  4. Using Zooz ZEN32 Scene Controller as Trigger
8 Posts 4 Posters 3.0k Views 4 Watching
    Hello all, I recently installed a Zooz ZEN 32 scene controller and was looking for some guidance on how I could use a button press as a trigger in MSR. The scene controller has a total of 5 buttons that can activate scenes based on single press, double press, triple till 5 presses and also a press and hold. Currently in MSR I see an entity for the scene controller itself and separate entities for each button.
    Using the MSR native Z wave controller I can see the button.state (shows if it was pressed single double...) and button.since which shows the last time the button was pressed. The issue with the button.state is that say I press the scene controller button once its state is single but it never "resets" it's state will remain single. So if I press the button again the trigger won't work (pulse action won't work here because the state never changes).
    Going through HA similar issue but instead the x_hass.state is used and the number pertains to how many presses 0 means one press, 3 means 2 presses and so on. But again the x_hass.state never resets to an "off" state so retriggering the rule will not work if you press the button again.
    Before I tackle this in other ways using separate rules, input booleans and expressions is there any other way I can go about this? To me I need to trigger that is something like button_pressed.single but I don't see that option.
    No logs since there is technically no issues and no real examples since I am stuck at the triggers part lol.
    MSR 23302
    Z Wave 0.1.23194
    HA 2023.11.2
    • SnowmanS Offline
      SnowmanS Offline
      Snowman
      If I understand you correcltly, I had the same issue when I first setup this device. Here's what I did to ensure the button state gets reset after a button is pressed two times in my case.
      I am using the ZwaveJS controller provided by @togglebit.
      Triggers
      Controller Scene 001.button.state (primary) == double
      Set Reaction
      Controller Scene 001.button.release
      The "button.release" action ensures the button state resets.
      Give it a try.
      PablaP 1 Reply Last reply
      • SnowmanS Snowman
        Triggers
        Set Reaction
        Give it a try.
        @Snowman this is exactly what I needed!! Thanks 🙂
        • PablaP Pabla marked this topic as a question on
        • PablaP Pabla has marked this topic as solved on
          The "correct" way is to check both the button state and the timestamp (button.since changes each time the button is pressed).
          Using the button.release action is not recommended.
          • SnowmanS Offline
            SnowmanS Offline
            Snowman
            @togglebits Thanks for the recommendation. I do have to ask though.
            I am by no means an expert so how am I supposed to know this? The documentation does not mention anything about this. And based on your recommendation, I will have to review all my rules/logics using this device.
            Thanks in advance.
              The question has been asked and answered in prior forum posts.
              • SnowmanS Snowman
                Thanks in advance.
                Andr
                @Snowman
                I think my old thread could be helpful for you.
                Good luck 🙂
                Adding remotes, scene controllers as entities to MSR
                • SnowmanS Offline
                  SnowmanS Offline
                  Snowman
                  Thank you both @togglebits and @Andr. I got it now.
                  • C cd12172 referenced this topic on
                    157.7k
