reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Feature Request: Widget for Condition sustained time
I would like to ask if this is possible and if others would find this useful.
I have multiple rules that check if lights are turned on manually and then have “Condition must be sustained for” xxxx amount of seconds then use the set reaction to turn off the light if it has not been shutoff. I like the UI when the rule is expanded that shows sustained time. (See Screenshot Below) Could a “Widget” have this information on the status screen that would show which rules conditions are waiting to come true with the sustained time? Similar to the Running Reactions widget.
latest-22274
Synology Docker -
