  4. House mode change not registered
3 Posts 3 Posters 561 Views 3 Watching
    @toggledbits MSR both stable and latest does not pick up a house mode change in openLuup. If I create an expression it states "home" even if openLuup is in night and my test rule to notify when house mode changes never picks up the change. Nothing is logged when I change house mode either.
    • toggledbitsT Online
      toggledbitsT Online
      On Vera Luup, when the house mode changes, a status request will return with UserData_DataVersion updated. This is a signal to the API client that the user data has been changed and needs to be reloaded. It looks like openLuup does not do this, so MSR cannot see the mode change.
      Edit: looks like I can work around it. I will schedule that for a future build.
      • B Offline
        B Offline
        Buxton
        Hi @akbooer I have seen similar with using modes in openluup. I have my openluup modes set as default to change vera modes. Should this be fixed or is the behavior an intentional part of the sync process between openluup and vera.
          137.9k
