  4. [Solved] OWM error
Organizing/ structuring rule sets and rules
Hi guys,
Just wondering how you guys organize your rule sets and rules. I wish I had an extra layer to have some more granularity, but my feature request was not popular.
Maybe there are better ways to organize my rule sets.
I use the rule sets now primarily for rooms. So a rule set per room. But maybe grouping by functionality works better. Any examples/ suggestions would be appreciated.
Moving MSR from a QNAP container to RP 5 - some issues
Tom_DT
I have installed MSR on a RP5 bare metal and then copied the config and store files. Everything seems to be on the RP5 but I am missing all global expression and I don't see the controller time.
My browser is Microsoft Edge Version 135.0.3179.54 (Official build) (64-bit)
I have probably done something stupid or missed a step but I am stuck.
Thanks for any help.
Widget deletion does not work and landing page (status) is empy
It seems that the widget deletion does not work. I tried to drag the widget to the left (as explained in here https://smarthome.community/topic/1071/deleting-widgets?_=1744037333660)
but it does not delete it. Anyone else experiencing the same problem?
Also the landing page after login is empty and seems be have some JS issues on the dev console:
Using dockerized version of Reactor (Multi-hub) latest-25082-3c348de6 on Chromium 135.0.7049.52 (Official Build) snap (64-bit)
br,
Need help reducing false positive notifications
Good day all,
I have an notification set up for my washing machine to let me know when it's complete. I have a templete sensor set up in HAAS to let me know if it's Washing, in Standby, or off, based upon the power consumption (Shelly 1PM on outlets)
- name: "Washing Machine" state: > {% if states("sensor.washer_switch_0_power")|float == 0 %} Off {% elif states("sensor.washer_switch_0_power")|float <= 2.9 %} Standby {% else %} Washing {% endif %} icon: > {% if states("sensor.washer_switch_0_power") == "off" %} mdi:washing-machine-alert {% elif states("sensor.washer_switch_0_power")|float <= 2.9 %} mdi:washing-machine-off {% else %} mdi:washing-machine {% endif %} minutes: 2
The MSR code is relatively simple. I have a built in false positive attribute for if MSR gets rebooted, because I would suddenly get tons of notifications when I upgraded MSR.
What I'm trying to introduce, is a way to verify that I just didn't bump the knob on the washing machine when transferring loads from the washer to the dryer, which turns on the display and brings the power above the Standby threshold.
The power goes up to 3.7W for about 4 minutes if the selector knob is bumped/turned.
What would the best way to do this be? I have most of my MSR code set up for a couple of years now, and my coding logic is struggling a bit.
I think I need a power threshold to be substained for a minimum time period (say 2 or 3 minutes, above 10W), before the other triggers can act. What would the best way to do that be?
Running: latest-25082-3c348de6
Fedora 41 Server
HAAS:
Core
2025.3.4
Supervisor
2025.03.4
Operating System
15.1
Frontend
20250306.0
Home Assistant up to version 2021.8.6 supported; the online version of the manual will now state the current supported versions; Fix an error in OWMWeatherController that could cause it to stop updating; Unify the approach to entity filtering on all hub interface classes (controllers); this works for device entities only; it may be extended to other entities later; Improve error detail in messages for EzloController during auth phase; Add isRuleSet() and isRuleEnabled() functions to expressions extensions; Implement set action for lock and passage capabilities (makes them more easily scriptable in some cases); Fix a place in the UI where 24-hour time was not being displayed.
Deleting widgets
Hopefully a trivial question, but how do you delete widgets in a status page? Using build 22266
MQTT configuration question
I have the following yaml configuration in local_mqtt_devices file
x_mqtt_device: set_speed: arguments: speed: type: str topic: "command/%friendly_name%" payload: type: json expr: '{ "fan": parameters.speed }'
While this works fine, I'm wondering how this could be changed to "fixed" parameters, as in this case "fan" only accepts "A", "Q" or a numeric value of 1-5?
System Configuration Check - time is offset
Hi!
I get this message when I'm on the status tab:
The time on this system and on the Reactor host are significantly different. This may be due to incorrect system configuration on either or both. Please check the configuration of both systems. The host reports 2025-04-01T15:29:29.252Z; browser reports 2025-04-01T15:29:40.528Z; difference 11.276 seconds.
I have MSR installed as a docker on my Home Assistant Blue / Hardkernel ODROID-N2/N2+. MSR version is latest-25082-3c348de6.
HA versions are:
Core 2025.3.4
Supervisor 2025.03.4
Operating System 15.1
I have restarted HA as well as MSR multiple times. This message didn´t show two weeks ago. Don´t know if it have anything to do with the latest MSR version.
Do anyone know what I can try?
Thanks in advance!
Let's Be Careful Out There (Hill Street reference...) 🙂
/Fanan
Programmatically capture HTTP Request action status code or error
I have a very strange situation, where if InfluxDB restarts, other containers may fail when restarting at the same time (under not easy to understand circumstances), and InfluxDB remains unreachable (and these containers crashes). I need to reboot these containers in an exact order, after rebooting InfluxDB.
While I understand what's going on, I need a way to reliable determine that InfluxDB is not reachable and these containers are not reachable, in order to identify this situation and manually check what's going on - and, maybe, in the future, automatically restart them if needed.
So, I was looking at HTTP Request action, but I need to capture the HTTP response code, instead of the response (becase if ping is OK, InfluxDB will reply with a 204), and, potentially, a way to programmatically detect that it's failing to get the response.
While I could write a custom HTTP controller for this or a custom HTTP virtual device, I was wondering if this is somewhat on you roadmap @toggledbits
ZwaveJSUI - RGBWW BULB - Warm/Cold White interfered with RGB settings - Bulb doesn't change color if in WarmWhite state.
Hi ,
I'm on
-Reactor (Multi-hub) latest-25067-62e21a2d
-Docker on Synology NAS
-ZWaveJSUI 9.31.0.6c80945
Problem with ZwaveJSUI:
When I try to change color to a bulb RGBWW, it doesn't change to the RGB color and the bulb remains warm or cold white.
I tryed with Zipato RGBW Bulb V2 RGBWE2, Hank Bulb HKZW-RGB01, Aentec 6 A-ZWA002, so seems that it happens with all RGBWW bulb with reactor/zwavejsui.
I'm using from reator the entity action: "rgb_color.set" and "rgb_color.set_rgb".
After I send the reactor command, It changes in zwavejsui the rgb settings but doesn't put the white channel to "0", so the prevalent channel remains warm/cold White and the bulb doesn't change into the rgb color.
This is the status of the bulb in zwavejsui after "rgb_color.set" (235,33,33,) and the bulb is still warmWhite.
x_zwave_values.Color_Switch_currentColor={"warmWhite":204,"coldWhite":0,"red":235,"green":33,"blue":33}
The "cold white" and "warm white" settings interfer with the rgb color settings.
Reactor can change bulb colors with rgb_color set — (value, ui8, 0x000000 to 0xffffff) or rgb_color set_rgb — (red, green, blue, all ui1, 0 to 255) but if warm or cold white
are not to "0", zwavejsui doesn't change them and I can't find a way to change into rgb or from rgb back to warm white.
So if I use from reactor: rgb_color set_rgb — (235,33,33) in zwavejsui I have
x_zwave_values.Color_Switch_targetColor={"red":235,"green":33,"blue":33} 14/03/2025, 16:43:57 - value updated Arg 0: └─commandClassName: Color Switch └─commandClass: 51 └─property: targetColor └─endpoint: 0 └─newValue └──red: 235 └──green: 33 └──blue: 33 └─prevValue └──red: 235 └──green: 33 └──blue: 33 └─propertyName: targetColor 14/03/2025, 16:43:57 - value updated Arg 0: └─commandClassName: Color Switch └─commandClass: 51 └─property: currentColor └─endpoint: 0 └─newValue └──warmWhite: 204 └──coldWhite: 0 └──red: 235 └──green: 33 └──blue: 33 └─prevValue └──warmWhite: 204 └──coldWhite: 0 └──red: 235 └──green: 33 └──blue: 33 └─propertyName: currentColor
In zwavejsui, the bulb changes rgb set but warm White remains to "204" and the bulb remais on warm White channel bacause is prevalent on rgb set.
x_zwave_values.Color_Switch_currentColor_0=204 x_zwave_values.Color_Switch_currentColor_1=0 x_zwave_values.Color_Switch_currentColor_2=235 x_zwave_values.Color_Switch_currentColor_3=33 x_zwave_values.Color_Switch_currentColor_4=33
Is it possible to targetColor also for "warmWhite" and "coldWhite" and have something similar to this?
x_zwave_values.Color_Switch_targetColor={"warmWhite":0,"coldWhite":0,"red":235,"green":33,"blue":33}
Thanks in advance.
Problem with simultaneous notifications.
Good day all,
I have a reaction set up, that I use for both troubleshooting and changing home modes when one of my family members either arrive or are leaving. I use the companion app for HAAS on our iPhones, and HAAS reports if the person associated with the iPhone enters or leaves the geofenced area around my home. I'm sure most MSR and HAAS users are familiar with this.
I use this rule set mainly as a condition for other rules, however, as part of troubleshooting, a notification is sent through HAAS to the companion app when the rule becomes true. The problem is that I'm getting notifications now for both arriving and departing simultaneously.
36903cdd-a87f-473b-82ef-af9ef96d3c44-image.png It used to work fine as intended. I'm not sure exactly when it changed, but now I'm getting two notifications when either of these conditions change.
Any idea what could be happening?
Edit:
Running: latest-25082-3c348de6, bare-metal Linux
ZWaveJSControllerr [0.1.25082]
Problem after upgrading to 25067
MSR had been running fine, but I decided to follow the message to upgrade to 25067. Since the upgrade, I have received the message "Controller "<name>" (HubitatController hubitat2) could not be loaded at startup. Its ID is not unique." MSR throws the message on every restart. Has anyone else encountered this problem?
I am running MSR on a Raspberry Pi4 connecting to two Hubitat units over an OpenVPN tunnel. One C8 and a C8 Pro. Both are up-to-date. It appears that despite the error message that MSR may be operating properly.
Global expressions not always evaluated
Similarly as for local expressions, global expressions evaluate and update fine when getEntity(...) structure is used. However, at least when certain functions are in use, expressions do not update.
Consider the following test case:
Even though auto-evaluation is active, value does not change (it changes only if that expression is manually run). MSR restarts do not help.
Note: Tested using build 25067 on Docker. I have also a PR open (but couldn't now get details or PR number as my Mantis account was somehow expired?).
[Solved] Local expression evaluation
Trying to understand what cause a local expresssion to be evaluated. I have read the manual but I am still not clear about it. Using the test rule below, I can see in the log that the rule is being automatically evaluated every time the temperature entity is changing. That is great...
What I am trying to understand is why the expression is not evaluated based on time as well since the "case" statement has time dependencies.
Any help would be appreciated
I have the following test rule:
Here is the expressioncode:
vFrom1 = "09:25:00", vFrom2 = "09:30:00", vFrom3 = "09:41:00", vTo = "10:55:00", # Get current time (format HH:MM:SS) vToDay = strftime("%H:%M:%S"), #Get current house temperature CurrentHouseTemp = getEntity( "hass>Thermostat2 " ).attributes.temperature_sensor.value, case when CurrentHouseTemp <= 19 and vToDay >= vFrom1 && vToDay <= vTo: "true1" # From1 when CurrentHouseTemp <= 20 and vToDay >= vFrom2 && vToDay <= vTo: "true2" # From2 when CurrentHouseTemp < 26  and vToDay >= vFrom3 && vToDay <= vTo: "true3" # From3 else "false" end
[Solved] Runtime error when exiting global reaction that contains a group
I am getting a Runtime error on different browsers when I click exit when editing an existing or creating a new global reaction containing a group. If the global reaction does not have a group I don't get an error. I see a similar post on the forum about a Runtime Error when creating reactions but started a new thread as that appears to be solved.
The Runtime Error is different in the two browsers
Safari v18.3
@http://192.168.10.21:8111/reactor/en-US/lib/js/reaction-list.js:171:44 You may report this error, but do not screen shot it. Copy-paste the complete text. Remember to include a description of the operation you were performing in as much detail as possible. Report using the Reactor Bug Tracker (in your left navigation) or at the SmartHome Community.
Google Chrome 133.0.6943.142
TypeError: self.editor.isModified is not a function at HTMLButtonElement.<anonymous> (http://192.168.10.21:8111/reactor/en-US/lib/js/reaction-list.js:171:34) You may report this error, but do not screen shot it. Copy-paste the complete text. Remember to include a description of the operation you were performing in as much detail as possible. Report using the Reactor Bug Tracker (in your left navigation) or at the SmartHome Community.
Steps to reproduce:
Click the pencil to edit a global reaction with a group.
Click the Exit button.
Runtime error appears.
or
Click Create Reaction
Click Add Action
Select Group
Add Condition such as Entity Attribute.
Add an Action.
Click Save
Click Exit
I don’t know how long the error has been there as I haven’t edited the global reaction in a long time.
Reactor (Multi-hub) latest-25060-f32eaa46
Docker
Mac OS: 15.3.1
Cannot delete Global Expressions
SnowmanS
I am trying to delete a global expression (gLightDelay) but for some strange reason, it comes back despite clicking the Delete this expression and Save Changes buttons.
I have not created a global expression for some times and just noticed this while doing some clean-up.
I have upgraded Reactor to 25067 from 25060 and the behaviour is still there. I have restarted Reactor (as well as restarting its container) and cleared the browser's cache several times without success.
Here's what the log shows.
[latest-25067]2025-03-08T23:50:22.690Z <wsapi:INFO> [WSAPI]wsapi#1 rpc_echo [Object]{ "comment": "UI activity" } [latest-25067]2025-03-08T23:50:26.254Z <GlobalExpression:NOTICE> Deleting global expression gLightDelay [latest-25067]2025-03-08T23:50:27.887Z <wsapi:INFO> [WSAPI]wsapi#1 rpc_echo [Object]{ "comment": "UI activity" }
Reactor latest-25067-62e21a2d
Local notification methods?
Morning, experts. Hard on learning about the internet check script in MSR tools, I was wondering what suggestions anyone has about a local (i.e. non-internet dependent) notification method.
This was prompted by yesterday's fun and games with my ISP.
I've got the script Cronned and working properly but short of flashing a light on and off, I'm struggling to think of a way of alerting me (ideally to my phone)
I guess I could set up a Discord server at home, but that feels like overkill for a rare occasion. Any other suggestions?
TIA
Custom capabilities in MQTT templates
I'm trying to integrate the sonos-mqtt (https://sonos2mqtt.svrooij.io/) with the MSR and it's coming along nicely so far.
But cannot wrap my head around how to define custom capabilities in MQTT templates. I need this for the TTS announcements and similarly for the notification sounds where I would pass the sound file as parameter.
So this is what I have in the local_mqtt_devices.yaml
capabilities: x_sonos_announcement: attributes: actions: speak: arguments: text: type: string volume: type: int delay: type: int
And this is the template:
templates: sonos-announcement: capabilities: - x_sonos_announcement actions: x_sonos_announcement: speak: topic: "sonos/cmd/speak" payload: expr: > { "text": parameters.text, "volume": parameters.volume, "delayMs": parameters.delay, "onlyWhenPlaying": false, "engine": "neural" } type: json
So the speak action should send something like this to topic sonos/cmd/speak
{ "text": "message goes here", "volume": 50, "delayMs": 100, "onlyWhenPlaying": false, "engine": "neural" }
At startup the MSR seems to be quite unhappy with my configuration:
reactor | [latest-25016]2025-02-09T08:19:59.029Z <MQTTController:WARN> MQTTController#mqtt entity Entity#mqtt>sonos-announcement unable to configure capabilities [Array][ "x_sonos_announcement" ] reactor | i18n: missing fi-FI language string: Configuration for {0:q} is incomplete because the following requested capabilities are undefined: {1} reactor | i18n: missing fi-FI language string: Configuration for {0:q} has unrecognized capability {1:q} in actions reactor | Trace: Configuration for {0:q} is incomplete because the following requested capabilities are undefined: {1} reactor | at _T (/opt/reactor/server/lib/i18n.js:611:28) reactor | at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:125:25) reactor | at MQTTController.sendWarning (/opt/reactor/server/lib/Controller.js:627:30) reactor | at MQTTController.start (/var/reactor/ext/MQTTController/MQTTController.js:268:26) reactor | at async Promise.allSettled (index 0) Configuration for "sonos-announcement" has unrecognized capability "x_sonos_announcement" in actions Controller: MQTTController#mqtt Last 10:21:37 AM Configuration for "sonos-announcement" is incomplete because the following requested capabilities are undefined: x_sonos_announcement Controller: MQTTController#mqtt Last 10:21:37 AM
This is probably a pretty stupid question and the approach may not even work at all, but maybe someone or @toggledbits for sure, could point me to the right direction.
Basically the idea is to be able to send TTS messages from reactions using entity actions. I've previously used HTTP requests to Sonos HTTP API (https://hub.docker.com/r/chrisns/docker-node-sonos-http-api/) for the same functionality, but since moving to sonos-mqtt, I need a way to send the TTS notifications using MQTTController. Along with the actual message, volume and delay must also be parameterizable.
br,
MSR latest-25016-d47fea38 / MQTTController [0.2.24293]
[SOLVED]Hass websocket falsely reporting ready on boot??
Hi, @toggledbits
I just noticed that following a reboot of my raspberry pi, some of the rules, that I was expecting to recover, are not catching up following a reboot. I have made a simple test rule (rule-m6rz6ol1) with only "after Date/time" as trigger and "turn on a lamp" as a set reaction. All my infrastructure is on the same board so Reactor, Hass, Zwavejs, ... are all rebooting.
Here is the sequence of the test case (All time converted to Zulu to match logs):
Rule "after Date/Time" set to 14:05:00z Shutdown on Raspberry Pi at 14:04:00z Power back up at 14:08:00z Rule overview shows true as of 14:08:14z waiting for 00:00:00 in GUI
From the log I can see that MSR is picking up the rule and knows that the state of the rule has changed from false to true and tries to send the update to HASS but failed with websocket error.
Here is what I see from the log:
14:04:04z shutdown complete 14:08:08z Power up 14:08:13.111z websocket connection 14:08:15:323z Reaction to the light failed, Websocket not opened After there is a series of websocket connection attempt until 14:08:51z where it seemed to be really ready.
Back in 2021 we had a discussion (https://smarthome.community/topic/700/solved-start-up?_=1738766986566) and you proposed to add a startup_delay:xxxx and startup_wait:xxxx parameter in the engine section of "reactor.yaml". When I try the startup_delay (this used to be a hard delay), the engine failed to start (I think). I then try the startup_wait:xxxx without any success. Since it wait for the connection status to be up to cancel the delay, it does not do anyting since Hass is reporting the socket up without really being up ( I think...).
Questions:
Did I figured it all wrong? should the startup_delay:xxxxx have worked? Any ideas?
Here is the log:
OK now I am stuck. I did add the log but when I submit the editor complained saying that I am limited to 32767 characters. The log from the shutdown to the time the websocket is stable is about 300000 character long. What are my options?
[SOLVED]Logs permissions for Docker Install
Not a big issue simply a request if easily doable.
The MSR logs files inside the container are owned by root witch is fine however, the permissions are very restrictive. I do not know if there is something wrong with my installation but the logs permission are set to 222 (write only). Even if the docker volume is set for Read/Write the log files are retaining these values.
I go around the problem by doing a chmod 777 on all reactor logs but every time there is an MSR log rotation the permissions are set back to 222. So unless the permission are implemented in the container there is no permanent solution to this (that I know of).
I do not know much about Docker container so I do not know what is involved here.
Can the logfiles permission be simply chaged in the container to at least allow "other" read permission?
Could the MSR log rotation routine implement a chmod to set the permission?
Just a small anoyance
[Solved] OWM error
9 Posts 3 Posters 555 Views
  • wmarcolinW Offline
    Hi @toggledbits
    I'm trying to use OWM, apparently, I receive the correct information, but after a while, the MSR disconnects.
    My configuration is as follows.
      - id: weather
        enabled: true
        implementation: OWMWeatherController
        config:
          # Place your OWM API key here (remember to enable the controller after adding your appid)
          appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
          # How often weather is allowed to be refreshed. This helps limit OWN API use,
          # to keep you in their good graces (and on their free tier). This value is
          # in minutes.
          interval: 30
          locations:
          - id: home
            # Set the location by specifying ONE OF: latitude+longitude, OWN city
            # ID, or location (as postal,country). If none is set, the system
            # location will be used.
            latitude: 8.9936
            longitude: -79.5197
            city_id: 3703443
            #location: "30269,us"
            # Enable "save_full_response" to save the full response (you may have
            # need to use parts of the response that are not part of the wx
            # capability in your dashboard widgets).
            #save_full_response: false
    When I request a systemctl status reactor I get this message:
    root@main:/home/wilson/reactor/logs# systemctl status reactor
    ● reactor.service - Multi System Reactor
         Loaded: loaded (/etc/systemd/system/reactor.service; enabled; vendor preset: enabled)
         Active: active (running) since Fri 2023-09-08 21:03:13 EST; 5s ago
       Main PID: 194711 (node)
          Tasks: 11 (limit: 9390)
         Memory: 82.5M
            CPU: 2.508s
         CGroup: /system.slice/reactor.service
                 └─194711 /usr/bin/node app -p
    Sep 08 21:03:13 main node[194711]: Error: Incompatible serialization data; can't unserialize
    Sep 08 21:03:13 main node[194711]:     at System.unserialize (/home/wilson/reactor/server/lib/Entity.js:624:19)
    Sep 08 21:03:13 main node[194711]:     at /home/wilson/reactor/server/lib/Controller.js:458:70
    Sep 08 21:03:13 main node[194711]:     at Array.forEach (<anonymous>)
    Sep 08 21:03:13 main node[194711]:     at OWMWeatherController._restoreEntities (/home/wilson/reactor/server/lib/Controller.js:446:36)
    Sep 08 21:03:13 main node[194711]:     at new Controller (/home/wilson/reactor/server/lib/Controller.js:37:45)
    Sep 08 21:03:13 main node[194711]:     at new OWMWeatherController (/home/wilson/reactor/server/lib/OWMWeatherController.js:327:9)
    Sep 08 21:03:13 main node[194711]:     at /home/wilson/reactor/server/lib/Controller.js:93:37
    Sep 08 21:03:13 main node[194711]: [latest-23242]2023-09-09T02:03:13.855Z <NUTController:null> Module NUTController v22305
    Sep 08 21:03:13 main node[194711]: [latest-23242]2023-09-09T02:03:13.859Z <SystemController:null> Module SystemController v23214
    root@main:/home/wilson/reactor# systemctl status reactor
         Active: active (running) since Fri 2023-09-08 20:48:36 EST; 2min 58s ago
       Main PID: 194353 (node)
         Memory: 66.0M
            CPU: 9.493s
                 └─194353 /usr/bin/node app -p
    Sep 08 20:48:37 main node[194353]:     at System.unserialize (/home/wilson/reactor/server/lib/Entity.js:624:19)
    Sep 08 20:48:37 main node[194353]:     at /home/wilson/reactor/server/lib/Controller.js:458:70
    Sep 08 20:48:37 main node[194353]:     at Array.forEach (<anonymous>)
    Sep 08 20:48:37 main node[194353]:     at OWMWeatherController._restoreEntities (/home/wilson/reactor/server/lib/Controller.js:446:36)
    Sep 08 20:48:37 main node[194353]:     at new Controller (/home/wilson/reactor/server/lib/Controller.js:37:45)
    Sep 08 20:48:37 main node[194353]:     at new OWMWeatherController (/home/wilson/reactor/server/lib/OWMWeatherController.js:327:9)
    Sep 08 20:48:37 main node[194353]:     at /home/wilson/reactor/server/lib/Controller.js:93:37
    Sep 08 20:48:37 main node[194353]: [latest-23242]2023-09-09T01:48:37.017Z <NUTController:null> Module NUTController v22305
    Sep 08 20:48:37 main node[194353]: [latest-23242]2023-09-09T01:48:37.024Z <SystemController:null> Module SystemController v23214
    Sep 08 20:48:37 main node[194353]: [latest-23242]2023-09-09T01:48:37.475Z <Timer:null> Timer#rule-l7ujwva5 just a note: I'm setting a delay of >
    lines 1-20/20 (END)
    I can see this information in the log, but I don't understand what I should do to fix it.
    [latest-23242]2023-09-09T02:03:13.838Z <DynamicGroupController:null> Module DynamicGroupController v22313
    [latest-23242]2023-09-09T02:03:13.845Z <Structure:INFO> Structure#1 loading controller interface weather (OWMWeatherController)
    [latest-23242]2023-09-09T02:03:13.847Z <OWMWeatherController:null> Module OWMWeatherController v22294
    [latest-23242]2023-09-09T02:03:13.850Z <Controller:WARN> OWMWeatherController#weather failed (1) to restore entity controller_all: [Error] Inco>
    [latest-23242]2023-09-09T02:03:13.850Z <Controller:CRIT> Error: Incompatible serialization data; can't unserialize [-]
        at Group.unserialize (/home/wilson/reactor/server/lib/Entity.js:624:19)
    [latest-23242]2023-09-09T02:03:13.851Z <Controller:WARN> OWMWeatherController#weather failed (1) to restore entity default: [Error] Incompatibl>
    [latest-23242]2023-09-09T02:03:13.851Z <Controller:CRIT> Error: Incompatible serialization data; can't unserialize [-]
        at Entity.unserialize (/home/wilson/reactor/server/lib/Entity.js:624:19)
    [latest-23242]2023-09-09T02:03:13.852Z <Controller:WARN> OWMWeatherController#weather failed (1) to restore entity system: [Error] Incompatible>
    [latest-23242]2023-09-09T02:03:13.852Z <Controller:CRIT> Error: Incompatible serialization data; can't unserialize [-]
    [latest-23242]2023-09-09T02:03:13.853Z <Structure:INFO> Structure#1 loading controller interface nut (NUTController)
    [latest-23242]2023-09-09T02:03:13.855Z <Controller:INFO> Loaded NUTController version "0.1.22305"; Patrick Rigney/Kedron Holdings LLC <patrick@>
    [latest-23242]2023-09-09T02:03:13.857Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
    And finally, I have a second house, with the same OWM configuration I made today, and it doesn't show any errors.
    Please, your traditional help.
      replied to wmarcolin on last edited by
      @wmarcolin said in OWM error:
      Have you literally copy/pasted the config section from the working to the non-working?
      *Hubitat C-7 2.4.1.151
      *HASS 2025.3.4
      w/ ZST10-700 fw 7.18.3
      MSR: latest-25082-3c348de6
      MQTTController: 24257
      ZWave Controller: 25082
      wmarcolinW 1 Reply Last reply
        replied to gwp1 on last edited by
        @gwp1
        Same configuration on both systems, but there are differences in that one runs on a C7 and the other on a C8, and the computers are slightly different but the VM runs the same and has the same capacity, so I don't think this would interfere.
        root@main:/home/wilson# systemctl status reactor
             Active: active (running) since Sat 2023-09-09 15:48:22 EST; 4min 29s ago
           Main PID: 630 (node)
             Memory: 100.4M
                CPU: 13.985s
                     └─630 /usr/bin/node app -p
        Sep 09 15:48:26 main node[630]:     at new Controller (/home/wilson/reactor/server/lib/Controller.js:37:45)
        Sep 09 15:48:26 main node[630]:     at new OWMWeatherController (/home/wilson/reactor/server/lib/OWMWeatherController.js:327:9)
        Sep 09 15:48:26 main node[630]:     at /home/wilson/reactor/server/lib/Controller.js:93:37
        Sep 09 15:48:26 main node[630]: [latest-23242]2023-09-09T20:48:26.426Z <NUTController:null> Module NUTController v22305
        Sep 09 15:48:26 main node[630]: [latest-23242]2023-09-09T20:48:26.444Z <SystemController:null> Module SystemController v23214
        Sep 09 15:48:28 main node[630]: [latest-23242]2023-09-09T20:48:28.524Z <Timer:null> Timer#rule-l7ujwva5 just a note: I'm setting a delay of only 5ms (from 16942925>
        Sep 09 15:48:29 main node[630]: [latest-23242]2023-09-09T20:48:29.369Z <Notifier:null> Module Notifier v22283
        Sep 09 15:48:29 main node[630]: [latest-23242]2023-09-09T20:48:29.394Z <default:null> Module NotifyTelegram v21221
        Sep 09 15:48:35 main node[630]: /home/wilson/reactor/logs/reactor.log size hit rotation limit, rotating
        Sep 09 15:48:35 main node[630]: stream /home/wilson/reactor/logs/reactor.log not open boolean false
        lines 1-20/20 (END)
        I've just restarted the VM and checked the status, and the following error appears, but the MSR operates apparently normally.
        Thaks.
          Sounds like the persistence file for the entity is corrupt. You've probably had a disk full condition somewhere along the way, or maybe you're beginning to see a Flash wear problem. Just stop MSR, delete the storage/entitites/weather directory, and restart.
            replied to toggledbits on last edited by
            All right, no more errors.
            Thank you.
              @wmarcolin If this is solved can you please edit the topic to have the prefix [Solved]?
              *HASS 2025.3.4
              • wmarcolinW wmarcolin marked this topic as a question on
              • wmarcolinW wmarcolin has marked this topic as solved on
                @gwp1
                Hola, how do I edit the title to put [Solved]? I found how to change the status, but not how to change the name. Can you explain? Thank you.
                  @wmarcolin Go back to your original post, Edit, resave. 🙂
                  *HASS 2025.3.4
                    @gwp1
                    • Disaster recovery and virtualisation
                    • Remote access of Zwave stick from Z-wave server
                    • Organizing/ structuring rule sets and rules
                    • Moving MSR from a QNAP container to RP 5 - some issues
                    • Widget deletion does not work and landing page (status) is empy
                    • Need help reducing false positive notifications
                      35.1k
                    • Deleting widgets
                    • MQTT configuration question
                    • System Configuration Check - time is offset
