Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
67 Posts 3 Posters 35.6k Views 3 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    #44
    OK, putting the UZB1 back into the VeraPlus, it’s moved from 4.01 to 4.38 - do we think that’s enough, when the VeraSecure is reporting 6.01
      This is weird... It should be above 6. Not sure what this 4.38 corresponds to. It looks like you need to keep going... Or try it to see if it migrates. You never know.
      • parkercP Offline
        parkercP Offline
        parkerc
        #46
        Another Interesting observation - that recent bootloader upgrade has resulted in the z-wave dongle backup being reported as 4.38 rather that 4.5 when on the previous version ? -, see below extract of yesterdays and todays backups...
        16383 Sep 20 19:48 dongle.4.38.dump.0
        16383 Sep 19 20:37 dongle.4.5.dump.0
        Next steps
        touch /etc/cmh/dongle.restore.go  -- on target VeraSecure
        scp dongle.4.38.dump.0 root@192.168.1.145:/etc/cmh/dongle.4.38.dump.0  -- on source VeraPlus
        • parkercP Offline
          parkercP Offline
          parkerc
          #47
          Perhaps not a surprise but the restore failed.
          02	09/20/21 20:59:27.962	ZWave::Start reset 0 use45:1 minor:1 model:37 port:/dev/ttyS0 nodes:1 using_prefer: 1 prefer 0.0  ports:/dev/ttyS0 - /dev/ttyS0 <0x77ab6320>
          02	09/20/21 20:59:27.963	ZWave::Start restoring dongle firmware <0x77ab6320>
          03	09/20/21 20:59:27.963	JobHandler_LuaUPnP::m_bReloadCriticalOnly_set now 1 <0x77ab6320>
          01	09/20/21 20:59:27.977	ZWJob_BackupDongle::FixupBufferVersion don't know version 4.38 <0x77ab6320>
          01	09/20/21 20:59:27.977	ZWJob_BackupDongle::ZWJob_BackupDongle restore file invalid <0x77ab6320>
          03	09/20/21 20:59:27.983	JobHandler_LuaUPnP::Reload: Dongle Restore Critical 1 m_bCriticalOnly 1 dirty data 1 running 0 <0x77ab6320>
          04	09/20/21 20:59:28.319	<Job ID="1" Name="restore" Device="1" Created="2021-09-20 20:59:27" Started="2021-09-20 20:59:28" Completed="2021-09-20 20:59:28" Duration="0.354838000" Runtime="0.0" Status="Failed" LastNote="ERROR: Restore failed. Try again or contact tech support."/> <0x77ab6320>
          @rafale77 - What do you recommend next on the UZB1 upgrade
          I’m guessing i need to get to v6.01 ?
            yep.. that's what I would do.
            parkercP 1 Reply Last reply
              parkercP Offline
              parkercP Offline
              parkerc
              Any idea why the 5.7 (5.07) UZB1 firmware appears as 4.38 on Vera ?
              Also what do you recommend we do next? Update the bootloader again or continue on as is just with firmware ?
              What confuses me is that this link (https://z-wave.me/support/uzbrazberry-firmwares/) only goes to 5.36, no sight of 6.01?
              • parkercP Offline
                parkercP Offline
                parkerc
                #50
                Hold on,, I thought this was familiar 🙂 - we back to where we were last year with another UZB1 I had
                • https://smarthome.community/topic/121/uzb-razberry-firmwares-update/34
                So unless you disagree I will follow your previous advice.
                @rafale77 said in UZB/RaZberry Firmwares - Update:
                I went to read the map myself and here are the steps I would take:
                5.7 -> 5.7 40196 BL -> 5.27 ->5.36 ->5.39
                So yes Bootloader first in general but need to read the version.
                  You caught me there. I was probably smarter then than I am now. 😉
                  My entire system has been working so well that I stopped tinkering or upgrading it save for only occasional additions or optimization of a scene here or there on openLuup. I lost a lot by not practicing.
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    Well, it looks like I've made it to 5.39, although I'm surprised by the current update options ?
                    Being in the UK, and only ever using it on the EU frequency, any idea why it's giving me the option to switch to EU ? Where does it think I am set to at the moment ?
                    • parkercP Offline
                      parkercP Offline
                      parkerc
                      Maybe I’ve gone to far - v 5.39 appears as v6.09
                      And now every z-wave backup I try fails.. 😞
                      Any ideas ?
                        You should be able to downgrade back... But yeah that's what I feared... Upgrading too far would make it impossible for the vera to restore...
                        • parkercP Offline
                          parkercP Offline
                          parkerc
                          #55
                          Sadly there is no downgrade option available from v5.39 when I used the ‘all’ token, but I’m beginning to think that the Vera version numbering is related to the SDK
                          Using another UZB1 stick, and just moving from 5.26 & 5.27 both reported v4.61 on Vera (and both have the same SDK version - 6.71.01)
                          Observations so far…
                          UZB1 v5.06 [29304] SDK 6.??.?? = v4.01 on Vera
                          UZB1 v5.07 [29304] SDK 6.51.09 = v4.38 on Vera
                          UZB1 v5.26 [40196] SDK 6.71.01 = v4.61 on Vera
                          UZB1 v5.27 [40196] SDK 6.71.01 = v4.61 on Vera
                          UZB1 v5.32 [40196] SDK 6.81.00 = TBC on Vera
                          UZB1 v5.37 [40196] SDK 6.81.01 = TBC on Vera
                          UZB1 v5.39 [40196] SDK 6.82.01 = v6.09 on Vera
                          • parkercP Offline
                            parkercP Offline
                            parkerc
                            The version roadmap - > https://z-wave.me/support/uzbrazberry-firmwares/ has the following ..
                            However the actual UZB firmware update options I have available via the zway controller are different - i only have 5.33 and 5.36 - any ideas ?
                              5.33 =5.32 and 5.36=5.37 if I remember correctly. They were just version numbered for Razberry vs UZB.
                              • parkercP Offline
                                parkercP Offline
                                parkerc
                                #58
                                Would you believe it !
                                The target was to align with the standard v6.01 on the VeraSecure but the UZB1 v5.33 has ended us up on v6.02 !!!!
                                UZB1 v5.33 [40196] SDK 6.81.00 = v6.02 on Vera
                                So it seems it’s not possible to get to v6.01 ??
                                • parkercP Offline
                                  parkercP Offline
                                  parkerc
                                  Perhaps not unexpected, trying to back up UZB1 5.33 / Vera v6.02 failed..
                                  • parkercP Offline
                                    parkercP Offline
                                    parkerc
                                    @rafale77
                                    Quick question, if i restore a z-wave backup onto a new controller - I will have two controllers both with the exact same z-wave devices and network registered
                                    I’m curious what are the issues in running both controllers ?
                                      #61
                                      Using the vera backup process you would have to go up or remain on the same version. If you backed up your vera which is on 6.01 into a stick in 6.02, you should be able to restore onto another vera with an SDK 6.02 and above. Have you tried that? Upgrading the vera?
                                      To answer your question if you have both your controller with the same node ID, it will cause a mess to your network. In that case I would add the second controller so it takes a different node ID. (I ran vera and zway together this way for several months).
                                      Here is the type of mess it will cause:
                                      Controller1: turn the light one
                                      Light: Ok the light is on
                                      Controller2: Got it... euh What? who told you to?
                                      Controller1: Are you on yet? Timeout, let me ask again. Retry!
                                      This will cause the network to be very busy as nodes do not who to report back to or think they already reported and got an ack...
                                        parkercP Offline
                                        parkercP Offline
                                        parkerc
                                        Thanks @rafale77
                                        How can I upgrade the onboard zwave firmware on my VeraSecure, which is on v6.01?
                                          Oh gosh... I need to remember this. I think at one point I found the firmware for the chip and using a serial updater, managed to manually upgrade the chip firmware through SSH. That was a long time ago. I think I published how to do this in the old forum but not sure if it's been deleted. At the moment, I no longer have any veras... Also the Vera secure runs on a different/cheaper chip than the vera plus I had.. Why don't you just let the vera run on the dongle?
                                            162.4k
