  4. Updated to latest MSR 21243 and no entities are being executed I Hubitat
(I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
47 Posts 6 Posters 18.8k Views 6 Watching
    @matteburk Try installing 21200 just to see if you get MSR running again.
    Matteburk
    @crille tried .....
      The messages in the log you posted indicate that NODE_PATH is incorrectly set, so I now cannot be sure if we're back at your original problem because you have tried to run it from the command line and this log is from that, or if this log is from an attempted systemd startup, which makes no sense because the service file you published earlier sets the environment variable correctly.
      I've given you everything you need to get going again. I'm not sure what else to do. You need to figure it out, though, because this is how this and all future builds will be working, and right now, you're the only person I know of that isn't running, so I'm assuming its a local configuration issue and not a package/software issue.
      Can you stop any local startup, start again with systemd, and post the startup portion of the log file? I don't want to see the error message again, I need to see all the messages from a Reactor startup under systemd. That will start with the string Reactor <version> starting on <nodejs version> and give me everything up to Startup complete.
      Matteburk
      #21
      I dont see the string reactor version starting on XXXX as you wrote.
      From the var/log syslog I get this after stopped and started reactor via systemctl restart reactor
      Sep 6 20:58:49 raspberrypi systemd[1]: Started Multi System Reactor.
      Sep 6 20:58:50 raspberrypi systemd[1]: reactor.service: Succeeded.
      Sep 6 21:00:41 raspberrypi dbus-daemon[402]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.57' (uid=1000 pid=1071 comm="/usr/lib/chromium-browser/chromium-browser-v7 --fo")
      Sep 6 21:00:41 raspberrypi systemd[1]: Starting Hostname Service...
      Sep 6 21:00:41 raspberrypi dbus-daemon[402]: [system] Successfully activated service 'org.freedesktop.hostname1'
      Sep 6 21:00:41 raspberrypi systemd[1]: Started Hostname Service.
        In reactor.log
        M 1 Reply Last reply
          In reactor.log
          Matteburk
          hmmm nothing is being logged there after stop ,start. the log file has not been updated since I tried node app.js for a couple of hours ago
            OK. Post that startup, then. It will tell me a few things as well.
              #25
              Wait, I'm really confused, you said "nothing is being logged there after stop ,start". Then where did the stuff you posted here come from?
              M 2 Replies Last reply
                Matteburk
                @toggledbits they that you refer to are there but nothing after I now stopped and started
                  Matteburk
                  @toggledbits But if I no try to start via node app.js
                  I get in terminal window
                  pi@raspberrypi:~ $ node app.js
                  internal/modules/cjs/loader.js:883
                  throw err;
                  Error: Cannot find module '/home/pi/app.js'
                  at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
                  at Function.Module._load (internal/modules/cjs/loader.js:725:27)
                  at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
                  at internal/main/run_main_module.js:17:47 {
                  code: 'MODULE_NOT_FOUND',
                  requireStack: []
                  pi@raspberrypi:~ $
                    Well that's because you're not in the Reactor directory.
                      Matteburk
                      Gaaah..... im tired and beginner.....Sorry....
                      ok so this I no get when I run node app.js
                      2021-09-06T19:59:36.893Z Rule:5:980:Rule.js Rule#rule-kmst5xze._evaluate() mutex acquired, evaluating
                      2021-09-06T19:59:36.894Z Rule:5:984:Rule.js Rule#rule-kmst5xze update rate is 1/min limit 60/min
                      2021-09-06T19:59:36.895Z Rule:5:904:Rule.js Rule#rule-kmst5xze evaluateExpressions() with 0 expressions
                      2021-09-06T19:59:36.897Z Rule:CRIT Error: Cannot find module 'common/util'
                      Require stack:
                      • /home/pi/reactor/server/lib/Engine.js
                      • /home/pi/reactor/server/lib/httpapi.js
                      • /home/pi/reactor/app.js
                        Require stack:
                        at Module.require (internal/modules/cjs/loader.js:952:19)
                        at require (internal/modules/cjs/helpers.js:88:18)
                        at Engine._get_lexp_extensions (/home/pi/reactor/server/lib/Engine.js:862:25)
                        at Rule.evaluateExpressions (/home/pi/reactor/server/lib/Rule.js:904:330)
                        at Rule._evaluate (/home/pi/reactor/server/lib/Rule.js:994:344)
                        at processTicksAndRejections (internal/process/task_queues.js:93:5)
                        at async /home/pi/reactor/server/lib/Rule.js:963:17
                        #30
                        Right. And we've covered that. If you run it from the command line, you need to use
                            NODE_PATH=$(pwd) node app
                        Do that, and please post (a) the startup messages from logs/reactor.log as specified in my previous post, and (b) the contents of /etc/systemd/system/reactor.service again.
                          Matteburk
                          We have a winner!
                          I did
                          cd reactor
                          NODE_PATH=$(pwd) node app ( this line I totally missed)
                          and my house lit up like a Christmas trea!😂
                          Thank you for your patience with me Patrick!
                            No, we're not done. That's not the way to run Reactor. You need to be running it under systemd. Please provide the information above as requested.
                              Matteburk
                              #33
                              hehe.... went exited
                              /etc/systemd/system/reactor.service......
                              [Unit]
                              After=network.target
                              [Service]
                              Type=simple
                              User=pi
                              WorkingDirectory=/home/pi/reactor
                              Environment=NODE_PATH=/home/pi/reactor
                              ExecStart=/home/pi/.local/lib/nodejs/node-v14.15.4-linux-armv7l/bin/node
                              Restart=on-failure
                              RestartSec=5s
                              [Install]
                              WantedBy=multi-user.target
                              Reactor log......
                              2021-09-06T20:07:08.063Z <app:null> Reactor "1.0.1-21243-ab6d917" starting on v14.15.4
                              2021-09-06T20:07:08.066Z <app:INFO> Process ID 3029; platform linux/arm #1408 SMP Mon Mar 22 12:49:24 GMT 2021; locale [ "sv-SE", "UTF-8" ]
                              2021-09-06T20:07:08.067Z <app:INFO> Basedir /home/pi/reactor; data in /home/pi/reactor/storage
                              2021-09-06T20:07:08.067Z <app:INFO> NODE_PATH /home/pi/reactor; module paths [ "/home/pi/reactor/node_modules", "/home/pi/node_modules", "/home/node_modules", "/node_modules" ]
                              2021-09-06T20:07:08.241Z <Plugin:null> Module Plugin v21173
                              2021-09-06T20:07:08.273Z <default:INFO> Module Entity v21177
                              2021-09-06T20:07:08.284Z <Controller:null> Module Controller v21226
                              2021-09-06T20:07:08.286Z <default:null> Module Structure v21229
                              2021-09-06T20:07:08.305Z <default:null> Module Ruleset v21096
                              2021-09-06T20:07:08.306Z <default:null> Module Rulesets v21096
                              2021-09-06T20:07:08.380Z <default:null> Module Rule v21224
                              2021-09-06T20:07:08.397Z <default:null> Module Engine v21213
                              2021-09-06T20:07:08.399Z <default:null> Module httpapi v21238
                              2021-09-06T20:07:08.406Z <default:null> Module httpproxy v21054
                              2021-09-06T20:07:08.450Z <default:null> Module wsapi v21196
                              2021-09-06T20:07:08.454Z <app:NOTICE> Starting Structure...
                              2021-09-06T20:07:08.463Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController)
                              2021-09-06T20:07:08.473Z <Structure:INFO> Structure#1 starting controller interface hubitat (HubitatController)
                              2021-09-06T20:07:08.480Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController)
                              2021-09-06T20:07:08.622Z <default:null> Module VeraController v21236
                              2021-09-06T20:07:08.629Z <default:null> Module HubitatController v21243
                              2021-09-06T20:07:08.632Z <default:null> Module SystemController v21102
                              2021-09-06T20:07:08.642Z <VeraController:NOTICE> VeraController#vera starting
                              2021-09-06T20:07:08.765Z <VeraController:INFO> VeraController#vera loaded mapping ver 21236 rev 1 format 1 notice
                              2021-09-06T20:07:08.767Z <VeraController:INFO> VeraController: deviceclass vera_system_object capability sys_system does not provide attribute state
                              2021-09-06T20:07:08.887Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
                              2021-09-06T20:07:09.035Z <app:INFO> Structure running; pausing for controllers' initial ready
                              2021-09-06T20:07:09.044Z <Controller:NOTICE> HubitatController#hubitat not ready; performing initial connect/query
                              2021-09-06T20:07:09.629Z <VeraController:NOTICE> Controller VeraController#vera is now online.
                              2021-09-06T20:07:10.118Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                              2021-09-06T20:07:10.158Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                              2021-09-06T20:07:10.274Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                              2021-09-06T20:07:10.281Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                              2021-09-06T20:07:10.287Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                              2021-09-06T20:07:10.289Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                              2021-09-06T20:07:10.318Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                              2021-09-06T20:07:10.326Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                              2021-09-06T20:07:10.331Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                              2021-09-06T20:07:10.478Z <Controller:INFO> HubitatController#hubitat connecting to hub's eventsocket WebSocket API at ws://192.168.68.145/eventsocket
                              2021-09-06T20:07:10.484Z <Controller:NOTICE> Controller HubitatController#hubitat is now online.
                              2021-09-06T20:07:10.489Z <app:NOTICE> Starting Reaction Engine...
                              2021-09-06T20:07:10.491Z <Engine:INFO> Reaction Engine starting
                              2021-09-06T20:07:10.492Z <Engine:INFO> Checking rule sets...
                              2021-09-06T20:07:10.504Z <Engine:INFO> Checking rules...
                              2021-09-06T20:07:10.506Z <Engine:INFO> Data check complete; no corrections.
                                OK. Looks good.
                                First, make sure your command line Reactor is stopped. This is important, obviously, as the systemd Reactor will not start and keep trying to start if your command line Reactor is still running. Also, let's remove the existing Reactor log file:
                                    rm /home/pi/reactor/logs/reactor.log
                                Then, sudo systemctl daemon-reload
                                Then, sudo systemctl restart reactor
                                Then try to get into the Reactor UI. If you can't get into the UI, look at the reactor.log file for messages. In you still have the "common/util" exception, go up to the startup lines and look at what it reports for NODE_PATH and post that here.
                                  OK. Looks good.
                                  Matteburk
                                  @toggledbits Could not reach thrue UI .
                                  The reactor.log file is no missing since the rm command.....
                                    #36
                                    OK. Then /var/log/syslog
                                    And tell me, how did you edit the service file? There are some excess blank lines in what you posted when I got it formatted as code on the forums... that's... odd... did you edit it on the system, or did you pull it up to a Mac or Windows, edit it, and then push it down? Or something else?
                                      Matteburk
                                      I edited them directly on the pie in the textfile.
                                      this is what the var log file said:
                                      Sep 6 22:17:23 raspberrypi dhcpcd[428]: wlan0: fe80::465:fde6:f33:2344 is reachable again
                                      Sep 6 22:17:23 raspberrypi avahi-daemon[429]: Withdrawing address record for fe80::2598:15e9:620:fe7d on eth0.
                                      Sep 6 22:17:26 raspberrypi dhcpcd[428]: eth0: leased 192.168.68.126 for 7200 seconds
                                      Sep 6 22:17:26 raspberrypi avahi-daemon[429]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.68.126.
                                      Sep 6 22:17:26 raspberrypi dhcpcd[428]: eth0: adding route to 192.168.68.0/24
                                      Sep 6 22:17:26 raspberrypi dhcpcd[428]: eth0: adding default route via 192.168.68.1
                                      Sep 6 22:17:26 raspberrypi avahi-daemon[429]: New relevant interface eth0.IPv4 for mDNS.
                                      Sep 6 22:17:26 raspberrypi avahi-daemon[429]: Registering new address record for 192.168.68.126 on eth0.IPv4.
                                      Sep 6 22:17:34 raspberrypi systemd[1]: systemd-fsckd.service: Succeeded.
                                      Sep 6 22:50:34 raspberrypi systemd-timesyncd[339]: Synchronized to time server for the first time 178.16.128.13:123 (2.debian.pool.ntp.org).
                                      Sep 6 22:50:41 raspberrypi systemd[1]: systemd-hostnamed.service: Succeeded.
                                      Sep 6 22:53:32 raspberrypi dbus-daemon[626]: [session uid=1000 pid=626] Activating service name='ca.desrt.dconf' requested by ':1.28' (uid=1000 pid=1084 comm="mousepad /var/log/syslog ")
                                      Sep 6 22:53:32 raspberrypi dbus-daemon[626]: [session uid=1000 pid=626] Successfully activated service 'ca.desrt.dconf'
                                      Sep 6 22:54:50 raspberrypi dbus-daemon[418]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.51' (uid=1000 pid=1100 comm="/usr/lib/chromium-browser/chromium-browser-v7 --fo")
                                      Sep 6 22:54:50 raspberrypi systemd[1]: Starting Hostname Service...
                                      Sep 6 22:54:50 raspberrypi dbus-daemon[418]: [system] Successfully activated service 'org.freedesktop.hostname1'
                                      Sep 6 22:54:50 raspberrypi systemd[1]: Started Hostname Service.
                                      Sep 6 22:54:50 raspberrypi gvfsd[665]: mkdir failed on directory /var/cache/samba: Åtkomst nekas
                                      Sep 6 22:54:51 raspberrypi gvfsd[665]: mkdir failed on directory /var/cache/samba: Åtkomst nekas
                                      Sep 6 22:54:52 raspberrypi gvfsd[665]: mkdir failed on directory /var/cache/samba: Åtkomst nekas
                                      Sep 6 22:54:53 raspberrypi gvfsd[665]: mkdir failed on directory /var/cache/samba: Åtkomst nekas
                                      Sep 6 22:54:54 raspberrypi gvfsd[665]: mkdir failed on directory /var/cache/samba: Åtkomst nekas
                                      Sep 6 22:54:55 raspberrypi gvfsd[665]: mkdir failed on directory /var/cache/samba: Åtkomst nekas
                                        #38
                                        I just noticed, the ExecStart line in your edited service file is incomplete. It should read:
                                            ExecStart=/home/pi/.local/lib/nodejs/node-v14.15.4-linux-armv7l/bin/node app -p
                                        Fix that. Then do:
                                          Fix that. Then do:
                                          Matteburk
                                          @toggledbits said in Updated to latest MSR 21243 and no entities are being executed I Hubitat:
                                          Changed it and now i can reach msr thrue UI!
                                          Here is the reactor.log
                                          2021-09-06T21:05:42.633Z app:null Reactor "1.0.1-21243-ab6d917" starting on v14.15.4
                                          2021-09-06T21:05:42.636Z app:INFO Process ID 1780; platform linux/arm #1408 SMP Mon Mar 22 12:49:24 GMT 2021; locale [ "sv-SE", "UTF-8" ]
                                          2021-09-06T21:05:42.637Z app:INFO Basedir /home/pi/reactor; data in /home/pi/reactor/storage
                                          2021-09-06T21:05:42.637Z app:INFO NODE_PATH /home/pi/reactor; module paths [ "/home/pi/reactor/node_modules", "/home/pi/node_modules", "/home/node_modules", "/node_modules" ]
                                          2021-09-06T21:05:42.781Z Plugin:null Module Plugin v21173
                                          2021-09-06T21:05:42.797Z default:INFO Module Entity v21177
                                          2021-09-06T21:05:42.805Z Controller:null Module Controller v21226
                                          2021-09-06T21:05:42.806Z default:null Module Structure v21229
                                          2021-09-06T21:05:42.822Z default:null Module Ruleset v21096
                                          2021-09-06T21:05:42.823Z default:null Module Rulesets v21096
                                          2021-09-06T21:05:42.869Z default:null Module Rule v21224
                                          2021-09-06T21:05:42.880Z default:null Module Engine v21213
                                          2021-09-06T21:05:42.881Z default:null Module httpapi v21238
                                          2021-09-06T21:05:42.886Z default:null Module httpproxy v21054
                                          2021-09-06T21:05:42.925Z default:null Module wsapi v21196
                                          2021-09-06T21:05:42.928Z app:NOTICE Starting Structure...
                                          2021-09-06T21:05:42.936Z Structure:INFO Structure#1 starting controller interface vera (VeraController)
                                          2021-09-06T21:05:42.944Z Structure:INFO Structure#1 starting controller interface hubitat (HubitatController)
                                          2021-09-06T21:05:42.947Z Structure:INFO Structure#1 starting controller interface reactor_system (SystemController)
                                          2021-09-06T21:05:43.018Z default:null Module VeraController v21236
                                          2021-09-06T21:05:43.026Z default:null Module HubitatController v21243
                                          2021-09-06T21:05:43.029Z default:null Module SystemController v21102
                                          2021-09-06T21:05:43.037Z VeraController:NOTICE VeraController#vera starting
                                          2021-09-06T21:05:43.145Z VeraController:INFO VeraController#vera loaded mapping ver 21236 rev 1 format 1 notice
                                          2021-09-06T21:05:43.148Z VeraController:INFO VeraController: deviceclass vera_system_object capability sys_system does not provide attribute state
                                          2021-09-06T21:05:43.227Z Controller:NOTICE Controller SystemController#reactor_system is now online.
                                          2021-09-06T21:05:43.339Z app:INFO Structure running; pausing for controllers' initial ready
                                          2021-09-06T21:05:43.347Z Controller:NOTICE HubitatController#hubitat not ready; performing initial connect/query
                                          2021-09-06T21:05:43.896Z VeraController:NOTICE Controller VeraController#vera is now online.
                                          2021-09-06T21:05:45.291Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T21:05:45.322Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T21:05:45.383Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T21:05:45.387Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T21:05:45.391Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T21:05:45.394Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T21:05:45.409Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T21:05:45.414Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T21:05:45.418Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T21:05:45.510Z Controller:INFO HubitatController#hubitat connecting to hub's eventsocket WebSocket API at ws://192.168.68.145/eventsocket
                                          2021-09-06T21:05:45.517Z Controller:NOTICE Controller HubitatController#hubitat is now online.
                                          2021-09-06T21:05:45.522Z app:NOTICE Starting Reaction Engine...
                                          2021-09-06T21:05:45.524Z Engine:INFO Reaction Engine starting
                                          2021-09-06T21:05:45.525Z Engine:INFO Checking rule sets...
                                          2021-09-06T21:05:45.542Z Engine:INFO Checking rules...
                                          2021-09-06T21:05:45.544Z Engine:INFO Data check complete; no corrections.
                                            164.5k
