  4. MQTTController: two brokers?
8 Posts 2 Posters 1.5k Views 2 Watching
    I'm barely dipping a toe into MQTT and am wondering if MSRs MQTTController can be configured to listen to two brokers?
    ...is that even a thing in MQTT without bridging?
      Just add another instance in the controllers section; be sure to give it a different ID from the existing one.
        @toggledbits Ok, that's what I thought but wasn't positive.
        Will it work with a cloud MQTT broker?
          Any broker that is 3.1.1 compliant should work as long as it's accessible.
            @toggledbits I think where I'm falling down is the URL format. I'm testing out HiveMQ to see if I can improve my OwnTracks response time by using MQTT into MSR vs HTTP into HomeAssistant into MSR.
            Log shows me:
            [latest-22337]2022-12-10T14:53:04.155Z <MQTTController:NOTICE> Connecting to broker mqtt://7efxxxxxxxxxxxxxxc4a0d0.s2.eu.hivemq.cloud:8883
            [latest-22337]2022-12-10T14:53:04.373Z <MQTTController:NOTICE> MQTTController#mqtt2 broker offline!
            [latest-22337]2022-12-10T14:53:04.374Z <MQTTController:NOTICE> MQTTController#mqtt2 waiting for auto-reconnect
            The broker is running:
            MQTTController config for this broker is:
                enabled: true
                implementation: MQTTController
                config:
                  # Replace IP with that of your MQTT broker below
                  source: "mqtt://7efxxxxxxxxxxxxxxc4a0d0.s2.eu.hivemq.cloud:8883"
                  username: "<user>"
                  password: "<password>"
            I'm just tinkering for now. I'm remembering the Lobo days (I've yet to find anything that did presence like Lobo did...)
              I doubt any cloud broker uses an unencrypted channel. Type mqtts://.... Changing the port alone does not change the communication protocol. You have to be more specific.
              G 2 Replies Last reply
                @toggledbits OY. The difference a single letter can make. Totally glossed over that little detail.
                Connected.
                Thank you, as always!
                  @toggledbits In configuring the entity for OwnTracks... completely disregard my prior insanity. I'm finding all sorta good things BY READING ALL THE WORDS in the manual.
                  I'll be out the rest of the day - still just poking at this.
