  3. Vera/openLuup plugins
  4. Logic Programming
Logic Programming
Fork Mios VERASECURE
On start up the log indicates the following: 2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) The MQTT variables are all set to "skip": MQTT_BrightnessValue MQTT_PowerStatusOff MQTT_PowerStatusOn However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to. It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
RulesEngine
E
Netatmo – Oath2 login
Vera Alexa down?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech. I seem to be getting an odd timeout but no idea from where. Debian Bullseye, bare metal Good call from this morning: 2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28 Bad request from just now: 2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 Any thoughts? Cheers C
Device issues in Open Luup
Broadlink setup
Virtual Sensor Polling
Logic Programming
15 Posts 5 Posters 6.4k Views 5 Watching
    Home Automation means you have to have a way of describing the logical steps you want your home to implement automatically.
    Whilst I've always been a fan of the Lua language, as used in Vera (and openLuup) for scenes and plugins, it's perhaps not ideal. For this reason, there has been a long development history of plugins with their own "language" to help define the automation logic: PLEG (for those with a long memory), AltUI workflows, Rules Engine, Reactor, MSR, ...
    It's always seemed to me that the 'best' way of describing logic would be a language designed for that purpose – a "logic programming language". Perhaps one of the most famous, and venerable, is Prolog, which had its fiftieth birthday last year in 2022.
    Thanks to some relatively recent research A Hitchhiker’s Guide to Reinventing a Prolog Machine, Paul Tarau (2017) it's become possible to implement a very efficient Prolog engine in a reasonably concise way. So, just for fun, I'm developing a CGI plugin for describing openLuup actions in Prolog.
    I have an early prototype running (written in Lua, of course). It presents a web page which looks like a fairly typical Interactive Development Environment (IDE) and contains some primitives which allow basic access to the Luup engine.
    In a subsequent post, I'll give a glimpse of its capabilities...
      Brain the size of a planet, and what do they ask me to do?
        It's highly likely that you're not on every-day speaking terms with Prolog.
        According to the renowned TIOBE popularity index Prolog stands today (March 2023) at 0.23% (#39) – for perspective, Python (#1) is at 14.83%, Lua (#30) is at 0.36%.
        ...so a micro-tutorial may be in order.
        Prolog's universe is a database of facts and rules.
        Facts:
        small(lua).
        powerful(lua).
        powerful(python).
        large(python).
        meaning whatever you want it to mean, but let's say that it's true that lua is small and it's also true that it's powerful. On the other hand, python is powerful and large.
        Rules:
        great_to_use(X) :- small(X), powerful(X).
        meaning that X is great to use if it's small and also powerful. Note that X is a variable because it starts with an upper-case letter.
        Prolog's syntax is minimal and concise, and can take some getting used to. It has atoms (like lua), variables (like X), lists ([a,b,c]), strings "hello", and numbers 1.23. The things that look like procedure calls are predicates, and their arguments can be any other language construct. They can also succeed multiple times, returning different solutions.
        Using the above database of facts and rules, we can ask which languages are powerful:
        ?- powerful(X).
        and receive the result(s):
        powerful(lua).
        powerful(python).
        but we can also ask which languages are great to use, which invokes a rule acting on some of the database facts:
        ?- great_to_use(X).
        giving, of course:
        great_to_use(lua).
        Now just imagine how you can use rules like this when the facts in the database are the state of your HA devices...
          Shocked to find FORTAN occupying the #17 slot! And there's Groovy down at #34.
            Prolog rules can be applied to a live database of facts which reflect the state of your SmartHome and make a powerful combination.
            The first two predicates I've integrated into my openLuup Prolog prototype are:
            • luup_var (Device, Service, Variable, Value) and
            • luup_attr (Device, Attribute, Value)
            These mirror the standard Luup calls luup.variable_get() and luup.attr_get(), and, at first glance, provide the same functionality. Querying a variable:
            ?- luup_var(2,"openLuup","Memory_Mb",X).
            yields the result:
            luup_var(2,"openLuup","Memory_Mb",4.3).
            And similarly for a device attribute:
            ?- luup_attr(2,"room", X).
            gives:
            luup_attr(2,"room", 0)
            All very much as expected. But what happens when an unknown (a Prolog variable) is put in place of one of the usual 'input' parameters?
            ?- luup_var(2,"openLuup",V, X).
            Well, of course, you get all the possible solutions which match:
            luup_var(2,"openLuup","StartTime","2023-03-11T16:44:00").
            luup_var(2,"openLuup","Vnumber",230303).
            luup_var(2,"openLuup","Uptime_Days",0.03).
            luup_var(2,"openLuup","CpuLoad",0.1).
            luup_var(2,"openLuup","Memory_Mb",7.1).
            luup_var(2,"openLuup","Version","v23.3.3").
            luup_var(2,"openLuup","HouseMode",1).
            Here's an example of asking for which devices have been disabled:
            ?- luup_attr(D,"disabled", 1).
            and we discover that there are two of them:
            luup_attr(371,"disabled",1).
            luup_attr(349,"disabled",1).
            You could, if you must, also ask for the value of all variables in the system:
            ?- luup_var(D,S,V, X).
            This screenshot of the console:
            ...captures the beginning of the output, and shows that there are 466 variables in my test system.
            This only just scratches the surface of what is possible, and next post I'll show some slightly more sophisticated (and useful) examples.
              One of the joys of the Prolog language is the conciseness. You simply express the solution you are after as a series of assertions which must be true. There are no explicit variable declarations, for-loops, if-then-else statements, or begin-end blocks.
              Let's choose a simple, but realistic, example using the Luup primitives and answer the question: which devices are battery powered?
              luup_var(D,S,"BatteryLevel",Value)
              which, for my test system gives:
              luup_var(352,"urn:micasaverde-com:serviceId:HaDevice1","BatteryLevel",12)
              luup_var(353,"urn:micasaverde-com:serviceId:HaDevice1","BatteryLevel",19)
              luup_var(370,"urn:micasaverde-com:serviceId:HaDevice1","BatteryLevel",77)
              luup_var(351,"urn:micasaverde-com:serviceId:HaDevice1","BatteryLevel",100)
              luup_var(30004,"urn:micasaverde-com:serviceId:HaDevice1","BatteryLevel",97)
              By default, the user interface returns the results in the same form as the query itself. There is, however, the option to format the results as an arbitrary Prolog term, using the variables from the original query.
              So, asking the same question, but only wanting the device number and battery level as a result:
              Gives this result:
              [352,12]
              [353,19]
              [370,77]
              [351,100]
              [30004,97]
              A bit cryptic for you? Let's retrieve the device name too, and also say we're only interested in batteries which are under 20% full. Using a pattern of [D, Name, Value] and this query:
              luup_var(D,S,"BatteryLevel",Value), Value < 20, luup_attr(D, "name", Name)
              we get:
              [352,"Hue Hue motion sensor 1",12]
              [353,"Hue Hue ambient light sensor 1",19]
              ...very suitable output to trigger an alert email message, for example.
              This is significantly briefer than any Lua code that you could write to achieve the same result. Up to this point, through, we're just using it as a database query language, but Prolog is capable of significantly more complex logical inferences...
                mrFarmer
                Now this is a flashback to University. They tried to teach us logical and AI programming using prolog. I might still have a book on it, you know one of those things made out many sheets of paper 🙂
                And we used Fortran for mathematical problems I thought those professors where dinosaurs back then. Lol, how slow that world changes in our fast changing world.
                • M mrFarmer
                  @mrFarmer said in Logic Programming:
                  Ah! This one, perhaps?
                  Programming in Prolog
                  Originally published in 1981, this was the first textbook on programming in the Prolog language and is still the definitive introductory text on Prolog. Though many Prolog textbooks have been published since, this one has withstood the test of time because of its comprehensiveness, tutorial...
                  or this
                  https://mitpress.mit.edu/9780262691635/the-art-of-prolog/
                  ...both old favourites.
                  By its very nature, logic programming has very robust theoretical foundations and, although not widely used in its basic form, it did give rise to constraint-based programming (Ciao, for example), which is applied to almost everything you can think of these days.
                    or this
                    @akbooer a few months back, you hinted in post somewhere (can't find it), that you were working on a "new project"! It will be interesting to see how this works out.
                    In the openLuup realm you already have a large database of "Facts" that you can "Query" and apply "Rules" to - so off to a good start from that aspect. (don't quote me on the nomenclature).
                    The book referenced above can be downloaded from here: The Art of Prolog along with many other relevant texts.
                    This one is also a favorite - it can be downloaded but I don't have an account and I already have a physical copy (might be worth a few bucks on ebay). May be someone else could download the pdf and post it here? Not the latest Prolog but interesting all the same. The Borland people had some great products in the old days.
                    @mrFarmer said: flashback to University... you know one of those things made out many sheets of paper.
                    Yeah - you knew you were getting the latest stuff when it was a pile of photostats stapled together.
                    • A a-lurker
                      Any more work on this one - I'm sure University of North Texas. USA would be interested in your work? Eg as a teaching aid?
                      Mainstream IoT users or other parties may find, out of ignorance, that Prolog is a bit on the esoteric side - there is no doubt others would be interested?
                      Lua, in itself, was born under interesting circumstances (politics) and is now seen in many a device. Anyone got a FritzBox for example? Let alone the game industry.
                      Prolog is not a language I am familiar with but I also absolutely refused to learn Fortran - just one GO TO to many and let's not speak of the pre declaration of i, j, k .. etc. Almost assembly language. So easy to make a Fortran compiler - not surprising Fortran was all over the place.
                      At that point, I got regimented to using parallel C for a few weeks. Thought that was a back step but it certainly wasn't. I now write Lua like it was C - just habit and I wasn't that good at C.
                        Well, it went as far as I needed at the time, and then I went down a rabbit hole of some esoteric (and sometimes quite old) Prolog research papers.
                        I learned Fortran IV at school, and much later ran industrial research groups whose lingua franca was Fortran. Yes, easy enough to make a small compiler (although it’s worth looking at the early compilers’ treatment of arithmetic operator priorities!)
                        I’ve always thought of C as an assembly language (based on PDP 11 instructions) and always eschewed it.
                        Lua is almost perfection, but if you’re wanting straight-forward logical inference, then use a proper logic language! I think the examples I gave shows some of the advantages.
                          Just for fun, I checked the latest TIOBE index:
                          #11 Fortran 1.4%
                          #24 Prolog 0.77%
                          #33 Lua 0.44%
                            Arhhh just fashion - this language; that language - surely they all mostly have If then else or For loops in some form or a greater than test.
                            I did a lot of assembly language (poorly) and DSP (poorly) and main stream language programmers could not understand I new nothing about high level languages. Lots of stuffing around with moving stuff from the accumulator to some register. The 68000 Motorola orthogonality was a dream come true compared to the Intel stuff. I still have nighmares thinking about the Intel addressing modes.
                            If I remember correctly (unlikely) the Fairchild F8 reset the Accumulator command to zero was 70 hex.
                            Whoops I tripped and the punched cards went all over the place. I digress.
                            • A a-lurker
                              @akbooer
                              On the Lua sides of things - have a look at this GitHub blog and this chart about half way down the page. Lua has its supporters.
                                That’s a really interesting read – thanks!
                                  1.1k
                                  158.2k
