  4. Updated to latest MSR 21243 and no entities are being executed I Hubitat
(I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
47 Posts 6 Posters 18.8k Views 6 Watching
    Matteburk
    I checked and changed the lines to this ( I guess something is wrong there)
    [Unit]
    After=network.target
    [Service]
    Type=simple
    User=pi
    WorkingDirectory=/home/pi/reactor
    Environment=NODE_PATH=/home/pi/reactor
    ExecStart=/home/pi/.local/lib/nodejs/node-v14.15.4-linux-armv7l/bin/node
    Restart=on-failure
    RestartSec=5s
    [Install]
    WantedBy=multi-user.target
    and restarted reactor....... then I see this in log.....
    Sep 5 15:26:16 raspberrypi systemd[9870]: reactor.service: Failed to determine user credentials: No such process
    Sep 5 15:26:16 raspberrypi systemd[9870]: reactor.service: Failed at step USER spawning /usr/local/lib/nodejs/bin/node: No such process
    Sep 5 15:26:16 raspberrypi systemd[1]: reactor.service: Main process exited, code=exited, status=217/USER
    Sep 5 15:26:16 raspberrypi systemd[1]: reactor.service: Failed with result 'exit-code'.
    Sep 5 15:26:21 raspberrypi systemd[1]: reactor.service: Service RestartSec=5s expired, scheduling restart.
    Sep 5 15:26:21 raspberrypi systemd[1]: reactor.service: Scheduled restart job, restart counter is at 20060.
    Sep 5 15:26:21 raspberrypi systemd[1]: Stopped Multi System Reactor.
    Sep 5 15:26:21 raspberrypi systemd[1]: Started Multi System Reactor.
    Sep 5 15:26:21 raspberrypi systemd[9871]: reactor.service: Failed to determine user credentials: No such process
    Sep 5 15:26:21 raspberrypi systemd[9871]: reactor.service: Failed at step USER spawning /usr/local/lib/nodejs/bin/node: No such process
    Sep 5 15:26:21 raspberrypi systemd[1]: reactor.service: Main process exited, code=exited, status=217/USER
    Sep 5 15:26:21 raspberrypi systemd[1]: reactor.service: Failed with result 'exit-code'.
    Sep 5 15:26:22 raspberrypi systemd[1]: Reloading.
    Sep 5 15:26:22 raspberrypi systemd[1]: /etc/systemd/system/teamviewerd.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/teamviewerd.pid \u2192 /run/teamviewerd.pid; please update the unit file accordingly.
    Sep 5 15:26:26 raspberrypi systemd[1]: reactor.service: Service RestartSec=5s expired, scheduling restart.
    Sep 5 15:26:26 raspberrypi systemd[1]: reactor.service: Scheduled restart job, restart counter is at 20061.
    Sep 5 15:26:26 raspberrypi systemd[1]: Stopped Multi System Reactor.
    Sep 5 15:26:26 raspberrypi systemd[1]: Started Multi System Reactor.
    Sep 5 15:26:27 raspberrypi systemd[1]: reactor.service: Succeeded.
    Sep 5 15:26:42 raspberrypi systemd[1]: Started Multi System Reactor.
    Sep 5 15:26:43 raspberrypi systemd[1]: reactor.service: Succeeded.
    Sep 5 15:34:06 raspberrypi systemd[1]: Started Multi System Reactor.
    Sep 5 15:34:06 raspberrypi systemd[1]: reactor.service: Succeeded.
      It looks like it's referring to a different pathname for nodejs than you have configured in the service file. Did you make a change to that value somewhere along the way? If you make any changes to the config file, you need to do sudo systemctl daemon-reload to get systemd to read the updated config file. So the first step is to try sudo systemctl daemon-reload followed by sudo systemctl restart reactor.
      If that doesn't work, it is reported elsewhere that sudo systemctl daemon-reexec may resolve this (or perhaps simply rebooting the whole system).
      Then step three, if you're still not successful, is to see if Reactor is logging anything in its own log files.
      M 1 Reply Last reply
        Matteburk
        I have followed your instructions but no success.
        Dont no what to do..... Here is the log from msr
        /Mattias
        Require stack:
        • /home/pi/reactor/server/lib/Engine.js
        • /home/pi/reactor/server/lib/httpapi.js
        • /home/pi/reactor/app.js
          Error: Cannot find module 'common/util'
          Require stack:
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
          at Function.Module._load (internal/modules/cjs/loader.js:725:27)
          at Module.require (internal/modules/cjs/loader.js:952:19)
          at require (internal/modules/cjs/helpers.js:88:18)
          at Engine._get_lexp_extensions (/home/pi/reactor/server/lib/Engine.js:862:25)
          at Rule.evaluateExpressions (/home/pi/reactor/server/lib/Rule.js:904:330)
          at Rule._evaluate (/home/pi/reactor/server/lib/Rule.js:994:344)
          at runMicrotasks (<anonymous>)
          at processTicksAndRejections (internal/process/task_queues.js:93:5)
          at async /home/pi/reactor/server/lib/Rule.js:963:17
          2021-09-06T16:19:30.352Z Rule:5:980:Rule.js Rule#rule-ksn5u2pn._evaluate() mutex acquired, evaluating
          2021-09-06T16:19:30.352Z Rule:5:984:Rule.js Rule#rule-ksn5u2pn update rate is 0/min limit 60/min
          2021-09-06T16:19:30.353Z Rule:5:904:Rule.js Rule#rule-ksn5u2pn evaluateExpressions() with 0 expressions
          2021-09-06T16:19:30.354Z Rule:CRIT Error: Cannot find module 'common/util'
          Require stack:
          Require stack:
          2021-09-06T16:19:30.356Z Rule:5:980:Rule.js Rule#rule-ksm11ihr._evaluate() mutex acquired, evaluating
          2021-09-06T16:19:30.356Z Rule:5:984:Rule.js Rule#rule-ksm11ihr update rate is 0/min limit 60/min
          2021-09-06T16:19:30.357Z Rule:5:904:Rule.js Rule#rule-ksm11ihr evaluateExpressions() with 0 expressions
          2021-09-06T16:19:30.358Z Rule:CRIT Error: Cannot find module 'common/util'
          Require stack:
          Require stack:
        • M Matteburk
          /Mattias
          Require stack:
            Require stack:
            Require stack:
            Require stack:
            Require stack:
            Require stack:
          CrilleC Online
          CrilleC Online
          @matteburk Try installing 21200 just to see if you get MSR running again.
            The messages in the log you posted indicate that NODE_PATH is incorrectly set, so I now cannot be sure if we're back at your original problem because you have tried to run it from the command line and this log is from that, or if this log is from an attempted systemd startup, which makes no sense because the service file you published earlier sets the environment variable correctly.
            I've given you everything you need to get going again. I'm not sure what else to do. You need to figure it out, though, because this is how this and all future builds will be working, and right now, you're the only person I know of that isn't running, so I'm assuming its a local configuration issue and not a package/software issue.
            Can you stop any local startup, start again with systemd, and post the startup portion of the log file? I don't want to see the error message again, I need to see all the messages from a Reactor startup under systemd. That will start with the string Reactor <version> starting on <nodejs version> and give me everything up to Startup complete.
            M 2 Replies Last reply
              Matteburk
              @toggledbits ok... yes for sure it is me setting something up wrong... will struggle some more... 🙂
                Matteburk
                @crille tried .....
                  Matteburk
                  #21
                  I dont see the string reactor version starting on XXXX as you wrote.
                  From the var/log syslog I get this after stopped and started reactor via systemctl restart reactor
                  Sep 6 20:58:49 raspberrypi systemd[1]: Started Multi System Reactor.
                  Sep 6 20:58:50 raspberrypi systemd[1]: reactor.service: Succeeded.
                  Sep 6 21:00:41 raspberrypi dbus-daemon[402]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.57' (uid=1000 pid=1071 comm="/usr/lib/chromium-browser/chromium-browser-v7 --fo")
                  Sep 6 21:00:41 raspberrypi systemd[1]: Starting Hostname Service...
                  Sep 6 21:00:41 raspberrypi dbus-daemon[402]: [system] Successfully activated service 'org.freedesktop.hostname1'
                  Sep 6 21:00:41 raspberrypi systemd[1]: Started Hostname Service.
                    In reactor.log
                      In reactor.log
                      Matteburk
                      hmmm nothing is being logged there after stop ,start. the log file has not been updated since I tried node app.js for a couple of hours ago
                        OK. Post that startup, then. It will tell me a few things as well.
                          #25
                          Wait, I'm really confused, you said "nothing is being logged there after stop ,start". Then where did the stuff you posted here come from?
                            Matteburk
                            @toggledbits they that you refer to are there but nothing after I now stopped and started
                              Matteburk
                              @toggledbits But if I no try to start via node app.js
                              I get in terminal window
                              pi@raspberrypi:~ $ node app.js
                              internal/modules/cjs/loader.js:883
                              throw err;
                              Error: Cannot find module '/home/pi/app.js'
                              at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
                              at internal/main/run_main_module.js:17:47 {
                              code: 'MODULE_NOT_FOUND',
                              requireStack: []
                              pi@raspberrypi:~ $
                                Well that's because you're not in the Reactor directory.
                                  Matteburk
                                  Gaaah..... im tired and beginner.....Sorry....
                                  ok so this I no get when I run node app.js
                                  2021-09-06T19:59:36.893Z Rule:5:980:Rule.js Rule#rule-kmst5xze._evaluate() mutex acquired, evaluating
                                  2021-09-06T19:59:36.894Z Rule:5:984:Rule.js Rule#rule-kmst5xze update rate is 1/min limit 60/min
                                  2021-09-06T19:59:36.895Z Rule:5:904:Rule.js Rule#rule-kmst5xze evaluateExpressions() with 0 expressions
                                  2021-09-06T19:59:36.897Z Rule:CRIT Error: Cannot find module 'common/util'
                                  Require stack:
                                    Require stack:
                                    #30
                                    Right. And we've covered that. If you run it from the command line, you need to use
                                        NODE_PATH=$(pwd) node app
                                    Do that, and please post (a) the startup messages from logs/reactor.log as specified in my previous post, and (b) the contents of /etc/systemd/system/reactor.service again.
                                      Matteburk
                                      We have a winner!
                                      I did
                                      cd reactor
                                      NODE_PATH=$(pwd) node app ( this line I totally missed)
                                      and my house lit up like a Christmas trea!😂
                                      Thank you for your patience with me Patrick!
                                        No, we're not done. That's not the way to run Reactor. You need to be running it under systemd. Please provide the information above as requested.
                                          Matteburk
                                          #33
                                          hehe.... went exited
                                          /etc/systemd/system/reactor.service......
                                          [Unit]
                                          [Service]
                                          Type=simple
                                          User=pi
                                          Restart=on-failure
                                          RestartSec=5s
                                          [Install]
                                          Reactor log......
                                          2021-09-06T20:07:08.063Z <app:null> Reactor "1.0.1-21243-ab6d917" starting on v14.15.4
                                          2021-09-06T20:07:08.066Z <app:INFO> Process ID 3029; platform linux/arm #1408 SMP Mon Mar 22 12:49:24 GMT 2021; locale [ "sv-SE", "UTF-8" ]
                                          2021-09-06T20:07:08.067Z <app:INFO> Basedir /home/pi/reactor; data in /home/pi/reactor/storage
                                          2021-09-06T20:07:08.067Z <app:INFO> NODE_PATH /home/pi/reactor; module paths [ "/home/pi/reactor/node_modules", "/home/pi/node_modules", "/home/node_modules", "/node_modules" ]
                                          2021-09-06T20:07:08.241Z <Plugin:null> Module Plugin v21173
                                          2021-09-06T20:07:08.273Z <default:INFO> Module Entity v21177
                                          2021-09-06T20:07:08.284Z <Controller:null> Module Controller v21226
                                          2021-09-06T20:07:08.286Z <default:null> Module Structure v21229
                                          2021-09-06T20:07:08.305Z <default:null> Module Ruleset v21096
                                          2021-09-06T20:07:08.306Z <default:null> Module Rulesets v21096
                                          2021-09-06T20:07:08.380Z <default:null> Module Rule v21224
                                          2021-09-06T20:07:08.397Z <default:null> Module Engine v21213
                                          2021-09-06T20:07:08.399Z <default:null> Module httpapi v21238
                                          2021-09-06T20:07:08.406Z <default:null> Module httpproxy v21054
                                          2021-09-06T20:07:08.450Z <default:null> Module wsapi v21196
                                          2021-09-06T20:07:08.454Z <app:NOTICE> Starting Structure...
                                          2021-09-06T20:07:08.463Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController)
                                          2021-09-06T20:07:08.473Z <Structure:INFO> Structure#1 starting controller interface hubitat (HubitatController)
                                          2021-09-06T20:07:08.480Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController)
                                          2021-09-06T20:07:08.622Z <default:null> Module VeraController v21236
                                          2021-09-06T20:07:08.629Z <default:null> Module HubitatController v21243
                                          2021-09-06T20:07:08.632Z <default:null> Module SystemController v21102
                                          2021-09-06T20:07:08.642Z <VeraController:NOTICE> VeraController#vera starting
                                          2021-09-06T20:07:08.765Z <VeraController:INFO> VeraController#vera loaded mapping ver 21236 rev 1 format 1 notice
                                          2021-09-06T20:07:08.767Z <VeraController:INFO> VeraController: deviceclass vera_system_object capability sys_system does not provide attribute state
                                          2021-09-06T20:07:08.887Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
                                          2021-09-06T20:07:09.035Z <app:INFO> Structure running; pausing for controllers' initial ready
                                          2021-09-06T20:07:09.044Z <Controller:NOTICE> HubitatController#hubitat not ready; performing initial connect/query
                                          2021-09-06T20:07:09.629Z <VeraController:NOTICE> Controller VeraController#vera is now online.
                                          2021-09-06T20:07:10.118Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T20:07:10.158Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T20:07:10.274Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T20:07:10.281Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T20:07:10.287Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T20:07:10.289Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T20:07:10.318Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T20:07:10.326Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T20:07:10.331Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
                                          2021-09-06T20:07:10.478Z <Controller:INFO> HubitatController#hubitat connecting to hub's eventsocket WebSocket API at ws://192.168.68.145/eventsocket
                                          2021-09-06T20:07:10.484Z <Controller:NOTICE> Controller HubitatController#hubitat is now online.
                                          2021-09-06T20:07:10.489Z <app:NOTICE> Starting Reaction Engine...
                                          2021-09-06T20:07:10.491Z <Engine:INFO> Reaction Engine starting
                                          2021-09-06T20:07:10.492Z <Engine:INFO> Checking rule sets...
                                          2021-09-06T20:07:10.504Z <Engine:INFO> Checking rules...
                                          2021-09-06T20:07:10.506Z <Engine:INFO> Data check complete; no corrections.
                                            164.5k
