Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
67 Posts 3 Posters 35.6k Views 3 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    Maybe I’ve gone to far - v 5.39 appears as v6.09
    And now every z-wave backup I try fails.. 😞
    Any ideas ?
      You should be able to downgrade back... But yeah that's what I feared... Upgrading too far would make it impossible for the vera to restore...
      • parkercP Offline
        parkercP Offline
        parkerc
        #55
        Sadly there is no downgrade option available from v5.39 when I used the ‘all’ token, but I’m beginning to think that the Vera version numbering is related to the SDK
        Using another UZB1 stick, and just moving from 5.26 & 5.27 both reported v4.61 on Vera (and both have the same SDK version - 6.71.01)
        Observations so far…
        UZB1 v5.06 [29304] SDK 6.??.?? = v4.01 on Vera
        UZB1 v5.07 [29304] SDK 6.51.09 = v4.38 on Vera
        UZB1 v5.26 [40196] SDK 6.71.01 = v4.61 on Vera
        UZB1 v5.27 [40196] SDK 6.71.01 = v4.61 on Vera
        UZB1 v5.32 [40196] SDK 6.81.00 = TBC on Vera
        UZB1 v5.37 [40196] SDK 6.81.01 = TBC on Vera
        UZB1 v5.39 [40196] SDK 6.82.01 = v6.09 on Vera
        • parkercP Offline
          parkercP Offline
          parkerc
          The version roadmap - > https://z-wave.me/support/uzbrazberry-firmwares/ has the following ..
          However the actual UZB firmware update options I have available via the zway controller are different - i only have 5.33 and 5.36 - any ideas ?
            5.33 =5.32 and 5.36=5.37 if I remember correctly. They were just version numbered for Razberry vs UZB.
            • parkercP Offline
              parkercP Offline
              parkerc
              #58
              Would you believe it !
              The target was to align with the standard v6.01 on the VeraSecure but the UZB1 v5.33 has ended us up on v6.02 !!!!
              UZB1 v5.33 [40196] SDK 6.81.00 = v6.02 on Vera
              So it seems it’s not possible to get to v6.01 ??
              • parkercP Offline
                parkercP Offline
                parkerc
                Perhaps not unexpected, trying to back up UZB1 5.33 / Vera v6.02 failed..
                • parkercP Offline
                  parkercP Offline
                  parkerc
                  @rafale77
                  Quick question, if i restore a z-wave backup onto a new controller - I will have two controllers both with the exact same z-wave devices and network registered
                  I’m curious what are the issues in running both controllers ?
                    #61
                    Using the vera backup process you would have to go up or remain on the same version. If you backed up your vera which is on 6.01 into a stick in 6.02, you should be able to restore onto another vera with an SDK 6.02 and above. Have you tried that? Upgrading the vera?
                    To answer your question if you have both your controller with the same node ID, it will cause a mess to your network. In that case I would add the second controller so it takes a different node ID. (I ran vera and zway together this way for several months).
                    Here is the type of mess it will cause:
                    Controller1: turn the light one
                    Light: Ok the light is on
                    Controller2: Got it... euh What? who told you to?
                    Controller1: Are you on yet? Timeout, let me ask again. Retry!
                    This will cause the network to be very busy as nodes do not who to report back to or think they already reported and got an ack...
                    parkercP 1 Reply Last reply
                      parkercP Offline
                      parkercP Offline
                      parkerc
                      Thanks @rafale77
                      How can I upgrade the onboard zwave firmware on my VeraSecure, which is on v6.01?
                        Oh gosh... I need to remember this. I think at one point I found the firmware for the chip and using a serial updater, managed to manually upgrade the chip firmware through SSH. That was a long time ago. I think I published how to do this in the old forum but not sure if it's been deleted. At the moment, I no longer have any veras... Also the Vera secure runs on a different/cheaper chip than the vera plus I had.. Why don't you just let the vera run on the dongle?
                          parkercP Offline
                          parkercP Offline
                          parkerc
                          #64
                          I was looking to repurpose the UZB1 dongle and use it on something else like a raspberry pi.
                          Also what do you mean the Secure has a different cheaper (lesser quality ?) zwave chip compared to the plus ? Where can I look that up ?
                          Most of the specs I’d seen on the Verasecure had suggested that it was a performance bump compared to the plus, i.e dual cpu, more memory etc?
                          • parkercP parkerc
                            @parkerc
                            You must have missed my posts there... It has an extra CPU core indeed but the DRAM is unused by the software and the flash drive was catastrophically partitioned... netting less useable space than the Plus. After they got bought and my posts about the disastrous engineering they noodled around the partition with symlink (which I initiated with a script I provided on the forum too). I later moved on to boot the vera off of a USB SSD. I know about the zwave chip only because I dug into it. It makes no difference in functionality as the bridge mode the plus and edge had were not used by the vera. It makes the zwave firmware different though.
                            • parkercP Offline
                              parkercP Offline
                              parkerc
                              #66
                              Thanks @rafale77
                              Sorry i missed that, but I do recall your exroot discussions a while back, as I’m still tempted to do that.
                              So in your opinion, given the choice of running your home on a VeraPlus or a VeraSecure*, which one would you choose ?
                              *The VeraSecure is a bricked one I picked up for next to nothing, and somehow managed to restore, so it’s basically a free swap.
                              (QQ : Is there a specific script for the VeraSecure, as I could only see Edge & Plus files listed on your github page - > https://github.com/rafale77/vera-extroot)
                                I didn't test extroot on the verasecure because I didn't have one to try it on. I think others on the forum did it and reported to work fine. There is nothing about the vera secure which makes it perform better than the plus. The extra core is unused... the vera UI is single threaded. It also does not use the CPU enough for the speed to make a difference. Same for the DRAM. The only benefit is the battery which to me would be more of a problem than benefit since they have limited lifetime and prevent me from easily power cycling the unit.
                                  162.4k
