Hello,
Hello forum instigators.
Hello,
Many thanks 🙂
Hi folks,
Looking for a recommendation:
Kevin
Hey guys...
We need:
What technologi will be best?
[###BUILDVERSION###]2023-04-26T19:41:51.683Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs added file logger to zwavejs.log [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.837Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.0.10:3000 [###BUILDVERSION###]2023-04-26T19:41:51.874Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs connected [###BUILDVERSION###]2023-04-26T19:41:51.874Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs sending connection initialization [###BUILDVERSION###]2023-04-26T19:41:51.931Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs greeting from server: [Object]{ "type": "version", "driverVersion": "10.16.0", "serverVersion": "1.28.0", "homeId": 3631280043, "minSchemaVersion": 0, "maxSchemaVersion": 28 } [###BUILDVERSION###]2023-04-26T19:41:51.932Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing initial inventory [###BUILDVERSION###]2023-04-26T19:41:52.325Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs manufacturer-specific data for 134 (AEON Labs) from package ver 22315.1 [###BUILDVERSION###]2023-04-26T19:41:52.328Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 1 endpoint 0 (entity "1-0") [###BUILDVERSION###]2023-04-26T19:41:52.339Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs manufacturer-specific data for 543 (Elexa Consumer Products Inc.)I think this is going to be a problem. Is there a way in NodeBB to configure the default language for fenced code block markdown for the entire forum so that these display more as they did before the upgrade?
Many thanks in advance
ChatGPT samples:
Me:
It:
Me:
It:
It:
Me:
Me:
and
Me:
TIA for any guidance
Controller shift - How do you do it ?
Another Interesting observation - that recent bootloader upgrade has resulted in the z-wave dongle backup being reported as 4.38 rather that 4.5 when on the previous version ? -, see below extract of yesterdays and todays backups...
16383 Sep 20 19:48 dongle.4.38.dump.0 16383 Sep 19 20:37 dongle.4.5.dump.0
Next steps
touch /etc/cmh/dongle.restore.go -- on target VeraSecure scp dongle.4.38.dump.0 root@192.168.1.145:/etc/cmh/dongle.4.38.dump.0 -- on source VeraPlus
Perhaps not a surprise but the restore failed.
02 09/20/21 20:59:27.962 ZWave::Start reset 0 use45:1 minor:1 model:37 port:/dev/ttyS0 nodes:1 using_prefer: 1 prefer 0.0 ports:/dev/ttyS0 - /dev/ttyS0 <0x77ab6320> 02 09/20/21 20:59:27.963 ZWave::Start restoring dongle firmware <0x77ab6320> 03 09/20/21 20:59:27.963 JobHandler_LuaUPnP::m_bReloadCriticalOnly_set now 1 <0x77ab6320> 01 09/20/21 20:59:27.977 ZWJob_BackupDongle::FixupBufferVersion don't know version 4.38 <0x77ab6320> 01 09/20/21 20:59:27.977 ZWJob_BackupDongle::ZWJob_BackupDongle restore file invalid <0x77ab6320> 03 09/20/21 20:59:27.983 JobHandler_LuaUPnP::Reload: Dongle Restore Critical 1 m_bCriticalOnly 1 dirty data 1 running 0 <0x77ab6320> 04 09/20/21 20:59:28.319 <Job ID="1" Name="restore" Device="1" Created="2021-09-20 20:59:27" Started="2021-09-20 20:59:28" Completed="2021-09-20 20:59:28" Duration="0.354838000" Runtime="0.0" Status="Failed" LastNote="ERROR: Restore failed. Try again or contact tech support."/> <0x77ab6320>
@rafale77 - What do you recommend next on the UZB1 upgrade
I’m guessing i need to get to v6.01 ?
yep.. that's what I would do.
Any idea why the 5.7 (5.07) UZB1 firmware appears as 4.38 on Vera ?
Also what do you recommend we do next? Update the bootloader again or continue on as is just with firmware ?
What confuses me is that this link (https://z-wave.me/support/uzbrazberry-firmwares/) only goes to 5.36, no sight of 6.01?
Hold on,, I thought this was familiar - we back to where we were last year with another UZB1 I had
So unless you disagree I will follow your previous advice.
@rafale77 said in UZB/RaZberry Firmwares - Update:
I went to read the map myself and here are the steps I would take:
5.7 -> 5.7 40196 BL -> 5.27 ->5.36 ->5.39So yes Bootloader first in general but need to read the version.
You caught me there. I was probably smarter then than I am now.
My entire system has been working so well that I stopped tinkering or upgrading it save for only occasional additions or optimization of a scene here or there on openLuup. I lost a lot by not practicing.
Sadly there is no downgrade option available from v5.39 when I used the ‘all’ token, but I’m beginning to think that the Vera version numbering is related to the SDK
Using another UZB1 stick, and just moving from 5.26 & 5.27 both reported v4.61 on Vera (and both have the same SDK version - 6.71.01)
Observations so far…
UZB1 v5.06 [29304] SDK 6.??.?? = v4.01 on Vera
UZB1 v5.07 [29304] SDK 6.51.09 = v4.38 on VeraUZB1 v5.26 [40196] SDK 6.71.01 = v4.61 on Vera
UZB1 v5.27 [40196] SDK 6.71.01 = v4.61 on VeraUZB1 v5.32 [40196] SDK 6.81.00 = TBC on Vera
UZB1 v5.37 [40196] SDK 6.81.01 = TBC on VeraUZB1 v5.39 [40196] SDK 6.82.01 = v6.09 on Vera
The version roadmap - > https://z-wave.me/support/uzbrazberry-firmwares/ has the following ..
UZB1 v5.37 [40196] SDK 6.81.01 = TBC on VeraHowever the actual UZB firmware update options I have available via the zway controller are different - i only have 5.33 and 5.36 - any ideas ?
Using the vera backup process you would have to go up or remain on the same version. If you backed up your vera which is on 6.01 into a stick in 6.02, you should be able to restore onto another vera with an SDK 6.02 and above. Have you tried that? Upgrading the vera?
To answer your question if you have both your controller with the same node ID, it will cause a mess to your network. In that case I would add the second controller so it takes a different node ID. (I ran vera and zway together this way for several months).
Here is the type of mess it will cause:
Controller1: turn the light one
Light: Ok the light is on
Controller2: Got it... euh What? who told you to?
Controller1: Are you on yet? Timeout, let me ask again. Retry!This will cause the network to be very busy as nodes do not who to report back to or think they already reported and got an ack...
Thanks @rafale77
How can I upgrade the onboard zwave firmware on my VeraSecure, which is on v6.01?
Oh gosh... I need to remember this. I think at one point I found the firmware for the chip and using a serial updater, managed to manually upgrade the chip firmware through SSH. That was a long time ago. I think I published how to do this in the old forum but not sure if it's been deleted. At the moment, I no longer have any veras... Also the Vera secure runs on a different/cheaper chip than the vera plus I had.. Why don't you just let the vera run on the dongle?
I was looking to repurpose the UZB1 dongle and use it on something else like a raspberry pi.
Also what do you mean the Secure has a different cheaper (lesser quality ?) zwave chip compared to the plus ? Where can I look that up ?
Most of the specs I’d seen on the Verasecure had suggested that it was a performance bump compared to the plus, i.e dual cpu, more memory etc?
You must have missed my posts there... It has an extra CPU core indeed but the DRAM is unused by the software and the flash drive was catastrophically partitioned... netting less useable space than the Plus. After they got bought and my posts about the disastrous engineering they noodled around the partition with symlink (which I initiated with a script I provided on the forum too). I later moved on to boot the vera off of a USB SSD. I know about the zwave chip only because I dug into it. It makes no difference in functionality as the bridge mode the plus and edge had were not used by the vera. It makes the zwave firmware different though.
