  4. [Solved] OWM error
Time series documentation
Reset a delay
Reactor Loading Screen Safari
I'm having an issue with MSR's UI being very unresponsive. It started happening a couple days ago and I didn't make any changes that would have caused this except adding some meross lan devices in HA. When I go into an entity action and use the search functionality, it usually will start filtering and then get to a place after a few letters are entered where it will take 30 seconds or more (sometimes minutes) for the UI to show what I am typing. During this time MSR ui is completely unresponsive. I've tried multiple browsers and multiple computers. HA and MSR are both deployed in docker. I have run HTOP on the host and when the problem happens there are no CPU/Memory spikes at all. From a functionality standpoint MSR is working perfectly. This seems to be an UI issue only. Do i need to ditch Docker and run MSR on a Proxmox VM? I have both stand alone Docker and Proxmox environments. I dont mind doing that I just want to be able to use the UI again... Installation method Home Assistant Container Core 2025.7.3 Frontend 20250702.3 nothing crazy in the logs except some openweather map stuff that doesn't make any sense as it is working fine in MSR Any help would be greatly appreciated Reactor latest-25328-b2ed1365 app 25328 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.843Z <app:null> Reactor build latest-25328-b2ed1365 starting on v24.11.1 /usr/local/bin/node [latest-25328]2025-11-30T20:01:53.844Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #161-Ubuntu SMP Tue Jul 22 14:25:40 UTC 2025; locale (undefined) [latest-25328]2025-11-30T20:01:53.844Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-25328]2025-11-30T20:01:53.844Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.865Z <app:null> Resolved timezone=America/New_York, environment TZ=America/New_York; offset minutes from UTC=-300 [latest-25328]2025-11-30T20:01:53.867Z <default:null> Module i18n v25141 [latest-25328]2025-11-30T20:01:53.867Z <app:null> Configured locale (undefined); selected locale(s) en-US.UTF-8 [latest-25328]2025-11-30T20:01:53.879Z <app:null> Loaded locale en-US for en-US [latest-25328]2025-11-30T20:01:53.879Z <app:null> Local date/time using configured timezone and locale formatting is "11/30/2025, 3:01:53 PM" [latest-25328]2025-11-30T20:01:53.889Z <Structure:null> Module Structure v25326 [latest-25328]2025-11-30T20:01:53.890Z <Capabilities:null> Module Capabilities v24312 [latest-25328]2025-11-30T20:01:53.904Z <Plugin:null> Module Plugin v25141 [latest-25328]2025-11-30T20:01:53.923Z <Timer:null> Module Timer v25279 [latest-25328]2025-11-30T20:01:53.924Z <TimerBroker:null> Module TimerBroker v25314 [latest-25328]2025-11-30T20:01:53.927Z <Entity:null> Module Entity v25251 [latest-25328]2025-11-30T20:01:53.929Z <Controller:null> Module Controller v25253 [latest-25328]2025-11-30T20:01:53.930Z <AlertManager:null> Module AlertManager v25318 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Ruleset v25283 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Rulesets v25141 [latest-25328]2025-11-30T20:01:53.942Z <GlobalExpression:null> Module GlobalExpression v25258 [latest-25328]2025-11-30T20:01:53.953Z <Predicate:null> Module Predicate v25328 [latest-25328]2025-11-30T20:01:53.956Z <Rule:null> Module Rule v25323 [latest-25328]2025-11-30T20:01:53.958Z <GlobalReaction:null> Module GlobalReaction v25292 [latest-25328]2025-11-30T20:01:53.959Z <Engine:null> Module Engine v25325 [latest-25328]2025-11-30T20:01:53.964Z <httpapi:null> Module httpapi v25328 [latest-25328]2025-11-30T20:01:53.972Z <wsapi:null> Module wsapi v25328 [latest-25328]2025-11-30T20:01:53.994Z <TaskQueue:null> Module TaskQueue 24138 [latest-25328]2025-11-30T20:01:53.994Z <VeraController:null> Module VeraController v25141 [latest-25328]2025-11-30T20:01:54.179Z <HassController:null> Module HassController v25325 [latest-25328]2025-11-30T20:02:13.797Z <OWMWeatherController:null> Module OWMWeatherController v25268 [latest-25328]2025-11-30T20:02:13.800Z <SystemController:null> Module SystemController v25323 [latest-25328]2025-11-30T20:02:13.807Z <MQTTController:null> Module MQTTController v22092 [latest-25328]2025-11-30T20:02:20.630Z <OWMWeatherController:CRIT> FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxx&lon=-xxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxxxxxxxxx&units=standard&_r=1xxxxxxxxxxxxxxfailed, reason: [-] FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxxx&lon=-xxxxxxxxxxxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxx&units=standard&_r=xxxxxxxxxxxxxxxfailed, reason: at ClientRequest.<anonymous> (/opt/reactor/node_modules/node-fetch/lib/index.js:1501:11) at ClientRequest.emit (node:events:508:28) at ClientRequest.emit (node:domain:489:12) at emitErrorEvent (node:_http_client:108:11) at TLSSocket.socketErrorListener (node:_http_client:575:5) at TLSSocket.emit (node:events:508:28) at TLSSocket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:170:8) at emitErrorCloseNT (node:internal/streams/destroy:129:3) at processTicksAndRejections (node:internal/process/task_queues:89:21
Date/time condition
Device log?
This post does not apply to users of Intel/AMD-based systems. If you are using a Reactor image tagged latest-amd64 or stable-amd64, then this post does not apply to you. It also does not apply to bare-metal installs; it's for users of docker images on ARM-based systems only (principally Raspberry Pi hosts, but could be others). After January 15, 2026, I will no longer produce the aarch64-tagged docker image for Reactor. The ARM images will be arm64 for 64-bit operating systems, and armv7l for 32-bit operating systems. For those of you running a container from the aarch64 image today, this will be a relatively simple change: you just need to switch the image used for your docker container to a differently-tagged image. If you are using docker-compose, then this is a relatively simple matter of changing the image line in your docker-compose.yaml file and then stopping (docker-compose down) and restarting (docker-compose up -d) your Reactor daemon. But there's a catch... not all of you can safely just switch from the aarch64 image to the arm64 image. And, you can't just trust the output of uname -m, for example, because this exposes the CPU architecture, but not the word size of the OS running on that CPU. For Raspberry Pi systems, the transition to 64-bit operating systems was long (starting in 2016) and not always obvious — although there was a first "official" 64-bit OS for RPis in 2020, it did not become a default recommendation in the Raspberry Pi Imager until 2021, and then that was only the default for Pi 3/4 systems with >4GB RAM; it was 2022 before it was universally recommended for all 64-bit CPUs regardless of RAM size. Depending on when you first imaged your RPi system and what default you may have been offered/chosen, you could today easily have a 64-bit CPU Raspberry Pi running a 32-bit version of the operating system. Upgrades along the way would not change this; changing it to fully 64-bit requires a full reimage of the system. To establish if your OS is 64- or 32-bit, log in to your Pi and run: sudo dpkg-architecture -q DEB_HOST_ARCH. If the response is arm64 or aarch64, then you are running a 64-bit OS and you should use the arm64-tagged image. If it's anything else, you are running a 32-bit OS, and you should use the armv7l-tagged image. pi@rpi4-1:~ $ sudo dpkg-architecture -q DEB_HOST_ARCH armhf pi@rpi4-1:~ $ uname -m aarch64 pi@rpi4-1:~ $ In the example above, the uname command reports that the CPU is 64-bit architecture (aarch64), which is true for the host on which I ran these commands, but the DEB_HOST_ARCH value is armhf, indicating a 32-bit operating system. This system has to use the armv7l-tagged image. Other systems will have their own ways of determining the word size of the running OS. Since the majority of Reactor users running ARM systems are on Raspberry Pis, I am able to supply the above instructions, but if you happen to have a different ARM system, you'll need to do some web searching to figure out how to expose that information. Or, you can just try the arm64 image, and if it doesn't start up, try the armv7l image. Remember to always back up your system before making any changes. For everyone, please make this change as soon as possible, and if you have any trouble finding a working image, please (1) go back to the current aarch64 image; and (2) let me know in this thread along with as much detail about your host system as you can offer (including the output of the dpkg-architecture command mentioned above).
@toggledbits Do you know if this is related to that PR or is it a change they made in 2025.11.1? [latest-25310]2025-11-11T13:16:24.319Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag with { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.320Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag action: { "type": "call_service", "service_data": { "date": (null), "time": "10:45", "datetime": (null), "timestamp": (null) }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_dag" } } [latest-25310]2025-11-11T13:16:24.321Z <HassController:ERR> HassController#hass request 1762866984320<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.321Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "10:45" }) on Entity#hass>input_datetime_vvb_dag failed! [latest-25310]2025-11-11T13:16:24.321Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"10:45","datetime":null,"timestamp":null},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_dag"},"id":1762866984320} [latest-25310]2025-11-11T13:16:24.322Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.322Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 0 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Engine#1 action args: { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 1 [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt with { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt action: { "type": "call_service", "service_data": { "date": (null), "time": "03:00", "datetime": (null), "timestamp": 0 }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_natt" } } [latest-25310]2025-11-11T13:16:24.324Z <HassController:ERR> HassController#hass request 1762866984323<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "03:00", "timestamp": 0 }) on Entity#hass>input_datetime_vvb_natt failed! [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"03:00","datetime":null,"timestamp":0},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_natt"},"id":1762866984323} [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.324Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 1 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <Engine:INFO> Engine#1 action args: { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 2 [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Sätt Schema VVB i Home Assistant<AKTIV> all actions completed.
P
[Solved] OWM error
9 Posts 3 Posters 1.4k Views 3 Watching
  • wmarcolinW Offline
    Hi @toggledbits
    I'm trying to use OWM, apparently, I receive the correct information, but after a while, the MSR disconnects.
    My configuration is as follows.
      - id: weather
        enabled: true
        implementation: OWMWeatherController
          # Place your OWM API key here (remember to enable the controller after adding your appid)
          appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
          # How often weather is allowed to be refreshed. This helps limit OWN API use,
          # to keep you in their good graces (and on their free tier). This value is
          # in minutes.
          interval: 30
          locations:
          - id: home
            # Set the location by specifying ONE OF: latitude+longitude, OWN city
            # ID, or location (as postal,country). If none is set, the system
            # location will be used.
            latitude: 8.9936
            longitude: -79.5197
            city_id: 3703443
            #location: "30269,us"
            # Enable "save_full_response" to save the full response (you may have
            # need to use parts of the response that are not part of the wx
            # capability in your dashboard widgets).
            #save_full_response: false
    When I request a systemctl status reactor I get this message:
    root@main:/home/wilson/reactor/logs# systemctl status reactor
    ● reactor.service - Multi System Reactor
         Loaded: loaded (/etc/systemd/system/reactor.service; enabled; vendor preset: enabled)
         Active: active (running) since Fri 2023-09-08 21:03:13 EST; 5s ago
       Main PID: 194711 (node)
          Tasks: 11 (limit: 9390)
         Memory: 82.5M
            CPU: 2.508s
         CGroup: /system.slice/reactor.service
                 └─194711 /usr/bin/node app -p
    Sep 08 21:03:13 main node[194711]: Error: Incompatible serialization data; can't unserialize
    Sep 08 21:03:13 main node[194711]:     at System.unserialize (/home/wilson/reactor/server/lib/Entity.js:624:19)
    Sep 08 21:03:13 main node[194711]:     at /home/wilson/reactor/server/lib/Controller.js:458:70
    Sep 08 21:03:13 main node[194711]:     at Array.forEach (<anonymous>)
    Sep 08 21:03:13 main node[194711]:     at OWMWeatherController._restoreEntities (/home/wilson/reactor/server/lib/Controller.js:446:36)
    Sep 08 21:03:13 main node[194711]:     at new Controller (/home/wilson/reactor/server/lib/Controller.js:37:45)
    Sep 08 21:03:13 main node[194711]:     at new OWMWeatherController (/home/wilson/reactor/server/lib/OWMWeatherController.js:327:9)
    Sep 08 21:03:13 main node[194711]:     at /home/wilson/reactor/server/lib/Controller.js:93:37
    Sep 08 21:03:13 main node[194711]: [latest-23242]2023-09-09T02:03:13.855Z <NUTController:null> Module NUTController v22305
    Sep 08 21:03:13 main node[194711]: [latest-23242]2023-09-09T02:03:13.859Z <SystemController:null> Module SystemController v23214
    root@main:/home/wilson/reactor# systemctl status reactor
         Active: active (running) since Fri 2023-09-08 20:48:36 EST; 2min 58s ago
       Main PID: 194353 (node)
         Memory: 66.0M
            CPU: 9.493s
                 └─194353 /usr/bin/node app -p
    Sep 08 20:48:37 main node[194353]:     at System.unserialize (/home/wilson/reactor/server/lib/Entity.js:624:19)
    Sep 08 20:48:37 main node[194353]:     at /home/wilson/reactor/server/lib/Controller.js:458:70
    Sep 08 20:48:37 main node[194353]:     at Array.forEach (<anonymous>)
    Sep 08 20:48:37 main node[194353]:     at OWMWeatherController._restoreEntities (/home/wilson/reactor/server/lib/Controller.js:446:36)
    Sep 08 20:48:37 main node[194353]:     at new Controller (/home/wilson/reactor/server/lib/Controller.js:37:45)
    Sep 08 20:48:37 main node[194353]:     at new OWMWeatherController (/home/wilson/reactor/server/lib/OWMWeatherController.js:327:9)
    Sep 08 20:48:37 main node[194353]:     at /home/wilson/reactor/server/lib/Controller.js:93:37
    Sep 08 20:48:37 main node[194353]: [latest-23242]2023-09-09T01:48:37.017Z <NUTController:null> Module NUTController v22305
    Sep 08 20:48:37 main node[194353]: [latest-23242]2023-09-09T01:48:37.024Z <SystemController:null> Module SystemController v23214
    Sep 08 20:48:37 main node[194353]: [latest-23242]2023-09-09T01:48:37.475Z <Timer:null> Timer#rule-l7ujwva5 just a note: I'm setting a delay of >
    lines 1-20/20 (END)
    I can see this information in the log, but I don't understand what I should do to fix it.
    [latest-23242]2023-09-09T02:03:13.838Z <DynamicGroupController:null> Module DynamicGroupController v22313
    [latest-23242]2023-09-09T02:03:13.845Z <Structure:INFO> Structure#1 loading controller interface weather (OWMWeatherController)
    [latest-23242]2023-09-09T02:03:13.847Z <OWMWeatherController:null> Module OWMWeatherController v22294
    [latest-23242]2023-09-09T02:03:13.850Z <Controller:WARN> OWMWeatherController#weather failed (1) to restore entity controller_all: [Error] Inco>
    [latest-23242]2023-09-09T02:03:13.850Z <Controller:CRIT> Error: Incompatible serialization data; can't unserialize [-]
        at Group.unserialize (/home/wilson/reactor/server/lib/Entity.js:624:19)
    [latest-23242]2023-09-09T02:03:13.851Z <Controller:WARN> OWMWeatherController#weather failed (1) to restore entity default: [Error] Incompatibl>
    [latest-23242]2023-09-09T02:03:13.851Z <Controller:CRIT> Error: Incompatible serialization data; can't unserialize [-]
        at Entity.unserialize (/home/wilson/reactor/server/lib/Entity.js:624:19)
    [latest-23242]2023-09-09T02:03:13.852Z <Controller:WARN> OWMWeatherController#weather failed (1) to restore entity system: [Error] Incompatible>
    [latest-23242]2023-09-09T02:03:13.852Z <Controller:CRIT> Error: Incompatible serialization data; can't unserialize [-]
    [latest-23242]2023-09-09T02:03:13.853Z <Structure:INFO> Structure#1 loading controller interface nut (NUTController)
    [latest-23242]2023-09-09T02:03:13.855Z <Controller:INFO> Loaded NUTController version "0.1.22305"; Patrick Rigney/Kedron Holdings LLC <patrick@>
    [latest-23242]2023-09-09T02:03:13.857Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
    And finally, I have a second house, with the same OWM configuration I made today, and it doesn't show any errors.
    Please, your traditional help.
    • wmarcolinW wmarcolin
      Hi @toggledbits
        - id: weather
          enabled: true
            # in minutes.
            interval: 30
            locations:
            - id: home
              latitude: 8.9936
              longitude: -79.5197
              city_id: 3703443
           Memory: 82.5M
              CPU: 2.508s
           Memory: 66.0M
              CPU: 9.493s
      lines 1-20/20 (END)
      @wmarcolin said in OWM error:
      Have you literally copy/pasted the config section from the working to the non-working?
      *Hubitat C-7 2.4.3.171
      *HASS 2025.12.3
      MSR: latest-25328-b2ed1365
      wmarcolinW 1 Reply Last reply
        @gwp1
        Same configuration on both systems, but there are differences in that one runs on a C7 and the other on a C8, and the computers are slightly different but the VM runs the same and has the same capacity, so I don't think this would interfere.
        root@main:/home/wilson# systemctl status reactor
             Active: active (running) since Sat 2023-09-09 15:48:22 EST; 4min 29s ago
           Main PID: 630 (node)
             Memory: 100.4M
                CPU: 13.985s
                     └─630 /usr/bin/node app -p
        Sep 09 15:48:26 main node[630]:     at new Controller (/home/wilson/reactor/server/lib/Controller.js:37:45)
        Sep 09 15:48:26 main node[630]:     at new OWMWeatherController (/home/wilson/reactor/server/lib/OWMWeatherController.js:327:9)
        Sep 09 15:48:26 main node[630]:     at /home/wilson/reactor/server/lib/Controller.js:93:37
        Sep 09 15:48:26 main node[630]: [latest-23242]2023-09-09T20:48:26.426Z <NUTController:null> Module NUTController v22305
        Sep 09 15:48:26 main node[630]: [latest-23242]2023-09-09T20:48:26.444Z <SystemController:null> Module SystemController v23214
        Sep 09 15:48:28 main node[630]: [latest-23242]2023-09-09T20:48:28.524Z <Timer:null> Timer#rule-l7ujwva5 just a note: I'm setting a delay of only 5ms (from 16942925>
        Sep 09 15:48:29 main node[630]: [latest-23242]2023-09-09T20:48:29.369Z <Notifier:null> Module Notifier v22283
        Sep 09 15:48:29 main node[630]: [latest-23242]2023-09-09T20:48:29.394Z <default:null> Module NotifyTelegram v21221
        Sep 09 15:48:35 main node[630]: /home/wilson/reactor/logs/reactor.log size hit rotation limit, rotating
        Sep 09 15:48:35 main node[630]: stream /home/wilson/reactor/logs/reactor.log not open boolean false
        lines 1-20/20 (END)
        I've just restarted the VM and checked the status, and the following error appears, but the MSR operates apparently normally.
        Thaks.
          Sounds like the persistence file for the entity is corrupt. You've probably had a disk full condition somewhere along the way, or maybe you're beginning to see a Flash wear problem. Just stop MSR, delete the storage/entitites/weather directory, and restart.
            All right, no more errors.
            Thank you.
              Thank you.
              @wmarcolin If this is solved can you please edit the topic to have the prefix [Solved]?
              *HASS 2025.12.3
              • wmarcolinW wmarcolin marked this topic as a question on
              • wmarcolinW wmarcolin has marked this topic as solved on
                @gwp1
                Hola, how do I edit the title to put [Solved]? I found how to change the status, but not how to change the name. Can you explain? Thank you.
                  @gwp1
                  @wmarcolin Go back to your original post, Edit, resave. 🙂
                  *HASS 2025.12.3
                    @gwp1
                    • Time series documentation
                    • Reset a delay
                    • Single protocol?
                    • HDMI oddness
                    • Oh the joy of pairing
                      823
