  4. Sustained condition is missing from MSR
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
Reset a delay
Reactor Loading Screen Safari
I'm having an issue with MSR's UI being very unresponsive. It started happening a couple days ago and I didn't make any changes that would have caused this except adding some meross lan devices in HA. When I go into an entity action and use the search functionality, it usually will start filtering and then get to a place after a few letters are entered where it will take 30 seconds or more (sometimes minutes) for the UI to show what I am typing. During this time MSR ui is completely unresponsive. I've tried multiple browsers and multiple computers. HA and MSR are both deployed in docker. I have run HTOP on the host and when the problem happens there are no CPU/Memory spikes at all. From a functionality standpoint MSR is working perfectly. This seems to be an UI issue only. Do i need to ditch Docker and run MSR on a Proxmox VM? I have both stand alone Docker and Proxmox environments. I dont mind doing that I just want to be able to use the UI again... Installation method Home Assistant Container Core 2025.7.3 Frontend 20250702.3 nothing crazy in the logs except some openweather map stuff that doesn't make any sense as it is working fine in MSR Any help would be greatly appreciated Reactor latest-25328-b2ed1365 app 25328 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.843Z <app:null> Reactor build latest-25328-b2ed1365 starting on v24.11.1 /usr/local/bin/node [latest-25328]2025-11-30T20:01:53.844Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #161-Ubuntu SMP Tue Jul 22 14:25:40 UTC 2025; locale (undefined) [latest-25328]2025-11-30T20:01:53.844Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-25328]2025-11-30T20:01:53.844Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.865Z <app:null> Resolved timezone=America/New_York, environment TZ=America/New_York; offset minutes from UTC=-300 [latest-25328]2025-11-30T20:01:53.867Z <default:null> Module i18n v25141 [latest-25328]2025-11-30T20:01:53.867Z <app:null> Configured locale (undefined); selected locale(s) en-US.UTF-8 [latest-25328]2025-11-30T20:01:53.879Z <app:null> Loaded locale en-US for en-US [latest-25328]2025-11-30T20:01:53.879Z <app:null> Local date/time using configured timezone and locale formatting is "11/30/2025, 3:01:53 PM" [latest-25328]2025-11-30T20:01:53.889Z <Structure:null> Module Structure v25326 [latest-25328]2025-11-30T20:01:53.890Z <Capabilities:null> Module Capabilities v24312 [latest-25328]2025-11-30T20:01:53.904Z <Plugin:null> Module Plugin v25141 [latest-25328]2025-11-30T20:01:53.923Z <Timer:null> Module Timer v25279 [latest-25328]2025-11-30T20:01:53.924Z <TimerBroker:null> Module TimerBroker v25314 [latest-25328]2025-11-30T20:01:53.927Z <Entity:null> Module Entity v25251 [latest-25328]2025-11-30T20:01:53.929Z <Controller:null> Module Controller v25253 [latest-25328]2025-11-30T20:01:53.930Z <AlertManager:null> Module AlertManager v25318 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Ruleset v25283 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Rulesets v25141 [latest-25328]2025-11-30T20:01:53.942Z <GlobalExpression:null> Module GlobalExpression v25258 [latest-25328]2025-11-30T20:01:53.953Z <Predicate:null> Module Predicate v25328 [latest-25328]2025-11-30T20:01:53.956Z <Rule:null> Module Rule v25323 [latest-25328]2025-11-30T20:01:53.958Z <GlobalReaction:null> Module GlobalReaction v25292 [latest-25328]2025-11-30T20:01:53.959Z <Engine:null> Module Engine v25325 [latest-25328]2025-11-30T20:01:53.964Z <httpapi:null> Module httpapi v25328 [latest-25328]2025-11-30T20:01:53.972Z <wsapi:null> Module wsapi v25328 [latest-25328]2025-11-30T20:01:53.994Z <TaskQueue:null> Module TaskQueue 24138 [latest-25328]2025-11-30T20:01:53.994Z <VeraController:null> Module VeraController v25141 [latest-25328]2025-11-30T20:01:54.179Z <HassController:null> Module HassController v25325 [latest-25328]2025-11-30T20:02:13.797Z <OWMWeatherController:null> Module OWMWeatherController v25268 [latest-25328]2025-11-30T20:02:13.800Z <SystemController:null> Module SystemController v25323 [latest-25328]2025-11-30T20:02:13.807Z <MQTTController:null> Module MQTTController v22092 [latest-25328]2025-11-30T20:02:20.630Z <OWMWeatherController:CRIT> FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxx&lon=-xxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxxxxxxxxx&units=standard&_r=1xxxxxxxxxxxxxxfailed, reason: [-] FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxxx&lon=-xxxxxxxxxxxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxx&units=standard&_r=xxxxxxxxxxxxxxxfailed, reason: at ClientRequest.<anonymous> (/opt/reactor/node_modules/node-fetch/lib/index.js:1501:11) at ClientRequest.emit (node:events:508:28) at ClientRequest.emit (node:domain:489:12) at emitErrorEvent (node:_http_client:108:11) at TLSSocket.socketErrorListener (node:_http_client:575:5) at TLSSocket.emit (node:events:508:28) at TLSSocket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:170:8) at emitErrorCloseNT (node:internal/streams/destroy:129:3) at processTicksAndRejections (node:internal/process/task_queues:89:21
Date/time condition
Device log?
14 Posts 3 Posters 1.7k Views 2 Watching
  • E Offline
    E Offline
    eonnet
    Hello @toggledbits ,
    I'm testing the MSR and have connected VERA, EZLO and Home Assistant to it, i tried to do some automation but i'm missing the sustained for option in triggers
    i'm i missing something?
    Best regards
      There for me on latest 21243 using chrome for android
      Maybe try another browser
      • E Offline
        E Offline
        eonnet
        I'm on higher 21256
        screenshot from chrome
        ElcidE 1 Reply Last reply
          It's because you have the changes operator selected. Change is instantaneous. An infinitely small amount of time after, the value is the same as what it just changed to, so changes is no longer true.
          • E Offline
            E Offline
            eonnet
            What should i choose, what i'm trying to achieve is that when dimmer level changes and stays for example 35% for 3 seconds pass the dimmer level to a http call
            • E Offline
              E Offline
              eonnet
              • E eonnet
                @eonnet said in Sustained condition is missing from MSR:
                So, you want to do something when it has not changed for 3 seconds... think about how to structure that.
                • E eonnet
                  I'm on higher 21256
                  @eonnet, Dam I update yesterday morning, new update that evening lol.
                  So up date to latest 56 and the sustained is still there and set to changes.Screenshot_20210914-140102.png
                    E Offline
                    E Offline
                    eonnet
                    @toggledbits said in Sustained condition is missing from MSR:
                    What i'm trying to do is to import ezlo dimmer in vera and have 2 way communication. If i do action on change without sustain sometimes it goes in a loop, so i want to make sure that dimmer has reached the level and stayed on that level for couple of seconds before i send the information back to vera. In vera i'm using your virtual dimmer. But for some reason when you turn on ezlo the dimmers make a short stop for couple of hundred milliseconds somewhere in between causes a race between the two dimmers.
                      I understand. To repeat, you want to do something when the value has not changed for a couple of seconds. Think about how to structure that.
                        wrote on last edited by Elcid
                        I dont think you need sustained.
                        You can set ezlo dimmer > 0.
                        Then set a expression to grab the ezlo dimmer level.
                        Then in set reaction, set vera dimmer to ${{name_of_expression}},
                        and reset reaction set to vera dimmer to 0.
                        You can make the same rule in reverse for vera dimmer
                        Then if you turn on vera dimmer it will turn on ezlo, and if you turn of ezlo it will turn off vera.
                        Needs a bit more thought to follow dimming changes after that.
                          Here's the general structure of the conditions. Notice there's a group with "NOT" set to invert the sense of changes in the only condition the group has.
                          There are condition options applied to the group (not the changes condition):
                          When this group goes true, it means the dimmer has not changed for 3 seconds, the rule sets, and your Set reaction should copy the value to the other device.
                            This seems to work and stops the race condition, and there is no delay in reaponse from other device.
                            biuld the same rule for the other device. Both set the global expression dimming to 1 to stop the other reacting , and feeding back
                            Screenshot_20210914-184140.png Screenshot_20210914-184237.png Screenshot_20210914-184311.png Screenshot_20210914-185552.png
                            • E Offline
                              E Offline
                              eonnet
                              Thanks both @toggledbits and @Elcid. I will use the @toggledbits idea because i dont need instantaneous feedback from ezlo.
                              Did anybody tested ezlo with higher number of devices how it compares with Vera? i have around 50 zwave devices and when i turn on scene with multiple devices sometimes it takes 1 minute scene to complete, i get a lot of retries especially with the dimmers, the zwave network is good because the 50 devices are in 60 sqm apartment on 2 floors so 50 devices make excellent mesh 🙂 90% of the devices are mains powered.
                              My idea is to use Ezlo hub for zwave devices and transfer them to Control4 via HTTP calls. that is why i will use @toggledbits solution because ezlo -> Control4 is just for feedback i dont need instantaneous response, from C4 -> Ezlo i will use direct http call so that will be instant
                              • Copying a global reaction
                              • Need help with sequence
                              • Possible feature request?
                              • Time series documentation
                              • Reset a delay
