  3. Vera/openLuup plugins
  4. Vera Alexa down?
Logic Programming
Fork Mios VERASECURE
On start up the log indicates the following: 2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) The MQTT variables are all set to "skip": MQTT_BrightnessValue MQTT_PowerStatusOff MQTT_PowerStatusOn However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to. It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
RulesEngine
E
Netatmo – Oath2 login
Vera Alexa down?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech. I seem to be getting an odd timeout but no idea from where. Debian Bullseye, bare metal Good call from this morning: 2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28 Bad request from just now: 2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 Any thoughts? Cheers C
Device issues in Open Luup
Broadlink setup
Virtual Sensor Polling
Vera Alexa down?
16 Posts 2 Posters 4.1k Views 2 Watching
    8a13f3c8
    Any thoughts?
    Cheers
      There must be a temporary problem. They break something from time to time. Try to create a routine with a notification and see if it’s working this way.
        @therealdb Yeah I figured that was most likely. Certainly not the first time I've seen similar.
        When you say a routine?
          @CatmanV2 an Alexa routine. You can create it in the Alexa app.
            @therealdb Ahh gotcha. Yes that seems to work fine (at least my reminders are AOK)
              Yeah, routines are fine. Still no TTS although not getting a time out now 😞
                @CatmanV2 I’m sorry. It’s working on my part, even if I’m using it in a different fashion. Try to enable debug mode and see what are the commands that are generated. It’s done via the debugmode property set to 1.
                  How are you using it, chap?
                  023-01-19 20:03:21.812   openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=68&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=1 HTTP/1.1 tcp{client}: 0x557238cf3b58
                  2023-01-19 20:03:21.813   luup.call_action:: 68.urn:upnp-org:serviceId:SwitchPower1.SetTarget
                  2023-01-19 20:03:21.813   luup.call_action:: action will be handled by parent: 28
                  2023-01-19 20:03:21.813   luup.variable_set:: 68.urn:upnp-org:serviceId:SwitchPower1.Target was: 0 now: 1 #hooks:0
                  2023-01-19 20:03:21.814   luup.variable_set:: 68.urn:upnp-org:serviceId:VSwitch1.Target was: 0 now: 1 #hooks:0
                  2023-01-19 20:03:21.814   luup.variable_set:: 68.urn:upnp-org:serviceId:SwitchPower1.Status was: 0 now: 1 #hooks:0
                  2023-01-19 20:03:21.814   luup.variable_set:: 68.urn:upnp-org:serviceId:VSwitch1.Status was: 0 now: 1 #hooks:0
                  2023-01-19 20:03:21.814   luup.variable_set:: 68.urn:toggledbits-com:serviceId:Switchboard1.ImpulseResetTime was: 0 now: 1674158603 #hooks:0
                  2023-01-19 20:03:21.815   openLuup.server:: request completed (35 bytes, 1 chunks, 3 ms) tcp{client}: 0x557238cf3b58
                  2023-01-19 20:03:21.966   openLuup.server:: request completed (1324 bytes, 1 chunks, 644 ms) tcp{client}: 0x5572392faf38
                  2023-01-19 20:03:21.992   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55723982bdd8
                  2023-01-19 20:03:21.998   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5572392faf38
                  2023-01-19 20:03:21.998   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66517641&MinimumDelay=50&output_format=json&_r=1674158601992 HTTP/1.1 tcp{client}: 0x55723982bdd8
                  2023-01-19 20:03:22.004   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239891ef8
                  2023-01-19 20:03:22.004   openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674158602003 HTTP/1.1 tcp{client}: 0x557239891ef8
                  2023-01-19 20:03:22.005   luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say
                  2023-01-19 20:03:22.005   luup_log:22: VeraAlexa: addToQueue: added to queue for 22
                  2023-01-19 20:03:22.005   luup_log:22: VeraAlexa(addToQueue@226): addToQueue: before: 0
                  2023-01-19 20:03:22.005   luup_log:22: VeraAlexa(addToQueue@243): addToQueue: after: 1
                  2023-01-19 20:03:22.005   luup_log:22: VeraAlexa(checkQueue@200): checkQueue: 22 - 1 in queue
                  2023-01-19 20:03:22.005   luup_log:22: VeraAlexa(checkQueue@208): checkQueue: 22 - play next
                  2023-01-19 20:03:22.005   luup_log:22: VeraAlexa(setVar@115): setVar("urn:bochicchio-com:serviceId:VeraAlexa1","OneTimePassCode","",22) old value ""
                  2023-01-19 20:03:22.005   luup_log:22: VeraAlexa(sayTTS@313): Executing command [TTS]: "-e speak:'<s>Testing...1...2...3</s><break time=\"0s\" />' -d \"Everywhere\""
                  2023-01-19 20:03:33.384   luup_log:22: VeraAlexa(setVar@115): setVar("urn:micasaverde-com:serviceId:HaDevice1","CommFailure","0",22) old value "0"
                  2023-01-19 20:03:33.384   luup_log:22: VeraAlexa(setVar@115): setVar("urn:bochicchio-com:serviceId:VeraAlexa1","LatestResponse","sending cmd:speak:<s>Testing...1...2...3</s><break time=\"0s\" /> to dev:Everywhere type:A3C9PE6TNYLTCH serial:de3b4a21ca844817bc180e826e636425 customerid:A1CVTZEBJIUFJI",22) old value "sending cmd:speak:<s>Good Afternoon Chris. , Rachel will soon be home..... She is 2.5 kilometers away</s><break time=\"0s\" /> to dev:Everywhere type:A3C9PE6TNYLTCH serial:de3b4a21ca844817bc180e826e636425 customerid:A1CVTZEBJIUFJI"
                  2023-01-19 20:03:33.384   luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s>Good Afternoon Chris. , Rachel will soon be home..... She is 2.5 kilometers away</s><break tim... now: sending cmd:speak:<s>Testing...1...2...3</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH serial:de3b4a... #hooks:0
                  2023-01-19 20:03:33.384   luup_log:22: VeraAlexa(nil@270): Response from Alexa.sh: "sending cmd:speak:<s>Testing...1...2...3</s><break time=\"0s\" /> to dev:Everywhere type:A3C9PE6TNYLTCH serial:de3b4a21ca844817bc180e826e636425 customerid:A1CVTZEBJIUFJI"
                  2023-01-19 20:03:33.384   luup_log:22: VeraAlexa(sayTTS@327): Queue will be checked again in "3" secs
                  2023-01-19 20:03:33.385   openLuup.server:: request completed (29 bytes, 1 chunks, 11380 ms) tcp{client}: 0x557239891ef8
                  2023-01-19 20:03:33.386   openLuup.server:: request completed (1730 bytes, 1 chunks, 11687 ms) tcp{client}: 0x5572385f78d8
                  2023-01-19 20:03:33.386   luup.variable_set:: 20.urn:akbooer-com:serviceId:DataYours1.AppMemoryUsed was: 15537 now: 13085 #hooks:0
                  2023-01-19 20:03:33.400   luup.call_action:: 68.urn:upnp-org:serviceId:SwitchPower1.SetTarget
                  2023-01-19 20:03:33.400   luup.call_action:: action will be handled by parent: 28
                  2023-01-19 20:03:33.400   luup.variable_set:: 68.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 0 #hooks:0
                  2023-01-19 20:03:33.400   luup.variable_set:: 68.urn:upnp-org:serviceId:VSwitch1.Target was: 1 now: 0 #hooks:0
                  2023-01-19 20:03:33.400   luup.variable_set:: 68.urn:upnp-org:serviceId:SwitchPower1.Status was: 1 now: 0 #hooks:0
                  2023-01-19 20:03:33.400   luup.variable_set:: 68.urn:upnp-org:serviceId:VSwitch1.Status was: 1 now: 0 #hooks:0
                  2023-01-19 20:03:33.400   luup.variable_set:: 68.urn:toggledbits-com:serviceId:Switchboard1.ImpulseResetTime was: 1674158603 now: 0 #hooks:0
                  2023-01-19 20:03:33.401   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239891ef8
                  2023-01-19 20:03:33.401   openLuup.server:: GET /cmh/skins/default/img/devices/device_states/doorbell_active.png HTTP/1.1 tcp{client}: 0x5572385f78d8
                  2023-01-19 20:03:33.402   openLuup.server:: request completed (16068 bytes, 2 chunks, 0 ms) tcp{client}: 0x5572385f78d8
                  2023-01-19 20:03:33.402   openLuup.server:: request completed (1959 bytes, 1 chunks, 11967 ms) tcp{client}: 0x557238f18fb8
                  2023-01-19 20:03:33.403   openLuup.server:: request completed (1959 bytes, 1 chunks, 11404 ms) tcp{client}: 0x55723982bdd8
                  2023-01-19 20:03:33.414   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55723982bdd8
                  2023-01-19 20:03:33.423   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238d2de78
                  2023-01-19 20:03:33.423   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66517648&MinimumDelay=50&output_format=json&_r=1674158613422 HTTP/1.1 tcp{client}: 0x557238d2de78
                  2023-01-19 20:03:33.729   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66517642&Timeout=60&MinimumDelay=1500&_=1674030727178 HTTP/1.1 tcp{client}: 0x5572385f78d8
                  2023-01-19 20:03:33.834   openLuup.server:: request completed (1553 bytes, 1 chunks, 103 ms) tcp{client}: 0x5572385f78d8
                  2023-01-19 20:03:34.318   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66517648&Timeout=60&MinimumDelay=1500&_=1674137365531 HTTP/1.1 tcp{client}: 0x557238f18fb8
                  2023-01-19 20:03:34.759   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66517648&Timeout=60&MinimumDelay=1500&_=1674030727179 HTTP/1.1 tcp{client}: 0x5572385f78d8
                  2023-01-19 20:03:36.427   luup_log:22: VeraAlexa(checkQueue@200): checkQueue: 22 - 0 in queue
                  2023-01-19 20:03:36.428   luup_log:22: VeraAlexa(checkQueue@204): checkQueue: 22 - queue is empty
                  All looks OK to me, but any thoughts would be happily received 🙂
                    @CatmanV2 I have an mqtt wrapper for the bash script, since I’m moved away from luup.
                    Anyway, try to set a volume, change your device to a single device instead of a group and let me know.
                      Thanks. So getting timeouts. Volume change had no effect (unsurprisingly)
                      2023-01-20 06:51:08.337   openLuup.server:: request completed (830 bytes, 1 chunks, 15451 ms) tcp{client}: 0x557239726108
                      2023-01-20 06:51:08.344   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239726108
                      2023-01-20 06:51:08.356   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572387c0a18
                      2023-01-20 06:51:08.357   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66523159&MinimumDelay=50&output_format=json&_r=1674197468355 HTTP/1.1 tcp{client}: 0x5572387c0a18
                      2023-01-20 06:51:09.189   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66523159&Timeout=60&MinimumDelay=1500&_=1674137367566 HTTP/1.1 tcp{client}: 0x557238f18fb8
                      2023-01-20 06:51:09.732   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66523159&Timeout=60&MinimumDelay=1500&_=1674030729214 HTTP/1.1 tcp{client}: 0x5572385f78d8
                      2023-01-20 06:51:11.437   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239bde028
                      2023-01-20 06:51:11.437   openLuup.server:: GET /data_request?GroupZones=Living%20Room%20dot&DesiredVolume=20&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=SetVolume&output_format=json&_r=1674197471434 HTTP/1.1 tcp{client}: 0x557239bde028
                      2023-01-20 06:51:11.438   luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.SetVolume
                      2023-01-20 06:51:27.520   luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -1 degr... now: sending cmd:vol:20 to dev:Living Room dot type:A32DOYMUN6DTXA serial:G090U50991720NTM customerid:A1CVTZEBJIUFJI #hooks:0
                      2023-01-20 06:51:27.521   openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557239bde028
                      2023-01-20 06:51:27.521   openLuup.server:: ...only 0 bytes sent
                      2023-01-20 06:51:27.521   openLuup.server:: error 'closed' sending 35 bytes to tcp{client}: 0x557239bde028
                      2023-01-20 06:51:27.521   openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557239bde028
                      2023-01-20 06:51:27.522   openLuup.server:: ...only 0 bytes sent
                      2023-01-20 06:51:27.522   openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557239bde028
                      2023-01-20 06:51:27.522   openLuup.server:: request completed (35 bytes, 1 chunks, 16084 ms) tcp{client}: 0x557239bde028
                      2023-01-20 06:51:27.524   openLuup.server:: request completed (939 bytes, 1 chunks, 18334 ms) tcp{client}: 0x557238f18fb8
                      2023-01-20 06:51:27.525   openLuup.server:: request completed (939 bytes, 1 chunks, 17793 ms) tcp{client}: 0x5572385f78d8
                      2023-01-20 06:51:27.527   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5572387c0a18
                      2023-01-20 06:51:27.527   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239bde028
                      And still no voice, but no time out
                      2023-01-20 06:54:39.286   openLuup.server:: request completed (591 bytes, 1 chunks, 15401 ms) tcp{client}: 0x55723969d238
                      2023-01-20 06:54:39.289   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55723969d238
                      2023-01-20 06:54:39.299   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239858308
                      2023-01-20 06:54:39.300   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66523190&MinimumDelay=50&output_format=json&_r=1674197679298 HTTP/1.1 tcp{client}: 0x557239858308
                      2023-01-20 06:54:41.367   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572394a9a68
                      2023-01-20 06:54:41.368   openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Living%20Room%20dot&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674197681363 HTTP/1.1 tcp{client}: 0x5572394a9a68
                      2023-01-20 06:54:41.368   luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say
                      2023-01-20 06:54:41.369   luup_log:22: VeraAlexa: addToQueue: added to queue for 22
                      2023-01-20 06:54:52.251   luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK">Testing....One. Two. Three</lang></s><break time="0s" /> to dev:Everywh... now: sending cmd:speak:<s>Testing...1...2...3</s><break time="0s" /> to dev:Living Room dot type:A32DOYMUN6DTXA serial:G... #hooks:0
                      2023-01-20 06:54:52.252   openLuup.server:: request completed (29 bytes, 1 chunks, 10884 ms) tcp{client}: 0x5572394a9a68
                      2023-01-20 06:54:52.254   openLuup.server:: request completed (986 bytes, 1 chunks, 43160 ms) tcp{client}: 0x557238f18fb8
                      2023-01-20 06:54:52.256   openLuup.server:: request completed (986 bytes, 1 chunks, 42675 ms) tcp{client}: 0x5572385f78d8
                      2023-01-20 06:54:52.257   openLuup.server:: request completed (986 bytes, 1 chunks, 12956 ms) tcp{client}: 0x557239858308
                      2023-01-20 06:54:52.260   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5572394a9a68
                      2023-01-20 06:54:52.263   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239858308
                      2023-01-20 06:54:52.274   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239507918
                      2023-01-20 06:54:52.274   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66523191&MinimumDelay=50&output_format=json&_r=1674197692273 HTTP/1.1 tcp{client}: 0x557239507918
                      2023-01-20 06:54:52.300   luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 23 #hooks:0
                      2023-01-20 06:54:52.405   openLuup.server:: request completed (839 bytes, 1 chunks, 130 ms) tcp{client}: 0x557239507918
                      2023-01-20 06:54:52.417   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239507918
                      2023-01-20 06:54:52.427   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55723937d598
                      Let me know if debug logs are any use to you.
                      I wonder if perhaps there's another amazon host I could use.
                        @CatmanV2 it should be alexa.amazon.co.uk.
                        If you want to be sure that's working and to see the output, just try to execute the command via SSH:
                        alexa_remote_control.sh -d 'Everywhere' -e speak:'This is a test'
                        the bash file should be in the same directory of VeraAlexa.
                        try also
                        alexa_remote_control.sh -a
                        to be sure you're receiving the list of your devices.
                        see https://github.com/thorsten-gehrig/alexa-remote-control for additional commands/params
                          try also
                          @therealdb Ta
                          catman@openluup:~/Notvera/VeraAlexa$ ./alexa_remote_control.sh -d 'Everywhere' -e speak:'This is a test'
                          cookie does not exist. logging in ...
                          ^C
                          Which is odd:
                          catman@openluup:~/Notvera/VeraAlexa$ ls -ltra
                          total 840
                          -rw-r--r--  1 root root   7249 Jun 25  2020 .alexa.devicelist.txt.old
                          -rwxr-xr-x  1 root root  49902 May 29  2021 alexa_remote_control.sh.old
                          -rwxr-xr-x  1 root root  33826 May 29  2021 alexa_remote_control_plain.sh.old
                          -rwxr-xr-x  1 root root  34367 May 29  2021 alexa_remote_control_plain.sh
                          -rwxrwxrwx  1 root root  47437 May 29  2021 alexa_remote_control.sh
                          -rw-r--r--  1 root root    216 Dec 14  2021 TestLua
                          -rw-r--r--  1 root root   1413 Mar 25  2022 cookies.txt
                          drwxr-xr-x 15 root root  12288 Nov 17 19:04 ..
                          -rw-r--r--  1 root root 147036 Jan 18 17:44 .alexa.login
                          drwxr-xr-x  2 root root   4096 Jan 18 17:45 .
                          -rw-r--r--  1 root root  12274 Jan 18 17:45 .alexa.devicelist.json
                          -rw-r--r--  1 root root 455307 Jan 18 17:49 .alexa.cookie
                          -rw-r--r--  1 root root      9 Jan 20 12:14 .alexa.volume.de3b4a21ca844817bc180e826e636425
                          -rw-r--r--  1 root root      9 Jan 20 12:14 .alexa.volume.G090U50991550NLS
                          -rw-r--r--  1 root root      9 Jan 20 12:14 .alexa.volume.G090U50991720NTM
                          -rw-r--r--  1 root root      9 Jan 20 12:14 .alexa.volume.G090XG1215150M64
                          -rw-r--r--  1 root root      9 Jan 20 12:14 .alexa.volume.90F00818720507LD
                          -rw-r--r--  1 root root      9 Jan 20 12:14 .alexa.volume.G090U5099156024K
                          -rw-r--r--  1 root root      9 Jan 20 12:14 .alexa.volume.G090LF1181220107
                          -rw-r--r--  1 root root   1366 Jan 20 12:14 .alexa.cmd
                            @therealdb Ta
                            ^C
                            Which is odd:
                            total 840
                            @CatmanV2 Is the cookie file empty? have you customized the .sh script with your credentials?
                              @therealdb No and I was about to ask that 😉
                                @CatmanV2 if you're running it via command line, you'll need to pass some variables. see the GitHub page to know which ones are mandatory (host, username and password, at least).
                                  OK thanks. Much hacking it turns out it was unhappy with the cookie (for no clear reason, and despite multiple replacements)
                                  Went old skool, changed password, new browser, new cookie and we're good.
                                  Many thanks!
                                    1.1k
                                    158.2k
