  4. [Solved] Trigger based on door lock PIN code
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
4 Posts 2 Posters 657 Views 2 Watching
  • 3 Offline
    3 Offline
    I'm working to move some Vera scenes into MSR and am looking for a way to detect when any PIN code is entered on my front door lock. In my sample below I'm looking to turn on a light indoors when the lock changes from locked to unlock AND the sl_UserCode status changes from any to any. If I don't have the status change the light will turn on when I manually unlock the door to leave. I'm looking for a way to detect when the lock is operated from the outside only. The issue with the below is that when the same UserCode (PIN) is used, it doesn't ever get updated and won't trigger/become true. Is there another way I can accomplish this within MSR?
      See this post/thread: https://smarthome.community/post/7355
      • 3 Offline
        3 Offline
        THANK YOU! And Curses. This gives me ALL sorts of ideas now on how to better things and potentially kill off all of my Vera scenes.
        Initial testing looks good. Fully enabled the rule and waiting for Sunset to test it for real.
        • 3 Offline
          3 Offline
          Just an update for future readers. I set up a new rule to reset the sl_UserCode to none and then had the triggers defined as above. They were all matching/updating, but my Reactions would not fire. The problem ended up being the lock status changing from true to false. Even though MSR was showing it updating. Maybe it was too fast for Vera? I changed that trigger to sl_UserCode <> none and now everything is working as expected. Following @toggledbits setup from the other thread.
          • sl_UserCode changes from none to any
          • sl_UserCode <> none
          I also found the sl_LockButton variable. I included the changing of this value from 1 to 0 when I reset my UserID variable. When the physical lock button is pressed, the value of this gets updated to a 1. But that value never changes. Natively Vera was able to tell when the physical button was pressed, but RfV or MSR couldn't. Resetting this to 0 and then the physical button changing it to 1 allows MSR to see the update. YAY! That's another scene moved off of Vera.
            605
            3.6k
            3.2k
            793
