  4. Updated to latest MSR 21243 and no entities are being executed I Hubitat
(I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
47 Posts 6 Posters 18.8k Views 6 Watching
  • J Offline
    J Offline
    Jaggz
    Had the same issue. Reaction as a group would not fire but entities within the Reaction would when manually selecting them (hit the little play button next to them). Everything else looked normal from a Status perspective (i.e. motion detected sending the rule into green status, etc). I fixed the problem by installing a fresh copy (leaving the reactor-data folder untouched).
      Make sure you are on the latest version, and NODE_PATH (environment variable) is defined correctly (how that is done depends on how you run Reactor).
      M 1 Reply Last reply
        Matteburk
        @toggledbits I run it with Node app.js
        • M Matteburk
          @matteburk OK. So the direct solution to your problem is to run it this way: NODE_PATH=$(pwd) node app.js
          You really should be running it from systemd on the RPi, though. The command line startup is only for initial validation and setup, it's not meant to be the way to run MSR long term.
          In the tools subdirectory, you'll find a file called reactor.service-example. To install MSR under systemd, do the following:
          1. Copy the above-named file into your /etc/systemd/system directory and rename it to drop the -example part. For example:
             sudo cp tools/reactor.service-example /etc/systemd/system/reactor.service
          2. Edit the new file and change the pathnames to match your install directory. Remember that the file is installed in a restricted directory, so you need to use sudo with your editor:
             sudo nano /etc/systemd/system/reactor.service
          3. Once you have the file edited with correct names/parameters, stop your existing Reactor process.
          4. Make systemd aware of the changed configuration file:
             sudo systemctl daemon-reload
          5. Start Reactor under systemd:
             sudo systemctl start reactor
          If you need to stop Reactor later, that's systemctl stop reactor. You can also restart a running Reactor with systemctl restart reactor.
          Running Reactor under systemd will automatically restart it if it crashes, and start it up automatically when your RPi boots up.
            Matteburk
            @toggledbits@
            Followed your instructions to run it under systemd but when i do nr 4 and 5 reactor won't start...
            Should I write sudo systemctl start reactor under pi@raspberrypi as in picture?
            /Mattias
              This is correct. Check /var/log/syslog for startup errors.
                Matteburk
                This is what the log says:
                Sep 5 00:00:00 raspberrypi rsyslogd: [origin software="rsyslogd" swVersion="8.1901.0" x-pid="383" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
                Sep 5 00:00:00 raspberrypi systemd[1]: logrotate.service: Succeeded.
                Sep 5 00:00:00 raspberrypi systemd[1]: Started Rotate log files.
                Sep 5 00:00:00 raspberrypi systemd[1]: man-db.service: Succeeded.
                Sep 5 00:00:00 raspberrypi systemd[1]: Started Daily man-db regeneration.
                Sep 5 00:00:02 raspberrypi colord[955]: failed to get session [pid 17774]: Inga data tillg\u00e4ngliga
                Sep 5 00:00:05 raspberrypi systemd[1]: reactor.service: Service RestartSec=5s expired, scheduling restart.
                Sep 5 00:00:05 raspberrypi systemd[1]: reactor.service: Scheduled restart job, restart counter is at 9474.
                Sep 5 00:00:05 raspberrypi systemd[1]: Stopped Multi System Reactor.
                Sep 5 00:00:05 raspberrypi systemd[1]: Started Multi System Reactor.
                Sep 5 00:00:05 raspberrypi systemd[17799]: reactor.service: Failed to determine user credentials: No such process
                Sep 5 00:00:05 raspberrypi systemd[17799]: reactor.service: Failed at step USER spawning /usr/local/lib/nodejs/bin/node: No such process
                Sep 5 00:00:05 raspberrypi systemd[1]: reactor.service: Main process exited, code=exited, status=217/USER
                Sep 5 00:00:05 raspberrypi systemd[1]: reactor.service: Failed with result 'exit-code'.
                Sep 5 00:00:10 raspberrypi systemd[1]: reactor.service: Service RestartSec=5s expired, scheduling restart.
                Sep 5 00:00:10 raspberrypi systemd[1]: reactor.service: Scheduled restart job, restart counter is at 9475.
                Sep 5 00:00:10 raspberrypi systemd[1]: Stopped Multi System Reactor.
                Sep 5 00:00:10 raspberrypi systemd[1]: Started Multi System Reactor.
                Sep 5 00:00:10 raspberrypi systemd[17800]: reactor.service: Failed to determine user credentials: No such process
                Sep 5 00:00:10 raspberrypi systemd[17800]: reactor.service: Failed at step USER spawning /usr/local/lib/nodejs/bin/node: No such process
                Sep 5 00:00:10 raspberrypi systemd[1]: reactor.service: Main process exited, code=exited, status=217/USER
                Sep 5 00:00:10 raspberrypi systemd[1]: reactor.service: Failed with result 'exit-code'.
                Sep 5 00:00:15 raspberrypi systemd[1]: reactor.service: Service RestartSec=5s expired, scheduling restart.
                Sep 5 00:00:15 raspberrypi systemd[1]: reactor.service: Scheduled restart job, restart counter is at 9476.
                Sep 5 00:00:15 raspberrypi systemd[1]: Stopped Multi System Reactor.
                Sep 5 00:00:15 raspberrypi systemd[1]: Started Multi System Reactor.
                Sep 5 00:00:15 raspberrypi systemd[17801]: reactor.service: Failed to determine user credentials: No such process
                Sep 5 00:00:15 raspberrypi systemd[17801]: reactor.service: Failed at step USER spawning /usr/local/lib/nodejs/bin/node: No such process
                Sep 5 00:00:15 raspberrypi systemd[1]: reactor.service: Main process exited, code=exited, status=217/USER
                Sep 5 00:00:15 raspberrypi systemd[1]: reactor.service: Failed with result 'exit-code'.
                Sep 5 00:00:21 raspberrypi systemd[1]: reactor.service: Service RestartSec=5s expired, scheduling restart.
                Sep 5 00:00:21 raspberrypi systemd[1]: reactor.service: Scheduled restart job, restart counter is at 9477.
                Sep 5 00:00:21 raspberrypi systemd[1]: Stopped Multi System Reactor.
                Sep 5 00:00:21 raspberrypi systemd[1]: Started Multi System Reactor.
                Sep 5 00:00:21 raspberrypi systemd[17802]: reactor.service: Failed to determine user credentials: No such process
                Sep 5 00:00:21 raspberrypi systemd[17802]: reactor.service: Failed at step USER spawning /usr/local/lib/nodejs/bin/node: No such process
                Sep 5 00:00:21 raspberrypi systemd[1]: reactor.service: Main process exited, code=exited, status=217/USER
                Sep 5 00:00:21 raspberrypi systemd[1]: reactor.service: Failed with result 'exit-code'.
                Sep 5 00:00:26 raspberrypi systemd[1]: reactor.service: Service RestartSec=5s expired, scheduling restart.
                Sep 5 00:00:26 raspberrypi systemd[1]: reactor.service: Scheduled restart job, restart counter is at 9478.
                  Looks like you haven't set the User= line correctly in the reactor.service file. It should be the name of the user that owns the directory in which Reactor is installed. While you are at it, check the pathname to the Reactor install (in the WorkingDirectory and Environment keys), and the pathname to the node executable used in the ExecStart key. If you're not sure where your node lives, just type which node on the command line and it will tell you.
                    Matteburk
                    I checked and changed the lines to this ( I guess something is wrong there)
                    [Unit]
                    After=network.target
                    [Service]
                    Type=simple
                    User=pi
                    WorkingDirectory=/home/pi/reactor
                    Environment=NODE_PATH=/home/pi/reactor
                    ExecStart=/home/pi/.local/lib/nodejs/node-v14.15.4-linux-armv7l/bin/node
                    Restart=on-failure
                    RestartSec=5s
                    [Install]
                    WantedBy=multi-user.target
                    and restarted reactor....... then I see this in log.....
                    Sep 5 15:26:16 raspberrypi systemd[9870]: reactor.service: Failed to determine user credentials: No such process
                    Sep 5 15:26:16 raspberrypi systemd[9870]: reactor.service: Failed at step USER spawning /usr/local/lib/nodejs/bin/node: No such process
                    Sep 5 15:26:16 raspberrypi systemd[1]: reactor.service: Main process exited, code=exited, status=217/USER
                    Sep 5 15:26:16 raspberrypi systemd[1]: reactor.service: Failed with result 'exit-code'.
                    Sep 5 15:26:21 raspberrypi systemd[1]: reactor.service: Service RestartSec=5s expired, scheduling restart.
                    Sep 5 15:26:21 raspberrypi systemd[1]: reactor.service: Scheduled restart job, restart counter is at 20060.
                    Sep 5 15:26:21 raspberrypi systemd[1]: Stopped Multi System Reactor.
                    Sep 5 15:26:21 raspberrypi systemd[1]: Started Multi System Reactor.
                    Sep 5 15:26:21 raspberrypi systemd[9871]: reactor.service: Failed to determine user credentials: No such process
                    Sep 5 15:26:21 raspberrypi systemd[9871]: reactor.service: Failed at step USER spawning /usr/local/lib/nodejs/bin/node: No such process
                    Sep 5 15:26:21 raspberrypi systemd[1]: reactor.service: Main process exited, code=exited, status=217/USER
                    Sep 5 15:26:21 raspberrypi systemd[1]: reactor.service: Failed with result 'exit-code'.
                    Sep 5 15:26:22 raspberrypi systemd[1]: Reloading.
                    Sep 5 15:26:22 raspberrypi systemd[1]: /etc/systemd/system/teamviewerd.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/teamviewerd.pid \u2192 /run/teamviewerd.pid; please update the unit file accordingly.
                    Sep 5 15:26:26 raspberrypi systemd[1]: reactor.service: Service RestartSec=5s expired, scheduling restart.
                    Sep 5 15:26:26 raspberrypi systemd[1]: reactor.service: Scheduled restart job, restart counter is at 20061.
                    Sep 5 15:26:26 raspberrypi systemd[1]: Stopped Multi System Reactor.
                    Sep 5 15:26:26 raspberrypi systemd[1]: Started Multi System Reactor.
                    Sep 5 15:26:27 raspberrypi systemd[1]: reactor.service: Succeeded.
                    Sep 5 15:26:42 raspberrypi systemd[1]: Started Multi System Reactor.
                    Sep 5 15:26:43 raspberrypi systemd[1]: reactor.service: Succeeded.
                    Sep 5 15:34:06 raspberrypi systemd[1]: Started Multi System Reactor.
                    Sep 5 15:34:06 raspberrypi systemd[1]: reactor.service: Succeeded.
                      It looks like it's referring to a different pathname for nodejs than you have configured in the service file. Did you make a change to that value somewhere along the way? If you make any changes to the config file, you need to do sudo systemctl daemon-reload to get systemd to read the updated config file. So the first step is to try sudo systemctl daemon-reload followed by sudo systemctl restart reactor.
                      If that doesn't work, it is reported elsewhere that sudo systemctl daemon-reexec may resolve this (or perhaps simply rebooting the whole system).
                      Then step three, if you're still not successful, is to see if Reactor is logging anything in its own log files.
                        Matteburk
                        I have followed your instructions but no success.
                        Dont no what to do..... Here is the log from msr
                        /Mattias
                        Require stack:
                        • /home/pi/reactor/server/lib/Engine.js
                        • /home/pi/reactor/server/lib/httpapi.js
                        • /home/pi/reactor/app.js
                          Error: Cannot find module 'common/util'
                          Require stack:
                          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
                          at Function.Module._load (internal/modules/cjs/loader.js:725:27)
                          at Module.require (internal/modules/cjs/loader.js:952:19)
                          at require (internal/modules/cjs/helpers.js:88:18)
                          at Engine._get_lexp_extensions (/home/pi/reactor/server/lib/Engine.js:862:25)
                          at Rule.evaluateExpressions (/home/pi/reactor/server/lib/Rule.js:904:330)
                          at Rule._evaluate (/home/pi/reactor/server/lib/Rule.js:994:344)
                          at runMicrotasks (<anonymous>)
                          at processTicksAndRejections (internal/process/task_queues.js:93:5)
                          at async /home/pi/reactor/server/lib/Rule.js:963:17
                          2021-09-06T16:19:30.352Z Rule:5:980:Rule.js Rule#rule-ksn5u2pn._evaluate() mutex acquired, evaluating
                          2021-09-06T16:19:30.352Z Rule:5:984:Rule.js Rule#rule-ksn5u2pn update rate is 0/min limit 60/min
                          2021-09-06T16:19:30.353Z Rule:5:904:Rule.js Rule#rule-ksn5u2pn evaluateExpressions() with 0 expressions
                          2021-09-06T16:19:30.354Z Rule:CRIT Error: Cannot find module 'common/util'
                          Require stack:
                          Require stack:
                          2021-09-06T16:19:30.356Z Rule:5:980:Rule.js Rule#rule-ksm11ihr._evaluate() mutex acquired, evaluating
                          2021-09-06T16:19:30.356Z Rule:5:984:Rule.js Rule#rule-ksm11ihr update rate is 0/min limit 60/min
                          2021-09-06T16:19:30.357Z Rule:5:904:Rule.js Rule#rule-ksm11ihr evaluateExpressions() with 0 expressions
                          2021-09-06T16:19:30.358Z Rule:CRIT Error: Cannot find module 'common/util'
                          Require stack:
                          Require stack:
                        • M Matteburk
                          /Mattias
                          Require stack:
                            Require stack:
                            Require stack:
                            Require stack:
                            Require stack:
                            Require stack:
                          CrilleC Online
                          CrilleC Online
                          @matteburk Try installing 21200 just to see if you get MSR running again.
                            The messages in the log you posted indicate that NODE_PATH is incorrectly set, so I now cannot be sure if we're back at your original problem because you have tried to run it from the command line and this log is from that, or if this log is from an attempted systemd startup, which makes no sense because the service file you published earlier sets the environment variable correctly.
                            I've given you everything you need to get going again. I'm not sure what else to do. You need to figure it out, though, because this is how this and all future builds will be working, and right now, you're the only person I know of that isn't running, so I'm assuming its a local configuration issue and not a package/software issue.
                            Can you stop any local startup, start again with systemd, and post the startup portion of the log file? I don't want to see the error message again, I need to see all the messages from a Reactor startup under systemd. That will start with the string Reactor <version> starting on <nodejs version> and give me everything up to Startup complete.
                            M 2 Replies Last reply
                              Matteburk
                              @toggledbits ok... yes for sure it is me setting something up wrong... will struggle some more... 🙂
                                Matteburk
                                @crille tried .....
                                  Matteburk
                                  #21
                                  I dont see the string reactor version starting on XXXX as you wrote.
                                  From the var/log syslog I get this after stopped and started reactor via systemctl restart reactor
                                  Sep 6 20:58:49 raspberrypi systemd[1]: Started Multi System Reactor.
                                  Sep 6 20:58:50 raspberrypi systemd[1]: reactor.service: Succeeded.
                                  Sep 6 21:00:41 raspberrypi dbus-daemon[402]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.57' (uid=1000 pid=1071 comm="/usr/lib/chromium-browser/chromium-browser-v7 --fo")
                                  Sep 6 21:00:41 raspberrypi systemd[1]: Starting Hostname Service...
                                  Sep 6 21:00:41 raspberrypi dbus-daemon[402]: [system] Successfully activated service 'org.freedesktop.hostname1'
                                  Sep 6 21:00:41 raspberrypi systemd[1]: Started Hostname Service.
                                    In reactor.log
                                      In reactor.log
                                      Matteburk
                                      hmmm nothing is being logged there after stop ,start. the log file has not been updated since I tried node app.js for a couple of hours ago
                                        OK. Post that startup, then. It will tell me a few things as well.
                                          #25
                                          Wait, I'm really confused, you said "nothing is being logged there after stop ,start". Then where did the stuff you posted here come from?
                                            164.5k
