  4. Honeywell TH6320ZW2003_T6_Pro_ZWave shows hvac_control.state="heat" in zwaveJSController
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
3 Posts 2 Posters 1.0k Views 2 Watching
  • SnowmanS Offline
    SnowmanS Offline
    Snowman
    wrote on last edited by Snowman
    @togglebits I have another one for you.
    HASS controller shows hvac_control.state="heating, cooling or idle".
    ZWaveJSController controller shows hvac_control.state="heat, cool, or idle"
    I believe hvac_control.state="heating, cooling or idle" should be what the ZWaveJSController should show.
    "heat", "cool" or "off" are values assigned to the hvac_control.mode attribute.
    Again, not sure if this is related to Reactor/ZwaveJSController implementation or the actual Z-Wave JS UI docker version. I have copied, below, the attributes of the thermostat in hopes it can help.
    Thanks in advance.
    Reactor version 23302
    zwave-js version 12.2.3
    battery_power.level=0.95
    battery_power.since=1700301347874
    humidity_sensor.units="%"
    humidity_sensor.value=40
    hvac_blower_unit.filter_change=null
    hvac_blower_unit.mode="low"
    hvac_blower_unit.state=true
    hvac_control.mode="heat"
    hvac_cooling_unit.setpoint=23.5
    hvac_cooling_unit.state=false
    hvac_cooling_unit.units="°C"
    hvac_heating_unit.setpoint=20.5
    hvac_heating_unit.state=false
    hvac_heating_unit.units="°C"
    power_source.source=null
    temperature_sensor.units="°C"
    temperature_sensor.value=20.5
    x_debug.dt={"entity_class":"Thermostat","match":"deviceClass.generic.key=8","capabilities":["hvac_control"],"primary_attribute":"hvac_control.state","description":"T6 Pro Z-Wave Programmable Thermostat","model":"TH6320ZW","default_name":"Honeywell T6 Pro Thermostat","values":[{"valueId":"113:Power Management:Mains status","capabilities":{"power_source":{"attributes":{"source":{"expr":"([ 'unknown', 'unknown', 'dc', 'ac' ])[value ?# 0] ?? 'unknown'","update_only":true}}}}}],"manufacturerId":57,"productType":17,"productId":8}
    x_zwave_values.Battery_level=95
    x_zwave_values.Configuration_Adaptive_Intelligent_Recovery=1
    x_zwave_values.Configuration_Air_Filter_1_Reminder=0
    x_zwave_values.Configuration_Air_Filter_2_Reminder=0
    x_zwave_values.Configuration_Air_Filters=1
    x_zwave_values.Configuration_Auto_Changeover=0
    x_zwave_values.Configuration_Auto_Differential=0
    x_zwave_values.Configuration_Aux_Heat_Cycle_Rate=9
    x_zwave_values.Configuration_Aux_Heat_Outdoor_Lockout=0
    x_zwave_values.Configuration_Auxiliary_Emergency_Control=0
    x_zwave_values.Configuration_Auxiliary_Heat_Droop=0
    x_zwave_values.Configuration_Auxiliary_Heat_Type=0
    x_zwave_values.Configuration_Balance_Point=0
    x_zwave_values.Configuration_Clock_Format=1
    x_zwave_values.Configuration_Compressor_Protection=5
    x_zwave_values.Configuration_Cool_Stage_1_Cycle_Rate=3
    x_zwave_values.Configuration_Cool_Stage_2_Cycle_Rate=3
    x_zwave_values.Configuration_Cool_Stages=1
    x_zwave_values.Configuration_Daylight_Saving=1
    x_zwave_values.Configuration_Dehumidification_Filter_Reminder=0
    x_zwave_values.Configuration_Emergency_Heat_Cycle_Rate=9
    x_zwave_values.Configuration_Emergency_Heat_Type=0
    x_zwave_values.Configuration_Equipment_Type=2
    x_zwave_values.Configuration_Fossil_Kit_Control=0
    x_zwave_values.Configuration_Heat_Stage_1_Cycle_Rate=3
    x_zwave_values.Configuration_Heat_Stage_2_Cycle_Rate=3
    x_zwave_values.Configuration_Heat_Stages=1
    x_zwave_values.Configuration_High_Cool_Stage_Finish=0
    x_zwave_values.Configuration_High_Heat_Stage_Finish=0
    x_zwave_values.Configuration_Humidification_Pad_Reminder=0
    x_zwave_values.Configuration_Idle_Brightness=0
    x_zwave_values.Configuration_Maximum_Heat_Temperature=75
    x_zwave_values.Configuration_Minimum_Cool_Temperature=66
    x_zwave_values.Configuration_Outdoor_Temperature_Sensor=0
    x_zwave_values.Configuration_Reversing_Valve=0
    x_zwave_values.Configuration_Schedule_Type=2
    x_zwave_values.Configuration_Temperature_Offset=0
    x_zwave_values.Configuration_Temperature_Scale=1
    x_zwave_values.Configuration_UV_Bulb_1_Reminder=0
    x_zwave_values.Configuration_UV_Bulb_2_Reminder=0
    x_zwave_values.Configuration_UV_Devices=0
    x_zwave_values.Configuration_Up_Stage_Timer_Aux_Heat=0
    x_zwave_values.Configuration_Ventilation_Filter_Reminder=0
    x_zwave_values.Manufacturer_Specific_manufacturerId=57
    x_zwave_values.Manufacturer_Specific_productId=8
    x_zwave_values.Manufacturer_Specific_productType=17
    x_zwave_values.Multilevel_Sensor_Air_temperature=20.5
    x_zwave_values.Multilevel_Sensor_Humidity=40
    x_zwave_values.Notification_Power_Management_Mains_status=3
    x_zwave_values.Notification_alarmLevel=0
    x_zwave_values.Notification_alarmType=0
    x_zwave_values.Thermostat_Fan_Mode_mode=1
    x_zwave_values.Thermostat_Fan_Mode_off=false
    x_zwave_values.Thermostat_Fan_State_state=1
    x_zwave_values.Thermostat_Mode_manufacturerData=null
    x_zwave_values.Thermostat_Mode_mode=1
    x_zwave_values.Thermostat_Operating_State_state=0
    x_zwave_values.Thermostat_Setpoint_setpoint_1=20.5
    x_zwave_values.Thermostat_Setpoint_setpoint_11=18
    x_zwave_values.Thermostat_Setpoint_setpoint_12=26
    x_zwave_values.Thermostat_Setpoint_setpoint_2=23.5
    x_zwave_values.Version_firmwareVersions=["1.3","1.4"]
    x_zwave_values.Version_hardwareVersion=1
    x_zwave_values.Version_libraryType=6
    x_zwave_values.Version_protocolVersion="4.61"
    zwave_device.capabilities=[49,64,66,67,68,69,112,113,114,128,134]
    zwave_device.endpoint=0
    zwave_device.failed=false
    zwave_device.generic_class="Thermostat"
    zwave_device.impl_sig="23318:1:22315:1"
    zwave_device.is_beaming=false
    zwave_device.is_listening=true
    zwave_device.is_routing=true
    zwave_device.is_secure=false
    zwave_device.manufacturer_info=[57,17,8]
    zwave_device.node_id=16
    zwave_device.specific_class="General Thermostat V2"
    zwave_device.status=4
    zwave_device.version_info=[null,"1.3"]
      Try pulling the latest zwavejs_data.zip from the download server. Put it in your config directory and restart Reactor.
      • SnowmanS Offline
        SnowmanS Offline
        Snowman
        That did the trick. Thanks again.
          165.3k
