  4. Rule for devices battery level ?
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
43 Posts 6 Posters 8.5k Views 7 Watching
    Wanted to create a rule for monitoring the battery level of Z-Wave devices on my Vera hub.
    I can select the battery level as the trigger OK.
    But not sure how to handle the Reaction to send an alert / notification ?
    If in the triggers I have multiple devices monitored for their battery level
    How could I create say a TTS announcement or text alert that mentions the name of the device who's battery level has dropped below 10% ? The device that has triggered the rule.
    I'd rather not have to create an individual rule for each device etc.
      @cw-kid One of my to-do list tasks for expressions is to be able to create a list of devices that match a test. Until that comes, you can just build your own array of battery-operated devices like this (lets call this battery_device_list) :
      Then, you can reduce that list to all of the devices that have battery < 10%:
      That leaves you with an array of the entities that have low battery. Use another expression to convert that into a comma-separated list of entity names:
      Your rule just checks to see if that battery_low_names (a string now) expression is not empty, and runs whatever notifications you want to run if it is not. You can include the battery_low_names variable in the text of your email or other notification, too.
      cw-kidC toggledbitsT CrilleC 3 Replies Last reply
        Thanks for the detailed reply. I will try and follow your suggestions.
        So would these expressions be Global ones? Or ones within the rule?
        Also as you don't natively support Telegram messenger I am not sure how I could insert the name of the device in to a HTTP request.
          Its working I think, I set up the expressions as Global ones.
          And my rules trigger is Expression value > battery_low_names > is NOT Null
          As a test I have used the MSR internal Alert in the rules reaction
          But I don't think I can insert ${{ battery_low_names }} in to a HTTP request for either Telegram messenger or TTS to Google Home speaker via Node-Red etc.
          IanI 1 Reply Last reply
            IanI Offline
            IanI Offline
            Ian
            @cw-kid
            This works for me - having previously set up the accounts at CallMeBot.
            The Request URL is: http://api.callmebot.com/text.php?source=web&user=@username&text=${{message}}
            It just sends a text that is the content of message.
            • IanI Ian
              @cw-kid
              @ian
              Ian many thanks that is actually working for both of my HTTP requests.
              So now the Google Home Speakers says "Check Battery Level of X device name" and the Telegram text message also works stating the same.
              Cheers
                I seem to have a problem with my trigger however
                Its triggering the reaction when I don't want it to do so.
                I need to make the value of the expression "battery_low_names" null when no devices are below the battery level of 10% etc.
                I've tried adding in a ? in to the expression but it doesn't seem to be working
                join( each id in battery_low_list: getEntity(id)?.name, ', ')
                EDIT:
                This seems to work instead adding "? id: null" to the end of the expression.
                join( each id in battery_low_list: getEntity(id).name, ', ') ? id: null
                EDIT 2:
                Maybe it doesn't work because now its not putting in the devices name in the expression value
                EDIT 3:
                I then tried changing the trigger altogether to this, but it doesn't work and becomes true anyway.
                Likewise with this one:
                Maybe there is a bug? All of these are going true and running the reaction when I expect them not to do that
                  EDIT:
                  EDIT 2:
                  EDIT 3:
                  IanI Offline
                  IanI Offline
                  Ian
                  @cw-kid
                  I'm using this.
                  This goes true when battery_low_names is populated with the names of the devices with low battery levels.
                  • IanI Ian
                    @cw-kid
                    I'm using this.
                    @ian
                    That works !
                    Easy when you know how..
                    The trigger is now going false when no devices are in the battery_low_names expression results.
                      @toggledbits said in Rule for devices battery level ?:
                      Details.
                      Also these can be rule expressions, they do not need to be global.
                        Thanks I've changed the expressions to local rule ones instead and its all still working.
                          How can I make this rule re-trigger ?
                          Say I don't immediate go replace the battery on the device mentioned, can I have the rule run the alerts / notifications each day or week until I have done it and changed the batteries ?
                          Also can the alerts also state what the battery level percentage actually is ?
                          toggledbitsT IanI 2 Replies Last reply
                            @cw-kid said in Rule for devices battery level ?:
                            Wrap the condition in a group and put the group in "pulse" output mode with the timing you want.
                            Yes, but I'm going to leave it as an exercise for the reader. Level of difficulty: moderate.
                              IanI Offline
                              IanI Offline
                              Ian
                              @cw-kid
                              Try this.
                              • IanI Ian
                                @cw-kid
                                Try this.
                                @ian
                                Thanks Ian that works, my Telegram text message now has the number% at the end of the message now.
                                However this messes up the Google Home TTS announcement sent via node-red, if I have a "%" in the expression. So I had to change it to the word "percent" instead and now the TTS sounds correct when spoken.
                                join( each id in battery_low_list: getEntity(id).name + " " + "at" + " " + int(getEntity(id).attributes.battery_power.level * 100) + " percent", ', ')
                                  Like this?
                                  Seems to be working and the alerts are repeating every 60 seconds now. I will just set this to 24hrs I think.
                                    This is very useful, is it released yet or still on the to-do list?
                                      Still on the to-do list, but I think I'm close to figuring out what I want it to do. These things get harder with time: the more people use them, the more etched in stone they become, so making a "first guess" and completely changing things later isn't really something I want to do a lot of. If I can get something good on the first try, that's the way...
                                      Here's what I'm thinking...
                                      First, the matchEntities() function would quickly narrow down the set, in a manner similar to the filters on the Entities page and the Entity Picker:
                                          living_room_sensors = matchEntities( { controller: 'vera', capability: [ 'binary_sensor', 'value_sensor'' ], group: 'Living Room' } )
                                      This would return an array of entities. From here, you could use an each statement to further filter any deep refinements. This expression would take the above array of sensors in the Living Room and pick out those that are battery powered and have battery level under 50%:
                                          low_battery_living_room = each e in living_room_sensors: e.attributes.battery_power?.level <= 0.5 ? e : null
                                      I'm liking this approach because the function could do the bulk reduction of potential hundreds of entities down to a manageable list, and then the final filtering of the list can be done with expressions for maximum flexibility.
                                      Any thoughts about that?
                                        @toggledbits That would do it for me, is the matchEntities() function already available in Expressions? I get no error but no matter what I do the Expression always returns an empty array.
                                        I'd expect this to contain at least something:
                                        matchEntities( { controller: 'vera', capability: 'humidity_sensor' } )
                                          No, it's not yet available.
                                          CrilleC tunnusT 2 Replies Last reply
                                            330
                                          • Self test
                                          • Possible feature request 2?
