  4. Need Some Help Using browser_mod (HA integration)
26 Posts 2 Posters 11.3k Views 2 Watching
    Hello all I am trying to run the service call browser_mod.popup from MSR to HA. If I enter the service data in YAML like this:
      dismissable: true
      autoclose: false
      timeout: 120000
      content:
        type: custom:mushroom-alarm-control-panel-card
        entity: alarm_control_panel.home_partition
        states:
          - armed_home
          - armed_away
        layout: vertical
        show_keypad: true
    target:
      device_id: e684ad00b76e330e57a8c915dc367bc4
    For some reason the target portion of the data isn't sent and therefor the popup shows up on all my browser mod devices not the only one I had specified in the device_id. Here is a snippet of the reactor log, no errors that I see just looks like the target info isn't being passed on.
    [latest-23242]2023-10-12T23:51:50.795Z <Engine:INFO> Enqueueing "Main Floor Tablet Alarm Arming Popup<SET>" (rule-lnmn8t54:S)
    [latest-23242]2023-10-12T23:51:50.800Z <Engine:NOTICE> Starting reaction Main Floor Tablet Alarm Arming Popup<SET> (rule-lnmn8t54:S)
    [latest-23242]2023-10-12T23:51:50.813Z <HassController:INFO> HassController#hass action x_hass_system.call_service([Object]{ "service": "browser_mod.popup", "data": "data:\n  dismissable: true\n  autoclose: false\n  timeout: 120000\n  content:\n    type: custom:mushroom-alarm-control-panel-card\n    entity: alarm_control_panel.home_partition\n    states:\n      - armed_home\n      - armed_away\n    layout: vertical\n    show_keypad: true\ntarget:\n  device_id: e684ad00b76e330e57a8c915dc367bc4" }) on System#hass>system succeeded
    [latest-23242]2023-10-12T23:51:50.816Z <Engine:INFO> Resuming reaction Main Floor Tablet Alarm Arming Popup<SET> (rule-lnmn8t54:S) from step 1
    [latest-23242]2023-10-12T23:51:50.817Z <Engine:INFO> Main Floor Tablet Alarm Arming Popup<SET> all actions completed.
    So I used an online YAML to JSON converter since I am not the good with JSON and it converted the YAML to this:
      "data": {
        "dismissable": true,
        "autoclose": false,
        "timeout": 120000,
        "content": {
          "type": "custom:mushroom-alarm-control-panel-card",
          "entity": "alarm_control_panel.bar_partition",
          "states": [
            "armed_home",
            "armed_away"
          "layout": "vertical",
          "show_keypad": true
      "target": {
        "device_id": "34ae76561192c4bb0b64fb07ad0f01c1"
    When I use this in my reaction the popup doesn't show up properly. Something pops up but it's just a grey bar. Interestingly the JSON version actually does target only the device_id I had specified. Here is the reactor log output:
    [latest-23242]2023-10-12T23:52:39.875Z <Engine:INFO> Enqueueing "Main Floor Tablet Alarm Arming Popup<SET>" (rule-lnmn8t54:S)
    [latest-23242]2023-10-12T23:52:39.880Z <Engine:NOTICE> Starting reaction Main Floor Tablet Alarm Arming Popup<SET> (rule-lnmn8t54:S)
    [latest-23242]2023-10-12T23:52:40.291Z <HassController:INFO> HassController#hass action x_hass_system.call_service([Object]{ "service": "browser_mod.popup", "data": "{\n   \"data\": {\n      \"dismissable\": true,\n      \"autoclose\": false,\n      \"timeout\": 120000,\n      \"content\": {\n         \"type\": \"custom:mushroom-alarm-control-panel-card\",\n         \"entity\": \"alarm_control_panel.home_partition\",\n         \"states\": [\n            \"armed_home\",\n            \"armed_away\"\n         ],\n         \"layout\": \"vertical\",\n         \"show_keypad\": true\n      }\n   },\n   \"target\": {\n      \"device_id\": \"e684ad00b76e330e57a8c915dc367bc4\"\n   }\n}" }) on System#hass>system succeeded
    [latest-23242]2023-10-12T23:52:40.293Z <Engine:INFO> Resuming reaction Main Floor Tablet Alarm Arming Popup<SET> (rule-lnmn8t54:S) from step 1
    [latest-23242]2023-10-12T23:52:40.294Z <Engine:INFO> Main Floor Tablet Alarm Arming Popup<SET> all actions completed.
    My limited skill with JSON has kind of backed me into a corner here, so if anyone could help me format it correctly that would be great!
    MSR latest 23242
    HA 2023.10.1
      Try not using call_service on the System entity, but on the device entity you are specifying as the target (x_hass.call_service appears on all HA entities). You don't need the target in your YAML or JSON, just the data; MSR will supply the target.
      PablaP 1 Reply Last reply
        @toggledbits I used the media_player entity for the tablet that I am trying to show the pop up on and the result was the same. I used this code (both in yaml and JSON formats):
        data:
          dismissable: true
          autoclose: false
          timeout: 120000
          content:
            entity: alarm_control_panel.bar_partition
            states:
              - armed_home
              - armed_away
            layout: vertical
            show_keypad: true
        And the pop up came up on all my devices. Reactor log:
        [latest-23242]2023-10-13T22:53:27.248Z <HassController:INFO> HassController#hass action x_hass.call_service([Object]{ "service": "browser_mod.popup", "data": "data:\n  dismissable: true\n  autoclose: false\n  timeout: 120000\n  content:\n    type: custom:mushroom-alarm-control-panel-card\n    entity: alarm_control_panel.bar_partition\n    states:\n      - armed_home\n      - armed_away\n    layout: vertical\n    show_keypad: true" }) on MediaPlayer#hass>media_player_bar_tablet_2 succeeded
        Adding device_id info didn't make a change.
          Can you give more log context, please.
            [latest-23242]2023-10-14T23:57:30.998Z <Rule:INFO> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) starting evaluation; because startup
            [latest-23242]2023-10-14T23:57:31.015Z <Rule:INFO> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) trigger evaluation result is false (previously false)
            [latest-23242]2023-10-14T23:57:31.016Z <Rule:INFO> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) evaluated; trigger state unchanged (false); rule state remains RESET
            [latest-23242]2023-10-14T23:57:31.032Z <Rule:INFO> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) trigger evaluation result is false (previously false)
            [latest-23242]2023-10-14T23:57:31.033Z <Rule:INFO> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) evaluated; trigger state unchanged (false); rule state remains RESET
            [latest-23242]2023-10-14T23:57:31.033Z <Rule:INFO> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) evaluation complete
            [latest-23242]2023-10-14T23:57:31.033Z <Rule:INFO> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) started
            [latest-23242]2023-10-14T23:57:31.034Z <Rule:INFO> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) started
            [latest-23242]2023-10-14T23:57:32.277Z <Rule:INFO> Offline Devices (rule-l9wc2uka in Notifications) starting evaluation; because entity-changed ValueSensor#hass>sensor_bchydro_instantaneous_demand
            [latest-23242]2023-10-14T23:57:32.278Z <Rule:INFO> Online Devices (rule-ldxfrj64 in Notifications) starting evaluation; because entity-changed ValueSensor#hass>sensor_bchydro_instantaneous_demand
            [latest-23242]2023-10-14T23:57:32.285Z <Rule:INFO> Offline Devices (rule-l9wc2uka in Notifications) trigger evaluation result is false (previously false)
            [latest-23242]2023-10-14T23:57:32.286Z <Rule:INFO> Offline Devices (rule-l9wc2uka in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
            [latest-23242]2023-10-14T23:57:32.295Z <Rule:INFO> Online Devices (rule-ldxfrj64 in Notifications) trigger evaluation result is false (previously false)
            [latest-23242]2023-10-14T23:57:32.296Z <Rule:INFO> Online Devices (rule-ldxfrj64 in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
            [latest-23242]2023-10-14T23:57:32.297Z <Rule:INFO> Offline Devices (rule-l9wc2uka in Notifications) evaluation complete
            [latest-23242]2023-10-14T23:57:32.298Z <Rule:INFO> Online Devices (rule-ldxfrj64 in Notifications) evaluation complete
            [latest-23242]2023-10-14T23:57:33.972Z <Engine:INFO> Enqueueing "Bar Tablet Alarm Arming Popup Copy<SET>" (rule-lnoyj3ub:S)
            [latest-23242]2023-10-14T23:57:33.975Z <Engine:NOTICE> Starting reaction Bar Tablet Alarm Arming Popup Copy<SET> (rule-lnoyj3ub:S)
            [latest-23242]2023-10-14T23:57:33.983Z <HassController:INFO> HassController#hass action x_hass.call_service([Object]{ "service": "browser_mod.popup", "data": "data:\n  dismissable: true\n  autoclose: false\n  timeout: 120000\n  content:\n    type: custom:mushroom-alarm-control-panel-card\n    entity: alarm_control_panel.bar_partition\n    states:\n      - armed_home\n      - armed_away\n    layout: vertical\n    show_keypad: true" }) on MediaPlayer#hass>media_player_bar_tablet_2 succeeded
            [latest-23242]2023-10-14T23:57:33.984Z <Engine:INFO> Resuming reaction Bar Tablet Alarm Arming Popup Copy<SET> (rule-lnoyj3ub:S) from step 1
            [latest-23242]2023-10-14T23:57:33.985Z <Engine:INFO> Bar Tablet Alarm Arming Popup Copy<SET> all actions completed.
            [latest-23242]2023-10-14T23:57:34.261Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) starting evaluation; because entity-changed System#reactor_system>system
            [latest-23242]2023-10-14T23:57:34.262Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) starting evaluation; because entity-changed System#reactor_system>system
            [latest-23242]2023-10-14T23:57:34.263Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) trigger evaluation result is false (previously false)
            [latest-23242]2023-10-14T23:57:34.263Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
            [latest-23242]2023-10-14T23:57:34.267Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) trigger evaluation result is false (previously false)
            [latest-23242]2023-10-14T23:57:34.267Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
            [latest-23242]2023-10-14T23:57:34.268Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluation complete
            [latest-23242]2023-10-14T23:57:34.268Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluation complete
            [latest-23242]2023-10-14T23:57:34.275Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) starting evaluation; because entity-changed System#reactor_system>system
            [latest-23242]2023-10-14T23:57:34.276Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) starting evaluation; because entity-changed System#reactor_system>system
            [latest-23242]2023-10-14T23:57:34.277Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) trigger evaluation result is false (previously false)
            [latest-23242]2023-10-14T23:57:34.277Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
            [latest-23242]2023-10-14T23:57:34.280Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) trigger evaluation result is false (previously false)
            [latest-23242]2023-10-14T23:57:34.281Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
            [latest-23242]2023-10-14T23:57:34.281Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluation complete
            [latest-23242]2023-10-14T23:57:34.282Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluation complete
              OK. First of all, I don't think it's correct to use the data: key in the data field; that's duplicating the nesting of the contained data and I'm pretty sure that's not helping. It may or may not be the only thing. So first, try entering the service_data field text without the data: at the start and the indents it causes. Your service data should look like this:
              dismissable: true
              autoclose: false
              timeout: 120000
              content:
                states:
                  - armed_home
                  - armed_away
                layout: vertical
                show_keypad: true
              You are still using x_hass.call_service on the device entity, not the System entity for this, by the way.
              If that doesn't work, then boost the log level for HassController to level 5, restart, retry the test, and then post the log the snippet (with context). The specific log message I need to see contains sending payload for call_service, but give me lines before and after (until the action success/fail message).
                By the way, have you verified that this actually works the way you expect by doing it in HA directly first?
                  dismissable: true
                  autoclose: false
                  timeout: 120000
                  content:
                    states:
                      - armed_home
                      - armed_away
                    layout: vertical
                    show_keypad: true
                  wrote on last edited by Pabla
                  @toggledbits said in Need Some Help Formatting YAML to JSON:
                  Apologies I posted the log snipped of the rule where it calls the service on the System entity instead of the one for the device entity.
                  I set logging to 5 but nothing extra is shown when I manually trigger the set reaction. Here they are though:
                  [latest-23242]2023-10-17T01:23:35.860Z <wsapi:INFO> client "192.168.8.237#1" closed, code=1001, reason=
                  [latest-23242]2023-10-17T01:23:36.408Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.8.237: GET /api/v1/lang
                  [latest-23242]2023-10-17T01:23:36.531Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.8.237
                  [latest-23242]2023-10-17T01:23:37.358Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_ram
                  [latest-23242]2023-10-17T01:23:37.363Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_cpu
                  [latest-23242]2023-10-17T01:23:38.062Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.8.237: GET /api/v1/systime
                  [latest-23242]2023-10-17T01:23:38.102Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_temperature_cpu_2
                  [latest-23242]2023-10-17T01:23:38.518Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.8.237: GET /api/v1/systime
                  [latest-23242]2023-10-17T01:23:38.562Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_ram_used_percent
                  [latest-23242]2023-10-17T01:23:38.567Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_ram_used
                  [latest-23242]2023-10-17T01:23:38.572Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_ram_free
                  [latest-23242]2023-10-17T01:23:38.577Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_swap_used_percent
                  [latest-23242]2023-10-17T01:23:38.581Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_cpu_load
                  [latest-23242]2023-10-17T01:23:38.586Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_total
                  [latest-23242]2023-10-17T01:23:38.591Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_thread
                  [latest-23242]2023-10-17T01:23:38.595Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_cpu_used
                  [latest-23242]2023-10-17T01:23:40.094Z <HassController:5:HassController.js:352> HassController#hass updating hass entity device_tracker.ec_71_db_69_bf_c4
                  [latest-23242]2023-10-17T01:23:40.107Z <HassController:5:HassController.js:352> HassController#hass updating hass entity device_tracker.samsung_2
                  [latest-23242]2023-10-17T01:23:40.120Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_connected_devices
                  [latest-23242]2023-10-17T01:23:40.803Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.processor_use
                  [latest-23242]2023-10-17T01:23:40.808Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_free
                  [latest-23242]2023-10-17T01:23:40.813Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_use_percent
                  [latest-23242]2023-10-17T01:23:45.155Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                  [latest-23242]2023-10-17T01:23:48.840Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bar_tablet_internal_storage_free_space
                  [latest-23242]2023-10-17T01:23:48.851Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bar_tablet_free_memory
                  [latest-23242]2023-10-17T01:23:51.164Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                  [latest-23242]2023-10-17T01:23:54.192Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                  [latest-23242]2023-10-17T01:23:54.998Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.main_floor_tablet_internal_storage_free_space
                  [latest-23242]2023-10-17T01:23:55.004Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.main_floor_tablet_free_memory
                  [latest-23242]2023-10-17T01:23:55.809Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.processor_use
                  [latest-23242]2023-10-17T01:23:55.814Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_free
                  [latest-23242]2023-10-17T01:23:55.819Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_use_percent
                  [latest-23242]2023-10-17T01:23:57.151Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                  [latest-23242]2023-10-17T01:24:00.171Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_electricity_consumption
                  [latest-23242]2023-10-17T01:24:00.183Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_electricity_consumption_cost
                  [latest-23242]2023-10-17T01:24:00.192Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_electricity_consumption_cost
                  [latest-23242]2023-10-17T01:24:00.202Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.2_month_hydro_usage
                  [latest-23242]2023-10-17T01:24:00.213Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.2_month_hydro_cost
                  [latest-23242]2023-10-17T01:24:00.223Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.2_month_hydro_cost
                  [latest-23242]2023-10-17T01:24:00.993Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.east_basement_climate_air_temperature
                  [latest-23242]2023-10-17T01:24:01.180Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.east_basement_climate_humidity
                  [latest-23242]2023-10-17T01:24:05.679Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wan_download_speed
                  [latest-23242]2023-10-17T01:24:05.690Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wan_upload_speed
                  [latest-23242]2023-10-17T01:24:05.700Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wired_download_speed
                  [latest-23242]2023-10-17T01:24:05.708Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wired_upload_speed
                  [latest-23242]2023-10-17T01:24:05.718Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_bridge_download_speed
                  [latest-23242]2023-10-17T01:24:05.727Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_bridge_upload_speed
                  [latest-23242]2023-10-17T01:24:06.742Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_ram
                  [latest-23242]2023-10-17T01:24:06.751Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_cpu
                  [latest-23242]2023-10-17T01:24:09.086Z <Engine:INFO> Enqueueing "Bar Tablet Alarm Arming Popup Copy<SET>" (rule-lnoyj3ub:S)
                  [latest-23242]2023-10-17T01:24:09.092Z <Engine:NOTICE> Starting reaction Bar Tablet Alarm Arming Popup Copy<SET> (rule-lnoyj3ub:S)
                  [latest-23242]2023-10-17T01:24:09.102Z <HassController:5:HassController.js:100> HassController#hass MediaPlayer#hass>media_player_bar_tablet_2 performOnEntity x_hass.call_service no domain-specific cap, trying generic
                  [latest-23242]2023-10-17T01:24:09.107Z <HassController:5:HassController.js:222> HassController#hass: sending payload for x_hass.call_service on MediaPlayer#hass>media_player_bar_tablet_2 action: [Object]{ "type": "call_service", "service_data": { "dismissable": true, "autoclose": false, "timeout": 120000, "content": { "type": "custom:mushroom-alarm-control-panel-card", "entity": "alarm_control_panel.bar_partition", "states": [ "armed_home", "armed_away" ], "layout": "vertical", "show_keypad": true }, "entity_id": "media_player.bar_tablet_2" }, "domain": "browser_mod", "service": "popup" }
                  [latest-23242]2023-10-17T01:24:09.122Z <HassController:INFO> HassController#hass action x_hass.call_service([Object]{ "service": "browser_mod.popup", "data": "dismissable: true\nautoclose: false\ntimeout: 120000\ncontent:\n  type: custom:mushroom-alarm-control-panel-card\n  entity: alarm_control_panel.bar_partition\n  states:\n    - armed_home\n    - armed_away\n  layout: vertical\n  show_keypad: true" }) on MediaPlayer#hass>media_player_bar_tablet_2 succeeded
                  [latest-23242]2023-10-17T01:24:09.126Z <Engine:INFO> Resuming reaction Bar Tablet Alarm Arming Popup Copy<SET> (rule-lnoyj3ub:S) from step 1
                  [latest-23242]2023-10-17T01:24:09.127Z <Engine:INFO> Bar Tablet Alarm Arming Popup Copy<SET> all actions completed.
                  [latest-23242]2023-10-17T01:24:10.096Z <HassController:5:HassController.js:352> HassController#hass updating hass entity device_tracker.ec_71_db_69_bf_c4
                  [latest-23242]2023-10-17T01:24:10.111Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_connected_devices
                  [latest-23242]2023-10-17T01:24:10.780Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.armans_macbook_pro_browser_visibility
                  [latest-23242]2023-10-17T01:24:10.805Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.processor_use
                  [latest-23242]2023-10-17T01:24:10.813Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_free
                  [latest-23242]2023-10-17T01:24:11.323Z <HassController:5:HassController.js:352> HassController#hass updating hass entity binary_sensor.armans_macbook_pro
                  [latest-23242]2023-10-17T01:24:12.153Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                  [latest-23242]2023-10-17T01:24:12.587Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.armans_macbook_pro_browser_visibility
                  [latest-23242]2023-10-17T01:24:14.384Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.armans_iphone_activity
                  [latest-23242]2023-10-17T01:24:14.393Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.armans_iphone_battery_level
                  [latest-23242]2023-10-17T01:24:14.404Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.armans_iphone_storage
                  [latest-23242]2023-10-17T01:24:15.174Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                  [latest-23242]2023-10-17T01:24:17.862Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                  [latest-23242]2023-10-17T01:24:17.863Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                  [latest-23242]2023-10-17T01:24:17.865Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) trigger evaluation result is false (previously true)
                  [latest-23242]2023-10-17T01:24:17.866Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluated; rule state transition from SET to RESET!
                  [latest-23242]2023-10-17T01:24:17.892Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) trigger evaluation result is false (previously false)
                  [latest-23242]2023-10-17T01:24:17.893Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                  [latest-23242]2023-10-17T01:24:17.893Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluation complete
                  [latest-23242]2023-10-17T01:24:17.894Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluation complete
                  [latest-23242]2023-10-17T01:24:17.911Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                  [latest-23242]2023-10-17T01:24:17.912Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                  [latest-23242]2023-10-17T01:24:17.913Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) trigger evaluation result is false (previously false)
                  [latest-23242]2023-10-17T01:24:17.914Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                  [latest-23242]2023-10-17T01:24:17.918Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) trigger evaluation result is false (previously false)
                  [latest-23242]2023-10-17T01:24:17.918Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                  [latest-23242]2023-10-17T01:24:17.919Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluation complete
                  [latest-23242]2023-10-17T01:24:17.919Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluation complete
                  [latest-23242]2023-10-17T01:24:17.926Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                  [latest-23242]2023-10-17T01:24:17.926Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                  [latest-23242]2023-10-17T01:24:17.928Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) trigger evaluation result is false (previously false)
                  [latest-23242]2023-10-17T01:24:17.928Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                  [latest-23242]2023-10-17T01:24:17.930Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) trigger evaluation result is false (previously false)
                  [latest-23242]2023-10-17T01:24:17.931Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                  [latest-23242]2023-10-17T01:24:17.932Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluation complete
                  [latest-23242]2023-10-17T01:24:17.932Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluation complete
                  [latest-23242]2023-10-17T01:24:17.939Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                  [latest-23242]2023-10-17T01:24:17.941Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                  [latest-23242]2023-10-17T01:24:17.942Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) trigger evaluation result is false (previously false)
                  [latest-23242]2023-10-17T01:24:17.943Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                  [latest-23242]2023-10-17T01:24:17.948Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) trigger evaluation result is false (previously false)
                  [latest-23242]2023-10-17T01:24:17.948Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                  [latest-23242]2023-10-17T01:24:17.949Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluation complete
                  [latest-23242]2023-10-17T01:24:17.950Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluation complete
                    Did you see my other note about actually verifying in HA that this works the way you expect? There actually is more debug info in the log, and specifically what I said I was looking for, so not sure what the disconnect is there, but anyway, MSR is sending what I expect. so I'd like you to use the "Developer Tools > Services" stuff in the Hass UI to see if you can make it work the way you want. There's no point chasing this in MSR if it's broken in Hass.
                      @toggledbits Yes it does work in HA as expected.
                        OK. Please post the YAML generated by the UI for that service call in developer tools.
                        Also, there's no need to tag me in replies. Or in head posts. I get notified of all messages in this category.
                          service: browser_mod.popup
                          data:
                            dismissable: true
                            autoclose: false
                            content:
                              states:
                                - armed_home
                                - armed_away
                              layout: vertical
                              show_keypad: true
                            timeout: 120000
                          target:
                            device_id: 34ae76561192c4bb0b64fb07ad0f01c1
                            data:
                              dismissable: true
                              autoclose: false
                              content:
                                states:
                                  - armed_home
                                  - armed_away
                                layout: vertical
                                show_keypad: true
                              timeout: 120000
                            target:
                            OK. Download the latest hass_data.zip from here, and place the entire ZIP file in your config directory. Restart Reactor, and run your test again. Please post the log with context as before.
                              Uploaded the ZIP file and uploaded into the config directory. Here are the logs, the popup still showed up on all Browser Mod devices.
                              48.798Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                              [latest-23242]2023-10-18T06:04:48.804Z <HassController:5:HassController.js:352> HassController#hass updating hass entity device_tracker.ec_71_db_69_bf_c4
                              [latest-23242]2023-10-18T06:04:48.811Z <HassController:5:HassController.js:352> HassController#hass updating hass entity device_tracker.80_64_6f_85_fe_37
                              [latest-23242]2023-10-18T06:04:48.818Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_connected_devices
                              [latest-23242]2023-10-18T06:04:48.833Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.armans_macbook_pro_browser_path
                              [latest-23242]2023-10-18T06:04:48.838Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.armans_macbook_pro_browser_path
                              [latest-23242]2023-10-18T06:04:48.844Z <HassController:5:HassController.js:352> HassController#hass updating hass entity binary_sensor.ping_192_168_8_27
                              [latest-23242]2023-10-18T06:04:48.850Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.processor_use
                              [latest-23242]2023-10-18T06:04:48.855Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_free
                              [latest-23242]2023-10-18T06:04:48.860Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_use_percent
                              [latest-23242]2023-10-18T06:04:50.847Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                              [latest-23242]2023-10-18T06:04:53.869Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                              [latest-23242]2023-10-18T06:04:56.604Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.armans_macbook_pro_browser_visibility
                              [latest-23242]2023-10-18T06:05:00.095Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bar_tablet_free_memory
                              [latest-23242]2023-10-18T06:05:00.543Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.main_floor_tablet_internal_storage_free_space
                              [latest-23242]2023-10-18T06:05:00.548Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.main_floor_tablet_free_memory
                              [latest-23242]2023-10-18T06:05:01.952Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.8.237: GET /api/v1/systime
                              [latest-23242]2023-10-18T06:05:02.853Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_electricity_consumption
                              [latest-23242]2023-10-18T06:05:02.864Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_electricity_consumption_cost
                              [latest-23242]2023-10-18T06:05:02.873Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_electricity_consumption_cost
                              [latest-23242]2023-10-18T06:05:02.882Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.2_month_hydro_usage
                              [latest-23242]2023-10-18T06:05:02.894Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.2_month_hydro_cost
                              [latest-23242]2023-10-18T06:05:02.914Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.2_month_hydro_cost
                              [latest-23242]2023-10-18T06:05:03.280Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.processor_use
                              [latest-23242]2023-10-18T06:05:03.285Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_free
                              [latest-23242]2023-10-18T06:05:03.290Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_use_percent
                              [latest-23242]2023-10-18T06:05:05.686Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wan_download_speed
                              [latest-23242]2023-10-18T06:05:05.697Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wan_upload_speed
                              [latest-23242]2023-10-18T06:05:05.706Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wired_download_speed
                              [latest-23242]2023-10-18T06:05:05.715Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wired_upload_speed
                              [latest-23242]2023-10-18T06:05:05.723Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_bridge_download_speed
                              [latest-23242]2023-10-18T06:05:05.732Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_bridge_upload_speed
                              [latest-23242]2023-10-18T06:05:06.740Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_ram
                              [latest-23242]2023-10-18T06:05:06.750Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_cpu
                              [latest-23242]2023-10-18T06:05:11.275Z <HassController:5:HassController.js:352> HassController#hass updating hass entity binary_sensor.armans_macbook_pro
                              [latest-23242]2023-10-18T06:05:11.862Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                              [latest-23242]2023-10-18T06:05:15.436Z <HassController:5:HassController.js:352> HassController#hass updating hass entity device_tracker.ec_71_db_69_bf_c4
                              [latest-23242]2023-10-18T06:05:15.448Z <HassController:5:HassController.js:352> HassController#hass updating hass entity device_tracker.80_64_6f_85_fe_37
                              [latest-23242]2023-10-18T06:05:17.864Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                              [latest-23242]2023-10-18T06:05:18.306Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.processor_use
                              [latest-23242]2023-10-18T06:05:18.311Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_free
                              [latest-23242]2023-10-18T06:05:18.315Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_use_percent
                              [latest-23242]2023-10-18T06:05:20.886Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                              [latest-23242]2023-10-18T06:05:23.693Z <Engine:INFO> Enqueueing "Bar Tablet Alarm Arming Popup Copy<SET>" (rule-lnoyj3ub:S)
                              [latest-23242]2023-10-18T06:05:23.699Z <Engine:NOTICE> Starting reaction Bar Tablet Alarm Arming Popup Copy<SET> (rule-lnoyj3ub:S)
                              [latest-23242]2023-10-18T06:05:23.702Z <HassController:5:HassController.js:100> HassController#hass MediaPlayer#hass>media_player_bar_tablet_2 performOnEntity x_hass.call_service no domain-specific cap, trying generic
                              [latest-23242]2023-10-18T06:05:23.707Z <HassController:5:HassController.js:222> HassController#hass: sending payload for x_hass.call_service on MediaPlayer#hass>media_player_bar_tablet_2 action: [Object]{ "type": "call_service", "service_data": { "dismissable": true, "autoclose": false, "timeout": 120000, "content": { "type": "custom:mushroom-alarm-control-panel-card", "entity": "alarm_control_panel.bar_partition", "states": [ "armed_home", "armed_away" ], "layout": "vertical", "show_keypad": true }, "entity_id": "media_player.bar_tablet_2" }, "domain": "browser_mod", "service": "popup" }
                              [latest-23242]2023-10-18T06:05:23.715Z <HassController:INFO> HassController#hass action x_hass.call_service([Object]{ "service": "browser_mod.popup", "data": "dismissable: true\nautoclose: false\ntimeout: 120000\ncontent:\n  type: custom:mushroom-alarm-control-panel-card\n  entity: alarm_control_panel.bar_partition\n  states:\n    - armed_home\n    - armed_away\n  layout: vertical\n  show_keypad: true" }) on MediaPlayer#hass>media_player_bar_tablet_2 succeeded
                              [latest-23242]2023-10-18T06:05:23.718Z <Engine:INFO> Resuming reaction Bar Tablet Alarm Arming Popup Copy<SET> (rule-lnoyj3ub:S) from step 1
                              [latest-23242]2023-10-18T06:05:23.719Z <Engine:INFO> Bar Tablet Alarm Arming Popup Copy<SET> all actions completed.
                              [latest-23242]2023-10-18T06:05:23.846Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                              [latest-23242]2023-10-18T06:05:25.353Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_cpu_thermal_0_temperature
                              [latest-23242]2023-10-18T06:05:25.359Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_ram_used_percent
                              [latest-23242]2023-10-18T06:05:25.363Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_ram_used
                              [latest-23242]2023-10-18T06:05:25.368Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_ram_free
                              [latest-23242]2023-10-18T06:05:25.372Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_cpu_load
                              [latest-23242]2023-10-18T06:05:25.378Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_total
                              [latest-23242]2023-10-18T06:05:25.382Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_thread
                              [latest-23242]2023-10-18T06:05:25.387Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_sleeping
                              [latest-23242]2023-10-18T06:05:25.391Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_cpu_used
                              [latest-23242]2023-10-18T06:05:26.163Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_door1
                              [latest-23242]2023-10-18T06:05:26.173Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_east
                              [latest-23242]2023-10-18T06:05:26.182Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.back_garden
                              [latest-23242]2023-10-18T06:05:26.191Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.back_landing
                              [latest-23242]2023-10-18T06:05:26.199Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_entrance_east
                              [latest-23242]2023-10-18T06:05:26.208Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_entrance_west
                              [latest-23242]2023-10-18T06:05:26.216Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.backyard
                              [latest-23242]2023-10-18T06:05:26.225Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.east_side_house
                              [latest-23242]2023-10-18T06:05:26.233Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.deck_stairs
                              [latest-23242]2023-10-18T06:05:26.242Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.bar_landing
                              [latest-23242]2023-10-18T06:05:26.251Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.deck_door
                              [latest-23242]2023-10-18T06:05:26.259Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.west_side_back
                              [latest-23242]2023-10-18T06:05:26.264Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_door_main
                              [latest-23242]2023-10-18T06:05:26.553Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.armans_macbook_pro_browser_visibility
                              [latest-23242]2023-10-18T06:05:27.267Z <HassController:5:HassController.js:352> HassController#hass updating hass entity binary_sensor.armans_macbook_pro
                              [latest-23242]2023-10-18T06:05:29.853Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.main_floor_tablet_free_memory
                              [latest-23242]2023-10-18T06:05:30.300Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.armans_macbook_pro_browser_visibility
                              [latest-23242]2023-10-18T06:05:30.305Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bar_tablet_internal_storage_free_space
                              [latest-23242]2023-10-18T06:05:30.309Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bar_tablet_free_memory
                              [latest-23242]2023-10-18T06:05:33.283Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_free
                              [latest-23242]2023-10-18T06:05:33.293Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_use_percent
                              [latest-23242]2023-10-18T06:05:35.316Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                              [latest-23242]2023-10-18T06:05:35.317Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                              [latest-23242]2023-10-18T06:05:35.318Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) trigger evaluation result is false (previously true)
                              [latest-23242]2023-10-18T06:05:35.319Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluated; rule state transition from SET to RESET!
                              [latest-23242]2023-10-18T06:05:35.345Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) trigger evaluation result is false (previously false)
                              [latest-23242]2023-10-18T06:05:35.345Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                              [latest-23242]2023-10-18T06:05:35.346Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluation complete
                              [latest-23242]2023-10-18T06:05:35.346Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluation complete
                              [latest-23242]2023-10-18T06:05:35.395Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                              [latest-23242]2023-10-18T06:05:35.396Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                              [latest-23242]2023-10-18T06:05:35.408Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) trigger evaluation result is false (previously false)
                              [latest-23242]2023-10-18T06:05:35.408Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                              [latest-23242]2023-10-18T06:05:35.414Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) trigger evaluation result is false (previously false)
                              [latest-23242]2023-10-18T06:05:35.415Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                              [latest-23242]2023-10-18T06:05:35.415Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluation complete
                              [latest-23242]2023-10-18T06:05:35.416Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluation complete
                              [latest-23242]2023-10-18T06:05:35.471Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                              [latest-23242]2023-10-18T06:05:35.472Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                              [latest-23242]2023-10-18T06:05:35.473Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) trigger evaluation result is false (previously false)
                              [latest-23242]2023-10-18T06:05:35.474Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                              [latest-23242]2023-10-18T06:05:35.477Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) trigger evaluation result is false (previously false)
                              [latest-23242]2023-10-18T06:05:35.477Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                              [latest-23242]2023-10-18T06:05:35.478Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluation complete
                              [latest-23242]2023-10-18T06:05:35.478Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluation complete
                              [latest-23242]2023-10-18T06:05:35.483Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                              [latest-23242]2023-10-18T06:05:35.483Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                              [latest-23242]2023-10-18T06:05:35.485Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) trigger evaluation result is false (previously false)
                              [latest-23242]2023-10-18T06:05:35.485Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                              [latest-23242]2023-10-18T06:05:35.487Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) trigger evaluation result is false (previously false)
                              [latest-23242]2023-10-18T06:05:35.487Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                              [latest-23242]2023-10-18T06:05:35.488Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluation complete
                              [latest-23242]2023-10-18T06:05:35.488Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluation complete
                                You placed the entire ZIP file, not unzipped, in the config directory?
                                  That is correct. /home/arman/Documents/reactor/config/hass_data.zip
                                    Can you confirm that after restart of Reactor, you find a log message containing the text ZIP data update found, and another shortly after ZIP update file device configuration version 23240.2 overrides package version xxx.yyy?
                                      Here are the startup logs, looks like there is a error saying the ZIP file has no hass_capabilities.json. Also ignore the dynamic group errors its still a work in progress lol .
                                      [latest-23242]2023-10-18T18:58:22.258Z <app:NOTICE> Closing Structure...
                                      [latest-23242]2023-10-18T18:58:22.258Z <Structure:NOTICE> Structure#1 Stopping controllers...
                                      [latest-23242]2023-10-18T18:58:22.259Z <Structure:INFO> Structure#1 stopping HassController#hass
                                      [latest-23242]2023-10-18T18:58:22.259Z <HassController:NOTICE> HassController#hass stopping
                                      [latest-23242]2023-10-18T18:58:22.263Z <wsapi:WARN> client close from unknown connection? "192.168.8.185#3"
                                      [latest-23242]2023-10-18T18:58:22.271Z <HassController:NOTICE> HassController#hass websocket closing, 1000
                                      [latest-23242]2023-10-18T18:58:22.272Z <Controller:NOTICE> HassController#hass stopping
                                      [latest-23242]2023-10-18T18:58:22.285Z <Controller:ERR> Controller HassController#hass is off-line!
                                      [latest-23242]2023-10-18T18:58:25.508Z <Structure:INFO> Structure#1 stopping ZWaveJSController#zwavejs
                                      [latest-23242]2023-10-18T18:58:25.508Z <Controller:NOTICE> ZWaveJSController#zwavejs stopping
                                      [latest-23242]2023-10-18T18:58:25.514Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group open_zones: [TypeError] Cannot read properties of undefined (reading 'binary_sensor_babay_papa_windows') [-]
                                      [latest-23242]2023-10-18T18:58:25.515Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'binary_sensor_babay_papa_windows') [-]
                                          at HassController.getNamedEntity (/home/arman/Documents/reactor/server/lib/Controller.js:380:35)
                                          at Structure.findEntity (/home/arman/Documents/reactor/server/lib/Structure.js:460:151)
                                          at DynamicGroupController._update_group (/home/arman/Documents/reactor/server/lib/DynamicGroupController.js:318:60)
                                          at /home/arman/Documents/reactor/server/lib/DynamicGroupController.js:375:67
                                          at DynamicGroupController._update (/home/arman/Documents/reactor/server/lib/DynamicGroupController.js:367:274)
                                          at DynamicGroupController.notify (/home/arman/Documents/reactor/server/lib/DynamicGroupController.js:255:91)
                                          at /home/arman/Documents/reactor/server/lib/MessageBus.js:106:223
                                          at MessageBus._sendToBus (/home/arman/Documents/reactor/server/lib/MessageBus.js:103:47)
                                      [latest-23242]2023-10-18T18:58:25.517Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group phones: [TypeError] Cannot read properties of undefined (reading 'sensor_bar_tablet_battery_level') [-]
                                      [latest-23242]2023-10-18T18:58:25.518Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'sensor_bar_tablet_battery_level') [-]
                                      [latest-23242]2023-10-18T18:58:25.519Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group low_battery_35: [TypeError] Cannot read properties of undefined (reading 'sensor_backyard_gate_battery_level') [-]
                                      [latest-23242]2023-10-18T18:58:25.520Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'sensor_backyard_gate_battery_level') [-]
                                      [latest-23242]2023-10-18T18:58:25.521Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group low_battery_10: [TypeError] Cannot read properties of undefined (reading 'sensor_backyard_gate_battery_level') [-]
                                      [latest-23242]2023-10-18T18:58:25.522Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'sensor_backyard_gate_battery_level') [-]
                                      [latest-23242]2023-10-18T18:58:25.524Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group dead_battery: [TypeError] Cannot read properties of undefined (reading 'sensor_backyard_gate_battery_level') [-]
                                      [latest-23242]2023-10-18T18:58:25.524Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'sensor_backyard_gate_battery_level') [-]
                                      [latest-23242]2023-10-18T18:58:25.527Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group offline_devices: [TypeError] Cannot read properties of undefined (reading 'controller_all') [-]
                                      [latest-23242]2023-10-18T18:58:25.527Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'controller_all') [-]
                                      [latest-23242]2023-10-18T18:58:25.529Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group add_on_update_available: [TypeError] Cannot read properties of undefined (reading 'update_address_sign_light_firmware') [-]
                                      [latest-23242]2023-10-18T18:58:25.529Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'update_address_sign_light_firmware') [-]
                                      [latest-23242]2023-10-18T18:58:25.603Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group jammed_door_locks: [TypeError] Cannot read properties of undefined (reading 'binary_sensor_touchscreen_deadbolt_access_control_lock_jammed') [-]
                                      [latest-23242]2023-10-18T18:58:25.603Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'binary_sensor_touchscreen_deadbolt_access_control_lock_jammed') [-]
                                      [latest-23242]2023-10-18T18:58:25.622Z <Controller:ERR> Controller ZWaveJSController#zwavejs is off-line!
                                      [latest-23242]2023-10-18T18:58:26.470Z <Structure:INFO> Structure#1 stopping DynamicGroupController#groups
                                      [latest-23242]2023-10-18T18:58:26.471Z <DynamicGroupController:null> DynamicGroupController#groups stopping
                                      [latest-23242]2023-10-18T18:58:26.481Z <Controller:NOTICE> DynamicGroupController#groups stopping
                                      [latest-23242]2023-10-18T18:58:26.488Z <Controller:ERR> Controller DynamicGroupController#groups is off-line!
                                      [latest-23242]2023-10-18T18:58:26.503Z <Structure:INFO> Structure#1 stopping SystemController#reactor_system
                                      [latest-23242]2023-10-18T18:58:26.504Z <Controller:NOTICE> SystemController#reactor_system stopping
                                      [latest-23242]2023-10-18T18:58:26.512Z <Controller:ERR> Controller SystemController#reactor_system is off-line!
                                      [latest-23242]2023-10-18T18:58:26.520Z <Structure:INFO> Structure#1 Final data sync...
                                      [latest-23242]2023-10-18T18:58:26.521Z <default:INFO> Closing container Container#rulesets
                                      [latest-23242]2023-10-18T18:58:26.521Z <default:INFO> Closing container Container#reactions
                                      [latest-23242]2023-10-18T18:58:26.521Z <default:INFO> Closing container Container#states
                                      [latest-23242]2023-10-18T18:58:26.583Z <default:INFO> Closing container Container#default
                                      [latest-23242]2023-10-18T18:58:27.013Z <default:INFO> Closing container Container#expressions
                                      [latest-23242]2023-10-18T18:58:27.019Z <Structure:NOTICE> Structure Structure#1 stopped
                                      [latest-23242]2023-10-18T18:58:27.019Z <app:NOTICE> Stopping timers...
                                      [latest-23242]2023-10-18T18:58:27.025Z <app:null> Shutdown complete, process ID 19741
                                      [latest-23242]2023-10-18T18:58:35.498Z <app:null> Reactor build latest-23242-5ee8e1d4 starting on v16.15.1
                                      [latest-23242]2023-10-18T18:58:35.501Z <app:null> Process ID 20525 user/group 1000/1000; bare-metal; platform linux/arm #1642 SMP Mon Apr  3 17:20:52 BST 2023; locale en_CA.UTF-8
                                      [latest-23242]2023-10-18T18:58:35.502Z <app:null> Basedir /home/arman/Documents/reactor; data in /home/arman/Documents/reactor/storage
                                      [latest-23242]2023-10-18T18:58:35.503Z <app:null> NODE_PATH=/home/arman/Documents/reactor
                                      [latest-23242]2023-10-18T18:58:35.514Z <app:INFO> Configured locale (undefined); selected locale(s) en_CA.UTF-8
                                      [latest-23242]2023-10-18T18:58:35.712Z <app:INFO> Loaded locale en-US for en-CA
                                      [latest-23242]2023-10-18T18:58:35.729Z <Structure:null> Module Structure v23172
                                      [latest-23242]2023-10-18T18:58:35.740Z <Capabilities:null> Module Capabilities v22356
                                      [latest-23242]2023-10-18T18:58:35.840Z <Capabilities:NOTICE> System capabilities loaded from core distribution, data version 23914 revision 1
                                      [latest-23242]2023-10-18T18:58:35.901Z <Plugin:null> Module Plugin v22300
                                      [latest-23242]2023-10-18T18:58:35.926Z <TimerBroker:null> Module TimerBroker v22283
                                      [latest-23242]2023-10-18T18:58:35.937Z <Entity:null> Module Entity v22353
                                      [latest-23242]2023-10-18T18:58:35.950Z <Controller:null> Module Controller v23069
                                      [latest-23242]2023-10-18T18:58:36.003Z <default:null> Module Ruleset v22293
                                      [latest-23242]2023-10-18T18:58:36.005Z <default:null> Module Rulesets v22146
                                      [latest-23242]2023-10-18T18:58:36.054Z <GlobalExpression:null> Module GlobalExpression v23211
                                      [latest-23242]2023-10-18T18:58:36.112Z <Predicate:null> Module Predicate v23093
                                      [latest-23242]2023-10-18T18:58:36.126Z <AlertManager:null> Module AlertManager v22283
                                      [latest-23242]2023-10-18T18:58:36.137Z <Rule:null> Module Rule v23107
                                      [latest-23242]2023-10-18T18:58:36.150Z <GlobalReaction:null> Module GlobalReaction v22324
                                      [latest-23242]2023-10-18T18:58:36.156Z <Engine:null> Module Engine v23231
                                      [latest-23242]2023-10-18T18:58:36.174Z <httpapi:null> Module httpapi v23058
                                      [latest-23242]2023-10-18T18:58:36.229Z <wsapi:null> Module wsapi v23172
                                      [latest-23242]2023-10-18T18:58:36.232Z <app:NOTICE> Starting Structure...
                                      [latest-23242]2023-10-18T18:58:36.251Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping
                                      [latest-23242]2023-10-18T18:58:36.258Z <Structure:INFO> Structure#1 loading controller interface hass (HassController)
                                      [latest-23242]2023-10-18T18:58:36.347Z <HassController:null> Module HassController v23240
                                      [latest-23242]2023-10-18T18:58:36.380Z <Controller:WARN> HassController#hass failed (1) to restore entity binary_sensor_front_water_fountain_sensor_water_alarm_water_leak_detected: [Error] Incompatible serialization data; can't unserialize [-]
                                      [latest-23242]2023-10-18T18:58:36.381Z <Controller:CRIT> Error: Incompatible serialization data; can't unserialize [-]
                                          at Entity.unserialize (/home/arman/Documents/reactor/server/lib/Entity.js:624:19)
                                          at /home/arman/Documents/reactor/server/lib/Controller.js:458:70
                                          at HassController._restoreEntities (/home/arman/Documents/reactor/server/lib/Controller.js:446:36)
                                          at new Controller (/home/arman/Documents/reactor/server/lib/Controller.js:37:45)
                                          at new HassController (/home/arman/Documents/reactor/server/lib/HassController.js:36:9)
                                          at /home/arman/Documents/reactor/server/lib/Controller.js:93:37
                                      [latest-23242]2023-10-18T18:58:36.384Z <Controller:WARN> HassController#hass failed (1) to restore entity binary_sensor_z_wave_wireless_flood_freeze_sensor_sensor_state_water: [Error] Incompatible serialization data; can't unserialize [-]
                                      [latest-23242]2023-10-18T18:58:36.385Z <Controller:CRIT> Error: Incompatible serialization data; can't unserialize [-]
                                      [latest-23242]2023-10-18T18:58:38.603Z <Structure:INFO> Structure#1 loading controller interface zwavejs (ZWaveJSController)
                                      [latest-23242]2023-10-18T18:58:38.648Z <ZWaveJSController:null> Module ZWaveJSController v23194
                                      [latest-23242]2023-10-18T18:58:38.651Z <Controller:INFO> Loaded ZWaveJSController version "0.1.23194"; Patrick Rigney/Kedron Holdings LLC <patrick@toggledbits.com> https://reactor.toggledbits.com/docs/ZWaveJSController/
                                      [latest-23242]2023-10-18T18:58:38.970Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs added file logger to zwavejs.log
                                      [latest-23242]2023-10-18T18:58:38.971Z <Structure:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
                                      [latest-23242]2023-10-18T18:58:38.993Z <DynamicGroupController:null> Module DynamicGroupController v22313
                                      [latest-23242]2023-10-18T18:58:39.021Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
                                      [latest-23242]2023-10-18T18:58:39.035Z <SystemController:null> Module SystemController v23214
                                      [latest-23242]2023-10-18T18:58:39.048Z <Structure:INFO> Starting controller HassController#hass
                                      [latest-23242]2023-10-18T18:58:39.049Z <HassController:NOTICE> HassController#hass starting...
                                      [latest-23242]2023-10-18T18:58:39.063Z <Controller:INFO> HassController#hass ZIP data update found (/home/arman/Documents/reactor/config/hass_data.zip)
                                      [latest-23242]2023-10-18T18:58:39.066Z <Structure:INFO> Starting controller ZWaveJSController#zwavejs
                                      [latest-23242]2023-10-18T18:58:39.069Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming
                                      [latest-23242]2023-10-18T18:58:39.070Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming
                                      [latest-23242]2023-10-18T18:58:39.070Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming
                                      [latest-23242]2023-10-18T18:58:39.070Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming
                                      [latest-23242]2023-10-18T18:58:39.071Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1
                                      [latest-23242]2023-10-18T18:58:39.123Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23194 rev 1 format 1
                                      [latest-23242]2023-10-18T18:58:39.123Z <Structure:INFO> Starting controller DynamicGroupController#groups
                                      [latest-23242]2023-10-18T18:58:39.138Z <Controller:NOTICE> Controller DynamicGroupController#groups is now online.
                                      [latest-23242]2023-10-18T18:58:39.139Z <Structure:INFO> Starting controller SystemController#reactor_system
                                      [latest-23242]2023-10-18T18:58:39.146Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
                                      [latest-23242]2023-10-18T18:58:39.344Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.8.85:3000
                                      [latest-23242]2023-10-18T18:58:39.413Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs greeting from server: [Object]{ "type": "version", "driverVersion": "12.2.0", "serverVersion": "1.32.1", "homeId": 3775115912, "minSchemaVersion": 0, "maxSchemaVersion": 32 }
                                      [latest-23242]2023-10-18T18:58:39.416Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs connected
                                      [latest-23242]2023-10-18T18:58:39.417Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs sending connection initialization
                                      [latest-23242]2023-10-18T18:58:39.431Z <Controller:WARN> /home/arman/Documents/reactor/config/hass_data.zip: no hass_capabilities.json: hass
                                      [latest-23242]2023-10-18T18:58:39.432Z <Controller:INFO> HassController#hass loaded hass capabilities ver 23109 rev 1 format 1
                                      [latest-23242]2023-10-18T18:58:39.468Z <Controller:WARN> /home/arman/Documents/reactor/config/hass_data.zip: no hass_devices.json: [Error] Entry not found [-]
                                      [latest-23242]2023-10-18T18:58:39.468Z <Controller:INFO> HassController#hass loaded implementation data ver 23240 rev 1 format 1
                                      [latest-23242]2023-10-18T18:58:39.473Z <HassController:INFO> HassController#hass device mapping data loaded; checking...
                                      [latest-23242]2023-10-18T18:58:39.475Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability power_switch
                                      [latest-23242]2023-10-18T18:58:39.477Z <HassController:5:HassController.js:258> HassController#hass capability power_switch attributes [Array][ "state" ]
                                      [latest-23242]2023-10-18T18:58:39.477Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability toggle
                                      [latest-23242]2023-10-18T18:58:39.479Z <HassController:5:HassController.js:258> HassController#hass capability toggle attributes [Array][  ]
                                      [latest-23242]2023-10-18T18:58:39.480Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability dimming
                                      [latest-23242]2023-10-18T18:58:39.480Z <HassController:5:HassController.js:258> HassController#hass capability dimming attributes [Array][ "level", "step" ]
                                      [latest-23242]2023-10-18T18:58:39.481Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability rgb_color
                                      [latest-23242]2023-10-18T18:58:39.481Z <HassController:5:HassController.js:258> HassController#hass capability rgb_color attributes [Array][ "red", "green", "blue" ]
                                      [latest-23242]2023-10-18T18:58:39.482Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability hs_color
                                      [latest-23242]2023-10-18T18:58:39.482Z <HassController:5:HassController.js:258> HassController#hass capability hs_color attributes [Array][ "hue", "saturation" ]
                                      [latest-23242]2023-10-18T18:58:39.483Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability xy_color
                                      [latest-23242]2023-10-18T18:58:39.484Z <HassController:5:HassController.js:258> HassController#hass capability xy_color attributes [Array][ "x", "y" ]
                                      [latest-23242]2023-10-18T18:58:39.484Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability color_temperature
                                      [latest-23242]2023-10-18T18:58:39.485Z <HassController:5:HassController.js:258> HassController#hass capability color_temperature attributes [Array][ "value" ]
                                      [latest-23242]2023-10-18T18:58:39.486Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability light_effect
                                      [latest-23242]2023-10-18T18:58:39.486Z <HassController:5:HassController.js:258> HassController#hass capability light_effect attributes [Array][ "current" ]
                                      [latest-23242]2023-10-18T18:58:39.487Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability binary_sensor
                                      [latest-23242]2023-10-18T18:58:39.487Z <HassController:5:HassController.js:258> HassController#hass capability binary_sensor attributes [Array][ "state" ]
                                      [latest-23242]2023-10-18T18:58:39.488Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability person.binary_sensor
                                      [latest-23242]2023-10-18T18:58:39.488Z <HassController:5:HassController.js:258> HassController#hass capability person.binary_sensor attributes [Array][ "state" ]
                                      [latest-23242]2023-10-18T18:58:39.489Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability motion_sensor
                                      [latest-23242]2023-10-18T18:58:39.490Z <HassController:5:HassController.js:258> HassController#hass capability motion_sensor attributes [Array][ "state" ]
                                      [latest-23242]2023-10-18T18:58:39.490Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability tamper
                                      [latest-23242]2023-10-18T18:58:39.491Z <HassController:5:HassController.js:258> HassController#hass capability tamper attributes [Array][ "state" ]
                                      [latest-23242]2023-10-18T18:58:39.491Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability co_detector
                                      [latest-23242]2023-10-18T18:58:39.492Z <HassController:5:HassController.js:258> HassController#hass capability co_detector attributes [Array][ "state" ]
                                      [latest-23242]2023-10-18T18:58:39.492Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability door_sensor
                                      [latest-23242]2023-10-18T18:58:39.493Z <HassController:5:HassController.js:258> HassController#hass capability door_sensor attributes [Array][ "state" ]
                                      [latest-23242]2023-10-18T18:58:39.493Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability freeze_detector
                                      [latest-23242]2023-10-18T18:58:39.494Z <HassController:5:HassController.js:258> HassController#hass capability freeze_detector attributes [Array][ "state" ]
                                      [latest-23242]2023-10-18T18:58:39.494Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability gas_detector
                                      [latest-23242]2023-10-18T18:58:39.495Z <HassController:5:HassController.js:258> HassController#hass capability gas_detector attributes [Array][ "state" ]
                                      [latest-23242]2023-10-18T18:58:39.495Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability heat_detector
                                      [latest-23242]2023-10-18T18:58:39.496Z <HassController:5:HassController.js:258> HassController#hass capability heat_detector attributes [Array][ "state" ]
                                      [latest-23242]2023-10-18T18:58:39.496Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability presence_sensor
                                      [latest-23242]2023-10-18T18:58:39.497Z <HassController:5:HassController.js:258> HassController#hass capability presence_sensor attributes [Array][ "state" ]
                                      [latest-23242]2023-10-18T18:58:39.497Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability smoke_detector
                                      [latest-23242]2023-10-18T18:58:39.498Z <HassController:5:HassController.js:258> HassController#hass capability smoke_detector attributes [Array][ "state" ]
                                      [latest-23242]2023-10-18T18:58:39.498Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability window_sensor
                                      [latest-23242]2023-10-18T18:58:39.499Z <HassController:5:HassController.js:258> HassController#hass capability window_sensor attributes [Array][ "state" ]
                                      [latest-23242]2023-10-18T18:58:39.499Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability battery_maintenance
                                      [latest-23242]2023-10-18T18:58:39.500Z <HassController:5:HassController.js:258> HassController#hass capability battery_maintenance attributes [Array][ "rechargeable", "replace", "charging" ]
                                      [latest-23242]2023-10-18T18:58:39.500Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability value_sensor
                                      [latest-23242]2023-10-18T18:58:39.501Z <HassController:5:HassController.js:258> HassController#hass capability value_sensor attributes [Array][ "value", "units" ]
                                      [latest-23242]2023-10-18T18:58:39.501Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability temperature_sensor
                                      [latest-23242]2023-10-18T18:58:39.502Z <HassController:5:HassController.js:258> HassController#hass capability temperature_sensor attributes [Array][ "value", "units" ]
                                      [latest-23242]2023-10-18T18:58:39.502Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability humidity_sensor
                                      [latest-23242]2023-10-18T18:58:39.503Z <HassController:5:HassController.js:258> HassController#hass capability humidity_sensor attributes [Array][ "value", "units" ]
                                      [latest-23242]2023-10-18T18:58:39.503Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability pressure_sensor
                                      [latest-23242]2023-10-18T18:58:39.504Z <HassController:5:HassController.js:258> HassController#hass capability pressure_sensor attributes [Array][ "value", "units" ]
                                      [latest-23242]2023-10-18T18:58:39.504Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability voltage_sensor
                                        OK. Sorry. Try a fresh download of the ZIP file and install the updated version. Same routine... install (to config), restart Reactor, run test, post logs.
                                          So it looks like the ZIP file worked this time
                                          [latest-23242]2023-10-18T23:13:13.781Z <Structure:INFO> Structure#1 loading controller interface zwavejs (ZWaveJSController)
                                          [latest-23242]2023-10-18T23:13:13.825Z <ZWaveJSController:null> Module ZWaveJSController v23194
                                          [latest-23242]2023-10-18T23:13:13.827Z <Controller:INFO> Loaded ZWaveJSController version "0.1.23194"; Patrick Rigney/Kedron Holdings LLC <patrick@toggledbits.com> https://reactor.toggledbits.com/docs/ZWaveJSController/
                                          [latest-23242]2023-10-18T23:13:14.159Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs added file logger to zwavejs.log
                                          [latest-23242]2023-10-18T23:13:14.160Z <Structure:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
                                          [latest-23242]2023-10-18T23:13:14.182Z <DynamicGroupController:null> Module DynamicGroupController v22313
                                          [latest-23242]2023-10-18T23:13:14.214Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
                                          [latest-23242]2023-10-18T23:13:14.228Z <SystemController:null> Module SystemController v23214
                                          [latest-23242]2023-10-18T23:13:14.242Z <Structure:INFO> Starting controller HassController#hass
                                          [latest-23242]2023-10-18T23:13:14.243Z <HassController:NOTICE> HassController#hass starting...
                                          [latest-23242]2023-10-18T23:13:14.256Z <Controller:INFO> HassController#hass ZIP data update found (/home/arman/Documents/reactor/config/hass_data.zip)
                                          [latest-23242]2023-10-18T23:13:14.259Z <Structure:INFO> Starting controller ZWaveJSController#zwavejs
                                          [latest-23242]2023-10-18T23:13:14.262Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming
                                          [latest-23242]2023-10-18T23:13:14.263Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming
                                          [latest-23242]2023-10-18T23:13:14.263Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming
                                          [latest-23242]2023-10-18T23:13:14.264Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming
                                          [latest-23242]2023-10-18T23:13:14.264Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1
                                          [latest-23242]2023-10-18T23:13:14.317Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23194 rev 1 format 1
                                          [latest-23242]2023-10-18T23:13:14.317Z <Structure:INFO> Starting controller DynamicGroupController#groups
                                          [latest-23242]2023-10-18T23:13:14.336Z <Controller:NOTICE> Controller DynamicGroupController#groups is now online.
                                          [latest-23242]2023-10-18T23:13:14.336Z <Structure:INFO> Starting controller SystemController#reactor_system
                                          [latest-23242]2023-10-18T23:13:14.347Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
                                          [latest-23242]2023-10-18T23:13:14.553Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.8.85:3000
                                          [latest-23242]2023-10-18T23:13:14.626Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs greeting from server: [Object]{ "type": "version", "driverVersion": "12.2.0", "serverVersion": "1.32.1", "homeId": 3775115912, "minSchemaVersion": 0, "maxSchemaVersion": 32 }
                                          [latest-23242]2023-10-18T23:13:14.629Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs connected
                                          [latest-23242]2023-10-18T23:13:14.630Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs sending connection initialization
                                          [latest-23242]2023-10-18T23:13:14.644Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing initial inventory
                                          [latest-23242]2023-10-18T23:13:14.666Z <Controller:INFO> HassController#hass ZIP update file capabilities ignored; ZIP version 23109.1 <= package version 23109.1
                                          [latest-23242]2023-10-18T23:13:14.668Z <Controller:INFO> HassController#hass loaded hass capabilities ver 23109 rev 1 format 1
                                          [latest-23242]2023-10-18T23:13:14.758Z <Controller:INFO> HassController#hass ZIP update file device configuration version 23240.2 overrides package version 23240.1
                                          [latest-23242]2023-10-18T23:13:14.759Z <Controller:INFO> HassController#hass loaded implementation data ver 23240 rev 2 format 1
                                          [latest-23242]2023-10-18T23:13:14.763Z <HassController:INFO> HassController#hass device mapping data loaded; checking...
                                          [latest-23242]2023-10-18T23:13:14.765Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability power_switch
                                          [latest-23242]2023-10-18T23:13:14.766Z <HassController:5:HassController.js:258> HassController#hass capability power_switch attributes [Array][ "state" ]
                                          [latest-23242]2023-10-18T23:13:14.767Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability toggle
                                          [latest-23242]2023-10-18T23:13:14.768Z <HassController:5:HassController.js:258> HassController#hass capability toggle attributes [Array][  ]
                                          [latest-23242]2023-10-18T23:13:14.768Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability dimming
                                          However testing the rule the popup still showed on all browser mod devices. I know you had mentioned using x_hass.call_service on the device entity, but my question is how would MSR know what the browser_id would be for said entity? The browser_id is unique to this integration so I would think that MSR/HA would not have this info stored in the entity. Just a thought though. Is there any way we can get the call_service command for the HA system entity to work since it just seems like the target info isn't being passed through correctly?
                                          [latest-23242]2023-10-18T23:15:24.707Z <Rule:INFO> Fountain (rule-grpsdlp33d in Backyard Reactor) evaluated; trigger state unchanged (true); rule state remains SET
                                          [latest-23242]2023-10-18T23:15:24.710Z <Rule:INFO> Backyard Fountain (rule-grptitus9c in Backyard Reactor) starting evaluation; because data-changed Data#states:cs-rule-grpsdlp33d
                                          [latest-23242]2023-10-18T23:15:24.710Z <Rule:INFO> Fountain (rule-grpsdlp33d in Backyard Reactor) evaluation complete
                                          [latest-23242]2023-10-18T23:15:24.711Z <Rule:INFO> Backyard Fountain (rule-grptitus9c in Backyard Reactor) trigger evaluation result is true (previously true)
                                          [latest-23242]2023-10-18T23:15:24.711Z <Rule:INFO> Backyard Fountain (rule-grptitus9c in Backyard Reactor) evaluated; trigger state unchanged (true); rule state remains SET
                                          [latest-23242]2023-10-18T23:15:24.712Z <Rule:INFO> Backyard Fountain (rule-grptitus9c in Backyard Reactor) evaluation complete
                                          [latest-23242]2023-10-18T23:15:26.304Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_door1
                                          [latest-23242]2023-10-18T23:15:26.315Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_east
                                          [latest-23242]2023-10-18T23:15:26.324Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.back_garden
                                          [latest-23242]2023-10-18T23:15:26.333Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.back_landing
                                          [latest-23242]2023-10-18T23:15:26.342Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_entrance_east
                                          [latest-23242]2023-10-18T23:15:26.349Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_entrance_west
                                          [latest-23242]2023-10-18T23:15:26.355Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.backyard
                                          [latest-23242]2023-10-18T23:15:26.362Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.east_side_house
                                          [latest-23242]2023-10-18T23:15:26.369Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.deck_stairs
                                          [latest-23242]2023-10-18T23:15:26.375Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.bar_landing
                                          [latest-23242]2023-10-18T23:15:26.382Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.deck_door
                                          [latest-23242]2023-10-18T23:15:26.389Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.west_side_back
                                          [latest-23242]2023-10-18T23:15:26.395Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_door_main
                                          [latest-23242]2023-10-18T23:15:27.253Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                                          [latest-23242]2023-10-18T23:15:29.264Z <Engine:INFO> Enqueueing "Bar Tablet Alarm Arming Popup Copy<SET>" (rule-lnoyj3ub:S)
                                          [latest-23242]2023-10-18T23:15:29.271Z <Engine:NOTICE> Starting reaction Bar Tablet Alarm Arming Popup Copy<SET> (rule-lnoyj3ub:S)
                                          [latest-23242]2023-10-18T23:15:29.281Z <HassController:5:HassController.js:100> HassController#hass MediaPlayer#hass>media_player_bar_tablet_2 performOnEntity x_hass.call_service no domain-specific cap, trying generic
                                          [latest-23242]2023-10-18T23:15:29.287Z <HassController:5:HassController.js:222> HassController#hass: sending payload for x_hass.call_service on MediaPlayer#hass>media_player_bar_tablet_2 action: [Object]{ "type": "call_service", "service_data": { "dismissable": true, "autoclose": false, "timeout": 120000, "content": { "type": "custom:mushroom-alarm-control-panel-card", "entity": "alarm_control_panel.bar_partition", "states": [ "armed_home", "armed_away" ], "layout": "vertical", "show_keypad": true } }, "domain": "browser_mod", "service": "popup", "target": { "entity_id": "media_player.bar_tablet_2" } }
                                          [latest-23242]2023-10-18T23:15:29.298Z <HassController:INFO> HassController#hass action x_hass.call_service([Object]{ "service": "browser_mod.popup", "data": "dismissable: true\nautoclose: false\ntimeout: 120000\ncontent:\n  type: custom:mushroom-alarm-control-panel-card\n  entity: alarm_control_panel.bar_partition\n  states:\n    - armed_home\n    - armed_away\n  layout: vertical\n  show_keypad: true" }) on MediaPlayer#hass>media_player_bar_tablet_2 succeeded
                                          [latest-23242]2023-10-18T23:15:29.303Z <Engine:INFO> Resuming reaction Bar Tablet Alarm Arming Popup Copy<SET> (rule-lnoyj3ub:S) from step 1
                                          [latest-23242]2023-10-18T23:15:29.304Z <Engine:INFO> Bar Tablet Alarm Arming Popup Copy<SET> all actions completed.
                                          [latest-23242]2023-10-18T23:15:30.576Z <HassController:5:HassController.js:352> HassController#hass updating hass entity binary_sensor.pabla_windows
                                          [latest-23242]2023-10-18T23:15:33.070Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.pabla_windows_browser_path
                                          [latest-23242]2023-10-18T23:15:33.119Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.pabla_windows_browser_path
                                          [latest-23242]2023-10-18T23:15:33.243Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                                          [latest-23242]2023-10-18T23:15:34.425Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.pabla_windows_browser_path
                                          [latest-23242]2023-10-18T23:15:34.443Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.pabla_windows_browser_path
                                          [latest-23242]2023-10-18T23:15:35.627Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wan_download_speed
                                          [latest-23242]2023-10-18T23:15:35.640Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wan_upload_speed
                                          [latest-23242]2023-10-18T23:15:35.650Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wired_download_speed
                                          [latest-23242]2023-10-18T23:15:35.660Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wired_upload_speed
                                          [latest-23242]2023-10-18T23:15:35.670Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_bridge_download_speed
                                          [latest-23242]2023-10-18T23:15:35.679Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_bridge_upload_speed
                                          [latest-23242]2023-10-18T23:15:35.700Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.pabla_windows_browser_path
                                          [latest-23242]2023-10-18T23:15:36.247Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                                          [latest-23242]2023-10-18T23:15:36.678Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_ram
                                          [latest-23242]2023-10-18T23:15:36.684Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_cpu
                                          [latest-23242]2023-10-18T23:15:37.062Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.pabla_windows_browser_path
                                          [latest-23242]2023-10-18T23:15:38.841Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.processor_use
                                          [latest-23242]2023-10-18T23:15:38.851Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_free
                                            160.0k
