  4. Bind Zooz Zen32 (HASS/ ZWAVE JS UI) Zwave events to MSR Conditions
zen32
4 Posts 3 Posters 1.1k Views 3 Watching
  • C Offline
    C Offline
    cd12172
    wrote on last edited by cd12172
    HI -
    Direct question-
    • is there anything obvious wrong with my configuration below
    • since the ZEN32 scene controller really has no on/off state (for btn 1-4), and I am using it as a toggle without concern for long press or multi press - am I better off just looking for any change to x_hass.state in a rule condition to trap a toggle?
    Detailed Use case -
    A-Use ZEN32 scene controller to group and control sonos players
    B-Keep ZEN32 lights sync'd with real world sonos states. [B is alread working in my implementation by controlling the always on/always off led parms on the ZEN32]
    Environment
    Reactor - latest-23063-c464b68
    hass - 2023.12.3 core / 2023.12.0 Supervisor
    Zwave JS UI - 9.3.2
    • the add ons are running on the hass instance in a virtualbox vm
    prior reading:
    Using Zooz ZEN32 Scene Controller as Trigger
    Adding remotes, scene controllers as entities to MSR
    MSR Manual - Handling Home Assistant Events
    **Current ZEN32 zwave description to MSR - reactor.yaml **
          event_targets:
            "event.sonos_scene_controller_scene_001":
              name: "ZEN32 Button 1"
              capabilities:
                - button
              events:
                - event:
                    event_type: zwave_js_value_notification
                    data:
                      node_id: 008 # Put your ZWaveJS node ID here
                      property: scene
                      property_key: "001" #  001=button 1, 002=button 2, etc.
                  response:
                    button.since:
                    button.state:
                      map:
                        KeyHeldDown: hold
                        KeyPressed: single
                        KeyPressed2x: double
                        KeyPressed3x: triple
                        KeyReleased: release
            "event.sonos_scene_controller_scene_002":
              name: "ZEN32 Button 2"
              capabilities:
                - button
              events:
                - event:
                    data:
                      property: scene
                      property_key: "002" #  001=button 1, 002=button 2, etc.
                  response:
                    button.since:
                    button.state:
                      map:
                        KeyHeldDown: hold
                        KeyPressed: single
                        # dump_all_states - This is for troubleshooting. Do not enable unless asked.
                        #dump_all_states: false
    Findings-
    -The Hass logbook is seeing the events - also seen in the screenshot below
    • no update to the MSR created "ZEN32 Button 1"
    • The MSR manual indicates my HASS version is newer than supported (2023.11.3). I am assuming the issue is in my config.
    Area of interest:
    • Is my cannonical names correct in the Reactor.YAML code above - I took it from the Reactor entity dialog screenshoted below i.e. event.sonos_scene_controller_scene_001
      Take a look at this thread
      • C Offline
        C Offline
        cd12172
        Thanks - I referred to that post and a predesseor in my original post. I also went through the API documentation, still unable to trap events as a button.
          You don't need to configure any custom events. The ZWaveJSController mapping for the ZEN32 produces five entities, usually named xxx Scene001 through ...005 (where xxx is your base device name). These all publish the button capability.
          See also: https://smarthome.community/post/15176
