  4. Pushover duplicate messages.
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
15 Posts 3 Posters 3.9k Views 3 Watching
  • Tom_DT Offline
    Tom_DT Offline
    Tom_D
    wrote on last edited by Tom_D
    This problem seems resolved now. My new Pushover section of the notification.yaml file is:
      # Pushover
      Pushover:
        profiles:
          phonewin:
            description: Phone and Windows
            # user - (required) user key from Pushover. Refer to the Reactor docs for
            #        the Notify action for info on how to get your user key.
            user: "MyUserKey"
            # token - (required) token from Pushover site. Again, see the Reactor docs
            #         for info. This is the default token used for this profile if a
            #         token is not specified in the notification parameters.
            token: "MyToken"
            # default_device - (optional) name of the default device to receive not-
            #                  ifications. You can leave this blank, and the default
            #                  device will be whatever the Pushover API determines. If
            #                  set here, it's the default for this profile, when no
            #                  device is specified in the Notify action itself.
            default_device: "TomGS10,TomWin"
            # default_title - (optional) default notification title to use for this
            #                 profile. It will be used when no title is specified in
            #                 the Notify action. If no title is specified at all, the
            #                 system default title "Reactor" will be used.
            default_title: ""
          phone:
            description: Phone Only
            user: "MyUserKey"
            token: "MyToken"
            default_device: "TomGS10"
            default_title: ""
          windows:
            description: Windows Only
            user: "MyUserKey"
            token: "MyToken"
            default_device: "TomWin"
            default_title: ""
    latest-25082-3c348de6
    • Tom_DT Tom_D
        # Pushover
        Pushover:
          profiles:
            phonewin:
              user: "MyUserKey"
              token: "MyToken"
              default_title: ""
            phone:
              user: "MyUserKey"
              token: "MyToken"
              default_title: ""
            windows:
              user: "MyUserKey"
              token: "MyToken"
              default_title: ""
      @toggledbits Today I created a rule with default profile to see if I could reproduce @tom_d 's issue. I was not able to so I deleted the rule.
      Later this evening I got duplicate messages from one of my unedited previously working notifications. My logs have already rotated so I can't find any info there. Have you noticed this issue yourself? I don't know if I have enough info for a PR so just poking this thread again.
        It's really an intermittent problem. All my notifications were duplicated until I today switched to run MSR as systemd. I did not edit any rules/reactions or the notification.yaml and now I only get one per rule as expected. Could be the restart itself that solved it...
          Is anybody looking at the logs? You'll be able to see the reactions there, and confirm, I'm sure, that the notification action is occurring only one per run of the reaction. The action will only make one call to the Pushover API; there is no retry or attempt at error recovery if the API request fails. For more detail, set the NotifyPushover log level to 5 or 6 (5 would be sufficient to see and count the actual API calls to Pushover). Are you sure your reaction not running multiple times due to the controlling logic?
          It's also the case that Pushover has, in the past, had issues on Android specifically with duplicate messages due to Google's/Andoid's notification services. It could be a bug in their API or their app.
          I myself have never seen duplicate messages (and I'm on Android).
            @toggledbits My logs rotate to quick, I have about 7 min to grab them and notifications are sent when I'm not at my computer, so I have not found any hints there yet. Tried the console.log but it was too big to handle.
            I will try to catch it if it happens again.
            I'm almost certain the reactions are not running multiple times due to rather simple logic, will investigate logs if I catch it at the right time though.
            I'm on iPhone and suspecting it's generated at Pushover too but none of my other, non MSR calls, to their API has ever produced duplicates and it started when I tried to reproduce it and then suddenly vanished after a restart.
            Could MSR been running multiple instances when manually started by app.sh?
            Otherwise, lets leave it until I or anyone else find something of value to troubleshoot as it's working perfect again now.
              If your logs are rotating that quickly, can you post your logging.yaml and let's see if something has been left too high from other threads. Unless you are looking for something, everything except Engine should be at level 4; Engineis best left at 5 for the moment while looking at this. The default log level should never ever be set to anything higher than 4.
              And as I said, add NotifyPushover at level 5 or 6, but that's going to be so low traffic it should not matter.
              FYI, I have my logs set to rotate at 8MB (the default is 2MB), on a very busy system running my house Vera, Hass, Hubitat, and eZLO, and my log rotates about once every 4 days.
                @crille said in Pushover duplicate messages.:
                pgrep -a node will answer this question.
                  @toggledbits Ok, since I switched to systemd and rebooted the server today, unfortunately I can't see if it was running multiple instances yesterday. I now only see one.
                  I lowered EzloController from 7 to 4 yesterday and it's a bit better now, this is my current config:
                  logging:
                    default:
                      level: 4
                      streams:
                        - type: console
                          level: 6
                        - type: file
                          maxsize: 2  # megabytes
                          keep: 5     # copies of old logs
                    app:
                      level: 4
                    httpapi:
                      level: 4
                    httpproxy:
                      level: 4
                    wsapi:
                      level: 4
                    Structure:
                      level: 4
                    Controller:
                      level: 4
                    OWMWeatherController:
                      level: 4
                    VeraController:
                      level: 4
                    HubitatController:
                      level: 4
                    HassController:
                      level: 4
                    Rule:
                      level: 5
                    Engine:
                      level: 5
                    EzloController:
                      level: 4
                  So I should lower everything else except Engine to 4 as well? The log is very chatty right now in my opinion.
                  I will add NotifyPushover if the issue comes back but I'm suspecting it was multiple instances causing it.
                    Yes, set Rule down to 4, leave Engine at 5, and add NotifyPushover at 5 or 6.
                      Ok, done. Much better, thank you!
                        165.5k
