  4. Sustained condition is missing from MSR
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
14 Posts 3 Posters 2.1k Views 2 Watching
  • E Offline
    E Offline
    eonnet
    Hello @toggledbits ,
    I'm testing the MSR and have connected VERA, EZLO and Home Assistant to it, i tried to do some automation but i'm missing the sustained for option in triggers
    i'm i missing something?
    Best regards
      There for me on latest 21243 using chrome for android
      Maybe try another browser
      • E Offline
        E Offline
        eonnet
        I'm on higher 21256
        screenshot from chrome
        ElcidE 1 Reply Last reply
          It's because you have the changes operator selected. Change is instantaneous. An infinitely small amount of time after, the value is the same as what it just changed to, so changes is no longer true.
          • E Offline
            E Offline
            eonnet
            What should i choose, what i'm trying to achieve is that when dimmer level changes and stays for example 35% for 3 seconds pass the dimmer level to a http call
            • E Offline
              E Offline
              eonnet
              • E eonnet
                @eonnet said in Sustained condition is missing from MSR:
                So, you want to do something when it has not changed for 3 seconds... think about how to structure that.
                • E eonnet
                  I'm on higher 21256
                  @eonnet, Dam I update yesterday morning, new update that evening lol.
                  So up date to latest 56 and the sustained is still there and set to changes.Screenshot_20210914-140102.png
                    E Offline
                    E Offline
                    eonnet
                    @toggledbits said in Sustained condition is missing from MSR:
                    What i'm trying to do is to import ezlo dimmer in vera and have 2 way communication. If i do action on change without sustain sometimes it goes in a loop, so i want to make sure that dimmer has reached the level and stayed on that level for couple of seconds before i send the information back to vera. In vera i'm using your virtual dimmer. But for some reason when you turn on ezlo the dimmers make a short stop for couple of hundred milliseconds somewhere in between causes a race between the two dimmers.
                      I understand. To repeat, you want to do something when the value has not changed for a couple of seconds. Think about how to structure that.
                        wrote on last edited by Elcid
                        I dont think you need sustained.
                        You can set ezlo dimmer > 0.
                        Then set a expression to grab the ezlo dimmer level.
                        Then in set reaction, set vera dimmer to ${{name_of_expression}},
                        and reset reaction set to vera dimmer to 0.
                        You can make the same rule in reverse for vera dimmer
                        Then if you turn on vera dimmer it will turn on ezlo, and if you turn of ezlo it will turn off vera.
                        Needs a bit more thought to follow dimming changes after that.
                          Here's the general structure of the conditions. Notice there's a group with "NOT" set to invert the sense of changes in the only condition the group has.
                          There are condition options applied to the group (not the changes condition):
                          When this group goes true, it means the dimmer has not changed for 3 seconds, the rule sets, and your Set reaction should copy the value to the other device.
                            This seems to work and stops the race condition, and there is no delay in reaponse from other device.
                            biuld the same rule for the other device. Both set the global expression dimming to 1 to stop the other reacting , and feeding back
                            Screenshot_20210914-184140.png Screenshot_20210914-184237.png Screenshot_20210914-184311.png Screenshot_20210914-185552.png
                            • E Offline
                              E Offline
                              eonnet
                              Thanks both @toggledbits and @Elcid. I will use the @toggledbits idea because i dont need instantaneous feedback from ezlo.
                              Did anybody tested ezlo with higher number of devices how it compares with Vera? i have around 50 zwave devices and when i turn on scene with multiple devices sometimes it takes 1 minute scene to complete, i get a lot of retries especially with the dimmers, the zwave network is good because the 50 devices are in 60 sqm apartment on 2 floors so 50 devices make excellent mesh 🙂 90% of the devices are mains powered.
                              My idea is to use Ezlo hub for zwave devices and transfer them to Control4 via HTTP calls. that is why i will use @toggledbits solution because ezlo -> Control4 is just for feedback i dont need instantaneous response, from C4 -> Ezlo i will use direct http call so that will be instant
                                97.2k
                              • Next Release?
