  4. Support for Ezlo Atom controllers?
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
51 Posts 3 Posters 10.1k Views 3 Watching
    I just tried to add a connection for my Ezlo Atom, its added the Atom system in to the MSR Entities, but it has a "false" state and hasn't found my devices that are paired to the Atom.
    Also note that on the Atom controller there is no settings for:
    offlineAnonymousAccess: true or false
    offlineInsecureAccess: true or false
    So this line in the reactor.yaml file won't work for Atom's.
    set_anonymous_access: true
    This was what I added to my reactor.yaml file.
    - id: ezlo-atom
      enabled: true
      implementation: EzloController
        source: "wss://192.168.0.101:17000"  # change the IP address
        serial: "70060304"    # put your hub's serial here
        username: "myusername"  # put your username here between quotes
        password: "mypassword"  # and password
        # set_anonymous_access: true
      OK. Please do this:
      1. Disable any other EzloController instances (by setting enabled: false in their controller config in reactor.yaml), leaving just the Atom enabled.
      2. Restart MSR. Wait until the restart occurs and your browser/UI reconnect.
      3. Confirm no devices list.
      4. Open a PR and post the nnn_data_list.json, nnn_hub_info.json and nnn_mode_info.json files, where nnn is the ID of the Atom interface (from reactor.yaml). Based on your snip above, that would be ezlo-atom_data_list.;json, etc.
      You can put your other Ezlo instances back after grabbing and posting the files.
        OK. Please do this:
        I've tried that, with the Ezlo Plus controller disabled, then in Entities area for the Ezlo Atom controller and still no devices listed for the Atom.
        I can't see any file called ezlo-atom_data_list.json however or hub and mode info either.
        These one listed have time stamps from several hours ago earlier today.
        EDIT: I've searched in Winscp the entire Reactor folder and there is no .json files of that name with Atom.
          Not sure exactly what I am looking for in the reactor.log file but I can see several errors like these:
          2021-07-22T15:41:45.378Z <EzloController:5:Controller.js:581> EzloController#ezlo-atom ws_open caught TimedPromise timeout
          2021-07-22T15:41:45.383Z <EzloController:WARN> EzloController#ezlo-atom websocket error during open/negotation: Error: WebSocket was closed before the connection was established
          2021-07-22T15:41:45.385Z <EzloController:ERR> EzloController#ezlo-atom failed to connect websocket to wss://192.168.0.243:17000: TimedPromise timeout
          2021-07-22T15:41:45.389Z <EzloController:NOTICE> EzloController#ezlo-atom websocket to wss://192.168.0.243:17000 closed during open/negotiation
          I don't want to post the entire log here or in the ticket system, perhaps I can email it to you if needed?
            No, that's enough for now. Do we know if a local API for the Atom is even possible?
              @toggledbits said in Support for Ezlo Atom controllers?:
              The Ezlo dev just said "We don't have it on Atom" when I asked him why I couldn't see the offlineAnonymousAccess and offlineInsecureAccess settings in the API Tool for the Atom.
                I have Atom working, but it uses an undocumented method of access (not the one described on the eZLO Community, but similar), and I'm still working out some issues.
                  Via a local or cloud Web sockets API?
                  Why is it undocumented, do we need the Ezlo Devs to confirm that type of access will remain open and available.
                    Ezlo dev says
                    "We have local Web sockets API on the Atom and plughub but not the HTTP API"
                      It doesn't much matter what they say if the device doesn't answer (won't answer hub.offline.login.ui) on the published port number they use for the others (like Plus), and they don't tell us what the Atom-specific mechanism is. Or, maybe my Atom is too old, but it is a second-gen unit, so I don't think so. I can't work from "we have it". There needs to be documentation to not only describe it, but memorialize their commitment to supporting it.
                      Remote access is really the same. I can't build on unsupported/undocumented features and functions. It may work today, but if doesn't down the road, I look like the bad guy, and the onus is on me to fix it and restore the feature, which may not even be possible. Poor risk reward, especially for this context.
                        I totally agree.
                        I've asked him on Skype what the port number should be? and if they have any documentation for the Web socket API on the RTOS based controllers, such as the Atom.
                          The port number is right, it connects, it just never answers the usual login request, and doesn't issue any messages of any kind at all. I embellished details in my previous post there, and prompted Oleg in it. In any case, none of this is serviceable until this is documented.
                          Over a year ago on Skype, early on in perhaps March or April, I suggested that all of their PDF documents need to be in a single location/library where they can seen. This business of them posting single PDFs on demand in the forums is the worst possible way to get it done (maybe second worst: they were replying on Skype with them, which was actually worse). Did that ever happen? I know of no such repository. If there were, at least one could research, but as it is, their docs are a hodge-podge of "lucky if you have it" one-offs, a dated web reference site, and an incomplete/dated API tool. And no version control. Ugh. This entire situation is why I didn't want to do this eZLO interface, and I'm really regretting it this morning.
                            I feel your pain.
                            Forgot it for now then.
                            For me personally I don't need my Atom connected to MSR. But I just thought I'd try it and test it if it did connect.
                            As long as Ezlo Plus and Ezlo Secure works, I think most people will be happy with that.
                            That website you mentioned is all I know of and there's a bit of a library section they created on the forum here.
                              There is also this Ezlo Support Site here which has some API stuff in it, but overall it looks lacking in content.
                                Yeah, nothing there either. Cart before the horse. API docs. No docs for how to log in to the API. And enough people have asked, including you, to produce various unofficial mechanisms; that should have been enough prompt/repetition to cause an official document to be produced (and really, together with/as part of the API docs is the perfect place for it).
                                F 1 Reply Last reply
                                  wrote on last edited by Fanan
                                  Might be a bit OT, or not... I can't get my only Ezlo controller (a Plus) to work in MSR. I have the latest version of MSR (21203-9503e5d), and I have added all needed lines to my reactor.yaml. This is the message I get:
                                  2021-07-29T13:13:57.524Z <Structure:ERR> [Structure:start] failed to start controller ezlo: Error: Cannot find module 'server/lib/Configuration'
                                  Require stack:
                                  - D:\msr\server\lib\EzloController.js
                                  2021-07-29T13:13:57.525Z <Structure:CRIT> Error: Cannot find module 'server/lib/Configuration'
                                  Require stack:
                                  Require stack:
                                      at Function.Module._resolveFilename (node:internal/modules/cjs/loader:924:15)
                                      at Function.Module._load (node:internal/modules/cjs/loader:769:27)
                                      at Module.require (node:internal/modules/cjs/loader:996:19)
                                      at require (node:internal/modules/cjs/helpers:92:18)
                                      at Object.<anonymous> (D:\msr\server\lib\EzloController.js:527:157)
                                      at Module._compile (node:internal/modules/cjs/loader:1092:14)
                                      at Object.Module._extensions..js (node:internal/modules/cjs/loader:1121:10)
                                      at Module.load (node:internal/modules/cjs/loader:972:32)
                                      at Function.Module._load (node:internal/modules/cjs/loader:813:14)
                                      at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:201:29)
                                  Require stack:
                                      at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:201:29) {
                                    code: 'MODULE_NOT_FOUND',
                                    requireStack: [ 'D:\\msr\\server\\lib\\EzloController.js' ]
                                  And this is my reactor.yaml:
                                    - id: ezlo
                                      enabled: true
                                        source: "wss://192.168.50.211:17000"  # change the IP address
                                        serial: "90000453"    # put your hub's serial # here
                                        username: "My_secret_name"  # put your username here betw quotes
                                        password: "My_top_secret_password"  # and password
                                  I have restarted MSR several times, with no luck. Any clues?
                                    How is MSR installed, and how are you running/starting it?
                                      MSR is installed on Windows 10, bare metall.
                                      I open up Windows Powershell and navigate to the MSR folder, and then type "node app.js".
                                      Everything else is working. I have a Vera and a Home Assistant up and running since months back... It's just the Ezlo that's not working.
                                        OK. You need to set the shell environment variable NODE_PATH to the install directory where Reactor lives (the directory that contains Reactor's app.js file).
                                          @toggledbits . Thanks. Did that. Sadly it still don't work. Got this instead:
                                          PS D:\msr> node app.js
                                          basedir D:\msr
                                          confdir D:\msr\config
                                          datadir D:\msr\storage
                                          logsdir D:\msr\logs
                                          plugindir D:\msr\ext
                                          module.paths [ 'D:\\msr\\node_modules', 'D:\\node_modules' ]
                                          NODE_PATH D:\MSR
                                          Logging stream path spec may be using pre-21075 form; please remove ./logs/ from the path!
                                          2021-07-30T13:10:38.707Z <app:null> Reactor latest-21203-9503e5d starting on v15.11.0
                                          2021-07-30T13:10:38.708Z <app:INFO> Process ID 16096; platform win32/x64 Windows 10 Pro
                                          2021-07-30T13:10:38.709Z <app:INFO> Basedir D:\msr; data in D:\msr\storage
                                          2021-07-30T13:10:38.709Z <app:INFO> NODE_PATH D:\MSR; module paths [ "D:\\msr\\node_modules", "D:\\node_modules" ]
                                          2021-07-30T13:10:38.751Z <Plugin:null> Module Plugin v21173
                                          2021-07-30T13:10:38.757Z <default:INFO> Module Entity v21177
                                          2021-07-30T13:10:38.760Z <Controller:null> Module Controller v21191
                                          2021-07-30T13:10:38.761Z <default:null> Module Structure v21196
                                          2021-07-30T13:10:38.766Z <default:null> Module Ruleset v21096
                                          2021-07-30T13:10:38.766Z <default:null> Module Rulesets v21096
                                          2021-07-30T13:10:38.781Z <default:null> Module Rule v21168
                                          2021-07-30T13:10:38.786Z <default:null> Module Engine v21197
                                          2021-07-30T13:10:38.787Z <default:null> Module httpapi v21200
                                          2021-07-30T13:10:38.790Z <default:null> Module httpproxy v21054
                                          2021-07-30T13:10:38.806Z <default:null> Module wsapi v21196
                                          2021-07-30T13:10:38.810Z <app:NOTICE> Starting Structure...
                                          2021-07-30T13:10:38.814Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController)
                                          2021-07-30T13:10:38.820Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController)
                                          2021-07-30T13:10:38.822Z <Structure:INFO> Structure#1 starting controller interface hass (HassController)
                                          2021-07-30T13:10:38.823Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController)
                                          2021-07-30T13:10:38.860Z <default:null> Module VeraController v21202
                                          2021-07-30T13:10:38.924Z <default:null> Module HassController v21191
                                          2021-07-30T13:10:38.926Z <default:null> Module SystemController v21102
                                          2021-07-30T13:10:38.929Z <VeraController:NOTICE> VeraController#vera starting
                                          2021-07-30T13:10:38.960Z <VeraController:INFO> VeraController#vera loaded mapping ver 21202 rev 1 format 1 notice
                                          2021-07-30T13:10:38.970Z <Controller:CRIT> Controller: failed to load ezlo implementation file:///D:/msr/server/lib/EzloController.js: TypeError: Cannot read property 'getConfig' of undefined
                                          2021-07-30T13:10:38.970Z <Controller:CRIT> TypeError: Cannot read property 'getConfig' of undefined
                                              at Function.getInstance (D:\MSR\server\lib\Configuration.js:128:89)
                                              at Object.<anonymous> (D:\MSR\server\lib\Logger.js:154:49)
                                              at Object.<anonymous> (D:\MSR\server\lib\Capabilities.js:71:99)
                                            287
                                            3.6k
                                            3.2k
                                            775
