": --null--, "mapped_class": "rgbcontroller_plugin", "mapped_by": "*;device_type=urn:schemas-upnp-org:device:RGBController:1" }, "x_vera_svc_upnp_org_RGBController1": {  }, "x_vera_svc_upnp_org_SwitchPower1": {  }, "x_vera_svc_micasaverde_com_HaDevice1": {  }, "x_vera_rgbcontroller_plugin": { "device_type": "FGRGBWM-441", "configured": true, "color": "#0000000000", "message": "" } }
          2021-07-16T13:17:35.034Z <VeraController:ERR> VeraController#vera exception/error while updating VeraController#vera
          2021-07-16T13:17:35.034Z <VeraController:CRIT> Error: Entity#vera>device_434:setPrimaryAttribute() can't set power_switch.state, not defined for entity
          • toggledbitsT Online
            toggledbitsT Online
            Are you using a docker container or the archive download? If archive, I just realized I forgot to mention: do npm update --no-save in your reactor directory after unpacking.
              I am not using docker no.
              I downloaded the file from the bug tracker site and ran the commands in SSH to update MSR on my Debian Linux box.
                OK I see the Ezlo-Plus controller now in entities.
                I have the username and password commented out still in my reactor.yaml file.
                  toggledbitsT Online
                  If you already have anonymous access enabled, that's fine. The instructions describe the process to get to that point, and those work whether you already have it enabled or not (i.e. cloud login and token access always work, so it's the safest path to start with). You're a step ahead of the game so you can skip that. Username and password not needed. You can also remove/comment out the set_anonymous_access line.
                    toggledbitsT Online
                    Did your reactor_system come back? If not, check your location configuration.
                      @toggledbits said in Issues connecting to Ezlo Controller:
                      No its still missing from Entities.
                      I have never changed my location information in the reactor.yaml file since I very first started using MSR.
                        I've just created my first two Global Reactions with the Ezlo controller to change the colours on an RGB bulb, its working OK.
                        Its also imported all the "virtual devices" from the Ezlo Plus hubs (Rene's Vera to Ezlo bridge plugin) that was kind of expected.
                        I have several real Z-Wave devices paired to the Ezlo Plus hub now, so I will test out MSR with those.
                          toggledbitsT Online
                          Getting RGB bulbs working is a great example of blind luck, since I don't have any of those connected to my eZLO (and none that I do have are supported currently--all require plugins). So that's a bit of good news!
                          For your reactor_system, please fetch this URL and paste output here:
                          http://your-msr-host-ip:8111/diag/sun
                            I see you saw (liked) my post on the Vera forum. I edited it however and said it can be laggy when pressing the buttons in the Home Remote app to change to the different colours of the bulb.
                            If I over do it and press them quickly to change to different colours, the bulb can stop responding for a period of time.
                            This is most likely the Ezlo HTTP web socket API falling behind with what commands MSR is sending to it.
                              I used R,G,B in my reactions. I haven't tried using HEX colour codes yet.
                                toggledbitsT Online
                                I'm guessing there's just a lot of plumbing in that hookup... you press a button in Home Remote, that makes the request to MSR (over WiFi directly, or is there a cloud component to that app?), then MSR has to make the request to the eZLO hub, then the eZLO hub has to send the request to the device, the device has to respond, and the finish traverse its way all the way backwards. The reactor.log file will have enough data for you to figure out (a) when the request to start the reaction was received (search for "Enqueueing" with your reaction name/id following); (b) when the reaction started the request to the hub (search for "sending payload for", requires debug enabled per post instructions); and (c) when the hub action completed (i.e. eZLO hub responded with success/done, search for "action rgbcolor.set_rgb completed", assuming that's the action you are using; change as needed); and (d) when the reaction ended (search for "all actions completed"). Each of those will have a time stamp with milliseconds, so you can compute the pace of each phase and the time overall of MSR's contribution to the timing.
                                  Its direct on the WLAN from the Home Remote app to the MSR HTTP API.
                                  I have this exact same setup with my Vera hub for my other colour lights paired to the Vera Plus.
                                  I haven't noticed those being laggy when pressing the buttons on the Home Remote app page etc.
                                  But to be fair I don't normally press all the buttons quickly to change colours in that manner. I will try it against a Vera controller as well to see.
                                    932
                                    2.0k
                                    3.7k
                                    3.3k
