  4. Running as a Windows Service
8 Posts 2 Posters 1.9k Views 2 Watching
    I've added a PowerShell script in the tools subdirectory of the latest Reactor build that, with a tailwind, will allow you Windows 10 users to install and run Reactor as a Windows service.
    The script is called install_reactor_windows_service.js
    Procedure is here (and also documented in the script header).
    • wmarcolinW Offline
      Hi @toggledbits, I just downloaded the latest version, and I can't find the script in the tolls directory.
        It's there. What version did you download, exactly.
          Last now reactor-1.0.0-21200-16a604f-generic.zip
            That's not the latest build. That's the last release build. Go to the latest subdirectory on the server for the actual latest.
              Oops my mistake, sorry!
              Now I have a question, I had already created a routine in the Task Scheduler to start the MSR running (node app.js ) on Windows startup. When I had to update it, it stopped running the task scheduler, do the update, and start the task again.
              And now, how do I stop the MSR? What is the task in Task Manager? I can't find anything with the name MSR or anything like it.
                You use the Services control panel to stop/start/restart the service (or restart using the Restart Reactor button in the Tools area of the Reactor UI).
                I use Win+X > Run and type "services" to bring up the Services control panel when I need it. Task manager also works.
                  Perfect, in the services panel the Reactor appears and I can then control it. Strangely in Task Manager does not appear the Reactor in running processes.
                  But ok, situation solved.
                    139.0k
