  4. Excluded vera devices in Hass
2 Posts 2 Posters 702 Views 2 Watching
  • V Offline
    V Offline
    I am in the process of moving all my devices from vera to Hass (using a pi-4 and a z-wave shield). In the interim, I am using the Hass Vera integration to see all my devices into Hass. MSR is connected to both the Vera and Hass (creating some duplication since a device can be seen from both systems. Nothing wrong here).
    As I move devices from Vera to Hass, I use the configuration of the Vera integration to excluded devices from showing into Haas. It is working as expected into Hass but the excluded devices are still showing into MSR (as haas->vera devices).
    Should the vera devices still be seen by MSR, through the Hass vera integration, when they are excluded from the Hass vera integration?
    It is not really causing problem just a bit of clutter when selecting entities.
    • toggledbitsT Online
      toggledbitsT Online
      This is planned but I haven't unified the idea across all controllers. But probably will happen in the not-too-distant future.
        146.7k
