  4. Issues connecting to Ezlo Controller
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
16 Posts 2 Posters 4.4k Views 2 Watching
    I've read the thread and the docs, thought I'd setup everything correctly, but MSR doesn't connect to my Ezlo controller.
    The docs don't say what to do if you have already previously enabled anonymous access via their Online API Tool.
    “offlineAnonymousAccess” and “offlineInsecureAccess” are set to true on my controller already.
    In my Reactor.yaml file I decided to try it first with the username and password entries commented out and also the "set_anonymous_access: true" commented out.
    I see these errors in the log file:
    2021-07-16T08:53:56.225Z <app:NOTICE> Starting Structure...
    2021-07-16T08:53:56.235Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController)
    2021-07-16T08:53:56.245Z <Structure:INFO> Structure#1 starting controller interface vera-edge (VeraController)
    2021-07-16T08:53:56.248Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController)
    2021-07-16T08:53:56.250Z <Structure:INFO> Structure#1 starting controller interface weather (OWMWeatherController)
    2021-07-16T08:53:56.252Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController)
    2021-07-16T08:53:56.379Z <default:null> Module VeraController v21195
    2021-07-16T08:53:56.402Z <default:null> Module OWMWeatherController v21140
    2021-07-16T08:53:56.407Z <default:null> Module SystemController v21102
    2021-07-16T08:53:56.419Z <VeraController:NOTICE> VeraController#vera starting
    2021-07-16T08:53:56.582Z <VeraController:INFO> VeraController#vera loaded mapping ver 21177 rev 1 format 1 notice
    2021-07-16T08:53:56.623Z <VeraController:NOTICE> VeraController#vera-edge starting
    2021-07-16T08:53:56.629Z <Controller:CRIT> Controller: failed to load ezlo implementation file:///home/username/reactor/server/lib/EzloController.js: Error: Cannot find module 'uuid'
    Require stack:
    - /home/username/reactor/server/lib/EzloController.js
    2021-07-16T08:53:56.632Z <Controller:CRIT> Error: Cannot find module 'uuid'
    Require stack:
    Require stack:
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:885:15)
        at Function.Module._load (internal/modules/cjs/loader.js:730:27)
        at Module.require (internal/modules/cjs/loader.js:957:19)
        at require (internal/modules/cjs/helpers.js:88:18)
        at Object.<anonymous> (/home/username/reactor/server/lib/EzloController.js:478:84)
        at Module._compile (internal/modules/cjs/loader.js:1068:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1097:10)
        at Module.load (internal/modules/cjs/loader.js:933:32)
        at Function.Module._load (internal/modules/cjs/loader.js:774:14)
        at ModuleWrap.<anonymous> (internal/modules/esm/translators.js:199:29)
    2021-07-16T08:53:56.692Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
    2021-07-16T08:53:56.828Z <Structure:ERR> [Structure:start] failed to start controller ezlo: Error: Cannot find module 'uuid'
    Require stack:
    2021-07-16T08:53:56.829Z <Structure:CRIT> Error: Cannot find module 'uuid'
    Require stack:
    Require stack:
    2021-07-16T08:53:56.831Z <Controller:CRIT> Controller: failed to start controller reactor_system (file:///home/username/reactor/server/lib/SystemController.js): TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
    2021-07-16T08:53:56.832Z <Controller:CRIT> TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
        at Entity.setAttribute (/home/username/reactor/server/lib/Entity.js:308:19)
        at SystemController.run (/home/username/reactor/server/lib/SystemController.js:224:643)
        at /home/username/reactor/server/lib/SystemController.js:172:35
        at new Promise (<anonymous>)
        at SystemController.start (/home/username/reactor/server/lib/SystemController.js:170:76)
        at /home/username/reactor/server/lib/Controller.js:273:89
    2021-07-16T08:53:56.833Z <Structure:ERR> [Structure:start] failed to start controller reactor_system: TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
    2021-07-16T08:53:56.833Z <Structure:CRIT> TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
    2021-07-16T08:53:56.835Z <app:INFO> Structure running; pausing for controllers' initial ready
      In the Reactor.yaml file I then removed the "#" next to username and password but not for "set_anonymous_access: true" and restarted MSR.
      The Ezlo controller is still not seen in Entities area.
      2021-07-16T09:09:11.206Z <app:NOTICE> Starting Structure...
      2021-07-16T09:09:11.216Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController)
      2021-07-16T09:09:11.226Z <Structure:INFO> Structure#1 starting controller interface vera-edge (VeraController)
      2021-07-16T09:09:11.229Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController)
      2021-07-16T09:09:11.231Z <Structure:INFO> Structure#1 starting controller interface weather (OWMWeatherController)
      2021-07-16T09:09:11.233Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController)
      2021-07-16T09:09:11.364Z <default:null> Module VeraController v21195
      2021-07-16T09:09:11.386Z <default:null> Module OWMWeatherController v21140
      2021-07-16T09:09:11.391Z <default:null> Module SystemController v21102
      2021-07-16T09:09:11.403Z <VeraController:NOTICE> VeraController#vera starting
      2021-07-16T09:09:11.574Z <VeraController:INFO> VeraController#vera loaded mapping ver 21177 rev 1 format 1 notice
      2021-07-16T09:09:11.606Z <VeraController:NOTICE> VeraController#vera-edge starting
      2021-07-16T09:09:11.613Z <Controller:CRIT> Controller: failed to load ezlo implementation file:///home/username/reactor/server/lib/EzloController.js: Error: Cannot find module 'uuid'
      Require stack:
      2021-07-16T09:09:11.615Z <Controller:CRIT> Error: Cannot find module 'uuid'
      Require stack:
      Require stack:
      2021-07-16T09:09:11.675Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
      2021-07-16T09:09:11.804Z <Structure:ERR> [Structure:start] failed to start controller ezlo: Error: Cannot find module 'uuid'
      Require stack:
      2021-07-16T09:09:11.804Z <Structure:CRIT> Error: Cannot find module 'uuid'
      Require stack:
      Require stack:
      2021-07-16T09:09:11.806Z <Controller:CRIT> Controller: failed to start controller reactor_system (file:///home/username/reactor/server/lib/SystemController.js): TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
      2021-07-16T09:09:11.807Z <Controller:CRIT> TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
      2021-07-16T09:09:11.808Z <Structure:ERR> [Structure:start] failed to start controller reactor_system: TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
      2021-07-16T09:09:11.809Z <Structure:CRIT> TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
      2021-07-16T09:09:11.811Z <app:INFO> Structure running; pausing for controllers' initial ready
        Finally I removed the "#" for the "set_anonymous_access: true" and restarted MSR.
        Also in the docs it says:
        source: "wss://192.168.1.15:17000" # change the IP address
        However all my other Vera controllers have single quotes around their URL.
        source: 'wss://192.168.1.15:17000' # change the IP address
        I tried changing the double quotes to single quotes in my Reactor.yaml file but it made no difference.
        Just thought I would point out the quotes thing.
          Should I also see Reactor System in the Entities area?
          Looking in my log file now I've just seen this:
          And these error:
          2021-07-16T13:17:31.337Z <Controller:CRIT> TypeError: Can't set NaN on attribute suninfo.astronomical_dawn (reactor_system>sun)
          And several errors like these:
          2021-07-16T13:17:35.032Z <default:ERR> [Entity:setPrimaryAttribute] Attempt to set primary to power_switch.state invalid, not in { "x_vera_device": { "device_number": 434, "device_type": "urn:schemas-upnp-org:device:RGBController:1", "parent_device": 0, "failed": --null--, "configured": --null--, "mapped_class": "rgbcontroller_plugin", "mapped_by": "*;device_type=urn:schemas-upnp-org:device:RGBController:1" }, "x_vera_svc_upnp_org_RGBController1": {  }, "x_vera_svc_upnp_org_SwitchPower1": {  }, "x_vera_svc_micasaverde_com_HaDevice1": {  }, "x_vera_rgbcontroller_plugin": { "device_type": "FGRGBWM-441", "configured": true, "color": "#0000000000", "message": "" } }
          2021-07-16T13:17:35.034Z <VeraController:ERR> VeraController#vera exception/error while updating VeraController#vera
          2021-07-16T13:17:35.034Z <VeraController:CRIT> Error: Entity#vera>device_434:setPrimaryAttribute() can't set power_switch.state, not defined for entity
            Are you using a docker container or the archive download? If archive, I just realized I forgot to mention: do npm update --no-save in your reactor directory after unpacking.
              I am not using docker no.
              I downloaded the file from the bug tracker site and ran the commands in SSH to update MSR on my Debian Linux box.
                OK I see the Ezlo-Plus controller now in entities.
                I have the username and password commented out still in my reactor.yaml file.
                  If you already have anonymous access enabled, that's fine. The instructions describe the process to get to that point, and those work whether you already have it enabled or not (i.e. cloud login and token access always work, so it's the safest path to start with). You're a step ahead of the game so you can skip that. Username and password not needed. You can also remove/comment out the set_anonymous_access line.
                    Did your reactor_system come back? If not, check your location configuration.
                      @toggledbits said in Issues connecting to Ezlo Controller:
                      No its still missing from Entities.
                      I have never changed my location information in the reactor.yaml file since I very first started using MSR.
                        I've just created my first two Global Reactions with the Ezlo controller to change the colours on an RGB bulb, its working OK.
                        Its also imported all the "virtual devices" from the Ezlo Plus hubs (Rene's Vera to Ezlo bridge plugin) that was kind of expected.
                        I have several real Z-Wave devices paired to the Ezlo Plus hub now, so I will test out MSR with those.
                          Getting RGB bulbs working is a great example of blind luck, since I don't have any of those connected to my eZLO (and none that I do have are supported currently--all require plugins). So that's a bit of good news!
                          For your reactor_system, please fetch this URL and paste output here:
                          http://your-msr-host-ip:8111/diag/sun
                            I see you saw (liked) my post on the Vera forum. I edited it however and said it can be laggy when pressing the buttons in the Home Remote app to change to the different colours of the bulb.
                            If I over do it and press them quickly to change to different colours, the bulb can stop responding for a period of time.
                            This is most likely the Ezlo HTTP web socket API falling behind with what commands MSR is sending to it.
                              I used R,G,B in my reactions. I haven't tried using HEX colour codes yet.
                                I'm guessing there's just a lot of plumbing in that hookup... you press a button in Home Remote, that makes the request to MSR (over WiFi directly, or is there a cloud component to that app?), then MSR has to make the request to the eZLO hub, then the eZLO hub has to send the request to the device, the device has to respond, and the finish traverse its way all the way backwards. The reactor.log file will have enough data for you to figure out (a) when the request to start the reaction was received (search for "Enqueueing" with your reaction name/id following); (b) when the reaction started the request to the hub (search for "sending payload for", requires debug enabled per post instructions); and (c) when the hub action completed (i.e. eZLO hub responded with success/done, search for "action rgbcolor.set_rgb completed", assuming that's the action you are using; change as needed); and (d) when the reaction ended (search for "all actions completed"). Each of those will have a time stamp with milliseconds, so you can compute the pace of each phase and the time overall of MSR's contribution to the timing.
                                  Its direct on the WLAN from the Home Remote app to the MSR HTTP API.
                                  I have this exact same setup with my Vera hub for my other colour lights paired to the Vera Plus.
                                  I haven't noticed those being laggy when pressing the buttons on the Home Remote app page etc.
                                  But to be fair I don't normally press all the buttons quickly to change colours in that manner. I will try it against a Vera controller as well to see.
                                    165.3k
