  4. MSR http PUT error
MSR http PUT error
6 Posts 3 Posters 1.9k Views 3 Watching
  • W Offline
    W Offline
    whyfseeguy
    Using MSR on Docker. The automation is to send xml body to my Hikvision camera to change the WDR based on the time of day. But getting the following error:
    TypeError: Cannot read property 'length' of undefined
    at Engine._resume_reaction (/opt/reactor/server/lib/Engine.js:1319:192)
    at Engine._process_reaction_queue (/opt/reactor/server/lib/Engine.js:1114:100)
    My MSR rule:
    HTTP Request: PUT
    HTTP Request: http://camipaddr/ISAPI/Image/channels/1/WDR/day
    HTTP Header: Content-Type: application/xml; charset="UTF-8"
    HTTP Body:
    <?xml version="1.0" encoding="UTF-8"?>
    <WDR version="2.0" xmlns="http://www.hikvision.com/ver20/XMLSchema">
    <mode>open</mode>
    <WDRLevel>40</WDRLevel>
    </WDR>
    Any idea why I am getting the above error?
    E 1 Reply Last reply
      Do you get the error if the body is empty?
      • W Offline
        W Offline
        whyfseeguy
        Hi Patrick,
        I got a 403 when the body is empty, indicating it has passed through the MSR, it got rejected by the camera. So I say it is working without the body as MSR did not throw an error.
          New docker images posted. Update and give it a try.
          • W Offline
            W Offline
            whyfseeguy
            I updated to 21256 (docker). The http put is working for me now. Thank you for the quick fix to the issue.
            • W whyfseeguy
              My MSR rule:
              HTTP Request: PUT
              HTTP Body:
              <mode>open</mode>
              </WDR>
              E Offline
              E Offline
              Edwin1972
              @whyfseeguy I also have a Hikvision camera since a month and I'm playing with it. Now I read your post that you can set a variable remotely through ISAPI. That would be cool. Could you explain how you can do that with MSR. I want to turn the smart supplement light on and off at a certain hour. Now I do that with scheduled switch but it's better with sun rise and sun set with logic MSR
                147.7k
