  4. Entity is not visible
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
7 Posts 2 Posters 1.1k Views 3 Watching
    Trying my damndest to follow the guidelines......
    Reactor latest-22274-24dfd72c
    Intel NUC Debian Bullseye
    Using an online YAML editor I have managed to create a reactor.yaml with an entity that allows Reactor to start (no idea why vi seems to break the yaml)
      - id: mqqt
        enabled: true
        implementation: MQTTController
        config:
          source: "mqtt://192.168.70.249:8883/"
          username: xxxx
          password: xxxx
        entities:
          catman_iphone:
          topic: FCEB043-B975-490E-B051-198473F6A504
          uses_template: owntracks_in_region
          region: "Home"
    My expectation is that this would create a binary sensor. I can see no such sensor.
    Reactor log:
    [latest-22274]2022-10-09T15:13:55.580Z <app:null> Reactor latest-22274-24dfd72c starting on v16.15.0
    [latest-22274]2022-10-09T15:13:55.581Z <app:INFO> Process ID 10567; docker false; platform linux/x64 #1 SMP Debian 4.19.235-1 (2022-03-17); locale en_GB.UTF-8
    [latest-22274]2022-10-09T15:13:55.581Z <app:INFO> Basedir /home/catman/reactor; data in /home/catman/reactor/storage
    [latest-22274]2022-10-09T15:13:55.581Z <app:INFO> NODE_PATH=/home/catman/reactor
    [latest-22274]2022-10-09T15:13:55.583Z <app:INFO> Configured locale (undefined); selected locale(s) en_GB.UTF-8
    [latest-22274]2022-10-09T15:13:55.601Z <app:INFO> Loaded locale en-US
    [latest-22274]2022-10-09T15:13:55.612Z <Capabilities:null> Module Capabilities v22250
    [latest-22274]2022-10-09T15:13:55.659Z <Plugin:null> Module Plugin v21186
    [latest-22274]2022-10-09T15:13:55.663Z <TimerBroker:null> Module TimerBroker v22263
    [latest-22274]2022-10-09T15:13:55.665Z <default:INFO> Module Entity v22258
    [latest-22274]2022-10-09T15:13:55.667Z <Controller:null> Module Controller v22266
    [latest-22274]2022-10-09T15:13:55.668Z <default:null> Module Structure v22123
    [latest-22274]2022-10-09T15:13:55.675Z <default:null> Module Ruleset v21096
    [latest-22274]2022-10-09T15:13:55.675Z <default:null> Module Rulesets v21096
    [latest-22274]2022-10-09T15:13:55.680Z <GlobalExpression:null> Module GlobalExpression v21333
    [latest-22274]2022-10-09T15:13:55.697Z <Predicate:null> Module Predicate v22271
    [latest-22274]2022-10-09T15:13:55.699Z <AlertManager:null> Module AlertManager v22117
    [latest-22274]2022-10-09T15:13:55.701Z <default:null> Module Rule v22265
    [latest-22274]2022-10-09T15:13:55.704Z <GlobalReaction:null> Module GlobalReaction v21333
    [latest-22274]2022-10-09T15:13:55.705Z <default:null> Module Engine v22266
    [latest-22274]2022-10-09T15:13:55.705Z <default:null> Module httpapi v22248
    [latest-22274]2022-10-09T15:13:55.717Z <default:null> Module wsapi v22104
    [latest-22274]2022-10-09T15:13:55.719Z <app:NOTICE> Starting Structure...
    [latest-22274]2022-10-09T15:13:55.723Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping
    [latest-22274]2022-10-09T15:13:55.727Z <Structure:INFO> Structure#1 loading controller interface vera (VeraController)
    [latest-22274]2022-10-09T15:13:55.762Z <TaskQueue:null> Module TaskQueue 21351
    [latest-22274]2022-10-09T15:13:55.763Z <VeraController:null> Module VeraController v22258
    [latest-22274]2022-10-09T15:13:55.866Z <Structure:INFO> Structure#1 loading controller interface mqqt (MQTTController)
    [latest-22274]2022-10-09T15:13:55.869Z <MQTTController:null> Module MQTTController v22144
    [latest-22274]2022-10-09T15:13:55.930Z <MQTTController:INFO> instance topic ident is mqqt
    [latest-22274]2022-10-09T15:13:55.933Z <Structure:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
    [latest-22274]2022-10-09T15:13:55.938Z <DynamicGroupController:null> Module DynamicGroupController v22123
    [latest-22274]2022-10-09T15:13:55.941Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
    [latest-22274]2022-10-09T15:13:55.944Z <SystemController:null> Module SystemController v22257
    [latest-22274]2022-10-09T15:13:55.946Z <Structure:INFO> Starting controller VeraController#vera
    [latest-22274]2022-10-09T15:13:55.947Z <VeraController:NOTICE> VeraController#vera starting
    [latest-22274]2022-10-09T15:13:55.985Z <VeraController:INFO> VeraController#vera loaded mapping ver 22257 rev 3 format 1 notice (none)
    [latest-22274]2022-10-09T15:13:55.990Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute members
    [latest-22274]2022-10-09T15:13:55.990Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute empty
    [latest-22274]2022-10-09T15:13:56.000Z <Structure:INFO> Starting controller MQTTController#mqqt
    [latest-22274]2022-10-09T15:13:56.001Z <MQTTController:NOTICE> Connecting to broker mqtt://192.168.70.249:8883/
    [latest-22274]2022-10-09T15:13:56.036Z <Structure:INFO> Starting controller DynamicGroupController#groups
    [latest-22274]2022-10-09T15:13:56.041Z <DynamicGroupController:NOTICE> Controller DynamicGroupController#groups is now online.
    [latest-22274]2022-10-09T15:13:56.041Z <Structure:INFO> Starting controller SystemController#reactor_system
    [latest-22274]2022-10-09T15:13:56.043Z <SystemController:NOTICE> Controller SystemController#reactor_system is now online.
    [latest-22274]2022-10-09T15:13:56.081Z <app:NOTICE> Starting HTTP server and API...
    [latest-22274]2022-10-09T15:13:56.083Z <httpapi:NOTICE> Starting HTTP API v1 22248 on http://192.168.70.2
    Anyone comment on what I've done wrong?
    TIA
        - id: mqqt
          enabled: true
          config:
            username: xxxx
            password: xxxx
          entities:
            catman_iphone:
            region: "Home"
      Reactor log:
      TIA
      @catmanv2 said in Entity is not visible:
      This is a solid performance.
      If i had to guess, you're indenting with tabs rather than spaces. That would be the first thing I'd look at. No tabs allowed.
      Easy, at least at the first level: your entities section is at the same indent level as config. The entities section is part of config, so it should be indented underneath it. entities: and all of the lines that follow as part of it should be indented two more spaces. As you have it, MQTTController can't even see that section, and that would explain why you're not getting an entity created.
      Should be:
        - id: mqqt
          enabled: true
          config:
            username: xxxx
            password: xxxx
            entities:
              catman_iphone:
        Should be:
          - id: mqqt
            enabled: true
            config:
              username: xxxx
              password: xxxx
              entities:
                catman_iphone:
        @toggledbits said in Entity is not visible:
        Thanks. I promise I'm not not but I'll just do it in a browser for now 🙂
          - id: mqqt
            enabled: true
            config:
              username: xxxx
              password: xxxx
              entities:
                catman_iphone:
                topic: catmaniphone
                region: "Home"
        Everything starts fine. I've hard refreshed the browser.
        Still can't find any entity in either the entities screen or if I try to use 'it' in a rule.
        Clearly I've still done something idiotic, and there's an error in here, but damned if I know what it means?
        [latest-22274]2022-10-09T17:45:15.492Z <Structure:INFO> Starting controller MQTTController#mqqt
        [latest-22274]2022-10-09T17:45:15.493Z <Structure:INFO> Starting controller DynamicGroupController#groups
        [latest-22274]2022-10-09T17:45:15.496Z <DynamicGroupController:NOTICE> Controller DynamicGroupController#groups is now online.
        [latest-22274]2022-10-09T17:45:15.496Z <Structure:INFO> Starting controller SystemController#reactor_system
        [latest-22274]2022-10-09T17:45:15.498Z <SystemController:NOTICE> Controller SystemController#reactor_system is now online.
        [latest-22274]2022-10-09T17:45:15.538Z <Structure:ERR> Structure#1 controller mqqt failed to start: [TypeError]TypeError: Cannot read properties of null (reading 'uses_template')
        [latest-22274]2022-10-09T17:45:15.538Z <Structure:CRIT> TypeError: Cannot read properties of null (reading 'uses_template')
            at MQTTController.start (/home/catman/reactor/ext/MQTTController/MQTTController.js:73:21)
            at Structure.start (/home/catman/reactor/server/lib/Structure.js:346:56)
        [latest-22274]2022-10-09T17:45:15.538Z <MQTTController:NOTICE> MQTTController#mqqt stopping, sending LWT
        [latest-22274]2022-10-09T17:45:15.539Z <MQTTController:NOTICE> MQTTController#mqqt stopping
        [latest-22274]2022-10-09T17:45:15.540Z <app:NOTICE> Starting HTTP server and API...
        [latest-22274]2022-10-09T17:45:15.542Z <httpapi:NOTICE> Starting HTTP API v1 22248 on http://192.168.70.249:8111
        [latest-22274]2022-10-09T17:45:15.545Z <app:NOTICE> Starting Reaction Engine...
        [latest-22274]2022-10-09T17:45:15.545Z <Engine:INFO> Reaction Engine starting
        Cheers
        <edit> per the other thread I've also edited the DeviceID to catmaniphone on the phone and in the reactor.yaml. The log remains the same.
          OK. I just noticed one more error... if I had included more sample data in my last example to you, I would have noticed it earlier...
          All together now... entities: must be indented two spaces from config: (as per my last post), but also everything after catman_iphone: should be indented two spaces from that...
            - id: mqqt
              enabled: true
              config:
                username: xxxx
                password: xxxx
                entities:
                  catman_iphone:
                    topic: catmaniphone
                    region: "Home"
          General rule of thumb... if the : is the last character on the line, everything below it will need to be indented.
            I shall try to remember, thanks!
            So I have this:
              - id: mqqt
                enabled: true
                config:
                  username: xxxxx
                  password: xxxxx
                  entities:
                    catman_iphone:
                      topic: catmaniphone
                      region: "Home2"
            And in the logs:
            [latest-22274]2022-10-09T20:45:55.083Z <app:null> Reactor latest-22274-24dfd72c starting on v16.15.0
            [latest-22274]2022-10-09T20:45:55.084Z <app:INFO> Process ID 24110; docker false; platform linux/x64 #1 SMP Debian 4.19.235-1 (2022-03-17); locale en_GB.UTF-8
            [latest-22274]2022-10-09T20:45:55.084Z <app:INFO> Basedir /home/catman/reactor; data in /home/catman/reactor/storage
            [latest-22274]2022-10-09T20:45:55.084Z <app:INFO> NODE_PATH=/home/catman/reactor
            [latest-22274]2022-10-09T20:45:55.086Z <app:INFO> Configured locale (undefined); selected locale(s) en_GB.UTF-8
            [latest-22274]2022-10-09T20:45:55.105Z <app:INFO> Loaded locale en-US
            [latest-22274]2022-10-09T20:45:55.113Z <Capabilities:null> Module Capabilities v22250
            [latest-22274]2022-10-09T20:45:55.160Z <Plugin:null> Module Plugin v21186
            [latest-22274]2022-10-09T20:45:55.164Z <TimerBroker:null> Module TimerBroker v22263
            [latest-22274]2022-10-09T20:45:55.166Z <default:INFO> Module Entity v22258
            [latest-22274]2022-10-09T20:45:55.168Z <Controller:null> Module Controller v22266
            [latest-22274]2022-10-09T20:45:55.169Z <default:null> Module Structure v22123
            [latest-22274]2022-10-09T20:45:55.176Z <default:null> Module Ruleset v21096
            [latest-22274]2022-10-09T20:45:55.176Z <default:null> Module Rulesets v21096
            [latest-22274]2022-10-09T20:45:55.181Z <GlobalExpression:null> Module GlobalExpression v21333
            [latest-22274]2022-10-09T20:45:55.194Z <Predicate:null> Module Predicate v22271
            [latest-22274]2022-10-09T20:45:55.197Z <AlertManager:null> Module AlertManager v22117
            [latest-22274]2022-10-09T20:45:55.198Z <default:null> Module Rule v22265
            [latest-22274]2022-10-09T20:45:55.201Z <GlobalReaction:null> Module GlobalReaction v21333
            [latest-22274]2022-10-09T20:45:55.202Z <default:null> Module Engine v22266
            [latest-22274]2022-10-09T20:45:55.202Z <default:null> Module httpapi v22248
            [latest-22274]2022-10-09T20:45:55.214Z <default:null> Module wsapi v22104
            [latest-22274]2022-10-09T20:45:55.215Z <app:NOTICE> Starting Structure...
            [latest-22274]2022-10-09T20:45:55.218Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping
            [latest-22274]2022-10-09T20:45:55.221Z <Structure:INFO> Structure#1 loading controller interface vera (VeraController)
            [latest-22274]2022-10-09T20:45:55.258Z <TaskQueue:null> Module TaskQueue 21351
            [latest-22274]2022-10-09T20:45:55.259Z <VeraController:null> Module VeraController v22258
            [latest-22274]2022-10-09T20:45:55.362Z <Structure:INFO> Structure#1 loading controller interface mqqt (MQTTController)
            [latest-22274]2022-10-09T20:45:55.366Z <MQTTController:null> Module MQTTController v22144
            [latest-22274]2022-10-09T20:45:55.422Z <MQTTController:INFO> instance topic ident is mqqt
            [latest-22274]2022-10-09T20:45:55.425Z <Structure:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
            [latest-22274]2022-10-09T20:45:55.429Z <DynamicGroupController:null> Module DynamicGroupController v22123
            [latest-22274]2022-10-09T20:45:55.432Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
            [latest-22274]2022-10-09T20:45:55.435Z <SystemController:null> Module SystemController v22257
            [latest-22274]2022-10-09T20:45:55.438Z <Structure:INFO> Starting controller VeraController#vera
            [latest-22274]2022-10-09T20:45:55.438Z <VeraController:NOTICE> VeraController#vera starting
            [latest-22274]2022-10-09T20:45:55.477Z <VeraController:INFO> VeraController#vera loaded mapping ver 22257 rev 3 format 1 notice (none)
            [latest-22274]2022-10-09T20:45:55.482Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute members
            [latest-22274]2022-10-09T20:45:55.482Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute empty
            [latest-22274]2022-10-09T20:45:55.492Z <Structure:INFO> Starting controller MQTTController#mqqt
            [latest-22274]2022-10-09T20:45:55.492Z <MQTTController:ERR> MQTTController#mqqt entity catman_iphone uses_template=owntracks_in_region, template not defined
            [latest-22274]2022-10-09T20:45:55.493Z <MQTTController:NOTICE> Connecting to broker mqtt://192.168.70.249:8883/
            [latest-22274]2022-10-09T20:45:55.527Z <Structure:INFO> Starting controller DynamicGroupController#groups
            [latest-22274]2022-10-09T20:45:55.533Z <DynamicGroupController:NOTICE> Controller DynamicGroupController#groups is now online.
            [latest-22274]2022-10-09T20:45:55.533Z <Structure:INFO> Starting controller SystemController#reactor_system
            [latest-22274]2022-10-09T20:45:55.535Z <SystemController:NOTICE> Controller SystemController#reactor_system is now online.
            [latest-22274]2022-10-09T20:45:55.574Z <app:NOTICE> Starting HTTP server and API...
            [latest-22274]2022-10-09T20:45:55.576Z <httpapi:NOTICE> Starting HTTP API v1 22248 on http://192.168.70.249:8111
            [latest-22274]2022-10-09T20:45:55.579Z <app:NOTICE> Starting Reaction Engine...
            [latest-22274]2022-10-09T20:45:55.579Z <Engine:INFO> Reaction Engine starting
            Still no device. Thanks 🙂
              You need at least version 22260 of MQTTController
                Perfect! Thanks!
                Now to see if it works!
                  165.3k
