  4. localization settings
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
17 Posts 4 Posters 4.8k Views 4 Watching
    Using the following localization settings in reactor.yaml:
      units: metric
      locale: fi-FI
      time_format: "%H:%M:%S"
      date_format: "%d/%m/%Y"
    But still I'm getting US date & time formatting, so settings do not seem to override defaults? Using 23049 on Synology Docker
      There's no custom language file for Finnish that I'm aware of (there is definitely not one in the standard distribution). The config override of locale is really intended only for developer testing of localizations while they are doing them. In the absence of such a config/language file, Reactor can't know what to do and relies on nodejs to provide the formatting, which requires that the locale be correctly configured on the host.
      Locale for the host side is usually derived from configuration of the host itself (OS-dependent), or the docker container (by adding a LC_ALL environment variable to the container configuration).
      Display on the browser side (i.e. in the UI) is controlled by the browser's locale setting. Always (regardless of the locale setting on the host or in config).
        @toggledbits wasn't expecting language localization, but date & time. From the manual:
        "You can override the locale Reactor uses for both browser and host display by setting the locale key in the reactor section of reactor.yaml"
        "By default, dates and times are displayed in the settings determined by the locale (including the order of month, day and year in date displays, and 12/24 time display)"
        So by setting locale in reactor.yaml I was expecting to see e.g. 24 h time format. That didn't happen and then I added time_format and date_format, but still no change?
          @tunnus The time_format and date_format are no longer used, since the locale configuration now determines the date and time format.
            @toggledbits okay, but any idea why using "locale: fi-FI" in reactor.yaml does not change date & time format in UI? Or should it?
            FWIW, using Chrome with Finnish as preferred language (but as said, not expecting to see language impact here, only date/time formatting)
              ...I even tried adding LC_ALL variable to Docker with "fi_FI.UTF-8" as a value, but again no impact (for time formatting).
                At the moment it's an all or nothing deal... if there's a translation file, it will accept the locale; otherwise, it just sticks to default US English.
                Maybe you should write the fi-FI translation? 🙂
                  @toggledbits said in localization settings:
                  Might even do that 😁 But in the meanwhile wondering if nobody else is interested to get 24 hour time display. @therealdb & @Crille ?
                    The Swedish translation at http://[ip]:8111/reactor/sv-SE/ is in 24h format if the browsers locale setting is set to it.
                      @tunnus I have started Italian translation, but I'm busy with other things and I like American English anyway. But we could try to create an international English with 24h clock and right date formats, just in case 🤣
                        I'm working on some changes, but it may be another week. I'm swamped right now.
                          For anyone here trying to get the 24H & right date format 🙂 just add this to your reactor config file (at least v 23063 required):
                          reactor:
                            units: metric
                          Restart, hard refresh your browser and you're good to go. Thanks @toggledbits !
                            Note: you only need to do this if your locale-defined time format isn't 24 hour.
                            Also, the format shown by @therealdb might be normal for his locale, but not yours specifically. This config will also override the locale-defined date format; if you don't want that, set time_format only.
                            Final note: Locale setting is determined by (both) the locale set for the host OS and the locale settings of your browser. This is the preferred way to set locale. Setting locale in Reactor's config is specifically not recommended.
                            Edit: to be clear, to get your language's preferred date and time formats, you should do the following, in the order listed:
                            1. Configure your host system (or the Reactor docker container) and your browser for the correct locale. This may be sufficient for most uses. Make sure to re-open browser windows from the "root" of the Reactor URL (e.g. click the Reactor logo in the upper-left corner of the page).
                            2. If the time or date format presented by correctly completing step 1 does not suit your preferences, then and only then set date_format and/or time_format in Reactor's config.
                            3. Never use the Reactor config locale setting; this is for developers only and is not a complete solution for getting the correct locale. Locale configuration is always inherited from (both) your host system and browser, and that is the only correct way to do it permanently.
                              @toggledbits so with build 23063 Docker environment variable LC_ALL should work (tried with build 23049, but no success)?
                                That will change it on the host side. It has no effect on the browser settings (which are browser-dependent).
                                  @toggledbits yes, just wanted to confirm that with earlier builds LC_ALL was essentially ignored
                                    Not ignored, just not used if there was no language file present for the selected language.
                                      162.9k
