  4. [Solved] OWM error
[Solved] OWM error
9 Posts 3 Posters 2.1k Views 3 Watching
  • wmarcolinW Offline
    Hi @toggledbits
    I'm trying to use OWM, apparently, I receive the correct information, but after a while, the MSR disconnects.
    My configuration is as follows.
      - id: weather
        enabled: true
        implementation: OWMWeatherController
          # Place your OWM API key here (remember to enable the controller after adding your appid)
          appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
          # How often weather is allowed to be refreshed. This helps limit OWN API use,
          # to keep you in their good graces (and on their free tier). This value is
          # in minutes.
          interval: 30
          locations:
          - id: home
            # Set the location by specifying ONE OF: latitude+longitude, OWN city
            # ID, or location (as postal,country). If none is set, the system
            # location will be used.
            latitude: 8.9936
            longitude: -79.5197
            city_id: 3703443
            #location: "30269,us"
            # Enable "save_full_response" to save the full response (you may have
            # need to use parts of the response that are not part of the wx
            # capability in your dashboard widgets).
            #save_full_response: false
    When I request a systemctl status reactor I get this message:
    root@main:/home/wilson/reactor/logs# systemctl status reactor
    ● reactor.service - Multi System Reactor
         Loaded: loaded (/etc/systemd/system/reactor.service; enabled; vendor preset: enabled)
         Active: active (running) since Fri 2023-09-08 21:03:13 EST; 5s ago
       Main PID: 194711 (node)
          Tasks: 11 (limit: 9390)
         Memory: 82.5M
            CPU: 2.508s
         CGroup: /system.slice/reactor.service
                 └─194711 /usr/bin/node app -p
    Sep 08 21:03:13 main node[194711]: Error: Incompatible serialization data; can't unserialize
    Sep 08 21:03:13 main node[194711]:     at System.unserialize (/home/wilson/reactor/server/lib/Entity.js:624:19)
    Sep 08 21:03:13 main node[194711]:     at /home/wilson/reactor/server/lib/Controller.js:458:70
    Sep 08 21:03:13 main node[194711]:     at Array.forEach (<anonymous>)
    Sep 08 21:03:13 main node[194711]:     at OWMWeatherController._restoreEntities (/home/wilson/reactor/server/lib/Controller.js:446:36)
    Sep 08 21:03:13 main node[194711]:     at new Controller (/home/wilson/reactor/server/lib/Controller.js:37:45)
    Sep 08 21:03:13 main node[194711]:     at new OWMWeatherController (/home/wilson/reactor/server/lib/OWMWeatherController.js:327:9)
    Sep 08 21:03:13 main node[194711]:     at /home/wilson/reactor/server/lib/Controller.js:93:37
    Sep 08 21:03:13 main node[194711]: [latest-23242]2023-09-09T02:03:13.855Z <NUTController:null> Module NUTController v22305
    Sep 08 21:03:13 main node[194711]: [latest-23242]2023-09-09T02:03:13.859Z <SystemController:null> Module SystemController v23214
    root@main:/home/wilson/reactor# systemctl status reactor
         Active: active (running) since Fri 2023-09-08 20:48:36 EST; 2min 58s ago
       Main PID: 194353 (node)
         Memory: 66.0M
            CPU: 9.493s
                 └─194353 /usr/bin/node app -p
    Sep 08 20:48:37 main node[194353]:     at System.unserialize (/home/wilson/reactor/server/lib/Entity.js:624:19)
    Sep 08 20:48:37 main node[194353]:     at /home/wilson/reactor/server/lib/Controller.js:458:70
    Sep 08 20:48:37 main node[194353]:     at Array.forEach (<anonymous>)
    Sep 08 20:48:37 main node[194353]:     at OWMWeatherController._restoreEntities (/home/wilson/reactor/server/lib/Controller.js:446:36)
    Sep 08 20:48:37 main node[194353]:     at new Controller (/home/wilson/reactor/server/lib/Controller.js:37:45)
    Sep 08 20:48:37 main node[194353]:     at new OWMWeatherController (/home/wilson/reactor/server/lib/OWMWeatherController.js:327:9)
    Sep 08 20:48:37 main node[194353]:     at /home/wilson/reactor/server/lib/Controller.js:93:37
    Sep 08 20:48:37 main node[194353]: [latest-23242]2023-09-09T01:48:37.017Z <NUTController:null> Module NUTController v22305
    Sep 08 20:48:37 main node[194353]: [latest-23242]2023-09-09T01:48:37.024Z <SystemController:null> Module SystemController v23214
    Sep 08 20:48:37 main node[194353]: [latest-23242]2023-09-09T01:48:37.475Z <Timer:null> Timer#rule-l7ujwva5 just a note: I'm setting a delay of >
    lines 1-20/20 (END)
    I can see this information in the log, but I don't understand what I should do to fix it.
    [latest-23242]2023-09-09T02:03:13.838Z <DynamicGroupController:null> Module DynamicGroupController v22313
    [latest-23242]2023-09-09T02:03:13.845Z <Structure:INFO> Structure#1 loading controller interface weather (OWMWeatherController)
    [latest-23242]2023-09-09T02:03:13.847Z <OWMWeatherController:null> Module OWMWeatherController v22294
    [latest-23242]2023-09-09T02:03:13.850Z <Controller:WARN> OWMWeatherController#weather failed (1) to restore entity controller_all: [Error] Inco>
    [latest-23242]2023-09-09T02:03:13.850Z <Controller:CRIT> Error: Incompatible serialization data; can't unserialize [-]
        at Group.unserialize (/home/wilson/reactor/server/lib/Entity.js:624:19)
    [latest-23242]2023-09-09T02:03:13.851Z <Controller:WARN> OWMWeatherController#weather failed (1) to restore entity default: [Error] Incompatibl>
    [latest-23242]2023-09-09T02:03:13.851Z <Controller:CRIT> Error: Incompatible serialization data; can't unserialize [-]
        at Entity.unserialize (/home/wilson/reactor/server/lib/Entity.js:624:19)
    [latest-23242]2023-09-09T02:03:13.852Z <Controller:WARN> OWMWeatherController#weather failed (1) to restore entity system: [Error] Incompatible>
    [latest-23242]2023-09-09T02:03:13.852Z <Controller:CRIT> Error: Incompatible serialization data; can't unserialize [-]
    [latest-23242]2023-09-09T02:03:13.853Z <Structure:INFO> Structure#1 loading controller interface nut (NUTController)
    [latest-23242]2023-09-09T02:03:13.855Z <Controller:INFO> Loaded NUTController version "0.1.22305"; Patrick Rigney/Kedron Holdings LLC <patrick@>
    [latest-23242]2023-09-09T02:03:13.857Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
    And finally, I have a second house, with the same OWM configuration I made today, and it doesn't show any errors.
    Please, your traditional help.
    • wmarcolinW wmarcolin
      Hi @toggledbits
        - id: weather
          enabled: true
            # in minutes.
            interval: 30
            locations:
            - id: home
              latitude: 8.9936
              longitude: -79.5197
              city_id: 3703443
           Memory: 82.5M
              CPU: 2.508s
           Memory: 66.0M
              CPU: 9.493s
      lines 1-20/20 (END)
      @wmarcolin said in OWM error:
      Have you literally copy/pasted the config section from the working to the non-working?
      *Hubitat C-7 2.5.2.135
      Core 2026.10.1
      MSR: latest-26287-0a7107d5
      wmarcolinW 1 Reply Last reply
        @gwp1
        Same configuration on both systems, but there are differences in that one runs on a C7 and the other on a C8, and the computers are slightly different but the VM runs the same and has the same capacity, so I don't think this would interfere.
        root@main:/home/wilson# systemctl status reactor
             Active: active (running) since Sat 2023-09-09 15:48:22 EST; 4min 29s ago
           Main PID: 630 (node)
             Memory: 100.4M
                CPU: 13.985s
                     └─630 /usr/bin/node app -p
        Sep 09 15:48:26 main node[630]:     at new Controller (/home/wilson/reactor/server/lib/Controller.js:37:45)
        Sep 09 15:48:26 main node[630]:     at new OWMWeatherController (/home/wilson/reactor/server/lib/OWMWeatherController.js:327:9)
        Sep 09 15:48:26 main node[630]:     at /home/wilson/reactor/server/lib/Controller.js:93:37
        Sep 09 15:48:26 main node[630]: [latest-23242]2023-09-09T20:48:26.426Z <NUTController:null> Module NUTController v22305
        Sep 09 15:48:26 main node[630]: [latest-23242]2023-09-09T20:48:26.444Z <SystemController:null> Module SystemController v23214
        Sep 09 15:48:28 main node[630]: [latest-23242]2023-09-09T20:48:28.524Z <Timer:null> Timer#rule-l7ujwva5 just a note: I'm setting a delay of only 5ms (from 16942925>
        Sep 09 15:48:29 main node[630]: [latest-23242]2023-09-09T20:48:29.369Z <Notifier:null> Module Notifier v22283
        Sep 09 15:48:29 main node[630]: [latest-23242]2023-09-09T20:48:29.394Z <default:null> Module NotifyTelegram v21221
        Sep 09 15:48:35 main node[630]: /home/wilson/reactor/logs/reactor.log size hit rotation limit, rotating
        Sep 09 15:48:35 main node[630]: stream /home/wilson/reactor/logs/reactor.log not open boolean false
        lines 1-20/20 (END)
        I've just restarted the VM and checked the status, and the following error appears, but the MSR operates apparently normally.
        Thaks.
          Sounds like the persistence file for the entity is corrupt. You've probably had a disk full condition somewhere along the way, or maybe you're beginning to see a Flash wear problem. Just stop MSR, delete the storage/entitites/weather directory, and restart.
            All right, no more errors.
            Thank you.
              Thank you.
              @wmarcolin If this is solved can you please edit the topic to have the prefix [Solved]?
              Core 2026.10.1
              • wmarcolinW wmarcolin marked this topic as a question on
              • wmarcolinW wmarcolin has marked this topic as solved on
                @gwp1
                Hola, how do I edit the title to put [Solved]? I found how to change the status, but not how to change the name. Can you explain? Thank you.
                  @gwp1
                  @wmarcolin Go back to your original post, Edit, resave. 🙂
                  Core 2026.10.1
                    @gwp1
                      148.8k
