  4. Programmatically capture HTTP Request action status code or error
3 Posts 2 Posters 1.3k Views 2 Watching
    I have a very strange situation, where if InfluxDB restarts, other containers may fail when restarting at the same time (under not easy to understand circumstances), and InfluxDB remains unreachable (and these containers crashes). I need to reboot these containers in an exact order, after rebooting InfluxDB.
    While I understand what's going on, I need a way to reliable determine that InfluxDB is not reachable and these containers are not reachable, in order to identify this situation and manually check what's going on - and, maybe, in the future, automatically restart them if needed.
    So, I was looking at HTTP Request action, but I need to capture the HTTP response code, instead of the response (becase if ping is OK, InfluxDB will reply with a 204), and, potentially, a way to programmatically detect that it's failing to get the response.
    While I could write a custom HTTP controller for this or a custom HTTP virtual device, I was wondering if this is somewhat on you roadmap @toggledbits
      Currently, if an HTTP request fails and the request is set up to save the response, the target response variable will be null. Will that not suffice?
        So, an empty string is 200ish, otherwise error/timeout is null? That works, thank you!
          1.1k
          158.0k
