  3. Vera/openLuup plugins
  4. RulesEngine
Logic Programming
Fork Mios VERASECURE
On start up the log indicates the following: 2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) The MQTT variables are all set to "skip": MQTT_BrightnessValue MQTT_PowerStatusOff MQTT_PowerStatusOn However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to. It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
RulesEngine
E
Netatmo – Oath2 login
Vera Alexa down?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech. I seem to be getting an odd timeout but no idea from where. Debian Bullseye, bare metal Good call from this morning: 2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28 Bad request from just now: 2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 Any thoughts? Cheers C
Device issues in Open Luup
Broadlink setup
Virtual Sensor Polling
RulesEngine
32 Posts 3 Posters 16.5k Views 3 Watching
    Any other errors in the startup log, or since startup in the main log?
      @DesT
      I did an install of the latest openLuup from the development branch (v23.3.21) and semm to have no problem accessing the console page. Will try again, now, to install the lxp module and fire up the RulesEngine...
        #23
        On the RulesEngine saving issue...
        I've been seeing this error in the browser console:
        POST
        http://172.16.42.10:49162/cgi-bin/cmh/upload_upnp_file.sh
        404 Not Found
        ...and I found that the file was missing from my installation (which I had done manually, because the AltAppStore configuration doesn't handle the GitHub structure of the repository.)
        Do you have the folders and file (within the openLuup home folder) ?
        • DesTD Offline
          DesTD Offline
          DesT
          yes I have the file and it contain:
          #!/usr/bin/env wsapi.cgi
          module(..., package.seeall)
          -- @vosmont's implementation of /cgi-bin/cmh/upload_upnp_file.sh
          -- converted to WSAPI application by @akbooer
          -- see: http://keplerproject.github.io/wsapi/manual.html
          -- 2016.02.18  extract vosmont's modification from openLuup.server and make into WSAPI app
          local _log    -- defined from WSAPI environment as error.write(...) in run() method.
          -- create the file
          local function upload_file (URL)
            local file, status, result
            local path = "" -- should use a specific folder for security reason ?
            local fileName, fileContent = URL.upnp_file_1_name, URL.upnp_file_1
            if fileName and fileContent then
              file = io.open(path .. fileName, "w")
            fileName = fileName or '?'
            if (file == nil) then
              _log ("File '" .. path .. fileName .. "' cannot be created")
               result = "KO"
               status = 400   -- Bad Request.
            else
              file:write(fileContent)
              file:close()
              _log ("File '" .. path .. fileName .. "' has been written")
              result = "OK"
              status = 201    -- Created. The request has been fulfilled and resulted in a new resource being created
            return status, result .. "|" .. fileName, "text/html"
          -- gets headers in multipart content
          local function read_part_headers (content, pos)
                  local EOH = "\r\n\r\n"
                  local i, j = string.find(content, EOH, pos, true)
                  if i then
                          local header_data = string.sub(content, pos, j - 1)
                          local headers = {}
                          for type, val in string.gmatch(header_data, '([^%c%s:]+):%s+([^\n]+)') do
                                  headers[type] = val
                          return headers, j + 1
                  else
                          return nil, pos
          -- gets fields in multipart headers
          local function get_field_names(headers)
                  local disp_header = headers["Content-Disposition"] or ""
                  local attrs = {}
                  for attr, val in string.gmatch(disp_header, ';%s*([^%s=]+)="(.-)"') do
                          attrs[attr] = val
                  return attrs.name, attrs.filename and string.match(attrs.filename, "[/\\]?([^/\\]+)$")
          -- gets the data in multipart content
          local function read_field_content(content, boundary, pos)
                  local i, j = string.find(content, "\r\n" .. boundary, pos, true)
                  if i then
                          return string.sub(content, pos, i - 1), j + 1
                  else
                          return nil, pos
          -- global entry point called by WSAPI connector
          The environment is a Lua table containing the CGI metavariables (at minimum the RFC3875 ones) plus any
          server-specific metainformation. It also contains an input field, a stream for the request's data,
          and an error field, a stream for the server's error log.
          The input field answers to the read([n]) method [AKB: NOT YET IMPELMENTED],
          where n is the number of bytes you want to read
          (or nil if you want the whole input[AKB: THIS IS IMPLEMENTED]).
          The error field answers to the write(...) method.
          return values: the HTTP status code, a table with headers, and the output iterator.
          function run (wsapi_env)
            _log = wsapi_env.error.write     -- set up the log output
                  -- vosmont : add upload file management
            -- inspired from https://github.com/keplerproject/wsapi
            local URL = {}
            -- get POST content,
            local post_content = wsapi_env.input.read()
            local content_type = wsapi_env["CONTENT_TYPE"]
            -- get uploaded file
            if string.find(content_type, "multipart/form-data", 1, true) then
              local boundary = "--" .. string.match(content_type, "boundary%=(.-)$")
              -- get all the parts
              local pos = 1
              local _, part_headers, name, value
              _, pos = string.find(post_content, boundary, 1, true)
              pos = pos + 1
              part_headers, pos = read_part_headers(post_content, pos)
              while (part_headers) do
                --_log ("HTTP POST request multipart headers : " .. json.encode(part_headers))
                name, _ = get_field_names(part_headers) -- do not use "file_name" in Vera implementation of uploading files
                value, pos = read_field_content(post_content, boundary, pos)
                URL[name] = value
                -- prepare next multipart scan
            --_log ("HTTP POST request content : " .. post_content)
            --_log ("HTTP POST request content : " .. json.encode(URL))
            local status, return_content, return_content_type = upload_file (URL)
            local headers = {["Content-Type"] = return_content_type}
            local function iterator ()     -- one-shot iterator, returns content, then nil
              local x = return_content
              return_content = nil
              return x
            return status, headers, iterator
          • DesTD Offline
            DesTD Offline
            DesT
            @akbooer had some time to find something? 😉
              Been away for a couple of weeks. That missing file was the last thing I tried. Will get back to it now!
                So I've got this far. What so I do now...?
                • DesTD Offline
                  DesTD Offline
                  DesT
                  You can try to create a basic rule like that:
                  than try to save it!
                  • DesTD Offline
                    DesTD Offline
                    DesT
                    You should see the rule in the list after but you will not be able to edit it or see it!
                    Clicking on the pen will bring the EDIT window BUT you should see nothing as the rule is not saved properly.
                    Clicking on the big icon on the left, should bring the "view" and should see nothing also as the rule is not saved properly
                      I see these errors in the bowser console when constructing the rule:
                      When saving, I get from the openLuup log:
                      2023-09-20 15:00:49.723   openLuup.server:: POST /cgi-bin/cmh/upload_upnp_file.sh HTTP/1.1 tcp{client}: 0x55edaf542828
                      2023-09-20 15:00:49.758   openLuup.wsapi.cgi:: /cgi-bin/cmh/upload_upnp_file.sh : File 'C_RulesEngine_Rules.xml' has been written
                      2023-09-20 15:00:49.758   openLuup.server:: request completed (124 bytes, 0 chunks, 34 ms) tcp{client}: 0x55edaf542828
                      2023-09-20 15:00:49.767   openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=5&serviceId=urn:upnp-org:serviceId:RulesEngine1&action=LoadRules&fileName=C_RulesEngine_Rules.xml&ruleIdx=1 HTTP/1.1 tcp{client}: 0x55edaf542828
                      2023-09-20 15:00:49.768   luup.call_action:: 5.urn:upnp-org:serviceId:RulesEngine1.LoadRules
                      2023-09-20 15:00:49.768   openLuup.server:: request completed (62 bytes, 1 chunks, 0 ms) tcp{client}: 0x55edaf542828
                      2023-09-20 15:00:49.768   openLuup.context_switch::  ERROR: [dev #5] [string "I_RulesEngine1.xml"]:25: attempt to index field 'RulesFile' (a nil value)
                      2023-09-20 15:00:49.768   openLuup.scheduler:: job aborted : [string "I_RulesEngine1.xml"]:25: attempt to index field 'RulesFile' (a nil value)
                      2023-09-20 15:00:49.771   openLuup.server:: GET /data_request?id=lr_RulesEngine&command=getRulesInfos&output_format=json HTTP/1.1 tcp{client}: 0x55edaf542828
                      2023-09-20 15:00:49.771   openLuup.server:: request completed (31 bytes, 1 chunks, 0 ms) tcp{client}: 0x55edaf542828
                      So it's not clear what's going wrong here. There are some 5,400 lines of Lua, and 1,950 of Javascript to look through...
                        #31
                        I see also that it does create the file C_RulesEngine_Rules.xml with valid XML.
                        • DesTD Offline
                          DesTD Offline
                          DesT
                          If that can help.... the "TEST" rule I created 2 days ago for you, I'm able to delete it BUT any other rules I can't... maybe it's related to changing/removing a rule that it's not the last one...
                          I can do some more testing if you want!
                            148.1k
