  4. Rule for devices battery level ?
43 Posts 6 Posters 16.1k Views 7 Watching
    @cw-kid One of my to-do list tasks for expressions is to be able to create a list of devices that match a test. Until that comes, you can just build your own array of battery-operated devices like this (lets call this battery_device_list) :
    Then, you can reduce that list to all of the devices that have battery < 10%:
    That leaves you with an array of the entities that have low battery. Use another expression to convert that into a comma-separated list of entity names:
    Your rule just checks to see if that battery_low_names (a string now) expression is not empty, and runs whatever notifications you want to run if it is not. You can include the battery_low_names variable in the text of your email or other notification, too.
    Thanks for the detailed reply. I will try and follow your suggestions.
    So would these expressions be Global ones? Or ones within the rule?
    Also as you don't natively support Telegram messenger I am not sure how I could insert the name of the device in to a HTTP request.
      Its working I think, I set up the expressions as Global ones.
      And my rules trigger is Expression value > battery_low_names > is NOT Null
      As a test I have used the MSR internal Alert in the rules reaction
      But I don't think I can insert ${{ battery_low_names }} in to a HTTP request for either Telegram messenger or TTS to Google Home speaker via Node-Red etc.
      IanI 1 Reply Last reply
        IanI Offline
        IanI Offline
        Ian
        @cw-kid
        This works for me - having previously set up the accounts at CallMeBot.
        The Request URL is: http://api.callmebot.com/text.php?source=web&user=@username&text=${{message}}
        It just sends a text that is the content of message.
        • IanI Ian
          @cw-kid
          @ian
          Ian many thanks that is actually working for both of my HTTP requests.
          So now the Google Home Speakers says "Check Battery Level of X device name" and the Telegram text message also works stating the same.
          Cheers
            I seem to have a problem with my trigger however
            Its triggering the reaction when I don't want it to do so.
            I need to make the value of the expression "battery_low_names" null when no devices are below the battery level of 10% etc.
            I've tried adding in a ? in to the expression but it doesn't seem to be working
            join( each id in battery_low_list: getEntity(id)?.name, ', ')
            EDIT:
            This seems to work instead adding "? id: null" to the end of the expression.
            join( each id in battery_low_list: getEntity(id).name, ', ') ? id: null
            EDIT 2:
            Maybe it doesn't work because now its not putting in the devices name in the expression value
            EDIT 3:
            I then tried changing the trigger altogether to this, but it doesn't work and becomes true anyway.
            Likewise with this one:
            Maybe there is a bug? All of these are going true and running the reaction when I expect them not to do that
              EDIT:
              EDIT 2:
              EDIT 3:
              IanI Offline
              IanI Offline
              Ian
              @cw-kid
              I'm using this.
              This goes true when battery_low_names is populated with the names of the devices with low battery levels.
              • IanI Ian
                @cw-kid
                I'm using this.
                @ian
                That works !
                Easy when you know how..
                The trigger is now going false when no devices are in the battery_low_names expression results.
                  @toggledbits said in Rule for devices battery level ?:
                  Details.
                  Also these can be rule expressions, they do not need to be global.
                    Thanks I've changed the expressions to local rule ones instead and its all still working.
                      How can I make this rule re-trigger ?
                      Say I don't immediate go replace the battery on the device mentioned, can I have the rule run the alerts / notifications each day or week until I have done it and changed the batteries ?
                      Also can the alerts also state what the battery level percentage actually is ?
                      toggledbitsT IanI 2 Replies Last reply
                        @cw-kid said in Rule for devices battery level ?:
                        Wrap the condition in a group and put the group in "pulse" output mode with the timing you want.
                        Yes, but I'm going to leave it as an exercise for the reader. Level of difficulty: moderate.
                          IanI Offline
                          IanI Offline
                          Ian
                          @cw-kid
                          Try this.
                          • IanI Ian
                            @cw-kid
                            Try this.
                            @ian
                            Thanks Ian that works, my Telegram text message now has the number% at the end of the message now.
                            However this messes up the Google Home TTS announcement sent via node-red, if I have a "%" in the expression. So I had to change it to the word "percent" instead and now the TTS sounds correct when spoken.
                            join( each id in battery_low_list: getEntity(id).name + " " + "at" + " " + int(getEntity(id).attributes.battery_power.level * 100) + " percent", ', ')
                              Like this?
                              Seems to be working and the alerts are repeating every 60 seconds now. I will just set this to 24hrs I think.
                                This is very useful, is it released yet or still on the to-do list?
                                  Still on the to-do list, but I think I'm close to figuring out what I want it to do. These things get harder with time: the more people use them, the more etched in stone they become, so making a "first guess" and completely changing things later isn't really something I want to do a lot of. If I can get something good on the first try, that's the way...
                                  Here's what I'm thinking...
                                  First, the matchEntities() function would quickly narrow down the set, in a manner similar to the filters on the Entities page and the Entity Picker:
                                      living_room_sensors = matchEntities( { controller: 'vera', capability: [ 'binary_sensor', 'value_sensor'' ], group: 'Living Room' } )
                                  This would return an array of entities. From here, you could use an each statement to further filter any deep refinements. This expression would take the above array of sensors in the Living Room and pick out those that are battery powered and have battery level under 50%:
                                      low_battery_living_room = each e in living_room_sensors: e.attributes.battery_power?.level <= 0.5 ? e : null
                                  I'm liking this approach because the function could do the bulk reduction of potential hundreds of entities down to a manageable list, and then the final filtering of the list can be done with expressions for maximum flexibility.
                                  Any thoughts about that?
                                    @toggledbits That would do it for me, is the matchEntities() function already available in Expressions? I get no error but no matter what I do the Expression always returns an empty array.
                                    I'd expect this to contain at least something:
                                    matchEntities( { controller: 'vera', capability: 'humidity_sensor' } )
                                      No, it's not yet available.
                                      CrilleC tunnusT 2 Replies Last reply
                                        Ah, that explains a lot 🙂 I like the idea, it seems very flexible.
                                          @toggledbits Thanks, the new matchEntities() is brilliant. Now we can have dynamic arrays of devices.
                                            149.8k
