  4. Rule for devices battery level ?
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
43 Posts 6 Posters 17.2k Views 7 Watching
  • IanI Ian
    @cw-kid
    Try this.
    @ian
    Thanks Ian that works, my Telegram text message now has the number% at the end of the message now.
    However this messes up the Google Home TTS announcement sent via node-red, if I have a "%" in the expression. So I had to change it to the word "percent" instead and now the TTS sounds correct when spoken.
    join( each id in battery_low_list: getEntity(id).name + " " + "at" + " " + int(getEntity(id).attributes.battery_power.level * 100) + " percent", ', ')
      @cw-kid said in Rule for devices battery level ?:
      How can I make this rule re-trigger ?
      Wrap the condition in a group and put the group in "pulse" output mode with the timing you want.
      Also can the alerts also state what the battery level percentage actually is ?
      Yes, but I'm going to leave it as an exercise for the reader. Level of difficulty: moderate.
      @toggledbits said in Rule for devices battery level ?:
      Like this?
      Seems to be working and the alerts are repeating every 60 seconds now. I will just set this to 24hrs I think.
        @cw-kid One of my to-do list tasks for expressions is to be able to create a list of devices that match a test. Until that comes, you can just build your own array of battery-operated devices like this (lets call this battery_device_list) :
        Then, you can reduce that list to all of the devices that have battery < 10%:
        That leaves you with an array of the entities that have low battery. Use another expression to convert that into a comma-separated list of entity names:
        Your rule just checks to see if that battery_low_names (a string now) expression is not empty, and runs whatever notifications you want to run if it is not. You can include the battery_low_names variable in the text of your email or other notification, too.
        This is very useful, is it released yet or still on the to-do list?
          Still on the to-do list, but I think I'm close to figuring out what I want it to do. These things get harder with time: the more people use them, the more etched in stone they become, so making a "first guess" and completely changing things later isn't really something I want to do a lot of. If I can get something good on the first try, that's the way...
          Here's what I'm thinking...
          First, the matchEntities() function would quickly narrow down the set, in a manner similar to the filters on the Entities page and the Entity Picker:
              living_room_sensors = matchEntities( { controller: 'vera', capability: [ 'binary_sensor', 'value_sensor'' ], group: 'Living Room' } )
          This would return an array of entities. From here, you could use an each statement to further filter any deep refinements. This expression would take the above array of sensors in the Living Room and pick out those that are battery powered and have battery level under 50%:
              low_battery_living_room = each e in living_room_sensors: e.attributes.battery_power?.level <= 0.5 ? e : null
          I'm liking this approach because the function could do the bulk reduction of potential hundreds of entities down to a manageable list, and then the final filtering of the list can be done with expressions for maximum flexibility.
          Any thoughts about that?
            @toggledbits That would do it for me, is the matchEntities() function already available in Expressions? I get no error but no matter what I do the Expression always returns an empty array.
            I'd expect this to contain at least something:
            matchEntities( { controller: 'vera', capability: 'humidity_sensor' } )
              No, it's not yet available.
              CrilleC tunnusT 2 Replies Last reply
                Ah, that explains a lot 🙂 I like the idea, it seems very flexible.
                  @toggledbits Thanks, the new matchEntities() is brilliant. Now we can have dynamic arrays of devices.
                    @crille said in Rule for devices battery level ?:
                    Tell me about that...
                      @toggledbits Inspired by this topic I created a rule with similar expressions to monitor/notify x_ezlo_device.reachable for all my Ezlo devices. Instead of managing a static array, like the battery_device_list in this topic, the expression matchEntities( {capability: 'x_ezlo_device'} ) generates a list of devices that is dynamically updated if devices are added or removed from the controller.
                        @toggledbits I'm testing this new function, but somehow it does not show all the devices I'm expecting it to show. See examples below
                        Array is empty, although it should contain one device:
                        Strange, as device 216 definitely has capability "x_vera_device"
                          One of the issues I see in matchEntities() as it currently works is that it returns an array of entity objects with attribute values, but it does not update that array when any of the returned entities' attributes or other values changes. So it's certain, then, that the attributes will go stale in the result array.
                          For the next build, I will change the definition of this function to return canonical entity IDs only, rather than entity objects, so you will have to use getEntity() in your each over the results, as you did with your test_array example, and this will ensure that you are always looking at the latest attributes. You can test this theory now by modifying your each for d_failure_list to use getEntity( id.canonical_id ).
                            @toggledbits did what you suggested, but situation didn't really change, array is still empty:
                              Can you show the entity detail for device 216 please?
                                #29
                                @tunnus I had some issues as well. I got an empty array and when tried getEntity() I got some "Type Error". Was sure I was doing something wrong but I restarted Reactor and copied the same expression to a new one and suddenly it worked.
                                @toggledbits I also noticed the array isn't updated when entity changed so I pulse the trigger every minute to update it. Will change to getEntity() for next update.
                                  @toggledbits here you go:
                                  dimming.level=0
                                  dimming.step=null
                                  power_switch.state=false
                                  x_vera_device.configured=false
                                  x_vera_device.device_number=216
                                  x_vera_device.device_type="urn:schemas-upnp-org:device:DimmableLight:1"
                                  x_vera_device.failed=true
                                  x_vera_device.mapped_by="*;device_type=/urn:schemas-upnp-org:device:DimmableLight:/"
                                  x_vera_device.mapped_class="generic_dimmer"
                                  x_vera_device.parent_device=1
                                  x_vera_device.room_id="1"
                                  x_vera_energy.amps=null
                                  x_vera_energy.day_kwh=null
                                  x_vera_energy.kwh="6.7000"
                                  x_vera_energy.life_kwh=null
                                  x_vera_energy.month_kwh=null
                                  x_vera_energy.power_factor=null
                                  x_vera_energy.volts=null
                                  x_vera_energy.watts=""
                                  x_vera_energy.week_kwh=null
                                  x_vera_energy.year_kwh=null
                                  x_vera_svc_cd_jackson_com_DataMine1.errorStatus="true"
                                  x_vera_svc_micasaverde_com_EnergyMetering1.ActualUsage="1"
                                  x_vera_svc_micasaverde_com_EnergyMetering1.KWH="6.7000"
                                  x_vera_svc_micasaverde_com_EnergyMetering1.KWHReading="1597268716"
                                  x_vera_svc_micasaverde_com_EnergyMetering1.Log="0,0,0,1633073400,1"
                                  x_vera_svc_micasaverde_com_EnergyMetering1.Watts=""
                                  x_vera_svc_micasaverde_com_HaDevice1.AutoConfigure="0"
                                  x_vera_svc_micasaverde_com_HaDevice1.CommFailure="1"
                                  x_vera_svc_micasaverde_com_HaDevice1.CommFailureAlarm="1628783888,1"
                                  x_vera_svc_micasaverde_com_HaDevice1.CommFailureTime="1628780288"
                                  x_vera_svc_micasaverde_com_HaDevice1.Configured="0"
                                  x_vera_svc_micasaverde_com_HaDevice1.FirstConfigured="1526668133"
                                  x_vera_svc_micasaverde_com_HaDevice1.LastTimeCheck="1605041801"
                                  x_vera_svc_micasaverde_com_HaDevice1.LastTimeOffset="2"
                                  x_vera_svc_micasaverde_com_HaDevice1.LastUpdate="0"
                                  x_vera_svc_micasaverde_com_HaDevice1.ModeSetting="1:;2:;3:;4:"
                                  x_vera_svc_micasaverde_com_HaDevice1.PollRatings="0.20"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.AgiInfo="X"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.AlarmType="0x4,0x8,"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.AlarmVersion="0,2"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.AssociationGroups="1"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.AssociationNum="4"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.Capabilities="211,156,1,4,17,1,L,R,B,RS,|37S,38S:3,39S,43S,44S,50S:3,89S,90B,94,112S,113S:4,114,115S,122S,129S,133S,134,152,"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.ConfiguredAssoc=""
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.ConfiguredVariable="80-Status notification type,1d,3,90- Enable or Disable energy reporting (0-1),1d,1,91-Minimum change in wattage for a REPORT (0-60000),2d,5,92-Minimum change in wattage percent for a REPORT,1d,5,120-Configure external switch mode for S1(0-3),1d,1,125,1d,1,128-Current working mode (0-2),1d,1,129-Dimming principle (0-2),1d,1,130-Dimmer load type connected(0-3),1d,1,131-Minimum brightness level,1d,20,132-Maximum brightness level,1d,90,249,1d,0"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.FirmwareInfo="134,111,41841"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.LastArr=""
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.LastNnu=""
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.LastReset="1526668110"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.LastRouteUpdate="1597229741"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.ManufacturerInfo="134,3,111"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.MeterScale="5"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.MeterType="1"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.NodeInfo="25S,26S,27S,2bS,2cS,32S,59S,5aB,5e,70S,71S,72,73S,7aS,81S,85S,86,98,"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.PlusInfo="1,5,0,6,0,6,0"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.PollNoReply="476"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.PollOk="37823"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.PollSettings="120"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.PollTxFail="1"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.SecurityFailed="0"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.SubscribedAlarms=",0x4,0x8,"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.SwitchMlSettings="2,0"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.VariablesGet="80,3,90,1,91,5,92,5,120,1,125,1,128,1,129,1,130,1,131,20,132,90,249,0,"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.VariablesSet="80-Status notification type,1d,3,90- Enable or Disable energy reporting (0-1),1d,1,91-Minimum change in wattage for a REPORT (0-60000),2d,5,92-Minimum change in wattage percent for a REPORT,1d,5,120-Configure external switch mode for S1(0-3),1d,1,125,1d,1,128-Current working mode (0-2),1d,1,129-Dimming principle (0-2),1d,1,130-Dimmer load type connected(0-3),1d,1,131-Minimum brightness level,1d,20,132-Maximum brightness level,1d,90,249,1d,0"
                                  x_vera_svc_micasaverde_com_ZWaveDevice1.VersionInfo="3,4,54,2,0"
                                  x_vera_svc_micasaverde_com_ZWaveNetwork1.ConsecutivePollFails="0"
                                  x_vera_svc_micasaverde_com_ZWaveNetwork1.LastPollSuccess="1597268720"
                                  x_vera_svc_upnp_org_Dimming1.LoadLevelLast="100"
                                  x_vera_svc_upnp_org_Dimming1.LoadLevelStatus="0"
                                  x_vera_svc_upnp_org_Dimming1.LoadLevelTarget="100"
                                  x_vera_svc_upnp_org_Dimming1.TurnOnBeforeDim="0"
                                  x_vera_svc_upnp_org_SwitchPower1.Status="0"
                                  zwave_device.capabilities="211,156,1,4,17,1,L,R,B,RS,|37S,38S:3,39S,43S,44S,50S:3,89S,90B,94,112S,113S:4,114,115S,122S,129S,133S,134,152,"
                                  zwave_device.failed=true
                                  zwave_device.manufacturer_info="134,3,111"
                                  zwave_device.node_id=53
                                  zwave_device.version_info="3,4,54,2,0"
                                  Capabilities: dimming, power_switch, toggle, x_vera_device, x_vera_energy, x_vera_svc_cd_jackson_com_DataMine1, x_vera_svc_micasaverde_com_Color1, x_vera_svc_micasaverde_com_EnergyMetering1, x_vera_svc_micasaverde_com_HaDevice1, x_vera_svc_micasaverde_com_ZWaveDevice1, x_vera_svc_micasaverde_com_ZWaveNetwork1, x_vera_svc_upnp_org_Dimming1, x_vera_svc_upnp_org_SwitchPower1, zwave_device
                                  Actions: dimming.down, dimming.set, dimming.up, power_switch.off, power_switch.on, power_switch.set, toggle.toggle, x_vera_device.set_variable, x_vera_energy.resetkwh, x_vera_svc_micasaverde_com_Color1.SetColor, x_vera_svc_micasaverde_com_Color1.SetColorRGB, x_vera_svc_micasaverde_com_Color1.SetColorTemp, x_vera_svc_micasaverde_com_EnergyMetering1.ResetKWH, x_vera_svc_micasaverde_com_HaDevice1.AllowPairing, x_vera_svc_micasaverde_com_HaDevice1.Poll, x_vera_svc_micasaverde_com_HaDevice1.Reconfigure, x_vera_svc_micasaverde_com_HaDevice1.Remove, x_vera_svc_micasaverde_com_HaDevice1.SetPollFrequency, x_vera_svc_micasaverde_com_HaDevice1.StressTest, x_vera_svc_micasaverde_com_HaDevice1.ToggleState, x_vera_svc_micasaverde_com_ZWaveNetwork1.AddNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.BackupDongle, x_vera_svc_micasaverde_com_ZWaveNetwork1.DownloadNetwork, x_vera_svc_micasaverde_com_ZWaveNetwork1.HealNetwork, x_vera_svc_micasaverde_com_ZWaveNetwork1.PollAllNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.PutByte, x_vera_svc_micasaverde_com_ZWaveNetwork1.ReconfigureAllNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.RemoveNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.SendData, x_vera_svc_micasaverde_com_ZWaveNetwork1.SetPolling, x_vera_svc_micasaverde_com_ZWaveNetwork1.SimulateIncomingData, x_vera_svc_micasaverde_com_ZWaveNetwork1.UpdateNeighbors, x_vera_svc_micasaverde_com_ZWaveNetwork1.UpdateNetwork, x_vera_svc_upnp_org_Dimming1.PauseRamp, x_vera_svc_upnp_org_Dimming1.ResumeRamp, x_vera_svc_upnp_org_Dimming1.SetLoadLevelTarget, x_vera_svc_upnp_org_Dimming1.SetOnEffect, x_vera_svc_upnp_org_Dimming1.SetOnEffectLevel, x_vera_svc_upnp_org_Dimming1.SetRampRate, x_vera_svc_upnp_org_Dimming1.SetStepDelta, x_vera_svc_upnp_org_Dimming1.StartRampDown, x_vera_svc_upnp_org_Dimming1.StartRampToLevel, x_vera_svc_upnp_org_Dimming1.StartRampUp, x_vera_svc_upnp_org_Dimming1.StepDown, x_vera_svc_upnp_org_Dimming1.StepUp, x_vera_svc_upnp_org_Dimming1.StopRamp, x_vera_svc_upnp_org_SwitchPower1.SetTarget, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config
                                    Perfect! Thank you. I think I see what's going on. New build coming later today...
                                      @toggledbits thanks Patrick! Works nicely
                                        How do I change my rule for devices with low batteries to use a dynamic array instead of the static manual array I am using currently ?
                                        battery_device_list:
                                        IanI 1 Reply Last reply
                                          IanI Offline
                                          IanI Offline
                                          Ian
                                          @cw-kid
                                          The first expression produces an array that includes all battery powered entities across all controllers.
                                          The second restricts the results to a specific controller.
                                            162.3k
