  4. Rule for devices battery level ?
43 Posts 6 Posters 16.1k Views 7 Watching
    Ah, that explains a lot 🙂 I like the idea, it seems very flexible.
      No, it's not yet available.
      @toggledbits Thanks, the new matchEntities() is brilliant. Now we can have dynamic arrays of devices.
        toggledbitsT Online
        toggledbitsT Online
        @crille said in Rule for devices battery level ?:
        Tell me about that...
          @toggledbits Inspired by this topic I created a rule with similar expressions to monitor/notify x_ezlo_device.reachable for all my Ezlo devices. Instead of managing a static array, like the battery_device_list in this topic, the expression matchEntities( {capability: 'x_ezlo_device'} ) generates a list of devices that is dynamically updated if devices are added or removed from the controller.
            @toggledbits I'm testing this new function, but somehow it does not show all the devices I'm expecting it to show. See examples below
            Array is empty, although it should contain one device:
            Strange, as device 216 definitely has capability "x_vera_device"
            • toggledbitsT Online
              toggledbitsT Online
              One of the issues I see in matchEntities() as it currently works is that it returns an array of entity objects with attribute values, but it does not update that array when any of the returned entities' attributes or other values changes. So it's certain, then, that the attributes will go stale in the result array.
              For the next build, I will change the definition of this function to return canonical entity IDs only, rather than entity objects, so you will have to use getEntity() in your each over the results, as you did with your test_array example, and this will ensure that you are always looking at the latest attributes. You can test this theory now by modifying your each for d_failure_list to use getEntity( id.canonical_id ).
                @toggledbits did what you suggested, but situation didn't really change, array is still empty:
                  toggledbitsT Online
                  Can you show the entity detail for device 216 please?
                    #29
                    @tunnus I had some issues as well. I got an empty array and when tried getEntity() I got some "Type Error". Was sure I was doing something wrong but I restarted Reactor and copied the same expression to a new one and suddenly it worked.
                    @toggledbits I also noticed the array isn't updated when entity changed so I pulse the trigger every minute to update it. Will change to getEntity() for next update.
                      @toggledbits here you go:
                      dimming.level=0
                      dimming.step=null
                      power_switch.state=false
                      x_vera_device.configured=false
                      x_vera_device.device_number=216
                      x_vera_device.device_type="urn:schemas-upnp-org:device:DimmableLight:1"
                      x_vera_device.failed=true
                      x_vera_device.mapped_by="*;device_type=/urn:schemas-upnp-org:device:DimmableLight:/"
                      x_vera_device.mapped_class="generic_dimmer"
                      x_vera_device.parent_device=1
                      x_vera_device.room_id="1"
                      x_vera_energy.amps=null
                      x_vera_energy.day_kwh=null
                      x_vera_energy.kwh="6.7000"
                      x_vera_energy.life_kwh=null
                      x_vera_energy.month_kwh=null
                      x_vera_energy.power_factor=null
                      x_vera_energy.volts=null
                      x_vera_energy.watts=""
                      x_vera_energy.week_kwh=null
                      x_vera_energy.year_kwh=null
                      x_vera_svc_cd_jackson_com_DataMine1.errorStatus="true"
                      x_vera_svc_micasaverde_com_EnergyMetering1.ActualUsage="1"
                      x_vera_svc_micasaverde_com_EnergyMetering1.KWH="6.7000"
                      x_vera_svc_micasaverde_com_EnergyMetering1.KWHReading="1597268716"
                      x_vera_svc_micasaverde_com_EnergyMetering1.Log="0,0,0,1633073400,1"
                      x_vera_svc_micasaverde_com_EnergyMetering1.Watts=""
                      x_vera_svc_micasaverde_com_HaDevice1.AutoConfigure="0"
                      x_vera_svc_micasaverde_com_HaDevice1.CommFailure="1"
                      x_vera_svc_micasaverde_com_HaDevice1.CommFailureAlarm="1628783888,1"
                      x_vera_svc_micasaverde_com_HaDevice1.CommFailureTime="1628780288"
                      x_vera_svc_micasaverde_com_HaDevice1.Configured="0"
                      x_vera_svc_micasaverde_com_HaDevice1.FirstConfigured="1526668133"
                      x_vera_svc_micasaverde_com_HaDevice1.LastTimeCheck="1605041801"
                      x_vera_svc_micasaverde_com_HaDevice1.LastTimeOffset="2"
                      x_vera_svc_micasaverde_com_HaDevice1.LastUpdate="0"
                      x_vera_svc_micasaverde_com_HaDevice1.ModeSetting="1:;2:;3:;4:"
                      x_vera_svc_micasaverde_com_HaDevice1.PollRatings="0.20"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.AgiInfo="X"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.AlarmType="0x4,0x8,"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.AlarmVersion="0,2"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.AssociationGroups="1"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.AssociationNum="4"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.Capabilities="211,156,1,4,17,1,L,R,B,RS,|37S,38S:3,39S,43S,44S,50S:3,89S,90B,94,112S,113S:4,114,115S,122S,129S,133S,134,152,"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.ConfiguredAssoc=""
                      x_vera_svc_micasaverde_com_ZWaveDevice1.ConfiguredVariable="80-Status notification type,1d,3,90- Enable or Disable energy reporting (0-1),1d,1,91-Minimum change in wattage for a REPORT (0-60000),2d,5,92-Minimum change in wattage percent for a REPORT,1d,5,120-Configure external switch mode for S1(0-3),1d,1,125,1d,1,128-Current working mode (0-2),1d,1,129-Dimming principle (0-2),1d,1,130-Dimmer load type connected(0-3),1d,1,131-Minimum brightness level,1d,20,132-Maximum brightness level,1d,90,249,1d,0"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.FirmwareInfo="134,111,41841"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.LastArr=""
                      x_vera_svc_micasaverde_com_ZWaveDevice1.LastNnu=""
                      x_vera_svc_micasaverde_com_ZWaveDevice1.LastReset="1526668110"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.LastRouteUpdate="1597229741"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.ManufacturerInfo="134,3,111"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.MeterScale="5"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.MeterType="1"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.NodeInfo="25S,26S,27S,2bS,2cS,32S,59S,5aB,5e,70S,71S,72,73S,7aS,81S,85S,86,98,"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.PlusInfo="1,5,0,6,0,6,0"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.PollNoReply="476"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.PollOk="37823"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.PollSettings="120"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.PollTxFail="1"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.SecurityFailed="0"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.SubscribedAlarms=",0x4,0x8,"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.SwitchMlSettings="2,0"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.VariablesGet="80,3,90,1,91,5,92,5,120,1,125,1,128,1,129,1,130,1,131,20,132,90,249,0,"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.VariablesSet="80-Status notification type,1d,3,90- Enable or Disable energy reporting (0-1),1d,1,91-Minimum change in wattage for a REPORT (0-60000),2d,5,92-Minimum change in wattage percent for a REPORT,1d,5,120-Configure external switch mode for S1(0-3),1d,1,125,1d,1,128-Current working mode (0-2),1d,1,129-Dimming principle (0-2),1d,1,130-Dimmer load type connected(0-3),1d,1,131-Minimum brightness level,1d,20,132-Maximum brightness level,1d,90,249,1d,0"
                      x_vera_svc_micasaverde_com_ZWaveDevice1.VersionInfo="3,4,54,2,0"
                      x_vera_svc_micasaverde_com_ZWaveNetwork1.ConsecutivePollFails="0"
                      x_vera_svc_micasaverde_com_ZWaveNetwork1.LastPollSuccess="1597268720"
                      x_vera_svc_upnp_org_Dimming1.LoadLevelLast="100"
                      x_vera_svc_upnp_org_Dimming1.LoadLevelStatus="0"
                      x_vera_svc_upnp_org_Dimming1.LoadLevelTarget="100"
                      x_vera_svc_upnp_org_Dimming1.TurnOnBeforeDim="0"
                      x_vera_svc_upnp_org_SwitchPower1.Status="0"
                      zwave_device.capabilities="211,156,1,4,17,1,L,R,B,RS,|37S,38S:3,39S,43S,44S,50S:3,89S,90B,94,112S,113S:4,114,115S,122S,129S,133S,134,152,"
                      zwave_device.failed=true
                      zwave_device.manufacturer_info="134,3,111"
                      zwave_device.node_id=53
                      zwave_device.version_info="3,4,54,2,0"
                      Capabilities: dimming, power_switch, toggle, x_vera_device, x_vera_energy, x_vera_svc_cd_jackson_com_DataMine1, x_vera_svc_micasaverde_com_Color1, x_vera_svc_micasaverde_com_EnergyMetering1, x_vera_svc_micasaverde_com_HaDevice1, x_vera_svc_micasaverde_com_ZWaveDevice1, x_vera_svc_micasaverde_com_ZWaveNetwork1, x_vera_svc_upnp_org_Dimming1, x_vera_svc_upnp_org_SwitchPower1, zwave_device
                      Actions: dimming.down, dimming.set, dimming.up, power_switch.off, power_switch.on, power_switch.set, toggle.toggle, x_vera_device.set_variable, x_vera_energy.resetkwh, x_vera_svc_micasaverde_com_Color1.SetColor, x_vera_svc_micasaverde_com_Color1.SetColorRGB, x_vera_svc_micasaverde_com_Color1.SetColorTemp, x_vera_svc_micasaverde_com_EnergyMetering1.ResetKWH, x_vera_svc_micasaverde_com_HaDevice1.AllowPairing, x_vera_svc_micasaverde_com_HaDevice1.Poll, x_vera_svc_micasaverde_com_HaDevice1.Reconfigure, x_vera_svc_micasaverde_com_HaDevice1.Remove, x_vera_svc_micasaverde_com_HaDevice1.SetPollFrequency, x_vera_svc_micasaverde_com_HaDevice1.StressTest, x_vera_svc_micasaverde_com_HaDevice1.ToggleState, x_vera_svc_micasaverde_com_ZWaveNetwork1.AddNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.BackupDongle, x_vera_svc_micasaverde_com_ZWaveNetwork1.DownloadNetwork, x_vera_svc_micasaverde_com_ZWaveNetwork1.HealNetwork, x_vera_svc_micasaverde_com_ZWaveNetwork1.PollAllNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.PutByte, x_vera_svc_micasaverde_com_ZWaveNetwork1.ReconfigureAllNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.RemoveNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.SendData, x_vera_svc_micasaverde_com_ZWaveNetwork1.SetPolling, x_vera_svc_micasaverde_com_ZWaveNetwork1.SimulateIncomingData, x_vera_svc_micasaverde_com_ZWaveNetwork1.UpdateNeighbors, x_vera_svc_micasaverde_com_ZWaveNetwork1.UpdateNetwork, x_vera_svc_upnp_org_Dimming1.PauseRamp, x_vera_svc_upnp_org_Dimming1.ResumeRamp, x_vera_svc_upnp_org_Dimming1.SetLoadLevelTarget, x_vera_svc_upnp_org_Dimming1.SetOnEffect, x_vera_svc_upnp_org_Dimming1.SetOnEffectLevel, x_vera_svc_upnp_org_Dimming1.SetRampRate, x_vera_svc_upnp_org_Dimming1.SetStepDelta, x_vera_svc_upnp_org_Dimming1.StartRampDown, x_vera_svc_upnp_org_Dimming1.StartRampToLevel, x_vera_svc_upnp_org_Dimming1.StartRampUp, x_vera_svc_upnp_org_Dimming1.StepDown, x_vera_svc_upnp_org_Dimming1.StepUp, x_vera_svc_upnp_org_Dimming1.StopRamp, x_vera_svc_upnp_org_SwitchPower1.SetTarget, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config
                        toggledbitsT Online
                        Perfect! Thank you. I think I see what's going on. New build coming later today...
                          @toggledbits thanks Patrick! Works nicely
                            How do I change my rule for devices with low batteries to use a dynamic array instead of the static manual array I am using currently ?
                            battery_device_list:
                            IanI 1 Reply Last reply
                              IanI Offline
                              IanI Offline
                              Ian
                              @cw-kid
                              The first expression produces an array that includes all battery powered entities across all controllers.
                              The second restricts the results to a specific controller.
                                Ian thank you. I thought it would be the battery_power capability, but I didn't know how to write that in an expression. I will try it now.
                                  #36
                                  I think this may work then, I just need to edit my existing rule:
                                  matchEntities ({controller: 'vera', capability: ['battery_power']})
                                  EDITED rule:
                                    EDITED rule:
                                    @cw-kid You could also do all that in one expression if you prefer and are not using the other ones for anything else.
                                    join(
                                      each id in matchEntities( { controller: 'vera', capability: 'battery_power' } ): do
                                        device=getEntity( id ),
                                        device.attributes.battery_power.level > 0.1 ? null : device.name + " at " + device.attributes.battery_power.level * 100 + " percent"
                                      done, ", " )
                                      join(
                                        done, ", " )
                                      @crille
                                      Great thank you, I will consider that.
                                        toggledbitsT Online
                                        #39
                                        Just a point here: why limit matchEntities() to one controller? Would you not perhaps want an alert for a device on any controller that has a low battery level?
                                        Also, don't forget about the format() function, which is meant for things like this...
                                            device.attributes.battery_power.level > 0.1 ? null : format( "{} at {:.1%}", device.name, device.attributes.battery_power.level )
                                        Oh, and in my home, any battery-operated device would be long dead if it was reporting 10% (0.1). Most of mine seem to start to malfunction below 50%.
                                          @toggledbits I'm trying to understand the pros and cons of using this vs the new DynamicGroupController, could you give a short summation?
                                          wmarcolinW 1 Reply Last reply
                                            149.8k
