  4. Honeywell TH6320ZW2003_T6_Pro_ZWave shows hvac_control.state="heat" in zwaveJSController
3 Posts 2 Posters 987 Views 2 Watching
  • SnowmanS Offline
    SnowmanS Offline
    Snowman
    wrote on last edited by Snowman
    @togglebits I have another one for you.
    HASS controller shows hvac_control.state="heating, cooling or idle".
    ZWaveJSController controller shows hvac_control.state="heat, cool, or idle"
    I believe hvac_control.state="heating, cooling or idle" should be what the ZWaveJSController should show.
    "heat", "cool" or "off" are values assigned to the hvac_control.mode attribute.
    Again, not sure if this is related to Reactor/ZwaveJSController implementation or the actual Z-Wave JS UI docker version. I have copied, below, the attributes of the thermostat in hopes it can help.
    Thanks in advance.
    Reactor version 23302
    ZWaveJSController version 23254
    Z-Wave JS UI version 9.3.0.724519f
    zwave-js version 12.2.3
    battery_power.level=0.95
    battery_power.since=1700301347874
    humidity_sensor.units="%"
    humidity_sensor.value=40
    hvac_blower_unit.filter_change=null
    hvac_blower_unit.mode="low"
    hvac_blower_unit.state=true
    hvac_control.mode="heat"
    hvac_cooling_unit.setpoint=23.5
    hvac_cooling_unit.state=false
    hvac_cooling_unit.units="°C"
    hvac_heating_unit.setpoint=20.5
    hvac_heating_unit.state=false
    hvac_heating_unit.units="°C"
    power_source.source=null
    temperature_sensor.units="°C"
    temperature_sensor.value=20.5
    x_debug.dt={"entity_class":"Thermostat","match":"deviceClass.generic.key=8","capabilities":["hvac_control"],"primary_attribute":"hvac_control.state","description":"T6 Pro Z-Wave Programmable Thermostat","model":"TH6320ZW","default_name":"Honeywell T6 Pro Thermostat","values":[{"valueId":"113:Power Management:Mains status","capabilities":{"power_source":{"attributes":{"source":{"expr":"([ 'unknown', 'unknown', 'dc', 'ac' ])[value ?# 0] ?? 'unknown'","update_only":true}}}}}],"manufacturerId":57,"productType":17,"productId":8}
    x_zwave_values.Battery_isLow=false
    x_zwave_values.Battery_level=95
    x_zwave_values.Configuration_Adaptive_Intelligent_Recovery=1
    x_zwave_values.Configuration_Air_Filter_1_Reminder=0
    x_zwave_values.Configuration_Air_Filter_2_Reminder=0
    x_zwave_values.Configuration_Air_Filters=1
    x_zwave_values.Configuration_Auto_Changeover=0
    x_zwave_values.Configuration_Auto_Differential=0
    x_zwave_values.Configuration_Aux_Heat_Cycle_Rate=9
    x_zwave_values.Configuration_Aux_Heat_Outdoor_Lockout=0
    x_zwave_values.Configuration_Auxiliary_Emergency_Control=0
    x_zwave_values.Configuration_Auxiliary_Heat_Droop=0
    x_zwave_values.Configuration_Auxiliary_Heat_Type=0
    x_zwave_values.Configuration_Balance_Point=0
    x_zwave_values.Configuration_Clock_Format=1
    x_zwave_values.Configuration_Compressor_Protection=5
    x_zwave_values.Configuration_Cool_Stage_1_Cycle_Rate=3
    x_zwave_values.Configuration_Cool_Stage_2_Cycle_Rate=3
    x_zwave_values.Configuration_Cool_Stages=1
    x_zwave_values.Configuration_Daylight_Saving=1
    x_zwave_values.Configuration_Dehumidification_Filter_Reminder=0
    x_zwave_values.Configuration_Emergency_Heat_Cycle_Rate=9
    x_zwave_values.Configuration_Emergency_Heat_Type=0
    x_zwave_values.Configuration_Equipment_Type=2
    x_zwave_values.Configuration_Fossil_Kit_Control=0
    x_zwave_values.Configuration_Heat_Stage_1_Cycle_Rate=3
    x_zwave_values.Configuration_Heat_Stage_2_Cycle_Rate=3
    x_zwave_values.Configuration_Heat_Stages=1
    x_zwave_values.Configuration_High_Cool_Stage_Finish=0
    x_zwave_values.Configuration_High_Heat_Stage_Finish=0
    x_zwave_values.Configuration_Humidification_Pad_Reminder=0
    x_zwave_values.Configuration_Idle_Brightness=0
    x_zwave_values.Configuration_Maximum_Heat_Temperature=75
    x_zwave_values.Configuration_Minimum_Cool_Temperature=66
    x_zwave_values.Configuration_Outdoor_Temperature_Sensor=0
    x_zwave_values.Configuration_Reversing_Valve=0
    x_zwave_values.Configuration_Schedule_Type=2
    x_zwave_values.Configuration_Temperature_Offset=0
    x_zwave_values.Configuration_Temperature_Scale=1
    x_zwave_values.Configuration_UV_Bulb_1_Reminder=0
    x_zwave_values.Configuration_UV_Bulb_2_Reminder=0
    x_zwave_values.Configuration_UV_Devices=0
    x_zwave_values.Configuration_Up_Stage_Timer_Aux_Heat=0
    x_zwave_values.Configuration_Ventilation_Filter_Reminder=0
    x_zwave_values.Manufacturer_Specific_manufacturerId=57
    x_zwave_values.Manufacturer_Specific_productId=8
    x_zwave_values.Manufacturer_Specific_productType=17
    x_zwave_values.Multilevel_Sensor_Air_temperature=20.5
    x_zwave_values.Multilevel_Sensor_Humidity=40
    x_zwave_values.Notification_Power_Management_Mains_status=3
    x_zwave_values.Notification_alarmLevel=0
    x_zwave_values.Notification_alarmType=0
    x_zwave_values.Thermostat_Fan_Mode_mode=1
    x_zwave_values.Thermostat_Fan_Mode_off=false
    x_zwave_values.Thermostat_Fan_State_state=1
    x_zwave_values.Thermostat_Mode_manufacturerData=null
    x_zwave_values.Thermostat_Mode_mode=1
    x_zwave_values.Thermostat_Operating_State_state=0
    x_zwave_values.Thermostat_Setpoint_setpoint_1=20.5
    x_zwave_values.Thermostat_Setpoint_setpoint_11=18
    x_zwave_values.Thermostat_Setpoint_setpoint_12=26
    x_zwave_values.Thermostat_Setpoint_setpoint_2=23.5
    x_zwave_values.Version_firmwareVersions=["1.3","1.4"]
    x_zwave_values.Version_hardwareVersion=1
    x_zwave_values.Version_libraryType=6
    x_zwave_values.Version_protocolVersion="4.61"
    zwave_device.capabilities=[49,64,66,67,68,69,112,113,114,128,134]
    zwave_device.endpoint=0
    zwave_device.failed=false
    zwave_device.generic_class="Thermostat"
    zwave_device.impl_sig="23318:1:22315:1"
    zwave_device.is_beaming=false
    zwave_device.is_listening=true
    zwave_device.is_routing=true
    zwave_device.is_secure=false
    zwave_device.manufacturer_info=[57,17,8]
    zwave_device.node_id=16
    zwave_device.specific_class="General Thermostat V2"
    zwave_device.status=4
    zwave_device.status_text="alive"
    zwave_device.version_info=[null,"1.3"]
      Try pulling the latest zwavejs_data.zip from the download server. Put it in your config directory and restart Reactor.
      • SnowmanS Offline
        SnowmanS Offline
        Snowman
        That did the trick. Thanks again.
          153.0k
