  3. Mosquitto and Owntracks
Software
Software
Software
Software
Software
BlueIris
Software
MyQ
Software
Software
Software
Software
Software
Light automation thoughts
Software
SnowmanS
Software
SnowmanS
Software
Any thoughts on this? OpenLuup / MSR on bare metal Debian Bullseye. The heating normally comes on an hour before the radio, this morning that was 0430. Normally this works perfectly and has done for many weeks. This morning though, something odd: Device in question is 20300. In shot, MSR correctly triggered and changed the setpoint to 21 at 2023-01-16T04:30:00.147Z But at 2023-01-16 04:31:51.128 OpenLuup has reset the set point to 18. More than prepared to accept this as a glitch, but curious as to any thoughts? Reactor log: [latest-23010]2023-01-16T04:29:11.701Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.70.70: GET /api/v1/systime [latest-23010]2023-01-16T04:30:00.002Z <Rule:INFO> Morning Lights are on (rule-l6gxvycu in Outside Lights) starting evaluation; because timer-trigger Timer#rule-l6gxvycu [latest-23010]2023-01-16T04:30:00.005Z <Rule:INFO> Morning Lights are on (rule-l6gxvycu in Outside Lights) trigger evaluation result is true (previously false) [latest-23010]2023-01-16T04:30:00.005Z <Rule:INFO> Morning Lights are on (rule-l6gxvycu in Outside Lights) evaluated; rule state transition from RESET to SET! [latest-23010]2023-01-16T04:30:00.022Z <Rule:INFO> Morning Lights are on (rule-l6gxvycu in Outside Lights) evaluation complete [latest-23010]2023-01-16T04:30:00.022Z <Engine:INFO> Enqueueing "Morning Lights are on<SET>" (rule-l6gxvycu:S) [latest-23010]2023-01-16T04:30:00.023Z <Rule:INFO> Morning Heating (rule-l60fkpo3 in Heating Control) starting evaluation; because timer-trigger Timer#rule-l60fkpo3 [latest-23010]2023-01-16T04:30:00.025Z <Rule:INFO> Morning Heating (rule-l60fkpo3 in Heating Control) trigger evaluation result is true (previously false) [latest-23010]2023-01-16T04:30:00.025Z <Rule:INFO> Morning Heating (rule-l60fkpo3 in Heating Control) evaluated; rule state transition from RESET to SET! [latest-23010]2023-01-16T04:30:00.033Z <Rule:INFO> Morning Heating (rule-l60fkpo3 in Heating Control) evaluation complete [latest-23010]2023-01-16T04:30:00.034Z <Engine:INFO> Enqueueing "Morning Heating<SET>" (rule-l60fkpo3:S) [latest-23010]2023-01-16T04:30:00.035Z <Engine:NOTICE> Starting reaction Morning Lights are on<SET> (rule-l6gxvycu:S) [latest-23010]2023-01-16T04:30:00.036Z <Engine:NOTICE> Starting reaction Morning Heating<SET> (rule-l60fkpo3:S) [latest-23010]2023-01-16T04:30:00.037Z <Rule:INFO> Morning Lights are on (rule-l6gxvycu in Outside Lights) starting evaluation; because timer-trigger Timer#rule-l6gxvycu [latest-23010]2023-01-16T04:30:00.038Z <Rule:INFO> Morning Lights are on (rule-l6gxvycu in Outside Lights) trigger evaluation result is true (previously true) [latest-23010]2023-01-16T04:30:00.038Z <Rule:INFO> Morning Lights are on (rule-l6gxvycu in Outside Lights) evaluated; trigger state unchanged (true); rule state remains SET [latest-23010]2023-01-16T04:30:00.038Z <Rule:INFO> Morning Lights are on (rule-l6gxvycu in Outside Lights) evaluation complete [latest-23010]2023-01-16T04:30:00.038Z <Rule:INFO> Morning Heating (rule-l60fkpo3 in Heating Control) starting evaluation; because timer-trigger Timer#rule-l60fkpo3 [latest-23010]2023-01-16T04:30:00.040Z <Rule:INFO> Morning Heating (rule-l60fkpo3 in Heating Control) trigger evaluation result is true (previously true) [latest-23010]2023-01-16T04:30:00.040Z <Rule:INFO> Morning Heating (rule-l60fkpo3 in Heating Control) evaluated; trigger state unchanged (true); rule state remains SET [latest-23010]2023-01-16T04:30:00.040Z <Rule:INFO> Morning Heating (rule-l60fkpo3 in Heating Control) evaluation complete [latest-23010]2023-01-16T04:30:00.077Z <VeraController:NOTICE> VeraController#vera action power_switch.on([Object]{ }) on Switch#vera>device_20170 succeeded [latest-23010]2023-01-16T04:30:00.079Z <Engine:INFO> Resuming reaction Morning Lights are on<SET> (rule-l6gxvycu:S) from step 1 [latest-23010]2023-01-16T04:30:00.147Z <VeraController:NOTICE> VeraController#vera action x_vera_svc_upnp_org_TemperatureSetpoint1_Heat.SetCurrentSetpoint([Object]{ "NewCurrentSetpoint": "21" }) on Thermostat#vera>device_20300 succeeded [latest-23010]2023-01-16T04:30:00.147Z <Engine:INFO> Resuming reaction Morning Heating<SET> (rule-l60fkpo3:S) from step 2 [latest-23010]2023-01-16T04:30:00.212Z <VeraController:NOTICE> VeraController#vera action power_switch.on([Object]{ }) on Switch#vera>device_20090 succeeded [latest-23010]2023-01-16T04:30:00.213Z <Engine:INFO> Resuming reaction Morning Lights are on<SET> (rule-l6gxvycu:S) from step 2 [latest-23010]2023-01-16T04:30:00.214Z <Engine:INFO> Morning Lights are on<SET> all actions completed. [latest-23010]2023-01-16T04:30:00.274Z <VeraController:NOTICE> VeraController#vera action x_vera_svc_upnp_org_TemperatureSetpoint1_Heat.SetCurrentSetpoint([Object]{ "NewCurrentSetpoint": "22" }) on Thermostat#vera>device_20380 succeeded [latest-23010]2023-01-16T04:30:00.276Z <Engine:INFO> Resuming reaction Morning Heating<SET> (rule-l60fkpo3:S) from step 3 [latest-23010]2023-01-16T04:30:00.276Z <Engine:INFO> Morning Heating<SET> all actions completed. [latest-23010]2023-01-16T04:30:43.031Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.70.253: GET /api/v1/systime [latest-23010]2023-01-16T04:32:28.489Z <Rule:INFO> Office Heater On (rule-laku2z5a in Office Environment) starting evaluation; because entity-changed ValueSensor#vera>device_25002 [latest-23010]2023-01-16T04:32:28.490Z <Rule:INFO> Office Heater On (rule-laku2z5a in Office Environment) trigger evaluation result is false (previously false) [latest-23010]2023-01-16T04:32:28.491Z <Rule:INFO> Office Heater On (rule-laku2z5a in Office Environment) evaluated; trigger state unchanged (false); rule state remains RESET [latest-23010]2023-01-16T04:32:28.491Z <Rule:INFO> Office Heater On (rule-laku2z5a in Office Environment) evaluation complete [latest-23010]2023-01-16T04:32:37.103Z <Rule:INFO> Server Room Temperature Alert (rule-l5sbqlpf in Server Room Conditions) starting evaluation; because entity-changed ValueSensor#vera>device_25005 [latest-23010]2023-01-16T04:32:37.105Z <Rule:INFO> Server Room Temperature Alert (rule-l5sbqlpf in Server Room Conditions) trigger evaluation result is false (previously false) [latest-23010]2023-01-16T04:32:37.105Z <Rule:INFO> Server Room Temperature Alert (rule-l5sbqlpf in Server Room Conditions) evaluated; trigger state unchanged (false); rule state remains RESET [latest-23010]2023-01-16T04:32:37.106Z <Rule:INFO> Server Room Temperature Alert (rule-l5sbqlpf in Server Room Conditions) evaluation complete [latest-23010]2023-01-16T04:35:22.545Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.70.70: GET /api/v1/systime [latest-23010]2023-01-16T04:35:44.866Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.70.253: GET /api/v1/systime [latest-23010]2023-01-16T04:41:19.045Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.70.70: GET /api/v1/systime OpenLuup log: 2023-01-16 04:29:55.988 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ac768 2023-01-16 04:29:55.988 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31057384&MinimumDelay=50&output_format=json&_r=1673843395986 HTTP/1.1 tcp{client}: 0x563e8a4ac768 2023-01-16 04:30:00.037 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4f1498 2023-01-16 04:30:00.040 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20170&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1673843400036 HTTP/1.1 tcp{client}: 0x563e 8a4f1498 2023-01-16 04:30:00.041 luup.call_action:: 20170.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-16 04:30:00.041 luup.call_action:: action will be handled by parent: 37 2023-01-16 04:30:00.041 luup.variable_set:: 20170.urn:upnp-org:serviceId:SwitchPower1.Target was: 0 now: 1 #hooks:0 2023-01-16 04:30:00.075 openLuup.server:: request completed (35 bytes, 1 chunks, 34 ms) tcp{client}: 0x563e8a4f1498 2023-01-16 04:30:00.076 luup_log:0: 14Mb, 1.8%cpu, 9.4days 2023-01-16 04:30:00.080 openLuup.server:: request completed (2214 bytes, 1 chunks, 33328 ms) tcp{client}: 0x563e8a5edc38 2023-01-16 04:30:00.081 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4f1498 2023-01-16 04:30:00.104 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a001648 2023-01-16 04:30:00.105 openLuup.server:: GET /data_request?NewCurrentSetpoint=21&DeviceNum=20300&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ATemperatureSetpoint1_Heat&action=SetCurrentSetpoint&output_format=json&_r=1673843400103 H TTP/1.1 tcp{client}: 0x563e8a001648 2023-01-16 04:30:00.105 luup.call_action:: 20300.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.SetCurrentSetpoint 2023-01-16 04:30:00.106 luup.call_action:: action will be handled by parent: 37 2023-01-16 04:30:00.106 luup.variable_set:: 20300.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.CurrentSetpoint was: 18 now: 21 #hooks:0 2023-01-16 04:30:00.146 openLuup.server:: request completed (44 bytes, 1 chunks, 41 ms) tcp{client}: 0x563e8a001648 2023-01-16 04:30:00.148 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a001648 2023-01-16 04:30:00.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8907a7d8 2023-01-16 04:30:00.179 openLuup.server:: request completed (2466 bytes, 1 chunks, 34377 ms) tcp{client}: 0x563e89c31bd8 2023-01-16 04:30:00.179 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20090&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1673843400174 HTTP/1.1 tcp{client}: 0x563e 8907a7d8 2023-01-16 04:30:00.180 luup.call_action:: 20090.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-16 04:30:00.180 luup.call_action:: action will be handled by parent: 37 2023-01-16 04:30:00.180 luup.variable_set:: 20090.urn:upnp-org:serviceId:SwitchPower1.Target was: 0 now: 1 #hooks:0 2023-01-16 04:30:00.210 openLuup.server:: request completed (35 bytes, 1 chunks, 30 ms) tcp{client}: 0x563e8907a7d8 2023-01-16 04:30:00.222 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8907a7d8 2023-01-16 04:30:00.239 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89c4cbd8 2023-01-16 04:30:00.239 openLuup.server:: GET /data_request?NewCurrentSetpoint=22&DeviceNum=20380&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ATemperatureSetpoint1_Heat&action=SetCurrentSetpoint&output_format=json&_r=1673843400238 H TTP/1.1 tcp{client}: 0x563e89c4cbd8 2023-01-16 04:30:00.240 luup.call_action:: 20380.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.SetCurrentSetpoint 2023-01-16 04:30:00.240 luup.call_action:: action will be handled by parent: 37 2023-01-16 04:30:00.240 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.CurrentSetpoint was: 18 now: 22 #hooks:0 2023-01-16 04:30:00.273 openLuup.server:: request completed (44 bytes, 1 chunks, 33 ms) tcp{client}: 0x563e89c4cbd8 2023-01-16 04:30:00.286 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89c4cbd8 2023-01-16 04:30:00.390 openLuup.server:: request completed (2946 bytes, 1 chunks, 4401 ms) tcp{client}: 0x563e8a4ac768 2023-01-16 04:30:00.406 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ac768 2023-01-16 04:30:00.417 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89ec0a88 2023-01-16 04:30:00.418 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31057399&MinimumDelay=50&output_format=json&_r=1673843400417 HTTP/1.1 tcp{client}: 0x563e89ec0a88 2023-01-16 04:30:00.452 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=31057396&Timeout=60&MinimumDelay=1500&_=1671788900248 HTTP/1.1 tcp{client}: 0x563e8a5edc38 2023-01-16 04:30:00.555 openLuup.server:: request completed (1474 bytes, 1 chunks, 103 ms) tcp{client}: 0x563e8a5edc38 2023-01-16 04:30:00.658 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=31057397&Timeout=60&MinimumDelay=1500&_=1673519752390 HTTP/1.1 tcp{client}: 0x563e89c31bd8 2023-01-16 04:30:00.761 openLuup.server:: request completed (1222 bytes, 1 chunks, 103 ms) tcp{client}: 0x563e89c31bd8 2023-01-16 04:30:01.553 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=31057399&Timeout=60&MinimumDelay=1500&_=1671788900249 HTTP/1.1 tcp{client}: 0x563e8a5edc38 2023-01-16 04:30:01.900 luup.variable_set:: 20090.urn:upnp-org:serviceId:SwitchPower1.Status was: 0 now: 1 #hooks:0 2023-01-16 04:30:01.900 luup.variable_set:: 20160.urn:micasaverde-com:serviceId:EnergyMetering1.KWHReading was: 1673842201 now: 1673843401 #hooks:0 2023-01-16 04:30:01.900 luup.variable_set:: 20170.urn:micasaverde-com:serviceId:EnergyMetering1.Watts was: 0 now: 0.6 #hooks:0 2023-01-16 04:30:01.949 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=31057399&Timeout=60&MinimumDelay=1500&_=1673519752391 HTTP/1.1 tcp{client}: 0x563e89c31bd8 2023-01-16 04:30:02.052 openLuup.server:: request completed (1462 bytes, 1 chunks, 102 ms) tcp{client}: 0x563e89c31bd8 2023-01-16 04:30:02.256 openLuup.server:: request completed (1462 bytes, 1 chunks, 1837 ms) tcp{client}: 0x563e89ec0a88 2023-01-16 04:30:02.258 openLuup.server:: request completed (1462 bytes, 1 chunks, 705 ms) tcp{client}: 0x563e8a5edc38 2023-01-16 04:30:02.270 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89ec0a88 2023-01-16 04:30:02.281 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a33bfe8 2023-01-16 04:30:02.282 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31057402&MinimumDelay=50&output_format=json&_r=1673843402280 HTTP/1.1 tcp{client}: 0x563e8a33bfe8 2023-01-16 04:30:02.397 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=31057402&Timeout=60&MinimumDelay=1500&_=1671788900250 HTTP/1.1 tcp{client}: 0x563e8a5edc38 2023-01-16 04:30:02.839 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=31057402&Timeout=60&MinimumDelay=1500&_=1673519752392 HTTP/1.1 tcp{client}: 0x563e89c31bd8 2023-01-16 04:30:02.986 luup.variable_set:: 20170.urn:micasaverde-com:serviceId:EnergyMetering1.Watts was: 0.6 now: 35.5 #hooks:0 2023-01-16 04:30:03.092 openLuup.server:: request completed (983 bytes, 1 chunks, 694 ms) tcp{client}: 0x563e8a5edc38 2023-01-16 04:30:03.411 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=31057403&Timeout=60&MinimumDelay=1500&_=1671788900251 HTTP/1.1 tcp{client}: 0x563e8a5edc38 2023-01-16 04:30:03.515 openLuup.server:: request completed (983 bytes, 1 chunks, 1233 ms) tcp{client}: 0x563e8a33bfe8 2023-01-16 04:30:03.517 openLuup.server:: request completed (983 bytes, 1 chunks, 678 ms) tcp{client}: 0x563e89c31bd8 2023-01-16 04:30:03.524 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a33bfe8 2023-01-16 04:30:03.535 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89ff6ce8 2023-01-16 04:30:03.536 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31057403&MinimumDelay=50&output_format=json&_r=1673843403534 HTTP/1.1 tcp{client}: 0x563e89ff6ce8 2023-01-16 04:30:03.666 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=31057403&Timeout=60&MinimumDelay=1500&_=1673519752393 HTTP/1.1 tcp{client}: 0x563e89c31bd8 2023-01-16 04:30:10.455 luup.variable_set:: 20761.urn:micasaverde-com:serviceId:EnergyMetering1.KWHReading was: 1673842206 now: 1673843409 #hooks:0 2023-01-16 04:30:10.558 openLuup.server:: request completed (994 bytes, 1 chunks, 7022 ms) tcp{client}: 0x563e89ff6ce8 2023-01-16 04:30:10.565 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89ff6ce8 2023-01-16 04:30:10.577 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89de6688 2023-01-16 04:30:10.577 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31057404&MinimumDelay=50&output_format=json&_r=1673843410576 HTTP/1.1 tcp{client}: 0x563e89de6688 2023-01-16 04:30:10.681 openLuup.server:: request completed (994 bytes, 1 chunks, 7014 ms) tcp{client}: 0x563e89c31bd8 2023-01-16 04:30:10.985 openLuup.server:: request completed (994 bytes, 1 chunks, 7573 ms) tcp{client}: 0x563e8a5edc38 2023-01-16 04:30:11.520 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=31057404&Timeout=60&MinimumDelay=1500&_=1671788900252 HTTP/1.1 tcp{client}: 0x563e8a5edc38 2023-01-16 04:30:11.951 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=31057404&Timeout=60&MinimumDelay=1500&_=1673519752394 HTTP/1.1 tcp{client}: 0x563e89c31bd8 2023-01-16 04:30:12.597 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 19 now: 18 #hooks:0 2023-01-16 04:30:12.701 openLuup.server:: request completed (990 bytes, 1 chunks, 1180 ms) tcp{client}: 0x563e8a5edc38 2023-01-16 04:30:12.804 openLuup.server:: request completed (990 bytes, 1 chunks, 2226 ms) tcp{client}: 0x563e89de6688 2023-01-16 04:30:12.815 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89de6688 2023-01-16 04:30:12.825 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a027f48 2023-01-16 04:30:12.825 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31057405&MinimumDelay=50&output_format=json&_r=1673843412824 HTTP/1.1 tcp{client}: 0x563e8a027f48 2023-01-16 04:30:13.130 openLuup.server:: request completed (990 bytes, 1 chunks, 1178 ms) tcp{client}: 0x563e89c31bd8 2023-01-16 04:30:13.541 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=31057405&Timeout=60&MinimumDelay=1500&_=1671788900253 HTTP/1.1 tcp{client}: 0x563e8a5edc38 2023-01-16 04:30:13.816 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=31057405&Timeout=60&MinimumDelay=1500&_=1673519752395 HTTP/1.1 tcp{client}: 0x563e89c31bd8 2023-01-16 04:30:28.245 openLuup.server:: request completed (742 bytes, 1 chunks, 15419 ms) tcp{client}: 0x563e8a027f48 2023-01-16 04:30:28.249 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a027f48 2023-01-16 04:30:28.260 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a3dc468 2023-01-16 04:30:28.261 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31057405&MinimumDelay=50&output_format=json&_r=1673843428259 HTTP/1.1 tcp{client}: 0x563e8a3dc468 2023-01-16 04:30:41.166 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 18 now: 19 #hooks:0 2023-01-16 04:30:41.371 openLuup.server:: request completed (990 bytes, 1 chunks, 27554 ms) tcp{client}: 0x563e89c31bd8 2023-01-16 04:30:41.575 openLuup.server:: request completed (990 bytes, 1 chunks, 13313 ms) tcp{client}: 0x563e8a3dc468 2023-01-16 04:30:41.587 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a3dc468 2023-01-16 04:30:41.597 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8978cad8 2023-01-16 04:30:41.597 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31057406&MinimumDelay=50&output_format=json&_r=1673843441596 HTTP/1.1 tcp{client}: 0x563e8978cad8 2023-01-16 04:30:41.690 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=31057406&Timeout=60&MinimumDelay=1500&_=1673519752396 HTTP/1.1 tcp{client}: 0x563e89c31bd8 2023-01-16 04:30:41.693 openLuup.server:: request completed (990 bytes, 1 chunks, 28151 ms) tcp{client}: 0x563e8a5edc38 2023-01-16 04:30:42.608 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=31057406&Timeout=60&MinimumDelay=1500&_=1671788900254 HTTP/1.1 tcp{client}: 0x563e8a5edc38 2023-01-16 04:30:56.899 openLuup.server:: request completed (742 bytes, 1 chunks, 15301 ms) tcp{client}: 0x563e8978cad8 2023-01-16 04:30:56.903 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8978cad8 2023-01-16 04:30:56.915 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a23eac8 2023-01-16 04:30:56.915 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31057406&MinimumDelay=50&output_format=json&_r=1673843456913 HTTP/1.1 tcp{client}: 0x563e8a23eac8 2023-01-16 04:31:12.352 openLuup.server:: request completed (742 bytes, 1 chunks, 15436 ms) tcp{client}: 0x563e8a23eac8 2023-01-16 04:31:12.356 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a23eac8 2023-01-16 04:31:12.369 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e896b9828 2023-01-16 04:31:12.369 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31057406&MinimumDelay=50&output_format=json&_r=1673843472367 HTTP/1.1 tcp{client}: 0x563e896b9828 2023-01-16 04:31:21.364 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 19 now: 20 #hooks:0 2023-01-16 04:31:21.471 openLuup.server:: request completed (990 bytes, 1 chunks, 9101 ms) tcp{client}: 0x563e896b9828 2023-01-16 04:31:21.473 openLuup.server:: request completed (990 bytes, 1 chunks, 39782 ms) tcp{client}: 0x563e89c31bd8 2023-01-16 04:31:21.490 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e896b9828 2023-01-16 04:31:21.500 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a45b318 2023-01-16 04:31:21.500 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31057407&MinimumDelay=50&output_format=json&_r=1673843481499 HTTP/1.1 tcp{client}: 0x563e8a45b318 2023-01-16 04:31:21.653 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=31057407&Timeout=60&MinimumDelay=1500&_=1673519752397 HTTP/1.1 tcp{client}: 0x563e89c31bd8 2023-01-16 04:31:21.757 openLuup.server:: request completed (990 bytes, 1 chunks, 39149 ms) tcp{client}: 0x563e8a5edc38 2023-01-16 04:31:22.598 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=31057407&Timeout=60&MinimumDelay=1500&_=1671788900255 HTTP/1.1 tcp{client}: 0x563e8a5edc38 2023-01-16 04:31:36.943 openLuup.server:: request completed (742 bytes, 1 chunks, 15443 ms) tcp{client}: 0x563e8a45b318 2023-01-16 04:31:36.949 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a45b318 2023-01-16 04:31:36.959 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a85f578 2023-01-16 04:31:36.959 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31057407&MinimumDelay=50&output_format=json&_r=1673843496958 HTTP/1.1 tcp{client}: 0x563e8a85f578 2023-01-16 04:31:51.128 luup.variable_set:: 20300.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.CurrentSetpoint was: 21 now: 18 #hooks:0 2023-01-16 04:31:51.233 openLuup.server:: request completed (994 bytes, 1 chunks, 28634 ms) tcp{client}: 0x563e8a5edc38 2023-01-16 04:31:51.337 openLuup.server:: request completed (994 bytes, 1 chunks, 29683 ms) tcp{client}: 0x563e89c31bd8 2023-01-16 04:31:51.339 openLuup.server:: request completed (994 bytes, 1 chunks, 14379 ms) tcp{client}: 0x563e8a85f578 2023-01-16 04:31:51.347 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a85f578 2023-01-16 04:31:51.359 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8985dd28 TIA C
Software
Zigbee2MQTT
Software
All great stuff going on One thing I am wondering about is is it possible to view the entire payload coming from Owntracks at all? Reason I ask is that my iPhone has changed its string_sensor.value to null even though we are snowed in. This obviously trips the binary sensor to off. The sensor entity I have set to owntracks_in_region however remains true. The change happened at 0523 this morning (UTC) when I was still asleep: [latest-22337]2022-12-13T05:19:13.053Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.70.70: GET /api/v1/systime [latest-22337]2022-12-13T05:22:05.883Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.70.253: GET /api/v1/systime [latest-22337]2022-12-13T05:23:01.087Z <MQTTController:WARN> MQTTController#mqqt if_expr expression payload._type == 'location' || payload._type='transition' returned non-boolean (string) [latest-22337]2022-12-13T05:23:01.091Z <MQTTController:ERR> MQTTController#mqqt event handler failed for owntracks/catman/catmaniphone on catman_owntracks: [TypeError] Can't set NaN on attribute battery_power.level (mqqt>catman_owntracks) [-] [latest-22337]2022-12-13T05:23:01.091Z <MQTTController:CRIT> TypeError: Can't set NaN on attribute battery_power.level (mqqt>catman_owntracks) [-] TypeError: Can't set NaN on attribute battery_power.level (mqqt>catman_owntracks) at Entity.setAttribute (/home/catman/reactor/server/lib/Entity.js:453:19) at MQTTController.handle_event (/home/catman/reactor/ext/MQTTController/MQTTController.js:935:19) at MqttClient.<anonymous> (/home/catman/reactor/ext/MQTTController/MQTTController.js:424:38) at MqttClient.emit (node:events:527:28) at MqttClient.emit (node:domain:475:12) at MqttClient._handlePublish (/home/catman/reactor/ext/MQTTController/node_modules/mqtt/lib/client.js:1547:12) at MqttClient._handlePacket (/home/catman/reactor/ext/MQTTController/node_modules/mqtt/lib/client.js:535:12) at work (/home/catman/reactor/ext/MQTTController/node_modules/mqtt/lib/client.js:438:12) at Writable.writable._write (/home/catman/reactor/ext/MQTTController/node_modules/mqtt/lib/client.js:452:5) at doWrite (/home/catman/reactor/ext/MQTTController/node_modules/readable-stream/lib/_stream_writable.js:409:139) [latest-22337]2022-12-13T05:23:01.092Z <Rule:INFO> Location Test (rule-lbl1mbdn in Home or Away) starting evaluation; because entity-changed BinarySensor#mqqt>catman_owntracks [latest-22337]2022-12-13T05:23:01.092Z <Rule:INFO> Location Test (rule-lbl1mbdn in Home or Away) starting evaluation; because entity-changed BinarySensor#mqqt>catman_owntracks [latest-22337]2022-12-13T05:23:01.097Z <Timer:null> Timer#rule-lbl1mbdn just a note: I'm setting a delay of only 9ms (from 1670908981095<13/12/2022, 05:23:01> to 1670908981104<13/12/2022, 05:23:01>) [latest-22337]2022-12-13T05:23:01.098Z <Rule:INFO> Location Test (rule-lbl1mbdn in Home or Away) evaluated; rule state transition from RESET to SET! [latest-22337]2022-12-13T05:23:01.118Z <Rule:INFO> Location Test (rule-lbl1mbdn in Home or Away) evaluated; trigger state unchanged (false); rule state remains SET [latest-22337]2022-12-13T05:23:01.118Z <Rule:INFO> Location Test (rule-lbl1mbdn in Home or Away) evaluation complete [latest-22337]2022-12-13T05:23:01.118Z <Rule:INFO> Location Test (rule-lbl1mbdn in Home or Away) evaluation complete [latest-22337]2022-12-13T05:23:01.119Z <Engine:INFO> Enqueueing "Location Test<SET>" (rule-lbl1mbdn:S) [latest-22337]2022-12-13T05:23:01.131Z <Engine:NOTICE> Starting reaction Location Test<SET> (rule-lbl1mbdn:S) [latest-22337]2022-12-13T05:23:01.138Z <Engine:INFO> Location Test<SET> all actions completed. FWIW I have noticed the issue with the NaN on battery_power.level previously but it was while I was messing around with stuff. My phone seems to update more frequently than Mrs C's which has not updated at all since I did a location push at 1218 UTC yesterday (to clear the battery_power.level issue. Debian Bullseye on bare metal The only thing I can think of right now is that for some reason my phone is sending something duff (although the other parameters (i.e. elevation, long and lat) all seem fine. Forcing a publish from the App results in everything updating as expected. Log level in Mosquitto is set to all. C
Software
Software
Software
Software
33 Posts 4 Posters 19.6k Views 4 Watching
    TIA
      Your mqtt Server must be publicly accessible for this to work. I’m using an http to mqtt broker I’ve built myself, but it’s definitely easier to publish your broker, using a limited user that has filters to avoid security problems.
        @therealdb Thanks
        My mqtt server is on my own network. Owntracks claims to be connected....
          So nothing else? No pointers? Please? 😉
            Your MQTT server is internal to your wifi network, so it's working only if you're inside. When outside, the server is not connected and it's failing. Faster route is to expose this via your firewall/router and an SSL cert. Owntracks doc should have more info.
              @therealdb said in Mosquitto and Owntracks:
              My MQTT server is accessible from outside my LAN. Tested and proven with a test server and Owntracks is connecting to my DynDNS hostname (so it's punching out to the net and back in, via my firewall) and I can see the traffic. I've increased the logging on Mosquitto and I can see loads of stuff (which is great)
              What I don't know is how to get Mosquitto to trigger MSR (or something)
              I mean, I don't know (as yet) what happens when the phone goes out of the home zone because it hasn't been outside that since I increased the logging, but any ideas would be great!
                I think your other post has pointed me in the right direction of the docs.
                Cheers!
                  Cheers!
                  @catmanv2 best thing to do is to map a custom device under MSR. Look at the doc.
                    Yeah now I've found the right bit of doc. Of course, I should have done something obvious like search for MQTT in the MSR manual, but sometimes I like to do things the hard way.
                    For some reason I can't add the controller section to my reactor.yaml file and get a running MSR but I'll dig into that.
                    Cheers
                      Cheers
                      @catmanv2 yaml is hard to edit, try VS code or an editor helping you with indentation and its format.
                        Cheers
                        I'm only trying to add this bit:
                          - id: mqtt
                            enabled: true
                            implementation: MQTTController
                            config:
                              # Replace IP with that of your MQTT broker below
                              source: "mqtt://127.0.0.1:8883/"
                        user: something
                        password: something
                        Although the user and password are correct, I'm not clear if I need to quote them or not. Restarting reactor with that in my (otherwise working) reactor.yaml: Reactor stops and just sits there, logging nothing. (Not checked the Mosquitto logs yet)
                        If I swap reactor.yaml back to a working version reactor starts fine. So it's got to be something real easy.....
                        S 1 Reply Last reply
                          Cheers
                            - id: mqtt
                              enabled: true
                              config:
                          user: something
                          password: something
                          @catmanv2 I am no expert but try this:
                          Change user: to username: Also, I believe both username: and password: should be the same indenting as source.
                          • S SweetGenius
                            @sweetgenius said in Mosquitto and Owntracks:
                            Thanks. username makes no difference. Does the indenting really matter? If so I shall have to get some code editor as vi isn't letting me get it right 🙂
                            S toggledbitsT 2 Replies Last reply
                              @catmanv2 said in Mosquitto and Owntracks:
                              Yes, indenting matters, like @therealdb said previously.
                              Is port 8883 the correct port for your setup?
                              • S SweetGenius
                                Lovely, ta. I shall fire up VS code! 8883 is correct as well
                                  Yes! YAML is highly dependent on indenting! And you must use spaces, not tabs. Here are a few good YAML tools on line to help:
                                  • https://yamllint.com - Check YAML (paste and click)
                                  • https://yamlchecker.com - Another checker
                                  • https://onlineyamltools.com/edit-yaml - A handy web-based syntax-driven editor
                                    Wow. Thanks ever so. Binned the sample code for the Owntracks manual and 'handcrafted it'. First time 🙂
                                    <edit: re reading, it's not clear that at this point Reactor happily started and now shows the MQTT entity, so problem solved>
                                      @catmanv2 not a fan of yaml, but I agree it’s easier than json or xml. but the indentation sometime drives me crazy, and the tools suggested (or vs code) are useful to double check the files.
                                        @therealdb VS code saw nothing. Yamlchecker picked up an issue, but even with that corrected, it didn't work <shrug>
                                        Now does anyone have an Owntracks template?
                                        Otherwise this is going to be a steep curve I suspect 😄
                                          it didn't work
                                          Three words that should never be written into a post asking for help. At least, as I've often said, not as the entire summary of where you are. I suggest a form more like this (the numbering is just to separate component parts of your question/post):
                                          "OK, It didn't work. Here's where I am with this darned thing..."
                                          1. Describe what part/thing you are trying to do; if part of multiple step process, tell us both what you are trying to do overall, and what step of that process you are working on that is going wrong
                                            "I'm trying to get my MQTTController instance in MSR to connect to my broker, and I need to use a username/password for authentication. I have configured the username and password in my reactor.yaml file."
                                          2. Describe what you expected to see.
                                            "When I restarted MSR and hard-refreshed my browser, I thought I would see the MQTT system entity in the Entities list, or the controller listed as "up" on the Controller Status widget on the Status page.
                                          3. Describe what you actually see (e.g. errors or exceptions) or what you don't see that you expected. If there's an error on the screen, make sure your narrative includes the full and complete text of it, and describe where it came up and what you were doing when it did. If it's a corrupted display or something better shown with a screen shot, add that behind your narrative.
                                            "The MQTT controller doesn't show up at all in either the Entities list or Controller Status widget."
                                            ... or maybe it's worse than that?
                                            "Reactor doesn't even start now."
                                          4. Show your work. Give the problem context.
                                            "Here's what the configuration section for my MQTTController instance looks like when it fails:". Paste the text of the configuration from first line to last without redaction or modification except passwords/access tokens/private keys[1].
                                          5. Show that you dug for an answer yourself:
                                            "I looked in the logs, and found these messages:" — follow with snippet of log, with one or two dozen lines of context before what you found. Never post just an error message without context.[1]
                                            In many cases, this last step will lead you to answering your own question. If you can't interpret what you are seeing, that's perfectly fine, but we need to see it to help you, and there's no point in making us ask for it. Go look for it yourself, and give it up front.
                                          Give us something to go on. Messaging back and forth in a forum like this is the worst way to play "Twenty Questions". The less detail you give, the longer it takes to get a solution. And the old Internet trope of the 2000s is still true in the current decade: "People will put as much effort into answering your question as you put into asking it."
                                          IMO, the posting guidelines I wrote for the Reactor category here (which are based on posted guidelines created for Home Assistant's forums, which are based on guidelines created elsewhere) should be applied everywhere. It's in your interest.
                                          [1] Formatting code and log snippets should be done using the ``` sequence on a line by itself, followed by the code or log snippet, followed by the ``` sequence on a line by itself again.
                                          controllers:
                                            - id: mqtt
                                              enabled: true
                                          looks like this when your post is later displayed (which is helpful/necessary for readability and finding errors in YAML in particular):
                                          controllers:
                                            - id: mqtt
                                              enabled: true
                                          (@CatmanV2 , you clearly know how to do this formatting, I'm just adding this for completeness/benefit of future readers).
                                            165.5k
