  4. Removed Devices and Scenes on Ezlo Plus remain in MSR
8 Posts 3 Posters 1.9k Views 3 Watching
    Hi
    I am noticing Entities in MSR that came from my Ezlo Plus that no longer exist on the Ezlo Plus controller.
    For example devices and scenes I have previously deleted off the Ezlo Plus controller, can still be seen in the Entities list in MSR.
    Does MSR not automatically also remove these ?
    Thank you.
      I've gone right through the Entities list in MSR and I cannot find anymore items that I know have since been deleted off the Ezlo Plus Controller.
      The ones I did find were a Fibaro Wall Plug that had two entries. I had issues with it on the Ezlo hub it stopped working for some reason so I unpaired it and paired it again on the Ezlo hub which fixed the issue, but then in MSR I had two of them. I manually deleted the old one from MSR with the now none existent device ID etc.
      Like wise I had a similar thing happen with a Zigbee Centralite Door sensor, that I had to delete and then add again on to the Ezlo hub and I also ended up with two entities for that device in MSR.
        Just looking at Entities now under my Vera Plus hub and I can see some older instances of devices that have a strike through them.
        I can manually now delete these from MSR. So looks like it doesn't auto delete them for me.
        Also I don't recall ever seeing any devices with strikes through them whilst looking at the Entities on the Ezlo Plus hub.
          Just seen these in the Entities list came from the Ezlo Plus controller.
          These were some test virtual devices I added to the Ezlo Plus but I know that they have all since been deleted off the Ezlo Plus controller. Yet they remain in MSR.
            I believe entities that are deleted in your controller auto-delete after 24 hours
              Them test virtual devices I highlighted have been deleted off my Ezlo Plus for way more than 24 hours. I am not too fussed about it auto deleting things from MSR, but if at least it put a strike through the devices and scenes that no longer exist on the controller, I could then easily tell which entities to manually delete.
              With the Vera Plus hub it does seem to strike them through. But for entities coming from the Ezlo Plus hub it does not it seems.
              • cw-kidC cw-kid
                @cw-kid @Pabla is correct, except that dead entity detection and purging has not yet been done for EzloController as it has for all other controllers. For the moment, you must delete any dead entities manually. Another release or two before this is remedied.
                  Thanks Patrick.
                    160.0k
