  4. Action Pace Configuration MSR
3 Posts 2 Posters 838 Views 2 Watching
  • P Offline
    P Offline
    Pmccraw
    Hello,
    I am using MS-Reactor with a Home Assistant hub running on a Synoogy NAS as well as a VERA Plus hub. So far MS-R works AMAZING! However I have one rule I use when cleaning the house that essentially turns all the lights on to 100% (25+ lights) and it takes sometime for the action to take effect. I noticed it worked slighlty faster when I had the items in a scene on the vera controller Vs. a rule triggered by a virtual switch in MS-R.
    I suspect I could address the issue by increasing the action pace value per the documentation however, I do not know where to edit this setting? Do I just add a line in the MS-R reactor.yaml config file below the VERA controller info that states: "ActionPace: 00500"?
    Please let me know where and how I can adjust he aforementioned setting.
    All the best,
    Phil
    • P Pmccraw
      Hello,
      All the best,
      Phil
      @pmccraw the ActionPace value can go below your source entry, indented at the same level (remember to use spaces, not tabs, for indenting). The value is a delay between tasks in milliseconds, so larger value means more delay (slower pace). The default is 25 (milliseconds).
      • P Offline
        P Offline
        Pmccraw
        Thanks much for the prompt reply, I just tried it and it noticeably improved the execution of the rule.
          312
          150.9k
