  4. Support for Ezlo Atom controllers?
(I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
51 Posts 3 Posters 20.6k Views 3 Watching
    #37
    OK its listed now in Entities
    Still not sure if this is gen 1 or 2 ? It was sent to me by Ezlo as part of their beta program.
    Also not seeing the one Z-Wave device that is currently paired to that Atom a TKB Home RGBW module.
      #38
      It says:
      sys_system.state=false
      Which I assume means its a gen 1 Atom ?
        #39
        Looking in the log I now see this, I have changed some sensitive items:
        2021-08-25T14:54:50.826Z <EzloController:null> EzloController#ezlo-atom account server replied { "PK_Device": "70060304", "NMAControllerStatus": 1, "NMAUuid": "a12bgd83-96b3-22d9-ad44-533df5564f44", "firmware_upgrade_progress": 100, "firmware_upgrade_status": "finished", "public_key_android": "", "public_key_ios": "", "Server_Relay": "wss://nma-server6-ui-cloud.ezlo.com:443", "MacAddress": "54:F5:4E:A4:5E:E5", "FK_Branding": "1", "HasWifi": "0", "HasAlarmPanel": "0", "UI": "4", "EngineStatus": "0", "LinuxFirmware": 1 }
        2021-08-25T14:54:50.828Z <EzloController:INFO> EzloController#ezlo-atom cloud auth succeeded
        2021-08-25T14:54:50.829Z <EzloController:6:EzloController.js:660> EzloController#ezlo-atom authinfo {  }
        2021-08-25T14:54:50.830Z <EzloController:INFO> EzloController#ezlo-atom opening hub connection to "70060304" at wss://nma-server6-ui-cloud.ezlo.com:443
        2021-08-25T14:54:50.832Z <EzloController:NOTICE> EzloController#ezlo-atom connecting via WS to wss://nma-server6-ui-cloud.ezlo.com:443
        2021-08-25T14:54:50.834Z <EzloController:5:Controller.js:537> EzloController#ezlo-atom websocket options { "maxPayload": 268435456, "followRedirects": true, "pingInterval": 60000, "agent": [object Object], "handshakeTimeout": 30000 }
        2021-08-25T14:54:51.518Z <EzloController:6:Controller.js:554> EzloController#ezlo-atom websocket connected to wss://nma-server6-ui-cloud.ezlo.com:443; starting ping check timer Timer#ezlo-atom-ping
        2021-08-25T14:54:51.519Z <EzloController:INFO> EzloController#ezlo-atom hub websocket connected (wss://nma-server6-ui-cloud.ezlo.com:443)
        2021-08-25T14:54:51.520Z <EzloController:INFO> EzloController#ezlo-atom sending remote hub login
        2021-08-25T14:54:51.522Z <EzloController:7:EzloController.js:1848> EzloController#ezlo-atom sending tracked request "17c8dcd8491" payload { "api": "1.0", "id": "17b7dce8481", "method": "loginUserMios", "params": { "MMSAuth": --undef--, "MMSAuthSig": --undef-- } }
        2021-08-25T14:54:51.523Z <EzloController:5:EzloController.js:1856> EzloController#ezlo-atom created tracked request "17c8dcd8491" with payload { "api": "1.0", "id": "17b7dce8481", "method": "loginUserMios", "params": { "MMSAuth": --undef--, "MMSAuthSig": --undef-- } }
        2021-08-25T14:54:51.675Z <EzloController:5:EzloController.js:1419> EzloController#ezlo-atom received message 144 bytes
        2021-08-25T14:54:51.676Z <EzloController:5:EzloController.js:1419> EzloController#ezlo-atom message data {"id":"17b7dce8481","method":"loginUserMios","error":{"code":2,"data":"cloud.error.failed_to_get_mms_autha_token","description":""},"result":{}}
        2021-08-25T14:54:51.678Z <EzloController:7:EzloController.js:1423> EzloController#ezlo-atom tracked request result slot { "req_id": "17c8dcd8491", "req_method": "loginUserMios", "expires": 1629903306521, "resolve": --function--, "reject": --function--, "promise": [object Promise] }
        2021-08-25T14:54:51.679Z <EzloController:ERR> EzloController#ezlo-atom request "17c8dcd8491" (loginUserMios) failed: { "code": 2, "data": "cloud.error.failed_to_get_mms_autha_token", "description": "" }
        2021-08-25T14:54:51.680Z <EzloController:7:EzloController.js:1855> EzloController#ezlo-atom removing resolved tracked request "17c8dcd8491"
        2021-08-25T14:54:51.681Z <EzloController:ERR> EzloController#ezlo-atom hub login failed: { "code": 2, "data": "cloud.error.failed_to_get_mms_autha_token", "description": "" }
        2021-08-25T14:54:51.685Z <EzloController:5:Controller.js:560> EzloController#ezlo-atom got websocket close
        2021-08-25T14:54:51.686Z <EzloController:NOTICE> EzloController#ezlo-atom websocket closing, 1006
        And as I said no devices from the Atom are being pulled in to MSR. Maybe at this stage I need your bug fix then..
          #40
          OK. Since it's a minor change, I just patched the build. Re-download the build package and reinstall it for the update. Then, you should be able to start with source commented out and get remote access.
          Once you have it connected, look at the system entity (the one with ID "system" matching the controller ID, like atom>system), and there is a hardware attribute that tells you the generation of Atom.
            #41
            Its connected now and has imported the devices and scenes from the Atom in to entities area.
            I see this though in alerts:
            x_ezlo_sys.hardware="rev2"
            So what's rev2 ?
            sys_system.state=true
            x_ezlo_sys.anonymous_access_enabled=null
            x_ezlo_sys.architecture="esp32"
            x_ezlo_sys.firmware="0.8.539"
            x_ezlo_sys.kernel="v4.1-rc-4-gbd72a9ab2"
            x_ezlo_sys.model="ATOM32"
            x_ezlo_sys.reconnects=1
            x_ezlo_sys.restarts=1
            x_ezlo_sys.serial="70060304"
            x_ezlo_sys.support_enabled=null
            x_ezlo_sys.support_status=null
            x_ezlo_sys.temperature_scale="fahrenheit"
            x_ezlo_sys.temperature_unit="F"
            x_ezlo_sys.upsince=1624528447000
            x_ezlo_sys.using_cloud_auth=true
            x_ezlo_sys.using_cloud_relay=true
            x_ezlo_sys.uuid=null
            Capabilities: sys_system, x_ezlo_sys
            Actions: sys_system.restart, x_ezlo_sys.runlua, x_ezlo_sys.set_setting
              That's gen2, so you may have local access. If you want to use local access, your Atom needs a stable IP address (static or DHCP reserved). You can put that into the source field (uncomment now), and also set disable_ecc_ciphers to true. Then restart Reactor.
                  source: "wss://your-atom-ip:17000"
                  serial: "7006nnnn"
                  username: "whatever"
                  password: "whatever"
                  disable_ecc_ciphers: true
              This may or may not work for you. My rev2 Atom is on firmware 0.8.798, and it allows remote access. I don't have an Atom with 0.8.539 that is at rev2, so I don't know if rev2 will work at that firmware level. I do have a rev3 Atom at 0.8.539, and it does allow remote access, so I think it should, but we'll see...
                    serial: "7006nnnn"
                @toggledbits said in Support for Ezlo Atom controllers?:
                Done that.
                I cleared the alert and restarted MSR. It hasn't come back again as yet.
                And I can still see the Ezlo Atom items in entities.
                  Done that.
                  @cw-kid said in Support for Ezlo Atom controllers?:
                  I'm not sure what you mean by this. What "it" are you referring to?
                    The yellow warning alert hasn't come back again since adding disable_ecc_ciphers: true to the reactor.yaml flie.
                    And I uncommented the source line. The Atom already has a DHCP reserved LAN IP.
                      #46
                      I didn't comment the username and password lines however.
                      I should do that if it is really only local access to the hub APi via the source line?
                        Don't uncomment the username and password. That only works for Plus/Secure hubs with anonymous access enabled. Atoms do not support anonymous access, so it is still necessary to get the access tokens from the cloud, even when connecting to the Atom locally.
                          OK. Do you know how long the tokens last and will MSR automatically request a new one when it does expire?
                            Supposedly 24 hours from what I can see. An expiration is given when the token is acquired. I haven't observed that there is any consequence to the expiration being met, though... it appears that access continues even after the token's expiration time/date. My presumption would be that access terminates when the token expires. Looks like more unfinished work there at eZLO to me.
                            Any disconnect will cause a reconnect retry.
                              I'm inclined to agree with you.
                              I have a token obtained by using Renes python script for my Ezlo Plus for use with curl commands and I bet that same token still works today I will have to try it again.
                              Token was probably obtained 12 months ago maybe.
                                Yup, that's definitely a security issue, and not the only one I'm concerned about, which is another reason I'm unlikely to be using an eZLO hub in my home for anything more than development of this tool.
                                  164.7k
